- Happy Friday All
- Flowmaster Super 44's
- im desperate!
- Realistic gas mileage
- white with black rims?
- 99 Dakota blower motor
- Dakota tube running steps
- lift kits
- smoke from vents
- please more power
- Got the R/T back!
- ecu???
- 4.7 programmer
- spark knock?
- gas light coming up and coming off
- 4.7 HO cams
- pulling out radio
- overfilled oil?
- Arizona Residents Unofficial Meeting 5/26/07
- PCV Breather?
- Wheel size question?
- Not staying started?
- doughboy accident
- 31.5 x12.5 tires on a stock 1997 dakota?
- Best cam for 5.9??
- 00 Dak QC 4.7 4x4 for sale
- heater core help
- ? about my 99' 5 speed
- what year engines fit
- A/C Doesnt work!!!
- PCM
- Big Clunk from front end
- should i buy an electric fan
- what to do to my dakota
- Body Work
- intake
- Changing Thermostat from stock 195 to lower?
- Front brakes overheating
- fuel injectors???
- Clogged Muffler?
- P0463 Fuel Level Sensor Circuit High Input???
- 4wd won't engage
- need a sub box...
- ring and pinion
- neutral safety switch?
- Highest amount of miles on one tank.
- A/C compressor
- Ram/cowl hood group buy....COME ON PEOPLE
- cooling fan
- Squeaking noise when I back up
- Bleeding the Clutch
- Carbon Diet
- sweet looking grill
- friday funny
- Steering column uj?
- Any Difference running high flow cat over stock?
- Steering shaft
- Can anyone post some pics of aftermarket wheels on their 4x4's?
- True duels with the 5.9, 00 dak
- Replacing U joints
- cheap and easy exhaust
- site
- Pre-cats...
- TPS
- Trans Issue
- just dreaming outloud
- custom flash on stock engine
- R/T Pics
- $300
- Fuel Tank Question
- Long tube or short tube headers for 5.9??
- Which exhaust system??
- I gotta ask....
- NGK V grove plugs for the 4.7 V8
- Time To Change Spark Plugs, NGK? Bosch?
- What size muffler to look for...
- dual shock kit
- bosch fuel injectors for my 3.9
- New
- Leaky trans.
- I saw a 3rd gen dakota R/T.
- dynomax exhaust installed
- squeeking noise
- exhaust question.....dumping?
- Constant tick changes with RPM's???
- Yet another towing Question!
- Input on CAI
- burnin oil
- 0455 again
- did something stupid
- new 02 sensor..didn't fix my mileage..
- 15.44 Seconds from 0-60
- new ball joints and camber???
- Brush guard ?
- Gear Whine
- What is best site to buy tires??
- '03 rear rotor replacement troubles
- Transmission noise???
- BAD LUCK(sucks)-story inside
- Heater control valve
- 99 5.2 DIFFS
- Please: Need help. Replaced my battery but car will not idle???
- Lowering kits for R/T's
- Trans fluid
- Best way to tow with a 4.7
- i want more power
- HF cat?
- Sirius satellite
- 2003 Windshield
- IAT mod?
- vinyl
- Gas Mileage 4.7 Ahhhh!
- Sticking Fuel Gauge - 01 Dakota
- Transmission want shift and idle correct
- wet floor board
- Input
- Over Heating
- CEL P0171
- bug deflector recommendations
- Water pump.
- Fixing an A/C line.
- Stock Tint
- '03 DAKOTA CHECK ENGINE LIGHT
- rubber/vinyl flooring
- wont start
- rear end vibration
- ABS help
- Right Part? 1997 Dakota 318
- Cant remember if i posted this already but i hope you like it!
- NEED HELP WITH HDLGHT FLUID!!
- vibration in steering/uneven tire wear...
- Uphill problems with 2004 4x4 4.7
- Voltage Leak?
- ball joints
- Stock 3.9L Intake
- did i do something wrong? probably...
- who likes bubble wrap
- Starter?
- brakes
- lh turn signal intermittant
- To gear or not to gear?
- keep blowing headlight bulb
- Odd noise when cornering...
- Threw this code today P0455
- ding..ding..ding
- Where to put a Hole in the Firewall
- high Idle
- white with chrome wheels
- Center Console for 98-2004 Dak/Dur- Auto Trans. $40.
- Synthetic with Lucas
- Well I Finally.....PICS AND VID INSIDE NOW!!!
- Getting ready to sell my truck
- Bumper Removal
- 99 dakota problems bad idle please help
- summit event pics...
- oil capacity on 5.9L
- exhaust pipe diameter
- SUNROOF
- Oil pump / Experience.
- 9.25 rear swap
- Xtang Full Tilt installed pics
- Odometer ?
- IAT relocate...again?
- Exhaust leak
- Threw a code this morning.. help
- no crank
- FOR SALE NEW $9,000/ DAKOTA EX. CAB SPORT PLUS
- Supercharger Kit
- Reverse and Ticking
- rear right brake shoes
- Hitch
- Im such a newb is the black box under hood relays?
- Fu*king HO upgade....Fu*ckin Throttle body size??
- overheating
- Trany slow shifting
- Electric Fan
- 420 and 432 catalyst problem
- Best radiator additive?
- tiptronic dakota...
- Radiator fan not turning on.
- WHICH ONE??????
- summit racing spring event...
- Weird ratteling
- new headlights do not fit!
- How many LBS can it tow?
- New Console. Opinions, please.
- Aussie Locker
- Got problem with shifting Automatic!
- Tranmission slamming
- Well I did a body lift~
- 1/4 Mile Info.... Updates....
- bay area dak r/t s
- ams oil
- front door speaker replacement
- inner tie rod
- 2002 towing capacity
- Would Any One Else Drive This.....UPDATE!!! Link.....
- Dakota for Sale
- Jack it up JACK
- problem getting diag code on 00 Durango
- just a couple questions!
- Little Movie i made: 2000 dakota R/T Burnouts/donuts ect..
- So I was thing for my exhaust....
- Throttle Body Recommendation
- Reverse glow gauges for 1991 Dodge Dakota
- My Dakota 97.
- Dual CAI
- Exhaust time!
- Just a quick ac condensor question!
- Newbie: More Pinging fun!
- Took advantage of the beautiful weather.. (Pictures)
- Bulldog RS700 remote starter 00 Dak ce code p 0123
- Need help changing a light,..
- Exhaust Leak
- Whats causing this problem?
- F*ck cold air intake and exhaust..
- Just my Luck
- Dakota MPG
- check gauges?!
- FOR SALE $10,000/ DAKOTA EX. CAB SPORT PLUS
- bed cover
- code 420 and 432 Dakota
- wheel hop
- New Member
- Steering swap
- Leveling torsion keys are a waste!!!
- HELP!!!4 wheel drive stuck in hi!!!! HELP!!!
- Removing Cat
- Pictures of my new toy
- WTB
- New Lights.....
- DAKOTA????? of the Month
- LT285 75 r16 bfgoodrich mud terrains
- What is the best on/off road tire?
- towing load range
- Oil Temp Gauge
- Mopar Performance PCMS
- dakota needs power
- Pulling My Hair Out! Update
- front end
- So PISS'D off!!!
- Hey i Need help, Its raining and its not starting
- Aftermarket Fuel Rail Option
- Tailgate Lettering
- LEAVES blowing out of vent, how do I stop?
- Exhaust
- New truck
- Oil Pressure?
- O2 sensor circuit high volts (sensor 2)
- tires
