PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Need help identifying what this wire harness goes to
  2. HELP! blower/dome light issue
  3. Stupid Question
  4. Some rear diff questions
  5. frame rusted around parking brake bracket
  6. P0304 problem
  7. PCM Troubleshooting + P0505
  8. 1997 Dakota horn switch
  9. Motor Swaps
  10. engine harness
  11. 3rd Gen Axles
  12. iron heads temp handling
  13. TV cable too tight??
  14. Polyurethane bushings too long?
  15. 2001 Dakota tranny
  16. Thanks 4 having me
  17. Pulley
  18. 5.2 to 5.9 swop. Pcm issues.
  19. Np231D t-case parts
  20. 2001 Dakota fan shroud
  21. Coolant drain plugs '04 3.7L Dak Club Cab
  22. 02 Dakota Sport 4.7L EXT Cab RWD Brake Lines
  23. Abs
  24. cruise not working
  25. 03 durango brake install
  26. 3.9
  27. 99 5.9l v8
  28. Engine swap.
  29. '98 front bench seat question
  30. Resealing rear glass
  31. Pcm.
  32. Upper control arm bushings, help needed
  33. Rolled my truck and now the transmission don't work!!!
  34. 2001 Dakota 4.7l Engine rebuild
  35. Performance Issue
  36. 97 Dakota SLT 5.2 V8 4x4 suspension help
  37. I need help
  38. Acceleration issues 2002 dakota 4x4 quad sport 3.9l 4 speed auto
  39. 2nd Gen: No rear blinkers, brake lights, flashers...
  40. Desperate. No lights.
  41. 97 dakota
  42. Converting 4.7L with heavy duty cooling pkg to electric fan only
  43. My 04 QC
  44. Code 1391 & 1491
  45. Rebuilt 42RE throws P0743 every night
  46. Transmission or PCM issue??
  47. Cooling issues 2000 5.9l dak
  48. Battery is dead after sitting 30 days
  49. Torsion bar installation. Help
  50. Dodge Dakota weird noise from the engine
  51. Crank no spark
  52. Tuner/Programer for 2002 4.7 Dakota
  53. Battery
  54. 1997 dodge dakota manual transmission v6 3.9
  55. Drivetrain question
  56. Shifting issues.
  57. question on map censor
  58. Battery drain from fuse #1
  59. 2003 extended cab AWD question
  60. Taillight electrical issues. 2003 dodge dakota V6 SXT
  61. 2000 Sport 2.5 Front Brakes
  62. Widest wheel
  63. 2002 4.7 lifter noise, still there after all new lifters
  64. 4.7 Jtech Cam Reluctor, Help Please!
  65. Charging system again
  66. Problem with brakes on 2003 SXT Dakota
  67. Lifter tick after head swap 5.9
  68. 99 Dakota Sport
  69. 1999 Dodge Dakota 2.5 i4 5 speed manual
  70. Brake light issue
  71. Losing coolant through rad cap
  72. 4.7L engine not taking more coolant
  73. Valve covers removed... any thoughts?
  74. Engine codes P0137 & P0138
  75. Throttle Grind?
  76. 2002 Dakota 4x4 Sport 3.9 miss.
  77. Using '83-'95 SRC-9 2.5L Jeep camshaft in '96-'02 MFI 2.5 Dakota
  78. 6x6 dakota build
  79. Transmission questions
  80. Anyone know where an AC mode door can be located?
  81. Lifter problem? 5.9 magnum engine
  82. 2000 dakota 5.9 tranny swap to nv 3500
  83. Towing a 2000 Dakota, 4.7 4WD
  84. Rear shoe slow to retract
  85. 2004 Dodge Dakota Replacement Shocks Suggestions
  86. Air Conditioning Not Blowing Cold
  87. Throttle body leak behind throttle lever spring.
  88. Starting issue. Possibly ASD?
  89. Blower problems
  90. Charging system
  91. K then buddy
  92. Idles too high
  93. 01 Dodge Dakota 2.5 liter
  94. 02 dakota 4.7L shaker
  95. Wiper problems
  96. New 4.7 in 2000 Dakota with no compression
  97. Another brake question
  98. Bad PCM? no VIN, need help
  99. 3.9l still stalling please help!!!
  100. Wont start with key
  101. Hole reduction
  102. Saga continues
  103. no crank
  104. Replacing Door Hinge
  105. Broken Ground Near PCM - What is it?
  106. 99 318 mods?
  107. 97 dodge dakota sport 2wd metal in oil pan
  108. Trans temp gauge
  109. Smoked PCM
  110. O2 sensor issues
  111. Whining noise coming from transmission/ mid truck.
  112. Rear drum breaks
  113. Fan blade bolts
  114. Double DIN installation for a 2001 Dodge Dakota?
  115. 2003 dakota shifter cable problems.
