PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. what cam would yal suggest
  2. How to change a Transmission
  3. fogs in stock location? need help
  4. 2001 Dakota Phatom wipers
  5. Towing Capacity
  6. optima battery froze needed a boost
  7. power question
  8. want to buy dodge truck
  9. Strange stalling issue
  10. weird vibration at high speeds?
  11. brake problem
  12. lights behind heat/ac controls
  13. hey people, lets not forget to nominate someone for DOTM
  14. 99 dakota perfomance mods
  15. 1998 Dodge Dakota Stalling when warm no code
  16. Looking for Suggestions
  17. Bad Ignition Switch?
  18. SCB rocker arms
  19. No heat and truck runs cold
  20. Winter / Snow Tire Recommendation: Michelin Latitude X-Ice
  21. truck wont start
  22. DOTM Dec. Nom.
  23. Dash Lights Blowing
  24. Cranshaft Position Sensor
  25. Terrible gas mileage after mods
  26. 2000-Dakota-SLT (automatic-door-locks prob)
  27. 2002 4 wheel drive lower ball joints question
  28. Fan problem?
  29. whistle under hood when cold
  30. So....it's the holiday season...
  31. Help Please!!!
  32. Driveshaft Help
  33. ding is driving me crazy!
  34. in/out diameter?
  35. Throwout bearing.
  36. my 03 is stuck in 4 hi
  37. 99 dakota
  38. Wheels
  39. new headlights
  40. Power Steering noise
  41. what should i do next
  42. need help asap we got hit with a good snow storm and my 4x4 is messed up
  43. Need help
  44. Problems removing heads
  45. rims! bolt patterns/spacing?!
  46. CEL problem
  47. 29" vs 31"...
  48. What size tires
  49. Out of Control Throttle/Brakes in Cold Weather
  50. 2001 dodge dakota 4x4 problems tccm
  51. FS: Kicker Amp, K40 and Bel radar detectors
  52. Bad mpg's = I dont care
  53. truck dimensions?
  54. Abs
  55. a little fun in the snow!
  56. low beams dont work, but high beams do?
  57. question
  58. DIY: 02 sims
  59. to all you noobs with tires size questions!!!
  60. DIY Rust Proofing with POR-15
  61. tire question
  62. Please help. Heater not working and Coolant issues
  63. nv231d not disengaging from 4wd hi?
  64. dakota doors
  65. Front Axles blow diff. fluid up vent tube
  66. HID conversion
  67. 2000 DAK. 4.7L Loss of Fuel Mileage, Wierd Knock
  68. Coolant hose gasket change - 5.9 L 2nd Gen. Dakota
  69. Fluid Capacities
  70. 2001 dodge dakota qaud cab 4.7 ignition switch
  71. 3.9 v6 MPG and Check engine light
  72. noob tuneup questions
  73. VIN check... any help?
  74. Anybody know what this part is and what it's used for???
  75. Exhaust going in next week...
  76. questions any help welcome
  77. Question
  78. Clutch fan
  79. 155k miles
  80. Instrument Cluster Problem!
  81. 3" lift for 33" tires?
  82. REALLY annoying squeal
  83. Project "Runt" COMPLETE!!
  84. 4 wheel drive not engaging
  85. If I clear the CEL codes, will they come back?
  86. P0139 code? Read but don't understand
  87. Air Bag Light!?!?!?!?
  88. Parts
  89. new touchscreen headunit!
  90. Trans fluid 99 dakota with 5 speed
  91. New Here
  92. 4.7 dual exhaust with flowmaster review
  93. question about upgrading 99 dakota sport
  94. Winter rubbers
  95. o2 sensors... Too High Voltage
  96. Is bumper 1 or 2 pieces on '01 qc?
  97. NO power to trailer hookup
  98. I need a tranny
  99. shock options for 01 rwd 4cyl -recommendations?
  100. calibrating gauges
  101. 97 Dakota Transmission Fluid change
  102. Mild lift for some 33" tires...
  103. WTF! brake rotors
  104. Time for some noise...
  105. Jet Performance Module
  106. Strange grinding noise!
  107. anti-freeze in the powersteering???
  108. Been asked a million times
  109. T-case
  110. Help
  111. Noise between motor and tranny...
  112. heating problems
  113. Trouble finding power steering leak source
  114. 99 Dakota - Where is my distributor cap?
  115. engine chatter???
  116. tweak help
  117. How hard??
  118. dakota tires
  119. be stylin
  120. Rear wheel speed sensor ??
  121. Trans Issue
  122. Power steering pump size for 2004 dakota??
  123. Large Evap leak.
  124. What SUV?
  125. Power seat
  126. 98 dakota
  127. replacement 1-piece lug nets??
