View Full Version : 2nd Gen Dakota Tech
- anyone want to lower there dak?
- tv cable help
- lifted 01
- Dakota 4.7 vs Tundra 4.7 Question
- 5.2L/5.9L Paxton Supercharger
- Where to buy
- Love the UPS man
- Livin the low life
- Low oil pressure on new engine?
- 3.9 litre with no power, low mpg
- Lil help so I can save myself a lotta work!
- Need some help with ODB codes plz.
- might become a traitor
- Anyone have a 4.7L with manual trans?
- Tps
- Tail light turn signal mod, anyone?
- Thoughts on my "not ready" problem
- New tires on
- my 3.9 to 5.9 swap starts soon!!!
- Problem with my blinkers - flasher or switch?
- 3.9 magnum remote turbo
- Slammed qc!!!!!!!!!!
- 99 RT Throttle body change???
- shorty headers
- Crash!
- Custom Exhaust ???
- will not start.Please help
- 97 3.9 running really rough and dies!
- I've had my third Dakota
- 1998 Dakota Towing Capacity
- TPS mod
- Mobil1 or Royal Purple for...
- No A/C!
- Rear Bed Spoiler?
- awesome pic
- How to Choose a Nitto Grappler Light Truck Tire
- Roof Rack
- New tires
- engine light 2002 Dakota
- what trans will fit my 97 Dakota
- 1999 Dakota obd II pinout and wire color
- Programming Alpine Alarm/Keyless Entry
- Subwoofer//AftermarketLights//Performance questions
- low oil pressure
- cooper s/t tires anyone got em??
- Just came into some money, The ol' Dak is gettin a makeover
- 97 Dakota V6 trans problems
- My New Wheels
- Back around and lookin for some opions
- A/C Sealers... and Getting it done right..
- Toot toot!!!
- got on the rollers
- 42re tail shaft/housing 2wd to 4wd swap
- Shocks
- Wanted to let everyone know
- Parts sources and rebuilding 4.7L
- Towing
- Can't find mods for v6? Wanna try some.
- 4.7 Won't Go Above 3k RPM
- Trans cooling lines question
- max my payload
- quick muffler question.
- New to sec gen, need to do a swap
- New guy! and i have some questions before i buy
- just finshed my new decals!
- intermittent passeger window
- automatic gear shifter
- powertrax and factory lsd
- a little light show for you
- replacing OS sensor DIY
- radiator flow
- Crank Shaft Position Sensor
- Pics!!! Finally
- 97 3.9l backfire?
- Its been a bit but Im back!!
- Using STP in oil
- Power steering too sensitive...
- Codes
- P0420 code- Cat?
- ok wtf crank crank crank wont start
- Oil Pressure Drops When Hot
- after market shocks
- transmission problems when truck gets wet
- Trouble Starting during weather
- Edelbrock Heads #61779 Knocking
- Bad luck strikes again!!!
- 46RE transmission
- New Badges!
- new here
- side mirrors?
- flowmaster outlaw muffler
- Banner ads driving me nuts
- Can't program remote for 2002 Dakota
- engine swap??
- Bosch O2 sensors
- Leaking oil from rear above drive shaft near gas tank! ?
- oxygen sensor keeps going bad
- Truck is pulling to the right when braking. Need some help lol.
- replacing old paint is fun
- Billet Engine Bay Parts Installed from Mike Moore.
- The twins live!
- My new hood
- Dodge Warranty
- water leak.
- 3inch body lift.
- Oil Pressure Relief Valve?
- Catalytic Converter
- Pics of the May 30th Meet.
- ignition switch will not turn, need advice
- Dakota wont shift into 3rd if I'm flooring it
- Ball Joint Replacement
- 2000 Dodge Dakota Sport idle problem
- Some new pics of the truck and some new vids.
- Airbox Mod?
- TPS Saves the day.
- Platinum Plugs
- Its getting hot time to get the A/C working!!
- uh oh!!!!
- Toyz yay!
- 4X4 won't disengage 2004 Dakota
- Overheating help?
- Same old ABS light question...
