PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. 5 speed transmission controller
  2. My dodge dakota ***pix***
  3. Whats it worth?
  4. Need Help
  5. Vibration problem
  6. air/fuel ratio gauge
  7. Help!!! Wheel guros where are you.
  8. 99 dakota former member !!! im back
  9. 2004 Dodge Dakota Daytime Running Lights
  10. rear shackles and bushings
  11. Power Windows
  12. Header related question.
  13. roller rocker MPG
  14. 5.9 ECM on a 5.2?
  15. Ebay chips
  16. Tuner, Chip, SCT, Jet
  17. ID on lift kit? (pic inside)
  18. big problem 2000 dakota
  19. Headlight problem
  20. need a ecm do you have one
  21. Torque converter thread size and cross threaded
  22. CEL code P0171 and running hot
  23. is my alternator working right?
  24. The Box
  25. Tint
  26. 97 dakota not shifting right..
  27. '00 4.7 cooling question
  28. '98 Where is the Power Outlet Fuse?
  29. 2003 Dakota 3.9 P0315 & MIL flashes 11 times - no spark
  30. New P/S Gear Box
  31. 99 dakota
  32. throttle cable question
  33. throttle body/intake manifold
  34. Fuel Injectors for a 2004
  35. 0158 Fault code help please!
  36. Noob with mpg/power problem
  37. CV shaft replacement
  38. 01 Club cab shocks
  39. I'm looking rear bumper molding
  40. RAM air intake
  41. Belgium Hi
  42. white face gauges
  43. Would this TB work or do I need the other one?
  44. Bcm
  45. axles
  46. mods for a 2003 4.7
  47. 46re hangs in seconds gear until 2500
  48. question about a coolant leak
  49. Lift options
  50. Upgrade by Hughes Engines
  51. custom O2 sensor Q
  52. 15" Rims on a 2004
  53. 99 dakota 1st gear studder
  54. A/C Compressor Clutch Help, Please
  55. Dakota of the Month!! VOTE!!
  56. cheap fixe up's q's
  57. Tires
  58. Performance Mods
  59. A little random and off topic
  60. Radio Problem
  61. Fender Flare question
  62. how to do a signature
  63. Chips!
  64. Cabin Swap
  65. 3.9 roars, then doesn't
  66. Turns over, but won't crank sometimes
  67. Trying to diagnose my 3.9 quad bogging - could use help
  68. Whining sound at low speeds
  69. Transmission swap
  70. truckseries
  71. Dakota rear wheel drive yoke
  72. door skin?
  73. Torsion Bar Key ?'s
  74. 4 different check engine numbers
  75. Axle Nut Size 98 Sport 4WD rear ABS
  76. Cheapest tuner for 3.9?
  77. Cost to remove broke header bolt on 3.9
  78. bucket seats installed
  79. Swap problems(3.9-5.2)
  80. misc. Questions about my 4.7
  81. 98 no start, whirring noise near relays
  82. 98 Dakota
  83. Truck sputters and stalls after going through mud
  84. 2001 Dodge Dakota 4x4 problems
  85. Power Loss and Knocking around 3k RPM
  86. How do I fix this?!?
  87. Wheels and Tires
  88. Weird power Steering Problem?????
  89. Helping a friend
  90. New "premium" plugs not panning out?
  91. How much lift do I have?
  92. Whining Noise?
  93. headliner fasteners
  94. It taps and needs a power steering something.
  95. 2004 dakota SXT headlight problem
  96. Turbo charging
  97. 1999 Dakota losing power uphill and clicking sound
  98. 42RE transmission problems
  99. my 0-60 time
  100. Tire air down question
  101. Coil spacers
  102. tires
  103. Transmission Shift issues - Guidance please
  104. Anybody try E3 plugs?
  105. change V6 to V8 Dakota
  106. Need a deep sounding exhaust
  107. 2001 Dakota Towing questions
  108. How do you remove the caliper pins?
  109. Problem with 97 Dakota (PLEASE HELP)
  110. Rear slider weather stripping
  111. converting old 4.7 into 4.7 HO
  112. Bolt pattern help
  113. 2001 dodge dakota four cylinder
  114. Power Steering Rack
  115. kick down problem
  116. distributor help
  117. front hitch
  118. Dak parts for sale
  119. need new bed...
  120. new seats
  121. Tailgate Light Bar??
  122. 3.9 engine rebuild kit?
  123. Sexy Pic
  124. Need hp and torque
  125. gears?
