View Full Version : 2nd Gen Dakota Tech
- OBDII P0551 2001 Dodge Dakota
- P0688 Code
- O2 sensor wiring and code p0132
- Replacing the ignition key cylinder - 2002 Dodge Dakota
- Short found removing fuse
- Several issues
- temperature gauge weirdness
- 2001 Dakota no crank
- Loose steering
- Intermittent/Full Power Steering Failure
- stalling out after 20-30 mins drive time need help
- Throttle whine
- Oil cooler lines
- 97 crank no start
- Whines in right turn
- 3 inch body lift, then trans malfunction
- No start issues
- 2004 dodge dakota error code P0700 help
- Electrical problem 2002 Dakota SXT
- Cab removal help
- 2wd to 4wd knob
- 4bt cummins swap
- Ac Wiring connector
- Steam coming from exhaust
- Center Console Fit
- 2000 Dakota Sport 3.9 4x4 driveline questions.
- AWD spare tire question?
- Help Finding Correct Engine
- 1999 Dakota Supercharger Options
- Trans help
- Remote unlock
- Ram rims on dakota
- Stalling dakota
- Hops rpms and dies, only when sitting. Out of ideas
- Honest Opinions
- 96 dakota DRL diagram
- Low idle, stalling
- 2000 Dakota need help
- 1999 Dodge Dakota Exhaust
- 1/2000 dakota master cylinder question
- air conditioning
- Stalling while driving
- Loud clicking when in drive
- 2003 Air out of Ac Vents Uneven
- Help Finding Crankshaft Position Sensor Part Number
- 03 Dakota trans issue
- Weak alternator?
- Brake lite fuse location
- 1998 Dodge Dakota 318 2wd Auto oil pressure gage drops when hot and you let off gas
- Cruise turns on ABS/Parking Brake light
- 2001 Dodge Dakota Clutch noise
- Rear Axle Leaf Spring Bolt/Lift Issues
- 04 Dakota 4.7 starting issues just bought
- Towing with bumper hitch, need some help
- 98 Dakota transmission problems
- Driveshaft issue
- Unkown problems
- Coolant leak by passenger door when AC/HEAT is ran
- 2002 Dakota 4.7 HP/TQ Upgrades? *PLEASE HELP*
- Replaced fuel pump
- 2004 Dodge Dakota 4dr 4x4 4.7L OD hard downshifting/jerking at about 85km/hr
- Shaft Slap - Front
- Rubbing and thunking
- Engine 1 fuse keeps blowing.
- Engine swap?
- 2000 Dakota
- Converting a 2wd 47re to 4wd
- Replacement Mud Flaps/Splash Guards
- Help With AC Leak
- Backspacing on these wheels?
- Problem dodge dakota
- few questions ..
- Desiel conversion
- Dodge Dakota Central Timing Module
- Rebuilding Engine - Oil Pump Advice RTV or nothing
- Head gasket blown? Or possible cracked head? Next steps
- Engine swap ideas
- Dakota Down
- Front Suspension Overhaul.
- Windshield wipers AND cowl cover buttons
- New to this forum
- Engine code P1391
- Could I get some help with parking brake cable part numbers
- Leaking coolant from timing cover I think? Pic in post.
- 1997 Dodge Dakota 3.9 L
- Need help 5.9l magnum multiple misfire
- 1998 2.5l radiator cooling fan amp draw
- 2000 3.9 V6 Sport 4wd...4wd woes...
- 2002 Quad Cab Subwoofer Successes
- AC Control Selector not rediredting Airflow
- 2003 4.7l Stalling, IAC replacement
- Shudder & Squeely Grind From Rear Diff ..
- Pulsating interior lights 01 Dakota HELP!
- Right front knuckle 1998 2WD?
- Ac/ trouble
- Passenger Side CV Failing
- Dreaded Spark Plug Heat Shields
- A few questions towards other Dakota Owners
- 03 Dakota lights turn off and on
- Replace Rusted Out Tailgate Pivots
- 98 Dak Occasional Stop Light Lope
- Headlight Issue - CTM?
- EIGHT CEL codes. EIGHT! Where do I even start???
- Electrical weirdness that I can't figure out PLEASE HELP!
- Gas issue
- Electrical woes
- Saying Goodbye
- lift kits
- 3" drop lower control arms.... Change ball joints or whole arm?
- Cruise control turning off while driving uphill
- Ball Joint Question
- 3.9L Ticking and Mediocre Power
- Code p0441/ fuel
- Problem running sputtering and backfiring once warm
- Fuel tank relocation - Return line
- Radiator cap blowing off.
- Need advise.
- need some help
- Crank, but no start.
