View Full Version : 2nd Gen Dakota Tech
- Fog lights
- Overdrive Off on Startup?
- Wheel Bearing/Hub
- How Does a Dakota Compare to a TJ Jeep?
- Hope my new forum will be as good as this one
- 2000 4.7L v8 4x4 Sport tires
- 1998 Dodge Dakota Headlights
- V8 TB, modded intake, plenum kit, 1.7 HS RRs
- rsult of loud grinding noise
- Bumpers for Dakotas
- Flowmaster!
- Upgrade PCM?
- Offset tires
- new trans mod
- help fix my headache - lift and tires for 2wd
- Normal idle speed 04 Dakota?
- Loud Crackling noise under truck
- Mods for my 99 dakota
- loud crackling noise under truck
- got a new black sport bumper
- 2001 Dakota PCM bad
- 99 dakota gremlin
- Vacuum line disconnected...what is it?
- drivetrain vibration...
- no overdrive when warm
- New guy with question
- Adding More Lift
- what size speakers can fit in my '04?
- 2004 Dodge Dakota gas mileage
- lift and tire question
- Roll bar/sport bar/ Light bar..None for Dakota's
- To do list:
- What is this part?
- Alternator wiring???
- ABS and brake light come on randomly
- How Bad-Driving in Limp Mode - P0750
- waterpump / bypass hose
- Code won't go away!
- Rear Transmission Seal
- Replace frt brake lines with s. steel braided
- 3.9 to 5.9 swap
- loud grinding noise in front end
- She may live again
- truck got taller this weekend.
- lower coupling/intermediate shaft...
- Is it just me??!!
- How long for a reprogrammed pcm to learn truck?
- Lift kit any kind will do
- Trying to build up my '04 QC
- Deisel Dakota
- Upgrades to 5.2L magnum
- Air bag light stays on after AC work done
- radiator drain plug
- Who Can Actually Read P0700 Codes?
- gear drive's
- strange sound
- '97 dakota, power steering
- 04QC Electrical Gremlin - wipers
- shuddering rear end
- Sony Ipod deck for sale
- straight piped
- 1997 Dodge Dakota Lights
- wiper fluid causing loss of paint on roof?
- Center Console mod
- Part out or sell as project
- Project Little B1tch
- 80W-90 Gear lube?
- Dakota no-start
- DIY rear sway bar links and bushings *Pic heavy*
- what size tire is this?
- 285/75/r16 fit?
- best price for intermediate shaft?
- NP231 transfer case oil fill plug.
- Weird shutting off problem...need a little help?
- Broken Exhaust Manifold Bolts
- Rattle noise
- need help on radiator drain-plug
- will an 01 16" rim fit a 98?
- 44RE transmission pan
- Air preassure question
- No more R/T
- 2nd Gen Dakota 4x4 issue
- oddball stumbling problems/power loss
- Question About Superchips?
- looking at a r/t
- What are these 2 red buttons?
- Drum Brakes Question
- throttle issues
- Going to Change Oil Pump?
- 99 Dakota Front door speaker wires, +, - ?
- Bucket Seat Consoles
- Need tech manual for brakes,...repair and adjustment;
- 2003 Dakota Power Window Regulator
- 2000 Dakota 4.7 Rear Wheel Bearings..
- problem taking out 5.2 engine.. LOOK
- Engine Misfire/injector clatter
- no fuel no spark
- 2001 lift kit help
- How Much Would It Cost
- Superchips 3715 for sale
- rear sway bar bushing size
- Hi how to access the firewall from the passenger side?
- tire help
- What removes Bradford pare tree sap best?
- 98 Dakota with Fuel Pump, Computer Issues?
- Transmission: 97 dakota 5.2 4x4 what year trans are universal?? Help me out
- A unique sand & trail tire from Nitto Tire
- tires and suspension
- 2002 Brakes/ABS jerking into a skid, releasing, then skid again?
- Cherrybomb or flowmaster...
- 01 3.9 4X2 QC Intake Backfire
- Got her Back today.
- PITA cel
- reading codes.. whose better to perform task ?
- Steering column
- Power Window Problem
- Vent Probem 03 Dakota
- Headlight is smoking!
- Dangerous brake ABS problem
- SHE'S BAAAAAAAAACK...Really Need Help with New Exhaust
- fuel leak
- interior door handle help!
