View Full Version : 2nd Gen Dakota Tech
- transmission fluid capacity?
- E...85...who the heck cares
- vacuum port on intake manifold
- need audio help please
- 99 Dak Headlight problem
- EGR valve
- Ready to Tow, need advice
- opinion pleeease
- Need advice
- No PCV valve?
- need help
- 02 SLT
- It just seems like my gears are way to tall...
- Exhaust diameter?
- My gas mileage sucks!
- magnaflow on a 3.9
- MTX Thunderform
- MTX Thunderform
- Performance help??
- PIAA H4 STAR WHITE vs SYLVANIA SILVERSTAR
- 2003 AC
- 32's
- misfire
- pics
- MOVED: Selling a 5.2L
- squishy brake fix
- how big?
- Possible stupid torsion bar question (I did search)
- "MULTIPLE CYLINDER MISFIRE" CODE HELP!!
- K&N for a 3.9L
- 2002 quad cab
- flowmaster
- Back end drop
- fuel mileage question
- Will my 3.9 L v6 pull my boat?
- trailer hitch
- Help!!!!!Charging system problem......
- no fire
- clogged cat?
- Looking for the strong silent type...
- 3.9 muffler help
- Factory radio problems
- Noob to this site!
- New DF member and Dakota RT ????
- Coolant Leak - question
- Passenger side water leak when using a/c
- Magnaflow Exhaust
- A Noob Dakota and Member
- Fresh rebuild, won't start!!!!!
- Brakes on Fire
- Mopar performance Valve covers
- Chip on a 2.5?
- Buying new Rims
- Throttle Body Spacer
- Tonneau Covers
- JET Performance Module or the Superchips Max Micro Tuner
- Say hi to the new guy
- any one looking for ceramic brake pads
- help me plz plz plz
- 01' quad cab with a 5.9?
- What clutch upgrade to get for towing?
- Spark plugs and fuel consumption issues
- Looking at 2000 quad cab with 4.7 and auto?
- HELP with the PCV valve
- HIT AND RUN [:(]
- Getting a 1998 Dakota with a V-6 questions
- Code P0442 & 0445, rpms bounce up and down, whats wrong?
- Engine Bogging down, barely reveves V6
- Some sort of problem.....I think!
- THIS IS VERY ODD
- 2002 Dakota lighting problem
- 97 dakota cummins turbo diesel
- a/c problems
- My new 2001 Dakota Sport
- running hot
- additional mods
- Performance Upgrades - 03 3.9L V6
- Stories
- 1999 dakota r/t... oil problem
- exhuast question
- check gauges light
- power steering hoses
- Service manual...
- Draining coolant...
- Hawaii Seat Cover
- heater/AC fan
- need audio help!
- NEED HELP WITH WATER SPOTS PLEASE!!!
- And so it ends....
- Directions for home made CAI???
- exhaust trouble
- Red or Green
- got a question
- Need help.
- Transmission question
- 1997 dodge dakota 3.8 steering
- Superchip microtuner or throttle body?
- Serpentine Belt Slipping off
- Flowmaster 40 or 50? (3.9)
- 2.5L I4
- I NEED HELP!!!!! PLEASE I'M GOING CRAZY
- underdrive pulley
- Stereo cutting out
- wheels and tires
- What is my next step for power?
- rear speaker question
- PLEASE HELP!!!
- Intermittant Fuel Guage False Empty
- lift
- Sugestions on wheels and rubber
- "01 Dakota 4x4 lower balljoint replacement
- Rev Rise
- Problem with electronics on cold starts? Brake/ABS light on. No electronics working (wipers, radio)
- Clutch adjustment?
- audio
- check engine light
- exhaust clicking...?
- Dakota pics
- bigger tires, tranny shift points?
- Check Guages Warning Light-After FLOWMASTER EXHAUST INSTALL.
- Diffs between an 01 and 03 Dakota R/T
- Water on Passenger Floor
- Limited slip or open?
- differential size??
