View Full Version : 2nd Gen Dakota Tech
- Hot rubber smell?
- 1997 dodge dakota need help missfire
- 2000 dodge Dakota SLT 4x4 4.7liter. With transmission problems.
- 1999 dodge Dakota 42re overdrive issue
- Towing and overdrive question
- Front End Pull
- Hesitate Starting
- Lifting power window without power
- 2002 SXT downstream O2 sensors
- 2000 Dakota Exhaust
- Front Half Axel breather Mod (To prevent water during offroading)
- Want to hook up aftermarket water temp gauge
- Power windows
- Cel
- Reset PCM
- 3.9L Magnum Rebuild, Swap anf other info
- New Dak owner trying to kill some gremlins
- Just sharing my plennum fix so far.. PIC HEAVY
- Ignition + CEL issues
- Questions about a few issues?
- Starter cranks when attaching battery cables
- 4 wheel drive
- Rim and tire help?
- Need help 02 quadcab heater blower wont run
- Dodge Dakota Dash Lights
- need help with transmission
- 545 RFE Soleinod issue
- light bar for off road lights
- Any tips on Dash removal????
- P/s messed up after playing in the snow
- Need some advise on moving forward...
- Security feature engaged
- Head gasket????
- dead horse intake question, kegger mod
- Leaking 3rd Brake light with no seal?
- Tccm
- stiffening the Rear suspension on a Base Model
- 2001 Dakota Parking Brake won't disengage
- '97 3.9 Died Today
- truck stalling
- loud noise
- Dakota mpg sucks worse than Ram???
- Winch for a 2000 dakota
- vehicle shaking, rear diff issue? help pls
- Custom work I'm doing explain later
- Headlight Wiring Gone Wrong
- power steering help!!!
- Terrible gas milage
- In out tie rod ends
- Replacing shocks...right forum?
- Catalytic converter replacement??
- Bumper cover 02 one piece on a 98?
- in need of some help please
- P0720 issue.
- 3.9L under heating issues in winter
- TCCM question
- 2000 4.7 Won't Idle
- 265/70/16 or 265/75/16?
- 2000 Dodge Dakota 4.7L issues
- OEM Headlights
- obd port replacement
- Need Help- Suspension/BUshing work
- warning lights
- Magnum Throttle Bodies
- Shifts out of OD randomly, otheerwise shifts great
- 2001 Service 4WD Troubleshooting
- Looking at a very high mileage Dakota Quad cab
- 2000 4.7 cooling system problem
- 545RFE fluid change question
- 2004 Dakota Dash Replacement
- Transmission problem
- Any pictures of body lifts?
- 2000 Dakota, many problems, worth keeping?
- Speedo jumping around
- 01 Dakota will not start
- fiber glass hood repair?
- Towing a Camper
- 97 dakota starts but doesnt run
- Truck whistling sound
- 4.7 o2 mystery
- lift question???
- 3.9 good, bad and ugly answers please
- School me on Lift/Tires
- 2.5l dakota sport -- full racing exhaust
- Diagnosing Codes. Need Help.
- 99 Dakota 2.5 replace engine
- 98 struggling and rough idle misfiring
- Which Magnaflow?
- big block dakota
- Any unlifted daks with 32" tires?
- misfire wont go away
- Shifting question and odometer question
- p1389 after head job????
- Clutch pack retainer clips
- throttle cable
- Sludge.. How to solve
- 01 dodge dakota 4.7 engine problem need help.
- shifting issue
- High pitch whistle
- O2 sensors, multiple misfires in all cylinders problems
- I have a 1998 Dodge Dakota SLT Magnum 2 wheel drive v6 3.9 liter
- Check Guages Dash notice
- Won't Start - No Electrical Power
- 02 sensor problems
- Resetting cruise control minimum engage speed
- manual transmission question
- hvac question
- oil filler neck smoking under the cap
- Intermittent noise from rear
- Shifter gone wild
- Time and Alarm Module/ Central Timer Module
- 2004 Dakota 4 low problems
- back up lamps blown fuses
- 03 dak brake issue
- 2nd gen Dakota
- Check Gages Light On
- Help me decode my build sheet
- Trans neutralizing in turns
- 42RE Transmission Help
- 3.7 to 4.7
- My Turn for an Accident
- 1998 dodge dakota multiple codes
- 2000 2wd lift kit
- p0351 1997 Dakota 3.9l
- Bad Harmonic Balancer?
