View Full Version : 2nd Gen Dakota Tech
- removing fuel rails and other things
- 95 2500 FRONT HUB BEARINGS
- HELP *URGENT*
- Is this problem the flasher, turn signal switch or trailer wiring?
- Starting Issues
- new here, overheating problem
- Raced a WRX, non STI
- transfer case
- NITROS
- dodge window regulator
- cold weather folks?
- electric radiator fans
- tranny problem
- Trouble starting truck (noob)
- Question(s) from a Noob
- wiper cowl?
- MOVED: fuel filler hose tutorial
- NEW PICS!!!!!
- surging while driving.
- Any advice on Infant seat for dodge Dakotas???
- Metal Scrapping noise?
- draining coolant system?
- Quad cab 4x4 problems...??
- tranny swap
- Tie rod replacement and torsion
- Chiltons or similar for 99' 4x4
- SuperChips Programmer SALE!
- pulley trouble
- limited slip out of a corporate 9 ram work in dakota with corporate 9 rear?
- Front drive axel
- dakota vs tree
- Oil Pressure Gauge...
- Rear Axles
- what trans do I have?
- lift kit
- Valve Cover Leaking Oil...
- pulley
- stroker kits
- radio plugs
- Instrument cluster
- How Important Is The Front Splash Shield?
- viper brakes
- Dodge Ram Lift?
- A/C lines
- spark plugs
- **UPDATE**Coolant leak
- heater/ac smell
- blowers????
- aFe CAI= Bad Ass
- Universal Joints
- stalls out at wierd times
- tow hooks
- transfer case
- vacuum diagrams
- For dak owners with satellite radio.....
- Scheduled service????
- Performance Fuel Injectors and coil
- DECALS
- Crankshaft sensor problems
- Blower motor/resister ??
- funny idle then stalling
- '01 water pump replacement
- ABS PUMP RUNS CONTINUESLY
- coni-seal....any opinions
- 01 Front Left Grinding....
- 04 3.7 dakota fuel filter
- transfer case fluid
- Tranny Slipping
- Removing 3.9 crankshaft
- 5.9..?
- Bench Seat
- im getting closer but still have problems
- ABS/Brake light
- New tires for sale!
- weird noise n the front end?
- Headers for V6...possibly found...
- Disabling the AC for winter time?? (How to / Possible / problems associatd with doing so)
- pilot fog lamps
- no heat
- looking for bed rail caps
- Racing Stripes
- Lost part
- o2 sensors
- low oil pressure and low idle when stopped
- Anybody Need a Rear Bumper? F/S
- Peeps from the Mud!
- Locks Go Up And Down While Driving W/ HLS On
- 2000 Dakota Electrical Problems
- parts for sale.
- HELP i screwed up big time
- Saw some cool Tail-lights on a Dak last night,..
- Jeezz,.. I can't get a break,..
- new seats found!!
- It's been a proud day.
- What do I need to Lift my Dak?
- Some upgrades for a '00 Dakota
- bad smell coming from vents?
- UP-DATE; On my burn't up interior,..
- For the money
- A list Of Problems
- Hurst T-handle
- Question on lifting
- Radio switch
- new rims
- truck threw a code for the first time
- Fuel Tank Upgrade
- gas tank
- Light not Blinking
- Chip/Programmer
- I think my truck should 'wind out' more
- hey!
- ball joints
- Cooking the front rotors...WTH?
- damn starter
- 3.9 engine
- Removing Cat.
- trouble shooting
- 98 Dakota
- Electrical testing question
- Tranny @#$%&
- Brakes
- Ticking Noise Narrow Down
- Stalling after fitting Cams
- Budget Intake
- strange smell
- HIDs in Stock housing?
- a/c and oil pressure problem
- Transmission swap, 3.9/5.2 interchangeable?
- Throttle body spacer?
- gutted
- Help on misfire
- Tranny and Shift kits
- Help Rear Diff problem
- Vacuum #'s
- dyno test
- block for sale
- pic upload prob
- 1.7 rockers for sale
- Reciever with rusted in hitch....
- My new DaKota
- short throw shifter
- console latch?
- Just got rearended
- Help gotta problem
- can sumone help me make a sig?
- 2001 kota sport radio
- New Parts on the way!
- Center Caps for 2003 Dodge Dakota Spare
- relay question
- Alchohol Injection
- viper fan
- owners manual?
- 160 thermo
- 4.7 throttle body question
- Leveling my truck?
- Picking out Parts
- 4.7 dakota gears
- wiring diagram
- Tranny question
- need parts!!!
- Fan clutch question?
- Roll bar
- Headlight Switch
- Torsion Bars
- 3.9 ENGINE NOISE
- What are your opinions!?
- Hello again ........
- '99 Dakota Club Cab(?) rear speaker/Panel help!!??
- pics of new tail lights
- np231 transfer case
- TB gasket?
- do you roll a 2x4 or drive a 4x4?
- Tranny Stutter
- 180 thermostat
- Front axle replacement
- ABS and E-Brake Light?
- Questions
- Play MP3?
- need wiring help
- buddy of mine
- New Deck
- front end
- Evap Code??
- sticking steering
- Just did tranny...
- best stickers?
- 4wd light on
- True Duals
- Lund Racerback Pickup Cab Fairing 87-96 dakota 14009 ebay
- Question about towing with a 2/3 drop?
- low oil pressure
- College Boredness...Hooker or Magnaflow?
- Flowmaster, Magnaflow....
- supercharger kits. whats the best?
- transfer case switching motor
- New Flow 44's and Hemi test drive
- Easy Mods?
- HEADER PURCHASE
- Gen 2 what to look for
- Cost of a shortbed and tailgate?
- Pcm swap test?
- Many questions
- stereo problem
- ECM question
- Steering
- Best Bang For My Buck?
- shift kit?
- oil pressure gauge
- HELP, I'm drowning!
- IAT location change?
- Speakers??
- complete suspension upgrade/rebuild and no i didnt use the hotchkiss TVS
- 97 forgetting how to drink
- what's up I'm a newbie! rear end Q...
- 1pc Headlights? Pics?
- tool box for sale...
- neon...
- Cabin Air Filter
- my blower went out!
- 2002 dakota 4wd wont engage
- Supersprings
- dropping some weight
- wanted parts
- 2001 3.9 V6 Dakota Won't start!
- running rich
- AC/heating problems
- Another E-fan question
- trans problem (imagine that)
- Adding power features
- Air Conditioner turns off when truck isn't moving
- cant find this piece
- Here's some pics of my Burn't-up DAK,..
- 1 of 117 Bright White Single Cab R/Ts
- what size
- Infinity or not?
- Noise in left front wheel on 98 Dakota
- Rattling noise from engine bay?
- Anyone got any foglights?
- Hi all,.. Been a while since I last posted on here,..
- 180 thermostat
- Offset or center for new muffler
- Bench seat for 97
- power steering problum
- lights out
- Switching from synthetic..
- 2000 R/T Manual
- Exhaust for Cali
- cam ideas!
- 45RFE Transmission on a 3.9l Motor????
- 5-45re tranny
