View Full Version : 2nd Gen Dakota Tech
- Transmission sensors, replacement
- HELP 5.7 terminator x hemi swap questions
- Ignition switch issues
- 97 to 02 transmission transplant
- P0753 and P1765
- Theft P0513
- truck bogging issues
- Torque specs
- Automatic computer with manual transmission
- Need a shove in the right direction…
- 98 2WD V6 auto: How many VSS are there??
- 97 Dakota 3.9 straight pipe
- Hubs And Bearings
- 5.9 for 5.9
- P0171 code fix
- Headlight not working
- Coolant Temp Sensor
- PLEASE HELP! power steering high pressure hose fittings?
- Now I Can See (Headlights)
- 2001 Dakota start issue
- Dakota seat foam
- Tdc
- Budget friendly seat covers?
- 4.7 updated rockers with smaller orafice question
- 2000 Dodge Dakota what seems like wheel bearing noise.
- 04 and 05 dakota pcm different?
- Radiator Replacement-External Trans Cooler
- Rear axle advise
- Weird coolant leak? Any suggestions?
- 2002 Dodge Dakota- NO BUS- won't start-HELP
- 04 Dakota 4.7l top end ticking....
- Pump leak
- 04 Engine swap
- 1999 Dakota
- Spark plugs
- Brake upgrade in progress...
- 2002 Dakota wanting to add power windows and locks
- ‘02 4.7 What would you do?
- 98 Dakota 5.2 minimal engine harness, starts but won’t run.
- 2000 2.5L Sport steering rack
- Interior lights stay on all the time
- 97 5.2 dakota won't shift out of 1st
- 2000 r/t hubcaps
- Back Up Lights! 1998 Dodge Dakota SLT V6 Auto
- Engine swap done
- Lame Heater
- 3.9L 42RE swap to 44RE
- 5.9 Swap PCM VIN
- Undercarriage rust protection...
- Reliability?
- Oil Filter Problems
- ABS and Brake Warning on at the same time
- P0440 and P0441 evap codes.
- Lower idle after a few procedures
- 2002 Dakota reurn to stock ride height
- Water leak in heavy rain - passenger floorboard
- 2 Stroke Oil in the Gas
- Spark Plugs after approx 8k miles
- 2002 Dakota Color Scheme Question
- Used 2002 Dakota purchase help
- Brake upgrade
- Seat cushion swap - passenger to driver's side
- aux water pump?
- Anything else I can check before replacing fuel pump?
- Help!!
- Aftermarket stereo will not turn off with ignition. I'm stumped
- Junkyard PCMs...
- Help me diagnose front end noise
- Barely starts
- Brief Low Pressure on Startup
- LEER camper top rack track questions
- p1698 code ground layout
- 02 3.9 crank but no start but when i leave battery off it starts next day then dies
- Vibration Turning Left
- Rough Idle
- Wrong pcm
- Transfer case
- low heat 2001 3.9
- 2000 Dodge Dakota Sport won't start
- Clunk in front end when turning while in reverse
- buy parts for Dodge dakota 2003 v6 3.9 club cab
- Intake Manifold upgrade/swap
- Electrical issues 2001
- Thank you for helping reach 18 years....
- bad speedo
- Dakota/Jeep 2.5 engine intake manifold modification to use a 64mm Throttle body
- Mystery harness plug near gas pedal.
- Child Car Seat Latch Points on Quad Cab
- tailgate lock 2004
- Power Window
- Grinding noise only in 2WD and not 4HI
- 2004 dodge dakota
- 02 Dodge Dakota 4.7
- Does anyone have the procedure to replace the front yoke on a 1999?
- ECU swap 2002 4.7
- 1999 Dodge Dakota SLT 2WD Spindle
- HVAC Mode door actuator and rods assembly
- 2002 dakota standard cab 2wd
- 2000 Dakota door latch mount.
- 03 Dakota Cab Mounts
- Random multiple cylinder misfire
- Parking brake parts (rear drum) needed 04 Dak 3.7L
- 2nd gen keyfob question
- Need Help Hardest Dodge code To Crack P1698!!!!!
- Rear Speakers No Power
- Searching for User HemiFever.....he still out there somewhere?
- 2000 2.5 Radiator Leak
- Oxygen sensor monitors
- e-Fan observation
- NV3500 Information needed
- 2000 Dakota vibration
- HP Tuners Lessons Learned 4.7 engine
- WTB: NV3500 manual transmission for V8 Dakota.
- 1999 Dodge Dakota R/T Manual Trans Conversion
- Crank no start- no check engine light at all
- Stuck in first gear solution
- I need your help
- Dakota Leaf spring specs
- Torsion Keys
- Dakota 03 stampede 4.7 tstat bolts
- Bed cover (Tonneau, Fiberglass cap etc....)
