PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Common swaybar size on v6 2k dakota 2wd slt?
  2. 98 4wd manual transmission leak HELP!!!!!!!
  3. Hello Everyone_First Post
  4. Need some Electronic Help
  5. 4.7 Tapping
  6. 97-04 Dakota OEM corner lamps
  7. 97-04 Dakota OEM side mirror
  8. 97-04 OEM tail light
  9. What adhesive to use?
  10. Ford taurus fan install by 87 GN
  11. Some info for 2.5L engine Dakota trucks no PVC system
  12. Well, I did it now,..
  13. White Smoke
  14. srs arming under braking?
  15. Follow-up< ABS light, Brake light ON
  16. My engine hates me
  17. Local junkyard inventory
  18. 4.7L, Hard Start & Slight Tap When Cold, Stall at Idle
  19. spectre cai
  20. idle problems 4.7l quad cab 2000 model
  21. Lights
  22. cleaning contacts
  23. Malfunction Indicator Light
  24. anybody know of a parts truck
  25. do I have a towing package?
  26. 2000 Dak Steering Problem
  27. starting problems
  28. Kota Took a dump!!!ERRRG!
  29. 42 overdrive raito
  30. a/c resistance
  31. break problems
  32. Interior Work
  33. A tip for the NV3500 5-speed
  34. Dakota Fuel intake problems??
  35. Help with 1999 Dakota Limp Mode (Unique)
  36. power steering cleaning of reservoir
  37. Alternator voltage output
  38. Brake and ABS brake lights up on dash?
  39. Heating and cooling (or not so much)
  40. running/parking lights problem
  41. Oil level changing
  42. ctm questions
  43. Malfunction Indicator Light
  44. FIX: Auto shifter locks with key on
  45. wana put dodge ran 20''s on mt 03 dodge dakota
  46. Lift install ?'s
  47. failed spring in steering column?
  48. switched ignition power source
  49. efan mod question
  50. awd driveshaft question
  51. Help dont know what to do.
  52. WTB: Fuel tank skid
  53. connector terminals
  54. Did plenum repair and found this....
  55. Tire size gear ratio best power question
  56. truck
  57. Upper ball joints
  58. Need new Headliner suggestions were and good price
  59. 4.7 Head Gaskets or Long Block
  60. Upstream 02 sensor 3.9
  61. having gears done in DFW
  62. got bit by the perfoemance bug
  63. True duals?
  64. 2002 Durango transmission shifting way late
  65. Crankshaft position sensor
  66. 1999 Dakota Blower Motor Doesn't Work
  67. Camber adjustment?
  68. 3.9L radiator fan swap, mechanical to electric???
  69. Radiator replaced twice
  70. Ordered a spintech...
  71. Falken High Country tires
  72. 3" Body lift handling like S*it -Please advise !!!
  73. 180 tstat change
  74. Real quick wheel question
  75. help... with clutch...?
  76. Ho cams.
  77. Normal Oil Pressure
  78. what do you think...?
  79. power window lock conversion
  80. Help with factory alarm
  81. 2001 Dakota 4.7 4x4 Transmission Swap
  82. speaker questions
  83. Air conditioner problem - Compressor Clutch?
  84. CCFL halo projection lights always on...
  85. Dash Removal 97 Dakota
  86. Help With Leaf Springs?
  87. water temp sending unit
  88. A note about oil pressure
  89. how hot is this
  90. 5.2L Intake question
  91. Malfunction Indicator Light
  92. wiring diagrams
  93. OEM Trans Cooler - Line Routing (Help)
  94. Don't ban me
  95. buying a 2002??? HELP
  96. oil question
  97. Want a cab visor!
  98. check gadges and oil pressure drops at idle.
  99. Oil capacity 4.7 with fl1a filter
  100. Just out And about, couple pics!
  101. Iyo
  102. 97 Dakota not shifting to 3rd
  103. whats the best way for about 50 horse more
  104. Prices
  105. Factory Rims
  106. Good place to mount offroad lights?
  107. What does a failing 45rfe feel like?
  108. What are the largest tires that will fit on my truck?
  109. What a wonderfull day!!!
  110. 2002 Dodge Dakota not starting help please!!
  111. Fan motor problem
  112. Installing condenser
  113. overheating
  114. New transmission mount. Looks crushed already.
  115. Bizarre Overheat
  116. location of 4HI on 99 Dakota Sport
  117. 98 dakota, air cond. pump pulley replace?
  118. Need Rear Supsension Help
  119. Dakota fan clutch removal
  120. truck will not start.....help!
  121. HemiDak-Quads 97,Jeep Hemi Swap....
  122. soft tread or normal wear?
