View Full Version : 2nd Gen Dakota Tech
- 99 dakota 318 idling issues
- advice?
- Need a Radiator Fan
- 99 dakota Need Help
- Rear brakes
- Bad Wheel Bearing?
- New pics of the dakota
- Hinge Pin Bushings
- Keeping It Running
- Air Conditioning Problem
- OFFICIAL 2nd gen Dakota of the month for September
- 1997 Dakota SLT Sound System..Need New Stuff
- Code po171
- 99 Dakota Front brake line burst...need some HELP!
- ***Rules and Tips for the Calendar contest***
- P0138
- Dakota truck bed trailer! (heavy pics)
- Code 12
- spark plug heat shields
- mpg test results ( long read)
- 2000 4.7 2wd inner tie rod boot?
- Oil Pressure Gauge Drop?
- longer shackles, lower rear end
- 98 dak 4x4 bleeding brakes
- Front Bumper Replacement
- Alternator/Battery voltage
- Air Bag fuses
- Noise coming from engine at high rpms
- water leak
- What is this, where does it go?
- Intake repair
- 2000 Dakota engine swap 4.7 to 5.9
- Transmission Problem
- no power for stereo or light
- 97 Dakota Hessitation on Hard Acceleration
- why does this keep happening?
- Possible Transmission Problems or something else????
- Need some guidance
- Couldn't remove the wheel bearing nut
- Never heard this before...
- help!!!
- 2001 Dakota 3.9 2wd 5spd, Front End Noise
- mudd terrain or all terrain
- Engine Swap from 4.7 to 5.9
- Will Drop-in bedliner for 08-10 fit 02?
- rear end squeak
- '02 4.7 trouble starting when hot
- Rough Idle/engine hesitation
- Shoulda Bought a 4X4 :(
- What for Inner panel protection??
- bearing squeal... need help
- Tires
- 2000 magnum V8 P/S
- t case info needed
- front end sqeak
- 1999 Dakota Won't Start
- changin the diff oil as i type
- cv joints after tbar crank
- how to achive the best gas mileage
- Dodge decals
- M-1 2bbl, 52TB, Cams, Tranny, Timing Chain for sale...
- fog light/high beams
- for my brother
- In Channel Vent Visors
- 2nd gen dakota with 3rd gen engine
- I have some questions about the head gasket on my 3.9
- noob here
- rear end noise
- How do you change the spark plugs? 4.7
- No sound from infinity
- need info on 4.7 to 5.2 swap
- Misfire 97 Dakota 5.2 V8
- Official Fastman Throttle Body Discussion Thread
- New member with a couple of questions.
- does the t-case take ATF or 90W?
- What size tires should i get
- Floorboard Wet
- 97 Dakota "LIL RED EXPRESS TRUCK"
- Best place to buy shocks right now?
- finally pics of my R/T and new exauhst
- Remote Start/Alarm... starting Randomly?
- A/C Pulley Bypass
- help with an intake problem
- Spots for accent lighting?
- rusted spark plugs
- nv3500 Transmission tear down
- 31's Or 33's
- Body Lift question
- Another Rear Dif question...
- Rotten service from Dodge Dealer : (
- Does any one have a 5.9l computer for an '01 Dakota?
- Need a new muffler
- Tire Sizing
- Towing Capacity
- Need some advice replacing the Power Steering Pressure Switch
- revs acting weird
- Wiring issues
- high and low hid's
- DIY Installing an aftermarket air intake
- Shudders while cruising
- What's your favorite <$100 mod? Be creative!
- shifting prob
- ticking sound under the hood
- Heater doesnt blow hot air
- 2003 4.7l hesitation
- 4.7/5.2
- 5224's or 3923's for 01 QC 3.6L, V6, 2WD??
- new guy - lots to truck q's
- 2000 dodge dakota 4.7litre Club Cab 4wd club cab
- Help
- Big Blower Motor Problem!
- no fuel
- 4.7L cranks, won't start
- could be 1 hellava deal! SORRY long read
- Can anyone help me? I am extremely devistated and don't know what to do...
- engine code 302- rough idle
- Question: Bank 2 Sensor 1 O2 sensor wires
- Need a vendor that has a fuel filler tube
- dakota ecm swap?
- Won't Downshift
- Off Road Bumper
- Engine Stumbles, no code
- truck cd player head Unit problem
- Tailgate Gate Keeper - Anyone used?
- anyone with a 3.9l v6
- Radiator Cracked & Overheated
- any ideas for a muffler/exhaust for 3.9l?
