PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Off topic question??? I need help
  2. [Poll] Engine and tranny set-up poll
  3. engine swap
  4. runs hot sometimes
  5. TB Gasket 4 the millionth time
  6. You guys got to read this.....
  7. rpm's drop in park
  8. 04 v6 hesitating
  9. i hate fords
  10. ---????? HEADS ?????---
  11. check engine light question..
  12. Loose steering column?????!!!
  13. Comments on a "newer" buy..
  14. Autolite 3923's
  15. Sound Systems
  16. Fuel Pressure Regulator
  17. o2 sensor question?
  18. welding required with body lift?
  19. Dash noise while idling - maybe speedometer
  20. sputtering
  21. saging doors 2000R/t
  22. tail lights & coils
  23. stalls in cold weather
  24. CAMSHAFT removal????????
  25. valve springs?
  26. engine shuts down at stop sign/ light
  27. No Bus...code p1698
  28. Engine Noise
  29. injectors?
  30. Acting weird after a trans pan and filter drop
  31. V8 Engine Swap
  32. Headlamp adjuster messed up
  33. NEED HELP ASAP please. Dont want to break...
  34. ABS ?
  35. Project Dakota pics...
  36. What is a good chip for a v6 dak?
  37. Tires Rubbing
  38. any wires under the seats
  39. Got the Dak back from the paint shop...
  40. TIRE help
  41. heat
  42. O2 Sensor Codes
  43. funny fog light problem.
  44. Running power from batter to cab
  45. injectors
  46. Cargo light and reverse lights
  47. Electrical problem - stumped! No park, dash, or fog lights
  48. idle senor
  49. 2002 Tailgate
  50. TOTM!
  51. Tranny Not Shifting at Redline
  52. almost time for tune up...help?
  53. Looking for Gauge Pods for A/C vents
  54. buddy looking to get 03 dak
  55. Viper Fan Install Questions
  56. Silly brake line question
  57. running boards for a quad cab
  58. CLUTCH FAN
  59. door locks
  60. HEAT PROBLEMS
  61. Light Rack
  62. Tranny
  63. 01 dakotaQC4x4 5.9L wont start..HELPPLZ!
  64. No spark. No comm w/PCM
  65. Common, but not so common problem with oil pressure
  66. tranny slip
  67. super lift
  68. Detonation at warm idle only?
  69. dakota on a chevy frame?
  70. 2x50mm Throttle Body
  71. Blinker Issue!
  72. stalls in reverse in colder weather
  73. problems starting....
  74. Locking Hub conversions
  75. Cracked
  76. 44RE trans fluid
  77. hew headlights (again)
  78. Help with brake shoes
  79. wanted: fuel injector retaining clips
  80. Just put in H.I.D in and wow they look mint!!
  81. will 33s fit on these?
  82. MIL eliminator...? cut my cat out now i got a check engine light
  83. CENTRAL TIMER MODULE
  84. FOR SALE DODGE Dakota 2wd Poly Bushings
  85. where to find fuel injector clips??
  86. Poor Gas Mileage- 4.7 V8 2WD
  87. 3" Rancho Lift
  88. 3m tape removel
  89. A Girl Named Dakota
  90. Horn, Dome Light, & Radio Not Working
  91. power door lock problems
  92. hitch
  93. engine light
  94. Brake Lights not working
  95. transfer case removal
  96. Oil Change Question?
  97. R/T RIMS
  98. tranny fluid
  99. changing ball joints
  100. "NO BUS" reads on the Odometer
  101. 4.7 engine mods
  102. finally stepped up to the 2nd gen
  103. 03 sxt 3.9l distributor problems !!
  104. distributor problems !!
  105. Dakota Wheels
  106. Amateur Radio Installation
  107. engine knocking
  108. crank sensor help
  109. ram air hood
  110. stalling
  111. Poor man's ram air
  112. Snow tires for the R/T
  113. problem after lowering?
  114. fender flares question
  115. Aftermarket bumper and Hella Lights
  116. recieved hughes manifold, questions
  117. Windshield Wipers for a 2000 Dakota Club Cab
  118. 2000 4.7L Club Cab - Rear Brake question
  119. Engine Code P0138
  120. jet chip for 3.9, anyone????
  121. Gear oil weight
  122. 2000 SLT Plus Radio Controls and aftermarket radio
  123. rear end gears
  124. The window doesn't come up... help
  125. Thinking about a new exhaust.....
  126. Getting ready for winter/winter maintence!
  127. 03 4.7L loud sucking sound from throttle body
  128. Dont you hate it when this happens?
  129. 1997 Dakota Manual??
