- Parts questions
- code P0442 how to fix..Evap Leak Monitor Medium
- Radiator
- Map sensor question.
- Air Box Mods
- Rear break problem.
- wheel options
- need new liscence plates
- Service 4WD Light on a 2WD truck
- Mileage tips on 3.9?
- Mopar PPHs Headers are DONE! Pics Inside.
- Broken Exhaust Manifold studs on 3.9
- anyone done it?
- New O2 sensor and still p0138 code....
- Light Flicker....Need Help!!
- another problem, wtf
- Tranny help
- Which Chip and CIA
- 03 Dakota Headlight switch??
- DF Video!
- Best fog lights?
- got some CEL's to deal with now, great.
- new hood
- Bigger rearend
- tranny fluid ?
- Pcm or connecting sockets ??
- bumper painted
- Check Engine P0420 Questions
- AEM Bruteforce CAI For Sale
- New Member - 2001 Dakota SLT
- gonna take some reicer's money this sunday
- 3.9 valve seats
- New R/T Pics
- Truck troubles... again
- Amp/Head unit question
- i have code P0500, VSS malfunction help!!!!
- New 5.9 R/T Owner
- air intake
- A/C water issue
- Heater core question and other engine Q.
- Wow!
- New and improved Dakota
- Brake lights not working
- p 1281 code
- 01 4.7 quad cab need help, started with valve prob. now maybe sensors
- going to order 1.7's need advice.
- supercharger for 98
- code p 1281
- Click Click Click
- transtemp, and od on/off turn on
- Air Vents
- Well People We Need...
- AC Recharge
- shaved bezel update
- sealing exaust
- spark upgrade
- badges
- decals removerd
- 01 4.7L missfire at idle no codes
- think i may have found my winter project!!!!
- Spark Plug Change - 2000 3.9L
- Dakota in TOTM
- Does anyone know?
- strange electrical issues
- *Fog lights*
- R&R Transmission
- tallight paint
- 10 million HP!!!!
- A few problems I was hoping to fix.
- My Latest MOD
- Tranny Oil Change
- WTB headders
- Whistling problem
- fuel gauge
- 01 dakota v6 3.9
- Check this out!
- 3.9 bucks when warm
- high flow cats
- Transmission issues - 2nd gear
- Brake Size
- Headers
- After throttle body swap help/suggestions
- headlights
- Tire Question (from Newbie)
- Home Audio in truck
- 98 upper Ball Joint installation
- AC Fan Motor Noise
- SAS dana 60's all around
- what do you think O2 simms would do to gas milage?
- O2 Sensor identify problem
- My new sig!!
- suspension problem
- Changed Clutch Slave and Master...What a pain!!!
- steering
- will a 3 in body lift for a durango fit
- o2 Sensor & speed sensor codes
- aftermarket headlights
- help with lift kits !!
- coils
- OS Heater Circuit Malfuntion code?
- Dak items for sale
- stupid question but i need help
- need advice on 1.7's
- 00 Dakota Rear Window Actuator/Regulator
- Does 3.9v6 have an egr valve?
- how much?
- 98 Dakota Drive shaft problem
- ECU/ECM Commands
- Check Engine Light P0152
- need help with clutch pack on auto trans
- Cleaned the Quad Cab
- Heat/AC fan switch
- Need a lil help with my banks and sensors
- QC Rear Seat Locked?
- 02 4X4 can't sell it!
- My new signature!!!!!!!!!!
- Dakota kit I saw
- Gettin my subs back!
- im looking at buying a 98 dakota
- ProComp Intake & Moore_716 T-bars installed
- cylinder head milling
- 00 Dakota 3.9v6 stall on start
- spider gear question
- 4.7 cams w/ lifters
- Which manual for my 99
- Hesitation problem
- Dodge Dakota Max Boat Size to Tow
- Transmission stopped pulling
- Problem while cruising sorta...
- 1998 Diesel dakota swap
- Weird engine knock !
- In dash scanner/ham radio install
- gen 1 and gen 2 ifs
- Differential woes
- rubbing when turning wheels
- Hey Everyone!
- 4.7L Towing Question
- lets talk security.
- All cylinders on Bank 1 misfire
- Radio Static Fixes?
- crank sensor?
- what's up
- ATTN: all R/T owners
- Running Light issues
- Rear end wobble
- 99 dakota sport V6 stalls when driving
- Gears & tuner?
- Slow evap leak...
- best mod
- 98 dakota 4x4 5.2
- Shifting problems
- I Went Out This Weekend
- 2002 possible CTM temp fix
- Questions about the LSD on a 98 Dak
- 98 R/T
- 04 sakota slt
- Knock in Steering Intermittently
- Hyper White Lightsg
- Transmission Swap
- Truck & Jeep Fest
- headers, probably been answered, sorry for the inconveniece
- CODE P0551
- Wont Start now.
- o2 question
- engine overhaul
- wiring issue with plug at blower resister
- My truck
- Windshield Washer Doesn't Work. Help
- cant decide on which V8 to get
- New Dakota Owner!
- head and tail lights
- kind of a dumb question....
- Amp location
- 0358
- will a 3.7 ac compressor fit on my 4.7 just
- Overheating?
- 3.9 chip
- do they sell this ac clutch for my truck?
- clear turn signals
- Turn a 4-speed to 5-speed?
- new tires for a lifted dakota
- 5.2 motor swap, need help!!
- 2004 dodge over heating at idle
- good mods for a 3.9?
- Newbie in need of some help
- new wheels
- what other sites are there for me to look for more info on my truck?
- Need help fast!!
- Whats the fix for these codes?
- need help really bad and fast ? about ac in my dakota
- Lowered the Dak
- Leaf Spring Add?
- '98 Completely Dead
- manual r/t???
- My Latest MOD
- Quicker way to get to closed loop?
- suspension help
- Governor Pressure
- R/T suspension
- new tires
- squeaking noise
- 1997 Dakota 2.5L Performance?
- 4.7 power vs 5.9
- What do you think of this exhaust
- flashing lights
- 4.7L intake manifold
- fastman o2 simm
- Front End Noise 2003 Dodge Dakota
- red R/T black rims
- P0305 Mis-Fire after it rains
- O2 sensor wiring **HELP**
- 1998 dodge ram super charger or turbo?
- New Tires are now squares
- Brake Line issue
- Fabtech Lift
- Random stalling?
- front end
- Dakota v-6 overheating
- pics of new roll pan on 98 dakota
- suspension
- Computer OK but not communicating.
- anyone have what i need????
- Ebay Projector Headlights
- more exhaust sound
- looking for new exhaust
- finally gone
- Upgrading new truck
- Surging Problem
- Brakes problem
- Looking to buy a V8 TB!
- Throttle body question
- tell me what you think
- rims???
- stupid irresponsible people..
- I Got Me My New Tails...Finally....
- What should I watch for when buying a 2004
- 1st gen to 2nd gen engine swap
- hooking up my CB? New CB?
- Red Connector right of ODBII/hood latch under dash
- wheels
- Part number for throttle body cable needed
- poor fuel mileage fix
- secondary o2 sensor
- Cold Air Intake Question
- transmission issues and my fix
- 2wd FABTECH 2inch leveling kit
- lug nut thread size???
- WANTED AIR INTAKE!!!