  123. 2002 Quad Cab parking lights/turn signal question
  124. Rear bumper restoration finished
  125. new rig
  126. Ball Joints...rip dakota?
  127. Cat and 02 sensor
  128. what did i do wrong with the seafoam?
  129. dumb question - adjusting rear view mirror
  130. Time for a new exhaust...
  131. want a sound system, but where to place amps and speakers
  132. Options for new transmission
  133. Sympton?
  134. New billet engine bay dress-up
  135. Anyone install an HHR fan into a second gen yet?
  136. What color paint to paint my truck?
  137. small coolant leak.
  138. front end noise
  139. Fan clutch info, with pics
  140. Nasty stock bumper
  141. 2004 Dakota SKT 4X4 steering wheel knock
  142. Radiator overheats
  143. Exhaust manifold flange
  144. 93 Dakota Fan Blows On All Settings But High
  145. 3.9 timeing chain gears dot alignment question ??
  146. headlights turn off when tilting steering wheel down
  147. Engine stalled. Will not start
  148. Preventative Maintenance?!?
  149. New Fluids
  150. Brake Trouble
  151. Check Engine Lite on here are the codes(Please Help)
  152. Mysterious Thud/Thump/Clunk
  153. New Headlights, need help on picking!
  154. Steering Vibration at highway speed
  155. 89 Octane gas
  156. hidden cut off switchs
  157. Help!! Stop running and won't start
  158. Transmisison help needed P0733
  159. Can you see me now?
  160. 2000 Dakota shift indicator out of alignment
  161. Brakes go to floor HELP
  162. Gear ratio??
  163. Coils! Help me!
  164. 03 dakota code p0442
  165. Lower temp plugs?
  166. Gotta pull some stumps
  167. HID fogs
  168. There and back again
  169. R12 freon for 2001 Dakota
  170. Brake job ?'s
  171. Does this look right?
  172. Installing fog lights
  173. axle shaft question 8.25 rear end.
  174. Head Gasket Kit
  175. new plugs @ 60,000 miles?
  176. STS turbo
  177. 2002 dakota running hot
  178. Exhaust Yay or Exhaust Nay?
  179. Truck rocks from side to side even with new shocks.
  180. a couple pics and Sullly!!
  181. MAP Sensor for 2001 Dakota $114.00?
  182. serpentine belt lenght 98 5.2 dakota
  183. truck run bad... wut do
  184. Trans, Transfer Case, Differential Oil changes
  185. left side speakers dont work
  186. Rats ate the seat belts
  187. 2wd lift
  188. 2001 dodge dakota
  189. I need a replacement back window
  190. Bull Bar did it's job, I guess...
  191. Door Hinge Pin & Bushing Kit
  192. New to the Board- Quick question about rear bumper
  193. 99 AC issues
  194. Electrical Issues...:(
  195. Tune up
  196. Selling the truck
  197. Guess what I'm up to
  198. '02 dodge dakota quad cab
  199. anybody heard of rally ignition coils
  200. fog wiring overkill?
  201. Auto to NV3550 conversion
  202. strong gas smell and cut out while the a/c is on
  203. need pics of leak detection pump installation or video for 2001 dakota
  204. howd they do that?
  205. side posts
  206. 2000 Dakota A/C
  207. Truck temp while towing in heat, and reducing
  208. Installing engine in dodge dakota 01
  209. 3.9 running rough
  210. Reseting PCM
  211. cold air intake (CAI) actually WORTH it on a V6 3.9l??
  212. motor change question
  213. Tricky starting and shifting.
  214. beat the dead horse: battery
  215. 2000 4.7 Surging and dying
  216. Engine swap?
  217. truck sticking or skipping first gear HELP!
  218. I gots a new plan...
  219. Methanol
  220. Engine fuse block
  221. Coolant Help
  222. Driveshaft removal questions - new member
  223. 2002 Dakota 4x4 FOR SALE!!!
  224. TB questions
  225. '98 v6 running too rich and I'm out of ideas
  226. Tune for 3.7 V6?
  227. Rear window question
  228. What presure to charge AC to?
  229. Rage thread! Share your stories!
  230. rocker arm troubles
  231. Transfer case
  232. Third Brake Light Malfunction
  233. Nice Quiet Stall
  234. 2000 Dodge Dakota Overheats
  235. how much should fan resistor cost?
  236. Minor body work and new paint!
  237. Help with noise and vibration
  238. side to side play new u-joint
  239. 3.9 cyl heads - what years will work on a `97 engine ?
  240. turbo...?
  241. rusted freeze plugs
  242. Stealership Got Me with a BG Trans flush
  243. Need advice on muliple misfire codes
  244. UGHHHH someone got a stick of c4!!
  245. Turn Signal Issues
  246. I need help please
  247. Need stock air hat
  248. Larger tires
  249. Replacing the clutch
  250. NV 3500 shifting problems