  126. 2000 4.7 1/4 mile
  127. help finding body part
  128. Throttle bodies for sale!!
  129. water pump
  130. Tire rotation/shakes?
  131. Shock questions.
  132. 2004 all disc brake rear parking brake
  133. Dakota Of The Month September!
  134. Problem with radio not working
  135. has anyone...
  136. Dakota parts FS
  137. Headliner Help?
  138. Tire Help... yes tires
  139. go fast goodies
  140. need some help
  141. a/c check eng. light
  142. Whats it called carpet on door?????
  143. 340 Dakota?
  144. parts for sale please help
  145. I need an expert!!!!!
  146. Problem with truck wont idle now.
  147. Fuel presure test adapter
  148. Ball Joints on an 02 Quad Cab
  149. Problem with my wiring harness
  150. Oil Light and Beep Issue
  151. a little mud
  152. Bolt Specs/Torq Specs
  153. Broken Spark Plug
  154. New and used parts
  155. Thermostat Issue?
  156. Radiator fan turns on and off when heat is on?
  157. diagnostic connector replacement
  158. fuel problems
  159. Flash TTEC?
  160. CLimate Control - Fan Air Speed?
  161. Window Regulator Issue
  162. you CAN pop the clutch in an automatic..
  163. Spark ADvance
  164. dripping water?
  165. Idle issue with my 4.7L V8
  166. solid axle swap
  167. Rough Idle And Won't Accelerate
  168. Advice tightening locknuts in 42RE
  169. 2003 Dakota Starting Issues, 4.7L
  170. dakota r/t spec questions
  171. For Sale
  172. shaker hood?
  173. TV Cable help ASAP
  174. 3.7 V6 stumbling issue first and now check engine light is on...
  175. New member ,Howdy
  176. Transmission Help - Band adjustment.
  177. 5.9 Swap Questions
  178. cold Idle issues
  179. brake prices
  180. Hitch for a 1999 Dakota
  181. DOTM Poll
  182. Keyless or Remote Entry
  183. Clutch/trans noise
  184. garage door opener
  185. Transfer Case help
  186. Tire rotation squeak
  187. Blinker problem???
  188. Loud belt squeal on 5.2
  189. Output Speed Sensor location
  190. Wheel bearings
  191. magnaflow on 4.7
  192. I want a stick shift
  193. Swap Help QUICK Please!!!
  194. Recent pics of my 1999 dodge dakota
  195. what do think about this truck?
  196. Fan Motor Resistor
  197. Suspension
  198. OH CRAP, Transmission problem
  199. Blower only blows through Defroster
  200. pop from front end
  201. Infinity Speakers for 1997 Dakota
  202. ignition key quit working
  203. 4.7 guys HELP!!!
  204. 1st gen vs 2nd gen V6 exhaust question
  205. My first Dakota.
  206. Transfer refill Urgent help please!!
  207. Rear end quetion
  208. 4.7l comp cams
  209. Steering Wheel Audio Controls
  210. Interested in joining the club, had a quick question. Timing chain?
  211. Why are they rubbing
  212. Ball Joint Help
  213. Would you buy one of these?
  214. 01 Slow going into Drive. Goes into R fine
  215. few quick questions.
  216. hooking up electric seats
  217. Transmission shifting problem
  218. Engine corrosion, help!
  219. Suspension issues/question
  220. I need a GOOD heavy-duty battery for the,.
  221. 02 Dakota only blowing air out the floor
  222. '02 Runs Rough During Day, OK At Night
  223. 1997 5.2l cam specs
  224. 2001 Dakota 4.7 V8 Balljoint issues
  225. viper swap help!
  226. Is a Durango Window Switch Compatible in a Dakota?
  227. front hitch
  228. Payload
  229. 2ooo dodge Dakota V8 SLT Starter?
  230. Guys, I needs some help...
  231. Intermittent Air Conditioning (A/C) Problems
  232. No EGR Valve on '98 3.9L??
  233. Bored got truck all cleaned
  234. 5.9 fuel economy...
  235. New to Dakota Scene...
  236. Bed stripe
  237. CODE! and rough idle
  238. Backspacing for 33x12.50's ???
  239. clutch squeals like a pig
  240. rear end question
  241. dvd-r in stock cd player
  242. Got new hood and grille on
  243. What engine would you want?
  244. WTB Roof basket and brush guard
  245. 2.5l i4 to something bigger
  246. MOTHER F****** Window Broke
  247. P0138 woes...
  248. damp floorboard
  249. Check gauges and no oil pressure on startup for 3 seconds
  250. Which oil for a weekend driver 4.7L, 2000 dakota
