PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. 2000 Dodge dakata 3.9L computer making noise and no start
  2. What is the part # for a 2008 dodge nitro evaperator temp sensor
  3. 02 Dakota SXT - center floor console wiring diagram
  4. No bus 99 Dakota 3.9L V6
  5. Differential question
  6. need an aftermarket replacement radiator for OEM 2004 Dodge Dakota
  7. New to group - resurection & upgrading wife's 2003 quad cab
  8. Over heating issue
  9. 04 Dakota stuck in 4wd lo
  10. 04 Dakota stuck in 4wd lo
  11. Catalytic converter question
  12. Key Fob
  13. P1698 accidentally pulled 10 amp transmission fuse while running
  14. New to the community and looking for performance advice
  15. Rough Idle, No Power from Take off
  16. Debating a Build
  17. Looking for Replacement Bed/Wheel Well Covers?
  18. Help removing lower control arm
  19. How to wire led drl's!?? As bed lights?? 99 dakota 5.9
  20. Diagnose That Sound
  21. Online parts
  22. 99 dakota remote question
  23. starting problems
  24. Wiring Harness to Headlight Switch Colors Mismatched
  25. Limp Mode
  26. headlight problem
  27. Brake pad movement?
  28. '02 3.9 turns over but won't start following engine cleaning
  29. Transmission locking me in 3rd randomly
  30. factory alarm
  31. P1762 Expert help? elecrical or no?
  32. Ball Joints
  33. Blower motor not running, but power at connector. Read on.
  34. Transfer cas interchange
  35. Transmission or other problem?
  36. Pick Up Box compatibility
  37. Antitheft malfunction
  38. Lifter Noise
  39. It start and will run but dosne,t run right
  40. seat belt removal
  41. What determines the towing capacity?
  42. Dakota Engine Trouble (02 4.7L V8)
  43. PCM plug Cable Black
  44. Speedometer Pinion Gear
  45. Brakes
  46. Odd noise
  47. 1998 Dakota Fuel Gauge not working
  48. 2001 dakota 3.9 need help please
  49. Will not start
  50. Pulling motor.
  51. tire/wheel size
  52. Power locks and windows
  53. Engine cuts out at 60-65 mph
  54. oil drain plug
  55. 2001 Dakota Key Question
  56. smell
  57. High idle
  58. 2001 Dakota needs a new computer
  59. Replacement Torsion Bars
  60. Passenger window/door lock not working
  61. Lighting issue please help!!!!
  62. 97 super gremlins
  63. Security
  64. High pitch sound at 40 MPH
  65. Gauges Inop after Welding Exhaust
  66. Input Speed Sensor CEL
  67. 2004 Dodge Dakota lift
  68. Dodge Dakota - PLEASE HELP
  69. Pitch building whine on loaded accelerating and decelerating
  70. 2002 Dakota Quad Cab manual window regulator
  71. Dodge 5.2 fuel pressure issue
  72. Wipers and Horn?
  73. Lift Kit, Brake Changing, Rotors
  74. '02 3.9: Got right turn signals back, but no lefts or hazards
  75. 2000 Dakota 4x4 5 speed transmission removal v6
  76. wont start wont crank
  77. Misfire cylinders 2,4 and 7
  78. P0442 to P0455
  79. headlights
  80. 2000 Dakota Weird Turn Signals and No Dash Lights
  81. Tires or hub
  82. Tailgate stuck shut from damage
  83. Something I learned regarding flickering/flashing dash
  84. What lift kit should I get??
  85. .0015
  86. transmission interchange
  87. 3rd brake light cargo light
  88. Fuel gauge stuck at full
  89. Blower resistor...[commom]
  90. Con Rod bearing issues
  91. Dropped truck off jack, need help!
  92. Luke Warm Cabin Heat
  93. Headlights quit working 2000 DAKOTA Sport 4x4
  94. Fule injector harness removal
  95. The last of my ticking sounds... any idea's?
  96. No AC in my 98 dakota
  97. Loud noise when driving - Quite when turning left - VIDEO
  98. Upper Control Arm Removal
  99. 1996 Dakota auto transmission
  100. 03 4x4 dakota
  101. engine swap
  102. Bumpers
  103. Control Arms
  104. Pwr st pump pressure..
  105. P0351- stumped
  106. auto ecm in a manual truck
  107. Solid Axle questions
  108. 4.7 to 5.7 swap
  109. 2.5 engine rebuild project
  110. Applying Math for Fuel Efficiency
  111. Need Information
  112. Front ride height
  113. I need a vacuum diagram
  114. 1997 dodge dakota
  115. Trans problem with my Dakota
  116. 318 magnum help
  117. Front axle making noise I think it's due to this
  118. How do I disable the alarm on a 2014 Durango?
  119. 2004 Dakota mode door calibration
  120. Huge 318/360 Turbo Kit for $1200????
  121. P0130, p0136, p0152, p0158
  122. 2002 Dakota with 4.7, rattle in upper engine, miss
  123. AC Condesation
  124. 5 speed to 340
  125. No Reverse
  126. 3.9 LA Block and Transmission Swapped into 2nd Gen -Possible?
  127. '02 3.9 alternator R&R basics-- what tools do I need?
  128. Blower not working on any setting
  129. odd sound when maintaining speed
  130. under hood insulation pad
  131. Transmission Swap for 2002 Dakota
  132. 2001 4.7L Dakota Motor Mount Help!