- 3.9 L barely heat idling, heat when accelerating
- Front Suspension Squeaking (bare with me)
- I got rearended BUT things are good
- Need HEAT. Help
- A loud noise on my 2001 Dodge Dakota, what is it?
- I may or may not be a very lucky man
- More Questions about SAS
- Help!!! New Transmission??? Really???
- No brake pressure
- Vac line question
- 2001 Quad Cab Sport driver seat install
- 1997 Dodge Dakota Rack & Pinion
- 3.9 Refuses to Idle when Cold
- 3.9L overheating; need help with what to do
- Dakota rear sway bar options
- 2001 drivers door
- 99 4wd dakota moaning sound from front
- Another quick coolant question
- Steering wheel and key locks up.
- trans fluid change?
- Wanting to add 5th gear
- Yet another exciting rear diff thread
- differential fluid change
- Battery \ Altenator Gaugue
- differential oil ?
- synthetic oil filter?
- Speedo doesn't work unless it's cold
- 4.7 Enging that needs TLC
- How to clean 2000 Sport temp sensor
- differential fluid?
- conventional or synthetic?
- Slight front end ticking
- lower ball joint retaining ? removal
- Front diff overflow?
- Back up camera install
- 98 Dakota 2.5 LWB Single Cab, Swap to 4.0, Thoughts & Opinions??
- No power steering
- Overheating issue (4.7)
- Leveling kit for a 4x2
- Tranny Swap question!!
- Diagnosing a clunk
- Dakota Won't Start
- Brake Line Fitting.. again
- EVAP 97 2.5 dakota
- Solid Axle Swap
- truck bed .... one whole piece or parts
- PO2098 check engine light code
- solid axle swap
- 3 gear wont switch to 4th
- dodge dakota 2nd generation
- Very Odd rear end noise while making Left Turns.....
- battery amps for dakota 2000
- Power outlet 1998 Dodge Dakota
- 2003 Dodge Dakota Starting Problems when wet
- Female Needs Tranny Info - PLEASE?
- Transmission swap
- 2002 dakota 4.7L and 99 dakota 5.2 any engine parts interchangeable?
- Heater Core Flush time... Which hose is IN/OUT ?
- Viscous fan delete
- Overheating
- odd bank misfire
- Ball joint question
- Fog Lights not working 2002 Dodge Dakota SLT 4.7 L 2wd
- Pinging noise at tranny inspection plate
- Led turn signals and marker lights
- no spark yes i did research
- Tie Rods
- Questions for putting procomps rim and 32" tires
- Troubleshooting Throttle problems? possible Vacuum leak?
- Transmission
- '97 Dakota Transmission overheat leak then fine
- Electric Radiator Fan 2004 3.7 Problem
- Cruise Control?
- starting issue
- Check Gauges Light
- Broken CV Joint someone HELP
- radiator for a 2001 Dakota
- Need part for seat
- Will these rims fit my 2002 Dakaota?
- Blown Blower Motor Control Module
- Cruise Control Cable
- 1998 3.9 Dakota.... How to Set the Timing
- Transfer case crack?
- CV Joint
- Block heater help?!
- need help
- Power steering problem. HELP!
- Lift Kit Question Someone HELP
- EGR valve or EGR tube or pipe questions
- RE: What engine will fit?
- need new pcm
- engine problem has me stumped
- Another Wonderfull Cam Position sensor question
- Felpro VC Gaskets
- Won't stay running till she's warm
- pcm 04 dakota
- 4.7 Dakota won't start
- missfire
- Bent control arm
- 2002 Dakota blower motor resistor - again
- Which side is bank 2
- Passenger Air Bag Problem
- Low On Coolant, Over filled on Oil
- all gauges dead unless parking brake is on
- Fuel system info request
- timing chain opions
- stalling in cold weather
- crashed...
- Newbie needs some help
- How to R&R the Power Door Lock Assembly ?
- CEL light
- Annoying starting issue.
- Transmission pan 1997
- 44RE Transmission help.
- Cranking Torsion Keys?
- Fuel injection ticking sound
- Programmers- Looking for feed back from actual users
- Tips on removing and replacing front shocks on a 1999 2wd dakota
- Engine Running COLD..... WHY ?
- Tire Clearence?
- Which water pump do I need?
- Check Engine Light. Help
- General Grabber AT2 vs. Nitto exo vs. Nitto Terra Grapplers
- 2002 Rear Brake Issues
- 1998 to 2003 bumper swap
