PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Persistent Belt Squeal
  2. drive line shudder?
  3. 2002 Dakota 4WD SLT bought today, a couple of small issues.
  4. Starting problem 2003
  5. Help!!! 98 dakota 3.9 here that won't start
  6. 2000 rt
  7. Merry Christmas & the chase for my elusive title
  8. 1998 Dak 318 v8 - ignition timing ...???
  9. Front suspension torque specs for 97 2wd Dakota(?)
  10. Incandescent to LED conversion for your HVAC controller!
  11. Power mirror inverted
  12. Sudden acceleration?
  13. Coolant system
  14. dang co worker
  15. 99 Dak 5.2 loss of power
  16. Power Window Cables
  17. Sputtering
  18. sentry key or not?
  19. flash needed for fog lights?
  20. Steering spindle
  21. need help finding a clutch
  22. Check timing and/or ECM on 4.7
  23. Engine swap
  24. 2001-02 dakota 4.7
  25. Add leaf spring Dakota 1997
  26. 99 heater core again
  27. Run without Front DriveShaft??? 2001 Dakota 4x4
  28. Can anyone tell me what this part is? Pics included
  29. '98 Dak intermittent wiper problem
  30. ASD / Fuel Pump Electrical Problem
  31. Auxiliary heater help
  32. Accel Programmer/Tuner
  33. Crown upper gasket kit
  34. Zone selector not switching
  35. 2000 Dakota - Seats Interchageability
  36. Muffler in/out
  37. 04 dakota 4.7
  38. Ownership update & the big switch
  39. Dakota thoughts, thinking diesel
  40. Headlight switch compatibility question...
  41. Will 05 transfer case fit in an 03?
  42. PCM diagnosis/ 5V on return
  43. AC Problem
  44. 2nd gen Dakota "deeply underrated."
  45. O2 Problems
  46. Nv233 to Nv244 swap
  47. 2003 Dakota temp gauge issues
  48. Noise when releasing clutch
  49. CTM / Headlight wiring issue NEED SOME HELP
  50. 3.9 intake manifold
  51. 2004 dakota shift tower
  52. My 2001 4.7 Hard starting I have to crank it over about 3 or 4 times
  53. 2001 Dakota Shut Off At Normal Temp, No Gauges
  54. po1491 bypass?
  55. 2100$ for timing chain and oil pump!?
  56. Need help from the 4.7 clan
  57. Transmission cooler questions 04 Dak SLT
  58. Does Anybody Make This? Air Cleaner Box
  59. 2004 Dodge Dakota Engine Sensor Issue
  60. Hemi swap
  61. Hydraulic vs solid lifters
  62. FOURWHEELER Show
  63. 2.5 to 4.0 Swap
  64. My fathers 99 Dakota 6 cylinder won’t down shift
  65. CTM Replacement
  66. Dash interchange 2nd gen questions
  67. Need starter
  68. 02 Dakota broken blend door differnt from Ram?
  69. Fuel rail crossover
  70. Injector harness plugs
  71. '99 Dakota R/T RC No Parking Light, Brake Lights or dash lights
  72. Red dash Brake light
  73. Fan clutch nut size
  74. 1998 Rear Leaf Spring, Must drop gas tank?
  75. Sure didn't see that coming
  76. Brake Line Kit
  77. Electric Fan
  78. Engine Swap
  79. Leaky heater hoses
  80. Starting a build of a 4.7, looking for some experience.
  81. Failing alternator?
  82. 04 QC Clutch hydraulics
  83. 5.2 to 5.9
  84. Transmission Slipping
  85. Test on plenum
  86. 5.2 magnum oil capacity
  87. 99 heater core?
  88. Pulling the engine
  89. Difference in rear end from a 2 wheel drive versus a 4 wheel drive
  90. Dakota doors
  91. Fluid in PCM
  92. Window guide
  93. 99 dak replace 8.25 rear axle with 9.25?
  94. 2001 Dodge Dakota Airbag Control Module Replacement
  95. Damaged Oxygen Sensor
  96. 2000 Dodge Dakota Cruise Control not working
  97. Oil Pressure Issue
  98. stainles headers
  99. Torsion bar tighten or loosen?
  100. Tranny or TC ?
  101. Rear Avle cover gasket or RTV ?
  102. 2001 Dakota brake controller
  103. Cross hairs
  104. whats the trick on front axle
  105. Torsion Bar Tool--Which? Necessary?
  106. 04 Dakota Quad 4X4 Rear End Froze up
  107. Bad crank sensor?
  108. Installed aftermarket radio and now speedometer doesn't work
  109. 4.7 bad valve seals?
  110. Pcm
  111. What part of "I DON'T want parts from China" dont the parts guys understand?
  112. Transmission fluid leak
  113. Help
  114. Help obd2 readings
  115. 04 Dakota Transfer Case Rebuild Manual
  116. Does the V8 trans bolt into a V6 truck? 2WD
  117. Metal parts in rear differential
  118. 5.9 Cylinder heads?