- Oil pan gasket & oil pump replacement 1999 dodge Dakota sport 5.2
- 5.9 cummins swap?
- Steering knuckle
- 97 dakota 3.9 5speed won't crank with ignition no spark at plugs no fuel pressure
- NV 3500 Input Shaft Bearing
- Fuse Blowing, Help?
- 3.7 Spark Plug change torque issues.
- Preventing the 4.7 Snot in the Oil Fill tube
- Rigid Ignite Flush Mount LED Lights in Rear Bumper
- 70MM Throttle body
- Imbalance while driving
- Brake problem with caliper
- code p1203 ??
- Most common diff
- 2000 Dakota 5.9
- 2nd gen seat interchange
- Caliper bracket.
- Charging issue is back
- Stupid question about PCM..
- 45RFE info
- Guages not working
- 97 Dakota sensors & gauges issue
- 2001 Dakota 4x4 SLT front leveling kit
- 03 dakota r/t external regulator install
- 42RE transmission issues '01 Dakota SLT 3.9L 4x4
- Idle issue
- no power to Injectors 2002 4.7
- Wheels to fit on a 2001 4x4 Dakota that can take LT tires
- New Dakota Owner - Asking Random Questions Here
- 3.9 to 4.7 engine swap
- Dakota & Durango rear swaybar differences
- 2003 3.9L vs Pennzoil Platinum
- Need..2002 dodge dakota 4.7 ignition capacitor-ignition
- Aluminum driveshaft
- Fuel Pressure Drops Randomly.
- 01 Dakota 3.9l cranks but won't start
- Dodge Dakota 1997
- cab swap
- Random stalling, rpm drops...
- No buss -code
- Dakota overhead trip computer install
- 01 Dakota sport 2.5 no crank no start
- Post trans filter replacement
- Changed out 24+yr. old wheel speed sensor , but
- 98 Dakota 2.5 Engine Swap
- 2001 Dakota No Start P0505 code
- changed trans fluid and filter, now won't drive at all
- 2000 Dakota, body lift and suspension lift issue
- Miss placed Dampener bolt, length and size ?
- Dakota driveshaft
- Drive shafts thru the years
- 1999 Dodge Dakota 4x4
- 2000 Dakota 5.9 Rough idle and high end.
- DIY Wheel Bearing Swap 2002 4x4 non-abs
- OBD communication problem and no bus message
- Guess my electrical issue
- Jeep TCM mod
- 2001 dodge dakota, 3.9 o2 sensor locations
- Code p0432/p2000
- 2002 Dakota 4.7 Power Steering Pump
- Transfer case swap info
- Rough idle, no power
- Source For Cab Mounts
- manual transmission radiator...
- Control Arm Discontinued - What now?
- New tranny now truck wont idle and stay running
- 265/75-16s with a crank or two on bars
- Condenser shroud?
- 2000 3.9 Dakota stalls after warmed up
- 04 Dakota 4.7 engine noise need help
- Light reverse thunk
- 2001 Dakota 4.7 liter V8 Blower Motor relay location
- 2004 Dakota 4.7L V8 possible fuel leak
- Any interest here in better mpg mods?
- Cracked Transmission - Help
- Update
- Engine cleaning... Internal
- C9.25
- Grinding Transfer case
- pivot pin, on the upper chain guide ? 2002 4.7
- Throttle revving still a problem
- Kickass Tail lights
- Temp guage at 1/4
- 2nd Gen Cab Sound Deadening
- AC Compressor/valve & oil Questions
- Sensor
- need valve cover bolts.studs
- Running the 180* t-stat
- Tight Steering
- Steering Wheel Locked up
- Rear Diff Identification
- Source a door for a 1999 SLT
- electric gremlin all gauges quit in dash
- New to me QC 4wd
- Horn Wouldn't Stop!!
- 3rd gen topper on a 2001?
- Engine revs on start up- update
- Rear swap out/#s
- Erratic RPMs and skipping on acceleration
- Where Is my EGR valve?
- Fan conversion
- Sway bar bushing help
- Pump issue
- Auto to NV3500 swap.
- Carrier bearings
- Fuel pump issues update
- Towing behind a Dakota
- 2004 Evaporator Temperature Sensor Replacement
- New pcm
- 3.7 V6 woes
- 2003 3.9L 2wd Dodge Dakota
- Fuel pump issues
- Steering wheel won't return to center
- Differential
- Identifacation
- Engine rev's on start up
- Transmission Oil Cooler Lines - I cant find the parts to buy!
- Hum noise
- Broken brake light
- "Thunk" Sound When Starting AC And Other Issues
- Temp staying at 1/4
- Another Gearing Post
- NO BUS 5v Signal is present
- 2000 Dakota - is PCM supposed to be powered key off?
- Hard/longer crank times after timing chain replacement
- Fuel pump issues
- Truck Sits Too Low
- Intermitent blower motor