- NV3500/NV3500HD how do you tell the difference?
- Service engine light on
- what should i buy first
- loud exhaust
- First Mods...
- Truck Pics
- Air Conditioner Check Valve
- anybody have problems with the 44re?
- Brakes?
- Ebay rotors and pads, think they any good???
- new
- Tailgate locks
- OEM PAINT?
- Sniper body kit
- HVAC Issue
- headers
- Overhead lights installed
- New Truck! - Wheels/tires
- TB Spacer
- Beef up a 3.9 V6 ??
- Wheels
- Im getting it tomorrow
- 1998 DAKOTA DIFFERENTIAL
- Exhaust System Info Plz
- July Ride of the Month Voting!!!
- oil
- how does this sound
- V8 Dissapointment
- Transmission
- 2002 4.7L fuel pressure?
- New to here & Dodge ownership
- Help on performance
- high rpms
- 2001 Dakota Sport
- high rpms
- OIL PRESSURE TAKES A WHILE TO GO UP???
- turbonator?
- Wheel fitment
- MORE MPG
- NEED HELP
- torsion bar question
- 1998 Steering
- speedometer
- Intake
- Meshing the front grill. HELP!!!!
- air intake temperature sensor
- Remote programming problems
- leveling kit
- Changing Transmission Fluid
- Wiring Harness/CPU differences??
- V8 engine swap
- got recalls fixed.. but they gave me a list of things to fix
- INFORMATION NEEDED PLEASE!!!!
- reading engine trouble codes 2001 4.7 Dakota
- Carbon Fibre Tail-lights
- Diagnostic Trouble Codes
- Cowl Trim Cover
- Dual Exhaust
- Axles?
- Rear Speaker Access
- New Life for my 97 W/5.2
- Parking lot stumble
- condenser fan
- *sigh* i have to sell it....
- Daytime Running Light Mystery
- 3.9L 1 in 2 out
- Catalytic converters on '03 4.7 QC
- 97-04 body style popularity
- cranking
- Heylo All
- Storage solition for stinger
- Flowmaster and Magnaflow single in, dual out mufflers
- hey there, im new! buying dakota
- Center Caps
- '01 QC 4.7L with engine starting problems/issues
- Noise when I start my truck
- SLT and SPORT
- Limited Slip
- Airbag Wiring?
- 2001 4x4 front axleshaft replacement
- A/C stuck on Defrost- 99 Dakota w/ 318
- Lift for 2004 dakota
- Tires-1997 SLT
- Dakota VS. Durango
- Replacing Battery Cable
- Please Help! 98 FWD Transfer Case situation
- Interior cabin filter
- ProCharger 1998 Dakota 318/5.2
- Fabtech Suspension Lift for 2WD on an '04?
- All-Mopar show in Albion, PA
- sound system
- 02 sensor
- loud fan
- tell me your thoughts....
- 04 dak. Quad cab V8 w/water leak on Drivers side floor boards
- body lift and factory warranty
- Jet PCM's?
- Fender Flares
- cam and crank sensors?
- Hello Folks
- Big Spare Tire
- bad gas mileage
- 2001 BCM ?
- CHEAP AND RELIABLE LIFT FOR '04 2WD?
- exhaust preference
- 2000 QC 4.7L SLT 4X4
- 2000 dakota eating O2 sensors
- Chip Mods
- Cold Air Intake
- Most miles on a 4.7l?!?!
- need help! 4.7 with a bouncy idle most of the time????
- exhaust shop in nashville area
- Dash / Gauge cluster styling upgrade
- Running Boards
- Difference between the R/T 5.9l and SLT 5.9l
- vacuum
- stock amplifier location??
- I NEED HELP!!!!!!
- picture avtar thingie
- FREEZE PLUGS LEAKING -ANYBODY KNOW ABOUT?
- bigger tires
- gas question
- 1/4 mile et, mph..
- Remote problems???
- Oil pressure jumping around, some ????'s
- I was wondering???