  116. Transfer case linkage
  117. Reverse lights stuck on and can't find center console lid hinge
  118. Lower front shock bolt
  119. NO BUS Error
  120. 3.9l stalling please help
  121. Dakota Wheel Swap Help
  122. transfer case
  123. Temp Control Vent control Backwards!
  124. I want
  125. 97 5.2 Won't Start After Changing Plugs
  126. All lights blink on n off
  127. project 2000 dakota
  128. Time for new wheels
  129. Time for new wheels
  130. Vacuum line question?
  131. 2001 Dakota PCV Valve fell into valve cover & is rattling
  132. Part Time 4wd Light
  133. Need help
  134. 2001 dodge Dakota 4x4
  135. Alternator issue
  136. PDC pinout / wire question
  137. Transmission
  138. 2000 dakota 3.9 high idle coolant leaking
  139. Can anyone tell me what these are?
  140. Engine question?
  141. Dodge Dakota 4/4 .318 automatic transmission.what can I swap into my truck
  142. What is this? Engine block leak?
  143. Transmission removal question
  144. Help! Tailgate won't close
  145. Is this ok ? I did it, but now I am worried if it is going to hold the heating
  146. 2003 Dakota ext cab renovation
  147. Radio wont turn off with the ignition off
  148. Lights and locks flickering
  149. No crank situation
  150. Spare tire hoist
  151. Misfire at Idle & Boggs down when given throttle
  152. Aluminum Driveshaft in what years?
  153. Engine swap
  154. What am I looking at?
  155. %#&%&#*%! Freeze Plug!
  156. “New Dakota”
  157. Speedometer off
  158. Rear Axle Help
  159. Difference in 03/4 Dakota and 03 Durango brakes
  160. DeadDak
  161. Are these stock connecting rods? Weird Markings
  162. Emissions fail
  163. swap 42rle to nv3500
  164. 2001 Dakota 4x4 stuck in 4hi
  165. Instrument panel lights
  166. Rear axle debate
  167. 3rd gen seats in 2nd gen
  168. Power steering issues
  169. 01 Dodge Dakota transmission problems
  170. Replacing dash lights
  171. Can't get interior trim reinstalled
  172. 3” lift
  173. 318 hemi
  174. Remote start help
  175. Any easy radios to install?
  176. Hey guys, I'm back
  177. Shifting problems manual transmission
  178. Starter wire harness connector
  179. 2002 Dodge Dakota Fuel Tank Removal
  180. 97 Dodge Dakota Electrical issues
  181. Another "Crank, No Start" Thread
  182. Dakota tcase swap
  183. need advice on collant issue
  184. P0307: Misfire Detected → (Cylinder 7)
  185. New mystery
  186. 2004 Dakota over heating
  187. Price range and info?
  188. Misfire Code, Engine Sputters
  189. 1999 Dakota stuck in 4x4 H
  190. Parking brake
  191. 1320 5-lug swap
  192. Injector wire size?
  193. Transmission question
  194. Fuel tank
  195. Failing injector 2003 4.7 Dakota
  196. 2002 Dakota lift issues
  197. 01 dakota spot transfer case swap
  198. 1998 Dodge dakota 5.2L
  199. Feedback
  200. 2nd gen dakota hub swap
  201. New Member/questiom about a temperature plague
  202. 4×4 issues
  203. Blower motor trouble shooting
  204. New Engine, 10,000 miles - which oil?
  205. need help with intake issue
  206. 3.7 Throttle body
  207. pump prime
  208. 2004 Dakota help
  209. Battery drain
  210. Cost comparison new motor
  211. Fuel pump finally dying @ 320K?
  212. Decouple flexplate / torque converter struggles
  213. Alternator issues / gage issue. Not charging. Check gages light.
  214. Remote starter
  215. Oil pan gasket
  216. headliner removal
  217. 2004 Dakota low oil indicator
  218. 2002 Dodge Dakota 3.9L Quad Cab 4x4 Sport 42RE Trans
  219. Died on highway, wont crank
  220. Over Heating Last options
  221. Factory service manuals: 2003 = 2004?
  222. Connector to ?
  223. Replaced the ECU and no spark again (but it ran fine for 10 minutes)
  224. 2004 Dakota shift knob
  225. 5.9 Magnum burning excessive oil
  226. 98 Dak 5.2 won't idle on startup
  227. Dak leveled
  228. Adjustment screws for headlights
  229. 2004 3.7l V6 Dodge Dakota idle problems even after new IAC valve installed
  230. HELLO! Power Steering leak
  231. Speaker replacement question
  232. 1998 Dak 318 - starter removal
  233. 3.9 to 5.9 swap adding 2 injectors
  234. 1996 46RE Tranny Leak
  235. 2004 Dakota electrical issues
  236. Issues to look for proior to purchase 2nd gen
  237. P0300 code that just will not go away!
  238. Want to put a carbureted 318 in a second gen
  239. help needed
  240. Talking to the modules
  241. 2002 Dakota - Windows work if mirrors are unplugged!
  242. Truck rebuild
  243. Steering issue
  244. Engine swap
  245. Seal/o ring
  246. 2004 v8 Starting issue
  247. Transmission losing fluid no leaks
  248. HELP: No Heat!!!
  249. Valve adjustment
  250. NV3500 manual transmission