  128. rear axle swap
  129. 2000-2002 Dakota 4x4 Suspension Lift
  130. touchscreen radio?
  131. Fuel Economy and Exhaust problems?
  132. DRB Scan Tool needed for 45RFE Fluid change?
  133. Rear Window Replacement Problems
  134. 99 dakota
  135. Redline Oils
  136. New to the 2nd gen Dakota's, got some questions?
  137. ABS Light question...
  138. Anyone Sell a Complete Bushing Kit for an 01 RWD 4cyl Dakota?
  139. Some quick questions
  140. NV4500 swap?
  141. Steering/Suspension Problems
  142. Determining Differential
  143. You know what sucks... UPDATED with PICS
  144. Transmission clicking?
  145. Gas Smell
  146. Play in drive shaft?
  147. What is a "PCM" ?
  148. Diff fluids & 2002 SM
  149. quick tire question
  150. 4.7 swap, showing no oil pressure
  151. No low range in 4x4
  152. Need some wheel help
  153. DOTM Come vote!
  154. schematics
  155. Foggy windows
  156. hood release problems
  157. 2003 4.7 V8 Dakota Quad cab, how can I get better MPG?
  158. Transfer case linkage
  159. Dakota sport decal for 2002
  160. R/T axle
  161. CV Axle question
  162. Rain water on driver's floor
  163. Misfiring? Went through some mud puddles
  164. Transmission Problem Code PO740
  165. Lift question.
  166. Strange Smell...
  167. Help Please?
  168. shift knob
  169. Quick oil question
  170. Cruise control problem
  171. 4wd Standard Transmission from 99 Dakota and other parts
  172. Weird RPM thing
  173. custom sniper style grille
  174. hood for sale
  175. FAQ subsection
  176. Nov. DOTM Nominations
  177. Transmission (I think)
  178. Daytime running lights/Taking truck back to Canada!
  179. axle weight limits
  180. wheels
  181. Fender flares
  182. Is it possible?
  183. Help!!!!!!!!!! Lights not working
  184. Tire sizes on stock 2002 4x4
  185. Torsion bar heigh affecting steering?
  186. Race advice
  187. Stalling coming to stop
  188. RPM limited issues
  189. Newbie!!Can someone help me??
  190. New guy needs transmission help...
  191. very poor mileage
  192. removing back windows
  193. free owners manual
  194. Fluids
  195. I just repaced my water pump and Spark Plugs and now truck wont idle
  196. AWD Dakota???
  197. any major differences from 2001-2004
  198. Glove box light?
  199. transmision swap manual to auto limpmode
  200. Po601.
  201. WaterPump Replacement
  202. motor questions
  203. Anyone ever change out piston rings on a 4.7: before?
  204. governor
  205. 97 v-8 swap
  206. Confusion on TTY bolts in the 4.7L
  207. 1997 with VSS problems, driving me nuts!!
  208. Anyone here plow with their Dak?
  209. exhaust with best low end...
  210. Intake manifold gasket replacement 2001 5.9
  211. Stereo
  212. Durable Shocks Search: who you got?
  213. 98 Dakota Audio
  214. HELP: Mystery Gremlin in Engine/Transmission Control
  215. 00 vs 02 Netural Safety
  216. 1.7RR question
  217. P0443.....My Solution
  218. Gasoline shoots out during fill-up-anyone else?
  219. Dodge Dakota lifts?
  220. How To: Fix bumper rust
  221. Tail Lights wont turn off
  222. Sweet Summer Pic...
  223. Interesting Main/Rod bearing wear marks
  224. Check Engine Codes
  225. B&M or Flex-a-lite?
  226. Hughes Air-Gap vs. M1 for 5.2L
  227. FAQ Ideas
  228. FAQ -------- General Info, DIY, Engine Swaps, Lift + Lowering kit, Modification Ideas
  229. Bad connecting rod in 4.7L
  230. clueless about exhaust
  231. 2000 Dakota question
  232. acceleration problem, bad tps?
  233. 04 Dakota Heater Problem
  234. SoCal Truck Club now accepting members
  235. Fact or Fiction
  236. Has anyone replaced a waterpump bypass hose?
  237. Headliner removal
  238. Question on Heater Core System
  239. Another tire question
  240. I have questions about mods I want to do
  241. difference in trim packages?? newbie here
  242. DIY: Rebuilding a Track-Lok LSD
  243. T-case shifter extension
  244. Will replacing the O2 sensor increase fuel economy?
  245. 97 Dakota Charging Issues: Please Help
  246. Dirty Tranny Fluid Flush...Yes or No
  247. 2004 2WD SXT Rear Brake Drum Diameter? 9" or 11"
  248. Suspension: Ball Joints & Shocks Install
  249. just a quick post
  250. suspension question