  119. Chasing down the no bus pin 2 on ecm not getting 12v
  120. HELP: OEM Radio Died - No Power
  121. Gross heads
  122. Power window problem
  123. Tow cap....
  124. Tilt wheel question
  125. Thermostat Question
  126. Front shocks
  127. Airbag control module and moisture
  128. seat questions
  129. 1999 Dodge Dakota sport no bus
  130. 01 4.7 Lopes at idle
  131. 2nd Gen Dakota Air Ride Kit
  132. Blower issue
  133. ‘01 4wd woes- again. Or, still
  134. No Bus
  135. Change Odometer from Miles to Kms - 2000 Dak 4.7L
  136. No bus message, use code reader?
  137. 5.9 dakota installed a nv3500 now it backfires when giving it gas help
  138. Default Over Heating Last options
  139. Where does this Vacuum line go?????
  140. P0455 and P0132 codes 01 model
  141. 04 Dak 4x4 susp lift /level discovery
  142. Most Accessories just went out
  143. 2001 4.7 wont run HELP please!!
  144. door weather strip
  145. 3"Susp Lift 04 SLT 4x4 QC
  146. Speed Sensor Question
  147. Hvac question
  148. Resistor issue
  149. Lift Kit Issues
  150. Good cam?
  151. New guy intro
  152. Front shocks
  153. ECM Module for 2003 5.9 litre
  154. Dakota Fan
  155. Speedo
  156. Torque loss ideas
  157. Power Steering Pump Pulley Installation
  158. Fender Flares
  159. Brake pedal issues
  160. F∆¢€|ng heater core
  161. 98 Dakota Brakes..I'm stumped
  162. 2000 Dodge Dakota V8 4wd Starter replacement
  163. Help!
  164. A/C compressor not engaging
  165. Racing rear diff
  166. Yellow plastic pull handle on top of fuel
  167. Front end noise
  168. 98 dak 3.9L 4x4 front end pop and steering play
  169. Largest tires with 11/2 wheel adapter no lift
  170. 03 dodge Dakota ac compressor not engaging
  171. Fuel Chip?
  172. 2000 Dakota lift kit suggestion
  173. No bus, no start
  174. 99 Dakota Clutch Cylinder Problems
  175. AC project question
  176. cruise control/abs?
  177. Helppppp
  178. 1997 Dodge Dakota has a dead driverside rear light.
  179. Engine swap.
  180. 12.5 mpg
  181. Center console ideas
  182. Relays failing, check engine light
  183. new alternator, still not charging (several things checked)
  184. Timing chain tensioner question
  185. Torsion bar help
  186. Dakota 5.2
  187. ABS Light
  188. HELP Throttle Cable 1997 5.2
  189. Orifice tube stuck in line
  190. Mystery tube
  191. No fire
  192. Found my water leak!!!
  193. 01 Dakota probs..ughh..
  194. The unusual Rattle noise
  195. 02 Dodge Dakota 4.7L Rwd Cats replacement?
  196. 2000 Dakota V8 Air Conditioning issue
  197. How many Oxygen Sensors does my Truck Have?
  198. Intermittent Rich Condition, Interpreting 02 Sensor Graphs
  199. Bed removal/swap 1999 to 2000
  200. 00 dakota abs light and brake light
  201. Engine sputter question.
  202. Pesky P1494
  203. Hello kind of new Dakota owner here
  204. Clutch issue
  205. Seat foam replacements?
  206. 02 3.9L exhaust, broken stud
  207. How much Oil to Add when just at low Safe mark?
  208. 2nd Gen - Drains in bottom of doors
  209. Nearest Available HOT and Brake Wires
  210. 1997 Dakota start problem
  211. O2 Sensor Replaced Still Getting Code
  212. I think my altenator isn't charging my battery right.
  213. A/C leak
  214. Multiple Issues (Possibly Related?)
  215. knock knock...... no one home
  216. Power steering leak
  217. Power steering leak.
  218. Recharging my ac. 2005 Dakota.
  219. It’s alive
  220. Brake question
  221. Lifting the 03 and 04
  222. 01 Dakota Serpentine belt comes off - I'm Stuck
  223. 1996 Dakota Gear Ratio Headache
  224. 02 Dakota A/C problems
  225. 5.5 quarts too much?
  226. How do you get o rings out of the radiator? Also where can you get the orings?
  227. Intermediate Steering Shaft Replacement
  228. heater, ac control module
  229. ECM plugs
  230. Transmission swap problems
  231. V8 swap someone help
  232. fender bender
  233. a little help on parts
  234. Climate control issues
  235. Accumulator freezing
  236. 04 stereo
  237. New guy here, saying Hi!
  238. 98 5.9 Manual?
  239. No power
  240. Flasher relay
  241. Dakota Engine Swap
  242. A/C not cooling well plus weird noise from evaporator?
  243. trans go ?
  244. Rear main seal leak?
  245. '98 Body Roll
  246. dodge dakota clunking noise on driver side
  247. 2002 Dakota dizzy
  248. Power telescoping tilt wheel
  249. Odd flasher behavior.
  250. 02 dodge Dakota part swap
