View Full Version : 2nd Gen Dakota Tech
- I think there really is a tranny problem this time...
- What is the thing after my muffler?
- Noob question
- Hot disc brakes
- LED replacement bulbs
- Somethings off...
- engine swap... yes another thread
- Stupid question regarding first cold start RPM's
- Thinking of switching to R/T..
- Not a Dak, but 4x4 owners might appreciate it:
- I must say thanks to the Dakota
- Transmission question
- Airbag Light On....Module or Clockspring?
- O2 sensor Wire Diagram needed
- Light bar question
- engine bogs down under accel. and steering full lock
- Florida to michigan
- 2000 4.7L 2wd dakota uneven braking issues; need major help! Tried almost everything
- Need help with my truck, 'codes"
- Spare tire question..
- 2 Gen Styling
- street<offroading *tons of pics*
- Has anyone coverted their stock Dak headlamps into the HID ?
- Dynomax muffler for '04 quad cab 3.7L
- Installing cruise control in 01 QC 4.7L
- Camper shell
- Front End Howl
- New grille
- Reese universal Hitch for 03 dak.. anyone else ever use one ?
- Programmer Question
- Moonroof/Sunroof
- 2004 dakota PLEASE HELP!!!!!!
- What should i do
- Towing a 20' boat, from Oregon to British Columbia-few questions
- Code P_1494 on my 2001 Quad Cab, 4.7L
- What size rims?
- rim and bolt pattern
- v6 to v8 swap to hard?
- 2003 Dodge dakota Sxt Club cab 3 inch body Lift
- Mega Parts List 2000 Dak R/T come get some
- 2003 Dodge Dakota Sxt Club cab Tires
- 2003 Dodge dakota sxt
- Newbie buying advice
- What to do, what to do..
- BIG rims on 3" body lift 4x4 dakota?
- 01 dakota exhaust
- Quick non dak question need opinions!!!
- 99 dakota
- Exhuast for 3.7 L?????
- come vote...
- New Cold Air Intake makes hissing noise
- Need opinions for this "supercharger"
- 2002 Dakota caliper removal
- Just got 2002 dakota...tranny problem?
- Needs the Lift kit Guro's.
- doors automatically unlock...
- Running rough after having heads off
- O/H console question
- hit and run.......pricks!!
- Hub/Bearing replace on 2001 Dakota 4x4
- i need sereous help!!!!! starter dont energize
- Replacing Muffler
- Looking for some help guys...
- cheap front lift?
- 97 Dakota A/C Problem
- Hemi Swap VS 5.9 Swap VS Change Heads?
- Offset Question
- Upshift Issues
- Cup Holder Rubber Inserts
- got some goodies... want some more
- what i gain, what i lost...
- 1998 Dakota
- 4 wheel drive instructions
- Door locks will not work correctly on 2000 Dakota
- How to: Home Made CAI?
- 99 3.9 v6 cutting out
- is this a bad idea body lift and tire question
- gas mileage
- Engine swap Vs. Performance Parts
- '03 Dakota Overheating issues
- Why would an alternator not put out a charge?
- dyno day results
- Code 0442??
- Wally World Rumor
- 3.9/5.2 swap?
- Running boards/ ground effects for Quad Cab??
- Completed the sound system.
- engin swap question
- Clutch fan delete?
- Was there a long bed on gen2?
- Non-Dak ? for any mechanics who will lend an ear..
- 1999 Dakota Sport
- Brand New V8 Emblems
- '04/V6 4x4 inner tie rod replacement
- Delayed engagement: 45rfe Transmission
- Superchips Flashpaq
- Another rear diff. problem!
- transmission swap
- Problem Leveling headlights!!
- Question on Control Arm Bushing Install
- Anyone running 265/75/16s on stock suspension
- i thought i bought a street truck. lol
- Bed Size
- leather interior????? any one
- Power steering reservoir
- 99 dokota tranmission
- An invite to 3rd Gen. TOTM!!
- Do ~02 Dakota's have Transponder Keys? (SKIM)
- 2004 V6 4x4 inner tie rod replacement
- Got a new (to me) Dakota- towing hitch/ wiring questions
- 255/70R15 tires on stock alloy wheels
- Front Vent Tube Leaking Gear Oil
- Is my CAT clogged???
- 2 truck projekt (help)
- MAY 30th Lake/BBQ/Potluck Meet, Grapevine Texas
- 2004 Air in Power steering pump
- Infinity amplifier removal
- Steering Squeal
- engine swap
- 3rd gen ram totm! Yall come vote
- What's up with my front sway bar?
- pmc updates
- 2002 v-8 w/trans issues
- Shaking while accelerating, possible trans problem?