- mufflers
- 99 Kota on 35's
- Clutch/ masetr/slave problem
- Cost For Repairs?
- cab swap compatabillity
- what is goin on with my power steering pump
- jw v6 magnum enginge in a monte carlo
- bad acceleration and shaking Help!
- 2001 4.7 Rattle
- seafoam (or something better?) for 01 dak qc 4wd?
- Fog Light mod?????
- transfer or front end
- cutting front coils
- Vht nightshade
- Progress on the Truck
- 2003 dakota 3.9 head gasket
- truck running like crap
- AIRAID cai, kicker comp 12" sub on ebay
- 03 dakota
- Brake fitting afu weirdness
- Speedo Problems
- Diesel swap?
- OFFICIAL 2nd Gen Dakota of the Month for August
- Starting/Idling Problem
- '02 Dodge Dakota PCM Question
- Shackle Hanger LIFT?
- replaced front hub today
- projectors with HID or with halogen?
- 01 dakota 3.9 auto 4x4 need help
- The R/T is running with a few new goodies installed.
- Can I keep stock size shocks and driveshaft with 2-3" of lift on my 2wd 3.7L?
- Lifting front end?
- best shocks for a 01 dak 4wd qc?
- EVAP/PURGE SOLENOID Hissing?
- Mystery Mechanical Problem
- 01 dakota wont run plz help
- 97 5.2 losing power on interstate
- Running Duals?
- 3.9 to 5.9!!!
- Front Brake issues
- Fuel pump went!!
- Looking at 98 Dakota w/ tranny issues
- V8 durango coils on v6 dakota?
- Header collector size ?
- 5.9L w/ Tranny.. value?
- CB radio
- Help: new owner, not very mechanically inclined
- 2002 Dakota Air Conditioner not blowing out dash.
- Dark Blue with Black Rims Pics?
- Power steering issue...
- Painting the plastic valances in front and back
- Power steering leak and can't really pin point it lol.
- Idle? A/C? MAPP? IAC?
- coil spacer question
- Pros/Cons of Dumped/side exit exhaust setups
- spring shackles
- P0303
- New Owner. New Here. Questions :)
- tranny problems
- Wireless Meter/dyno/economy calculator for truck
- CV Joints?
- black on the red truck
- Will Durango headlight covers fit my Dakota?
- Steering Wheel Shake when Braking
- Shift Indicator: Light
- front axle diff
- fixed the blower motor
- Help with lifting my Dakota
- Totally dead '97 Dodge Dakota
- Fan clutch issue
- Another Tranny Problem
- Tire size options for 2nd gen dakota, 4x2 RWD truck.
- Nasty cam bearing!
- 5.9, rough idle and power surge - only once per drive.
- ball joints and bushings: for 2001 dodge dakota sport 4x4 quad cab?
- Web link for Engine codes
- Coolent/Overheating from overflow!
- Vacum hose ???? Not sure what for??
- not starting
- Power Steering Fluid / Or Brake Fluid Leak ?
- Im Approaching the major milestone
- Flushing the cooling system on 2000
- break light issues
- Just bought a truck tool box
- Dakota CAI Question.
- Simple wiring questions 98 Dakota
- Looking for OEM Headers!
- Random Missfire 2000 DAKOTA
- odometer flashing gauges don't work
- Efan questions before I go get one
- How to raise 2wd front?
- 2 questions
- transmission trouble
- 2 A/C related issues?
- RPM's fluctuate - Need help
- Swap Hemi
- Roll pan and Hitch issues - Help
- Dakota a/c problem
- Common problems
- Daytime running lights switchable?
- Could use some radiator help.
- Inexpensive Ideas For Your Truck!
- 2002 Dakota TCM
- Darn 42RE...
- Front Shocks.. what do you use?
- injector replacment
- Replacing wheel stud
- Headlights/Chime oddity
- Bypassing the Heater Core and flushing cooling system
- Clutch is making loud sqeaky noise...
- Anyone Have Vacuum Line Schematics/Diagram for a 2001 Dakota QC?
- clunking noise
- Hood Pins
- rear disc brakes?
- Finished installing Mega in 04 QC (45rfe/545rfe)
- DFWDakotas Saturday August 28th Meet 1pm - Sponsored by Subway
- 3.9L freeze plug size (near oil filter)?
- oil on MAP Sensor
- P 0463?
- Just picked up a dakota, and i think the sticker in my glove box is wrong
- 98 dakota transmission swap-help standard to automatic