- i'd win totm for sure
- Some ?s about Dak/Durango Rears & Gears
- '03 4.7 knock sensor
- 17" r/t wheels
- To much torque = Broken Camera
- I broke down.... i coudn't do it...
- Map Light
- help please
- How do i know when I have enough r134a
- 5.2 V8 A/C help!
- Please help with my Transmission Question 42RE
- Rpms while driving...
- Need help installing Mopar side step/nerf bar on QC
- Constant DINGING!
- Fluid Capacities
- It's Official
- Upper ball joints
- Ram or Dakota PCM
- that time of the month over in the ram section
- leveling
- New system (56k no)
- vaccum leak
- Swaping out my V6 3.9 auto to a 5 speed.
- Quad-Cab Cap Recommendations?
- driveline fluid change... summary & pics
- a few problems.
- Intake advice
- New!
- Last day for TOTM
- ERG valve location ???
- Check Engine Light - DTC P1740 - resolved...for now
- 96 Stratus Code p0171
- Radiator Fan Clutch removal
- 2000 dakota 2wd, 4.7l front caliper thread size????
- New truck.
- Need head bolt torque specs for
- I Need input from all V6 owners re:mpg
- What's the deal with Ranch 5000 shocks?
- Door Leak
- High idle when transmission is engaged
- drivetrain/fluid questions
- 99 dakota squealing
- Shift kit
- Halo hid head lights any one got em?
- Can a ATX ECU be used in an MTX?
- left me stranded twice, I need help
- v6 wants to go fast
- fan clutch
- 99 Dakota won't start
- so I went chewing...
- Hey need some advice
- Sport, SLT, Base differences??
- sunroof in a reg cab?
- Engine radio interference...
- new to forum looking for input
- How many miles?
- Sound deadening on inside of hood...
- Shift Kit?
- Poor Gas mileage & Loss of Power "Solved"
- T-bar crank plus more!!!
- 2000 2WD Dakota dragging right front brake
- Pics of my dakota.
- 5.9 vs v6 Frontier
- yet another update....
- How much does it help ....
- 2004 Dodge Dakota with Engine Check P0138
- what ya think?
- Please help...about to kick the dog......
- *NEW* Reflexxion Steel Cowl Induction Hood '97-'04 Dakota / '97-'03 Durango
- What year that one?
- Manual Tranny Upshift Light
- Do I absolutly need the DRB?
- haha ok i'm an idiot
- '99 Dakota, Caliper (aftermarket) Mismatch
- knocking problem
- A/C Bypass Question
- I got bored yesterday...
- A couple questions
- Serpentine belt.
- Is this the radiator drain plug?
- ball joints
- Lift
- Odd rear bounce when breaking
- suspension differences
- sell or stay??
- 2WD Lift
- trailer lights blow transmission fuse?
- Color for my truck!!!
- 2003 dak 4.7 vs 04 hemi?
- Would any of these help performance?
- 4 vs 6 Gauge Clusters
- Sorry again
- carept dyeing
- does this sound like a good idea?
- FS: 5.9L K&N intake
- First Gear Only(barely)
- Its alive!!! / Clutch fan
- Rear diff HELP!
- Air/Fuel mixture gauge
- new rubbers :D
- Low oil pressure gauge?
- 97-99 Repair Manual and Question on Wheel Hub Replacement
- Tire wear issue/tranny issue
- Dakota window issue
- Dakota 2001 would not start
- New owner questions - brakes
- Clutch fan issue?
- transmission help
- rear ac in quadcab
- taking out front seats?
- electrical?
- So, last Thrusday...
- piaa light switch
- 2000 dakota lights won't go out
- Problem (and Resolution) with American Racing Baja Wheels
- Initial Mods Done w/pics
- CV Problem, assist please...
- dodge dakota R/T performance
- How should I paint my Dakota?
- 3.9 Idle issues
- Shifting probleme.
- check out what i just got.
- TOTM Voting
- please help...
- throttle body+mpg
- mopar action beauty shots of my truck
- buying a dakota tomorrow got some ?s
- Transmission dipstick