  133. 97 Dakota sport 6 speed
  134. 2001 Dakota 4.7 intermittent rough idle
  135. Frustration
  136. PLZ HELP! 4x4 is VIOLENTLY BANGING
  137. Window switches?
  138. 2000 Dakota key
  139. Air vents
  140. No Lights
  141. causes for no dash lights no start in ignition start position
  142. 2003 Dakota Front Speaker wiring colors
  143. 98 Dodge Dakota Air Conditioning Problem
  144. 1999 Dakota 3.9L V6 Auto 4x4 Transfer Case
  145. Grinding and squeal from left front wheel when 4wd is engaged
  146. P0032, p0038, p0052
  147. Need help with transmission drain and fill
  148. Speedometer stuck at 120.(2003 Dakota)
  149. leaf spring front bracket
  150. 5V voltage drop when plugged in?
  151. Cv axel replacement
  152. Aux IN to factory radio?
  153. 2000 Dodge Dakota winding noise
  154. Will Pioneer TS-A1686R A-Series 6.5" speakers fit?
  155. 02 4x4 rear axle swap
  156. p0351
  157. I inadvertently drove in 2nd gear at high speeds...
  158. ATF fluid /fill
  159. Transmission line o rings
  160. pickup bed
  161. Fender rust repair?
  162. 2001 dodge dakota is stuck in 4 low
  163. 3.9L, 42RE, STUCK IN 3rd(Limp mode)
  164. Fluid choice for differential
  165. '98 Dakota Hates Playing Nice
  166. Windshield Wiper Issues
  167. transmission interchange.
  168. 99 dakota R/T front end
  169. Transmission filter/Rear fluid
  170. Tool box or canvas cover.
  171. Recent purchase, 2003 Dakota 4.7L 4X4 5-speed
  172. 318/5.2 Magnum rocker arms questions
  173. 4.7l
  174. blower motor only blows on high.
  175. power add ons on a stock 5.2 95 dakota
  176. 2003 Dodge Dakota problems *please help*
  177. Ring and Pinion for sale
  178. Best 1/4 mile times possible with 3.9 v6?
  179. no spark
  180. 3.9l Sputtering and backfiring after reaching operating temp
  181. I have a 2001 dodge dakota slt 3.9 engine. cranks but doesnt starts
  182. Pulling someone out
  183. 98 dakota stalling problem. Any advice would be greatly appreciated
  184. 01 Sport 4.7L "No bu5" No fuel pressure or spark. Bad PCM?
  185. transfer case not shifting properly
  186. Gauges won't turn off
  187. Window lockout jumper
  188. misfire , bad coil?
  189. Seatbelt warning charm goes off when 2002 Dakota rolls
  190. dogge dakota fuel regulator
  191. brake problems HELP!
  192. Lock actuator/wiring
  193. '02 3.9L -- didn't know I have an electric fan...how to get to work?
  194. ready to swap in the monster 5.9
  195. Help finding and engine
  196. 97-2002 drivers side motor mounts 2.5 2wd 5spd
  197. 97 dakota 2.5 5spd 2wd PO443
  198. timing marks
  199. 2000 dodge dakota suspension
  200. 01 Dakota Sport 4.7L new crank sensor, cranks, no start
  201. Finding nv3500 reman
  202. Weird electrical happenings
  203. rear speakers
  204. fob key
  205. Wiring pic
  206. Upper control arm bushings
  207. 42re problem again
  208. Broke pin
  209. Bad Vibrations
  210. Torsion Bar Madness
  211. 2001 Dakota No Start No Crank
  212. Swap engine or engine with trans?
  213. 1999 Dakota Fuel Pump
  214. Radiator Brand?
  215. Lost all power
  216. Dodge dakota parts
  217. Growling noise
  218. 01 Dakota SLT v8 automatic stuck in 4x4, HELP!
  219. Rumble Strip sound
  220. Vacuum Leak
  221. How Screwed Am I?
  222. 06 dakota engine in 03 dakota
  223. Fan Clutch or something else
  224. 99 2nd gen v8 4x4 possible rear main seal leak
  225. 2003 Dodge Dakota
  226. Code P0523
  227. Can I swap transmissions from a 96 2500 automatic to a 2001 1500 automatic
  228. In Desperate Need Of Help!
  229. Changing out 2004 dakota oil pressure sender 4.7L
  230. 2001 front brake hose replacement problem
  231. Ian having problems after problems
  232. Chirp/squeal after truck is warm
  233. 1997 Dodge Dakota 5.2 comparability
  234. break light stays on.
  235. Trying to keep my grandpa's truck alive- Electrical
  236. Suspension Lift compatibility from 96-00. Please help.
  237. 65rfe
  238. Truck starts and drive BUT P0136 w/ new o2 sensor
  239. replacing rear speakers
  240. Rust
  241. Muffler change
  242. 2000 Dodge Dakota 5-speed
  243. Looking at a good deal on tires; will they fit? Help!
  244. 97 Dakota solid axle swap
  245. 01' Dakota Will Not Crank
  246. 2004 4x4 engine swap
  247. 2001 Dodge Dakota Sport 4.7L ground wire locations?
  248. Dakota won't start
  249. 99 dakota parking brake question
  250. What Transmission’s will fit my 1997 Dodge Dakota