- 03 dakota 4.7L
- transfer case Rear output shaft seal
- Oxygen sensor help please
- 03 dakota 5.9 r/t orifice location
- E-brake parts for my 97 4x4
- 1997 Dakota
- Won't idle - SOLVED
- fan clutch nut size
- Walker 50209 Ultra Domestic Converter non carb compliant
- 2000 Dodge Dakota Dying in Rain
- 98 transmission interchange with a 02?
- Stock throttle body size?
- transfer case noise?
- a\c not worling
- Trying to understand the heater actuator motors
- where should I start for better gas mileage?
- Engine swap question
- help installing aftermarket alarm and keyless remote entry rke
- No Power Door Locks or Power Mirrors
- Default ac/heater works when it wants to, but when it does come on all 100% of it is
- Broken oil pump! What?
- Radiator swap
- Charging system problem
- 2004 2-Wheel Drive 3.7 SLT Automatic Tranny whining
- My gas mileage and gas tank size issues?
- another problem, cluster and transmission
- Fuel pump issue.
- NEWBY...Several Questions
- Cold starting issue.
- 2000 Dodge Dakota SLT- shaking/white smoke
- Air Filter Swap
- 2004 Dakota SLT Tinking Noise When Turning
- Trans cooler fittings?
- 4.7 swap
- Cleaning Injectors in the vehicle
- Electrical Issues
- 2000 Sport 2.5L Power Steering Leak
- 2000 Sport 4cyl AC Compressor
- Code P0442 question
- What is this?
- 2000 Dakota V8 A/C issue
- Motor problem
- Transmission questions
- 2002 5.2 swap?
- 1997 dodge Dakota, tail light and dash light fuse blowing!
- Daughter`s truck II (Trans problem)
- Rear Bumper Parts!
- A year long struggle
- Overheating/coolant flow problems
- Door lock actuator motor
- No heat out the floor problem
- Tailgate latch issue
- 2001 Dakota motor swap
- 98 3.9 needs new engine. Any suggestions?
- help 99 3.9 magnum
- Replaced the O2 sensor but still have code p0155
- Pappy
- Engine Swap
- Stalls
- 97 and 99 Dakota engine to cab connector pinout. Please Help!
- '04 Dak - Fuel Tank Shield Retainers
- AIrbag Light/Seat Belt Pretensioner Code
- CEL issues
- Accidentley put some dexron vi in my 45rfe tranny
- Headlights blinking off and on
- Suspension help!!
- Might be moving on
- Engine swap
- loose shifter part needed
- To do or not to do! U_U
- 1997 - 2004 Dodge Dakota Specifications
- '98 Dakota Towing Capacity
- 2002 Dakota 4x4 brake issues?
- Where does the air enter the HVAC unit?
- cluster glitch ??
- 42RE Noises, Torque Converter?
- 1997 Dakota key fob program
- Not Starting While Hot
- 4.7L Engine Swap Issue
- Crankshaft Position Sensor problem
- Fuel Line Hose
- Part number for Autozone Shackle lift?
- 2000 dakota supercharged
- Shorten rear end
- Rear Cab Window replacement
- Overheating, low coolant, bubbles observed
- Belltech rear hanger kit vs replacement leafs?
- Low air flow from HVAC
- TPS reading
- shut off problems
- Changing out my transfer case selector motor, Any tips from anyone would be helpful!
- Idle issue
- 02 Dakota v6 rwd 5 speed
- Need help with starting problem.
- Dakota with VW Bug Engine
- Intermittent stalling
- Weird blower motor issue.
- Rear seat safety of Quad cab (head rests)?
- Boosting a 1999 5.2l Dodge Dakota
- Tires
- Cel 300, 301, 303
- 2002 4.7 knocking and P0320
- '99 Dakota cranks, no spark, no codes
- Rough shifting trans
- 01 Sport 4X4 V6 P0420 among other things
- 2004 Dodge Dakota SLT Quad Cab
- Vacuum hose diagram
- Truck bed help
- Thanks for the help!
- Guages not working
- 2000 Dodge Dakota Foggy Windows
- 98 Dakota random sputtering, dying. Where to find/reprogram PCM?
- Leak Detection Pump/Purge
- Odd oil leak
- Lift?
- Rear drums and shoes
- Door lock actuators....
- ABS Speed Sensors
- problems after transmission swap
- 04 door lock actuator
- jerking/rough idel
- Blower motor issue..common
- 98 Dakota fuel system trouble
- 2002 3.9 Sport
- 04 Dodge Dakota RIDE
- Engine dying Issue
- Flywheel torque
- 2003 Dodge Dakota Sport V6 something odd happened with the kms? Please look
- Looking at a 2004 Dodge Dakota SLT Quad Cab 4WD
- Best tire size and rims