  130. tree
  131. Trim Codes (rpo codes)
  132. pics with new tires!
  133. Problems fueling up...
  134. keyless entry
  135. POWER OUTLET PROBLEM 2000 Dakota
  136. Cats
  137. truck of the month comment
  138. i love my truck
  139. 4x4 front hubs
  140. serpentine belt
  141. squeeking left front 99R/T
  142. Dakota stat question?
  143. 2004 4.7L 4X4 upper ball joints??
  144. Cracked Fog Light Question?
  145. Parting out 2001 Dakota 2wd V6
  146. Engine Roars Loss Of Power ? Help
  147. Can anybody tell me what size fuse to use for my ,..
  148. engine swap
  149. Lowering an r/t?
  150. 99 Dakota w/ salvage title (has been fixed) worth $3K?
  151. jet performance chip
  152. complete battery failure
  153. Another rear diff question
  154. Ignition - Starting problems
  155. 9.25 Limited slip rear
  156. Parts 4 Sale
  157. headlight help
  158. Engine Flush
  159. overhead comp...
  160. wig wag headlights
  161. Power Door Locks
  162. Transmission problem help!!!
  163. Front End noise? HELP
  164. heater core??
  165. SoCal is burning down
  166. Side Thrust to Valve Spring
  167. Stock R/T Wheels F/S
  168. swapping parts
  169. What size speaker ?
  170. UMPH for my 94 dakota
  171. Power feed for cruise control
  172. Shifter lock
  173. DIY threads...
  174. Leak!
  175. 1.7 rocker arms $100
  176. Well, after 2 days work, the new interior is in,.. Pics,..
  177. looking for the fuse for CC
  178. Pics of 2wd lifted dakotas????
  179. Replace Shift Lever on Automatic
  180. 03 4.7 stalling in reverse
  181. Paint
  182. H.O. intake & cam conversion...
  183. Finally Removed the Headers...
  184. '04 CPO with issues
  185. Cat Problem
  186. 99 3.9 #4 CYL. MISS
  187. O2 sensor
  188. Doubles?
  189. Coolant Smell inside?
  190. build your own fiberglass panels! (56k? go make a sandwich)
  191. Cold Air Or Short Ram
  192. magnaflow exhaust
  193. 2001 dakota coolant?
  194. Off topic: Whatever is on ur mind thread
  195. Transmission problems, '99, 42RE
  196. winter/al season tires
  197. leak detection pump...p1494 help?!
  198. Best Launch Technique
  199. Tune up and more
  200. Dakota Long Bed
  201. who here has gotten a B&G computer flash?
  202. DIY 2nd Gen Dak Transfer Case Swap (preliminary)
  203. Transfer Case removal...
  204. Leer canopy 3d brake light wiring
  205. 2000 Dakota 3.9?
  206. Here's the Pics of all the interior out of the Dak,..
  207. Not quite off topic: trannys and engine fires
  208. Stalling on incline + tranny
  209. Trailer question
  210. Gettin New Rims Today!
  211. 2nd Gen Dakota Wannabe - Question
  212. for us with seasons
  213. dakota vs. Telephone Pole (PICS POSTED)
  214. RESOURCE LIST FOR EVERYBODY! ENJOY!
  215. hughes stage one intake
  216. Starts doesn't Run
  217. viper fan
  218. Front right parking bulb is on but wont blink
  219. front end carnage
  220. heat shield on 1999 Dakota?
  221. O2 sensors on 1999 Dakota
  222. 2000 CC V6 needs new tires
  223. power window
  224. Fastman O2 Sim
  225. canadians
  226. Resetting Engine Codes
  227. Brake problem on 2000 QC
  228. In Park Idle Moves up and Down
  229. not a quick start up
  230. PO455
  231. P0432 - Cat 1/2 - Which one is it?
  232. Putting it in park
  233. Well, I started the tear-down of my burn't up truck,..
  234. Standard or auto for off-road?
  235. Brake light and ABS light now on
  236. how to remove injectors??
  237. Day by day the truck keeps acting up :(
  238. 1998 Dakota Steering help
  239. Oxygen Sensor Question
  240. HELP! - Need radiator petcock/drain cock for 2000 Dakota
  241. After Market rer view mirrors
  242. 99 Floor Console
  243. TeraFlex Revolver shackles on Dakota
  244. 2004 frame on a 2000 Dakota finished
  245. 4.7L Engine Rebuilt finished
  246. computer code
  247. Tie Rods, Upper lower Control Arms?
  248. Blinker?? WTF!!!
  249. 2000 Dakota tranny filter ?
  250. dash lights