- Broken OD switch wire; please help!
- what parts will work
- Need help with my engine
- disconnecting power lock wires at ctm
- anything problematic
- Bought a 2nd gen Dakota my first V8
- 2000 dakota rear end
- fastmann like tb's for cheap
- Lack of forced induction
- 02/V6 dakota starts then dies
- Check engine light and power loss on hills
- power window conversion using OEM parts
- 02 QC 2wd Dakota - 255/65 R16 to 245/75 R16 and now to 265/70 R16????
- seat belt light is tweaking out
- Dakota Sport question, about Models and lifts?
- need help making myself a cold air intake tomorrow
- 2002 Dodge Dakota - Driver side headlight problem
- Tires for 01 Dakota?
- Radio and turn signals not working
- Suspension lift 01 dakota 4x4
- 04 dak 3.7 throttle body spacer
- Need help finding...
- lost oil from differential
- Master Cylinder over full
- Improving MPG
- winches ? ? ?
- P0441
- Where can I get this emblem???
- this question is sorta like beating a dead horse but im curious..
- My Dakota in the mud (vid link)
- Dodge dakota rear speaker installation help
- Altitude/Octane question
- 5.2L Cooling problem has me stumped
- Bearing hub assembly
- Ball joints on dodge dakota
- need help
- leakin antifreeze
- engine rebuild. main caps worn.. can i still rebuild?
- XM radio
- Diagnostic code Means what....P0522
- I would like to Say THANKS for the HELP and 1 other question...
- Coolant color?
- my 2000$ deal is becoming a nightmare
- Engine, Electric fan kit suggestions?
- 04 SXT Engine Parts and etc.
- 2-3rd shift issue.
- Cel is on =|
- newbie with o2 sensor issue
- Is It Possible?
- More transmission rebuild questions
- 01 Dakota 5 speed
- Help with transmission issue! won't shift
- tranny installed but some problems
- Lower ball joints -- am I being ripped off?
- flowmaster ceramic rust proofing
- Air Intake Bonnet Needed
- Power Window Problem
- Transmission: Shifting Into Drive Delay
- Mygig System
- Truck caps interchange
- Can someone let me know
- slave cylinder assembly. help me find one!
- straight axles - 97 Dakota
- hesitating on starting...after fuel pump?
- installed fastman
- dropin 'em
- Has anyone used one of those tuners like...
- For Sale From My 04- Pro Comp 16in Wheels And Dunlop Mud Rover Tires- 265/75/R16
- Rotors
- 2000 Dakota hub bore question
- My buddys Drag Dakota
- 2.5l dodge dakota
- Mounting Lights...
- What do you think
- Random Coolant Spray
- 97 Dakota, no heat through vents, only defroster
- leveling 01 dak 2wd
- Thoughts on plugs,oil and filters for 4.7 dak
- exhibition of speed
- 5.9 Dakota stars then dies
- 2002 Dakota 3.9L Auto Trans issue
- So today I found out...
- bed size and tonneau cover
- electrical problem on trailler plug
- Misfire, hesitation cold or warm: Cant Figure it out...
- Engine Help V8 4.7L
- Hissing Noise
- grinding sound only in reverse 4x4? help!
- exhaust took a dump
- 1998 Dodge dakota, water in oil, heads and gaskets are fine.
- '00 Dakota Rear Speakers!!! 6x9's?
- Projector headlights for '03
- educating me
- Need Help with some lights.
- 2002 V6 Dakota Sport Performance Upgrade
- Lifter noise, is it common?
- What are some other cars that have compatible engines
- 98 dakota 3.55 gears
- Putting more money into my truck :(
- Shifter VERY slowly spins as I drive, but can't turn it by hand!
- how do i identify wat rear i have
- poll for red truck of the month
- P1391 error code PLEASE HELP!
- ebay 2" level kit? need some input...
- need a yoke where do i get one???
- 99 Dakota ABS code 70 & 71
- how do I know what diff I have
- Pcm
- 99 Dakota Transmission Pan Question
- Few Questions!?
- Stafford, Va
- 2002 Dodge Dakota Roll Bar
- New shocks should be in tomorrow!
- steam coming from vents.... Heater core?
- Knocking when in park
- Backfiring and stuttering 2002 Dakota 3.9
- 2001 dakota- a rock in my (nonexistent) hubcap?
- 2000 Dakota Driver's Window Help Please!
- Need speakers for an 01 Quad Cab
- Autolite 3924
- rain water leaking
- Install of Rebuilt Tranny. Rough Idle/StallingTPS ?
- 2000 Dakota sport value?
- Tune up questions
