PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 [82] 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Headroom in a '00 Dakota
  2. Speedo not working
  3. rear end gears..gotta question??
  4. Thursday Funny
  5. A VERY well covered topic!
  6. funny story . . . what could have caused this?
  7. drop questions
  8. P0132, P0138 Codes
  9. need to find
  10. trick to unclipping o2 sensor OE wire connector???
  11. 4.7 L Cat.
  12. Automatic Transmission not going into reverse
  13. MOVED: 2001 Dashboard Cracks
  14. 02 dakota with 100k miles
  15. aftermarket alarm?
  16. V-6 Twin Turbo?
  17. Sway bar sizes
  18. installation of underdrive pulleys
  19. wiper motor replacement
  20. tire size
  21. Trans temp warning light
  22. 2.5L CRANKS NO FIRE
  23. headlight problem? anyone else had this happen??
  24. 408 help
  25. Where do i Start??
  26. Major Misfire issue
  27. CB?
  28. blower motor resistor, only blowing on HIGH
  29. Oil Change?
  30. Intermittent soft brake pedal
  31. diffrence between a 2bbl and 4bbl intake manifold
  32. Whats the biggest trailer you towed with a 4.7?
  33. Brake Rotors
  34. Power of the dakota.
  35. Another Dakota Parts site
  36. mandrel bend tubing vs standard tubing??
  37. new sub installed!!
  38. misfire problems
  39. 02 4wd is gone
  40. Help needed ASAP! Temp. Sensor location!!!
  41. a few questions
  42. modeling a Dak. Ingame preview :)
  43. hmm...good or bad idea?
  44. popping sounds?
  45. thermostat question?? now i did my research
  46. clutch for a nv3500??
  47. Dakota Differential
  48. big brake upgrade questions
  49. paint streak removal
  50. CEL Vacuum Leak problem
  51. mopar intake manifold?
  52. Trans shifting
  53. lowering kit
  54. Need some help
  55. hp gains, what to do to get alittle more umph :)
  56. Man I'm so confused please help overheating
  57. Heated seats???
  58. Regular Tune-up Question
  59. Turbocharger?
  60. Pullys
  61. Found this
  62. good aftermarket foglights?
  63. r/t upgrades?
  64. 2004 Blinker question!
  65. how many r/ts still rollin
  66. we got problems here in mopar world
  67. question on power steering pump pulley?
  68. Underdrive Pulleys, Are they worth it?
  69. adding grease ports??
  70. Anyone have a detailed write-up on how to remove,..
  71. Spare Connector?
  72. Superchips Programmer 4 SALE
  73. HOW TO: Make the O/D default to OFF on start
  74. Poor wet weather start 01 Dakota
  75. Speedometer fluctuation, break & abs
  76. Emergency brake Seized, Warped Drum Brakes
  77. 2.5l performance
  78. close call
  79. 99 Dakota Ext. cab FOR SALE
  80. This is what you do with your old tires
  81. HELP NEEDED
  82. rack and pinion removal and repalcement intructions
  83. Rev or speed limiter
  84. flushing the tranny?
  85. Its been covered oodles of times...want opinion
  86. 2003 Dodge Dakota Issues
  87. New HIDS
  88. 3/5 drop
  89. changing plugs and wires
  90. Leaving the dodge forums
  91. Couple questions...
  92. Bought used 2000 Dakota No A/C
  93. 1997 V8 3.55 rear end vs V6 3.55
  94. Rough start after being in garage?
  95. Where are the oxygen sensors?
  96. new plugs, stll rough
  97. where to buy magnaflow online for my truck
  98. coolant leak
  99. Intermediate shaft
  100. looking for a 15x10 rim.
  101. New tires again
  102. Gauges Installed, but problems. (pic)
  103. HeadLight problems.??
  104. new taillights
  105. truck sounds like a bird?
  106. 2nd Gen Dakota Sway Bar Bushing Install
  107. the 02 sensor?
  108. 02 sensor wire diagram/ fuel pressure gauge install
  109. question about factory 00 Dakota RT alarm...PLEASE HELP!!!
  110. Check gauges light
  111. neon update
  112. Engine Size Decals
  113. Noise...
  114. dakota seems to have an charging issue
  115. Paint peeling off my 97 dakota
  116. lots of problems which to do first?
