- stalling issues on a 98 V6
- performance for cheap
- Vibration at 1500 RPM's
- Looking for a topper
- April Ride of the Month Voting!!!!!!
- oil sludge
- Solid Front Axle and Power Options
- Let the mods begin....
- control arms
- Rear flip kit lift. 00 2wd How much lift ?
- Another reason I want a different make of truck...
- bearings
- Holy crap it's been a while
- fuel pump for 5.9
- tire size on bags
- New truck...is this normal?
- Rear Differential
- recall ????'s
- 97 Dakota rear brake drum to disk swap out
- suspension squeaking
- Gibson Headers Install Instructions?
- tuff country
- HAVE 2 ??
- ticking sound
- Water pooling problem - Need some help
- 98 dakota rear end locker ???/ any tips
- Front end thunk/whine
- LOOKING TO BUY A DAKOTA
- after market oil pressure gauge
- 2002 FactorySecurity HELP!!!
- Engine off-center?
- oil
- what a trip
- rev limiter/engine bog problem
- Dakota Towing – Power to the 7-pin Factory Harness
- body lift help
- WoooHooo! Just got a call.
- Did I buy good truck?
- ABS???
- glove box codes
- Vent Shade question
- 2000 brochures ?
- Buying a 2000 quad cab, what can I expect?
- Problems come in three's ...right?
- Engine clicking noise
- gas mileage on a 99 dakota sport
- Bump Stops
- Tire Question
- spark plugs
- my new 99 dakota sport
- Comments and Ideas please
- Help me decide which options...
- Trouble code print out
- TB
- tire sizes
- headers
- torsion bar
- which color stripes on a white Dakota?
- what should i know about daks
- Windshield Washers freezing
- check engine code on a 99 dakota
- rear leafs
- Aftermarket Stereoing & Amp Wiring
- 2003 4.7 Aftermarket?
- Interesting question
- New Lift?
- cragar rims
- transmission cooler
- Tranny Temp Sensor in Pan or Cooler Line
- Tailgate Problem
- interior light problems! HELP!!!!
- Which SI/SO Magnaflow?
- cant find part
- o2 simulator
- Viewing full TSB's
- Trouble codes
- heat is not hot!
- Under drive pulley
- 2000 problem starting
- 03-04 Crew cab with plow?
- headlamp adjustment
- Hot Tranny on 4.7 when pulling
- Need Some Opinions
- rpms jump up and then plumit.
- HeadLight Trouble
- 5.9 R/T
- spare tire
- LOng Tube Headers ???
- 2nd gen dakota magna flow catback system?
- R/T Running to rich
- need to see cervinis exhaust pics???
- Plenum gasket leak - symptoms?
- Exhaust Question
- Changing oil filter on a 4.7
- exhaust
- MOVED: WTB: clear tail lights
- V6 Supercharger for the Dakota
- Vacuum Line Question
- replacing springs on 99 dakota
- Lookin to do a few basic mods
- Need power
- Headlight bulb replacement
- motor replaced, now codes...
- Best place to get larger throttle body???
- Engine died - replace w/ same, or ?
- Few questions
- where are my power mirrors!!!!
- starting trouble...still
- Difference between 5.9L from R/T and 5.9L from Ram?
- fog lights not working
- PCV valve on 4.7
- dodgy AWD system
- Ride of the Month
- MOVED: r/t vs. eldorado
- trans wont shift.....
- Timing?
- wheels, how heavy is heavy?
- Continual "Check Engine" light with sluggish accelleration
- ticking in engine compartment on pass. side
- oil viscosity
- 2000 quad cab 4.7L fuel pump
- 2" blocks/motor mods
- 4Cyl Dakotas Any Good
- Fiberglass Doors fenders hoods etc
- False Nutural with Superchip
- Truck dieing
- Need Help on Neutral Safety Switch
- Transmission stutter between shifts
- rear speaker removal
- Bolwer Motor Resistor
- custom cold air intake
- No Heat Coming out of Floor Vents
- 2000 Dakota Club Cab rear speaker removall
- Performance coil
- How to Change Headlight Bulb?
- Clanking brake caliper
- 2002 vs 2001
- 2004 Dodge dokota (lift)
- Tow Hooks for '00 Dakota
- Check engine code: P0138
- Fan clutch?
- 0432 code
- 2nd Gen (97-04) Dakota and E85 fuel???
- superchip????
- m1 intake
- Tranny Question
- how stong is the Chrysler 8.25 in our dakotas?
- Dakota Pulls when Braking
- engine stumble
- Need a 5.9L R/T Engine, an need help LOL
- Speaker question
- 1997-1999 3.9L / 5.2L / 5.9L Volant Super Sale
- Truck Dying at coast or idle, suggestions?
- tranny shift kit help!!!!
- check engine light
- Dual Battery?
- Old Age?
- Seat mounting
- Difference between full time and part time transfer cases
- Fuel Guage
- MOVED: Taping into a headlight wire
- Can't start my truck.
- Question
- Turbos for R/T's
- Dakota performance
- Heater fan
- 98 Dakota won't turn over
- Air Bag Light
- power options for v6
- Anybody try the hp chip?
- No spark....
- Cabin Filter?
- 97 Dakota Horn inop or low
- Cruise Control Help
- 2000 Driver's Side Heated Mirror
- Fogs that fit factory holes?
- 5.9 dakota vs 5.7 ram
- how fast is my new truck
- Roof Consol
- sudden mileage drop
- lifts
- Reverse Lights
- Viper Wheels?
- Auburn Gear Limited-Slip Differential ??
- Ngks any good?
- Fog lights on a 2000
- Trouble code P1931
- Need a part number
- AWD to 4WD conversion
- buckets in the rear of a quad cab
- dynamat and aftermarket air boxes
- waterpump nut
- Disabling keyless entry
- Cuda Roll Pan
- Viper GTS Hood
- Starting Issue
- Tire Size
- Valve Covers?
- engine swap
- SC 5.9 QC
- MTX Thunderforms -- Subs for Ext.Cab
- Group Buy
- electric seats
- Newbie, Dak questions
- Problems?
- Agate or Gray Interior?
- Electric SC??
- I've got a few questions????
- Throttle body?
- HVAC controls...
- Ramcharger 360
- Just wanted to let you all know
- Need help finding a fuel filter for a 2003 Dakota
- Suggestions on a new rear bumper?
- AFR?? 99 dakota R/T
- backfiring
- headers
- after market radio
- Error Code P0141 O2 Sensor
- newbie
- headers&steering
- 99 Dak has serious vibration @ speed
- Quiet-ing the Transmission.
- pcm
- pcm
- Quick question, replacing headlight bulb
- question about gas mileage
- 2.5L Dodge dakota
- Body skins
- Engine oil 101
- 5.2L V8 engine runs on too high RPM while 'parking' after battery was empty
- Factory Suspension Tire options
- posi rear-end
- noisy fuel pump
- bed mat preference
- Apc Projector Headlights 403671HL
- What PSI should be in my tires?
- O2 Sensor
- Is this the wiper motor or switch?
- Tail-Gate Loading?
- Limited Slip Qeustion
- Headlights 1997 Dakota Flash on and off...
- tranny linkage
- 4.7 HO engine swap in Dakota!!
- Aftermarket radio, power but not sound
- TURBO!?!?!
- Fastman TB installed today
- Seat Springs
- Hurst 5 Spd..