- wheelss
- Taking off o2 sensor?
- Manual
- Check Engine Light Came On Then Turned Off
- Crappy heat
- Cylinder Heads for 3.9 V6n (2001)
- Threw a code P0442
- Bucket Seat Back
- Window falling out of track
- recall on upper ball joints 2002 dakota awd info
- My dodge...but better, check it.. PICS!!
- Finally got some pics!!!!!!
- 2003 Dakota Taillight Issue
- Front end squeeking driving me insane
- Just ordered Tires!
- Does every dakota quad cab have A/C??
- About to buy this 03 SLT Sport, price ok?
- Chips/ programmers/ new computer/ flash
- wiring a 6 pole trailer connector
- Auto to Manual swap question
- got some new fog lights today
- Brake issues
- Need some opinions on a truck
- New Offroad Bumper
- Shifting Problems
- Remote program
- Fuel Pump replacement This weekend
- 1 inch tb lift, before/after pics
- Exhaust Help!!!
- Exhaust advice needed...
- exhaust question
- What is wrong with my truck? :video
- Wheel Hub Conversion
- Dilemmas dilemmas
- So long deteriorating clear coat =)
- introduction and a ?
- hey second gen rammer here I NEED INPUT FOR THIS!
- Overhead console install Dim display
- 01 Dakota sport part out
- cab swap
- suspension question
- Dakota Pre-runner
- What is it?
- p0300,p0302,p0308 has anyone found a solution to these.
- Pics of the new Soft 8's
- Sticker gas mileage?
- Transmission Accumulator Plate Bent
- Started
- 2002 dakota 4.7 AWD lower ball joints
- 2002 4.7l V8 overheating
- How does the Rancho rs5000 shocks do in our trucks?
- Question on sludge...
- Basic Tuneup: What am I missing?
- Where to buy new ecm for 2k dakota 3.9?
- window Paint
- Atlas Tires
- 2.5L exhaust manifold fix
- Aux fan keeps running
- Is it worth getting a chip for a stock 318?
- rear bumper cover, i need one
- yay shiny new parts
- 2000 Dakota AC
- ignition relay fuse blowing???
- best way to seafoam?
- Torsion Bar Lift and Tie Rod Ends...DONE! *pic intensive*
- Normal Gas Mileage?
- new guy , looking to buy a 97 v8 4x4
- Hey all, new here with questions
- Idle, In Cab Idle, WOT Video
- o2 sensor
- what size jack stands?
- Anyone used this c.a.i.?
- 1998 Dakota speed sensor cable
- 4x4, tcase, front driveshaft experts!
- Trailer wiring
- Glad to be here!
- Topper brake light works, truck brake lights don't
- Dome LEDs- anyone tried the 24-48 led panels?
- water pump change
- Price of a spindle? 2k dakota 2wd.
- Lift kits
- need some help
- Turn Signals and Hazards(now) not working...
- Magnaflow high flow cat vs no cat
- 99 dakota
- weird squeak when im above 70
- Heater connection question..........help!!!!
- Thoughts, opinions?
- Squeeking from rear while accelerating...
- Rear seat in '04 QC
- Something causing relays to fail?
- 98 dodge dakota slt ext cab 2wd headlights don't work
- Output speed sensor fooler?
- Can you get the fog lights to fill the voids on the SXT?
- ABS Light Issues on Two Trucks
- I am so lost...
- new guy here, may be joining the dodge club, ive got some questions
- So got some bad news.
- Westin side bar mounting
- P/S pump is officially gone
- Stereo shut downs
- 97 dakota 5.2l no HVAC directional controls!
- roaring noise
- Front Drive Shaft Replacement
- Great deal on hitch for 97-03 Dakotas
- CAI Question..
- headlights/wiring issue?
- For Sale 04 dak parts. any interest?
- Starter Relay Ground Issue
- Need a good bed cover for my '04
- Power Programmers
- Shift Solenoid replacement
- center console armrest needed
- Will my exhaust fit
- lost power help me find it....
- Fuel Pump whine
- Front license plate holder
- Dakota Winter Tires or 4x4
- Need shocks...04 QC with plow
- fuel injectors
- E3 Spark Plugs
- FRT Drive Shaft Rear Joint??
- radiator fluid ok?
- My NEW truck
- Code Reader
- fan trouble
- Goodyear Wrangler Authority