  117. changing my own spark plugs
  118. Need some help
  119. fuel consumption
  120. Front Axel
  121. Couple of pictures,..
  122. New plugs finally...gap?
  123. Front end popping noise
  124. headlight covers
  125. Carrier bearing
  126. You think....
  127. In cab lights
  128. dodge ram lights on dakota
  129. 612 dolar alignment
  130. WAX TIME!!!
  131. r/t
  132. Engine swap Question
  133. need help fast! electric fan problems
  134. Quadcab Hitch question
  135. seat belt buckle
  136. 20" Rims
  137. Anyone done ring and pinion gears?
  138. another funny question to ask
  139. remote start revisited
  140. truck leans badly
  141. Easy cheap invisible way to keep your truck smelling fresh!
  142. interior NEON
  143. Seat belts locked
  144. fuse problem
  145. Oil for 4.7
  146. Front pinion. Please help
  147. Water Pump Leak
  148. 1997 5.2 magnum rear end interchangable w/ 2002 4.7 magnum?
  149. Led headlights
  150. Oxygen sensor no fit question
  151. Hmm, what can a Dak pull. How bout this. -Pics
  152. New to 2nd gen. but not to the dakota
  153. sweet headlight kit
  154. all chrome front grill?
  155. dakota tire size..Anyone?????
  156. Cold Air Intake my A**
  157. Body lift + Brush Guard
  158. More power?
  159. Need to vent....
  160. horn, lights and wipers randomly going off
  161. Off topic sorta...(brakes)
  162. Lift for my dakota
  163. poor baby...
  164. shift problem
  165. Change the shift points on automatic
  166. ac comp whine
  167. Turbo
  168. front end
  169. setting up rear gears
  170. 5 Speed ?
  171. looking to build a monster motor
  172. lift kit
  173. HP gains
  174. Fixin a dent...Painted :D
  175. Check Gauges?
  176. Leaking transfer case?
  177. tonneau cover
  178. Best Plug...
  179. Congrats User2006
  180. Header Wrap around Cold Air Intake
  181. Why is DF geting so SLOW latley :/
  182. Do i need A/C
  183. Whats the brightest headlight bulb?
  184. Check engine light
  185. 1999 Dakota Upper Ball Joint Removal HELP!
  186. I got 2 codes for sensors. Can anyone help me?
  187. I got 2 codes for sensors. Can anyone help me?
  188. Any O2's sensors for sale?
  189. New Member~ 1st time Dakota owner
  190. Hub Nut?!?!
  191. im new
  192. Doing a 3.9 to 5.9 swap.. questions!
  193. hitch reciever
  194. Which Engine?
  195. All right, what am I doing wrong?..
  196. A question.
  197. Towing capacity question.
  198. 2nd Gen meet?
  199. injection cleaner?
  200. Getting cams? was
  201. New to Dodge with a few questions
  202. Positrac/locker
  203. wires
  204. Leak
  205. Ebay viper seats??
  206. Engine code help!
  207. painting valve covers..design ideas?
  208. major power loss and strange loss of RPM's
  209. 2001 4.7 tune up
  210. HVAC speed control quit
  211. Trailer Brakes
  212. Piston Slap (?)
  213. r/t vs motorsports edition
  214. loose steering---99 Dodge Dakota
  215. licenses plate
  216. headers and so forth
  217. which plugs to buy???
  218. project
  219. super bee graphics
  220. Looking for some advice.
  221. ticking...exhaust leak?
  222. Bumper gaurd
  223. Cam Questions
  224. horn button?
  225. low coolant temp and heat
  226. Knocking sound???
  227. TOTM VOTING
  228. cylinder number
  229. Y pipe
  230. I hit a deer.
  231. crappy 02 sensors
  232. hello
  233. Drop in bedliner
  234. keyless entry
  235. Dakoa Gas Mileage
  236. Dumb question about 2 wheel drive
  237. Puzzler for all you tech types?
  238. Recalls
  239. Poor braking
  240. Sticks in 4x4
  241. hello
  242. Sway bar bushings
  243. To anyone thinking about cutting off the cats....
  244. head gasket
  245. Maintainace Manual??
  246. '01 - 4WD Dead!!!
  247. Headlights Flickering On and Off
  248. Aftermarket K&N Air Hat? Will it fit?
  249. Exaust fun time!
  250. Headlights on with factory Keyless
