- Multiple P codes as read from odm read out
- Inner axle replacement
- 2002 Dakota 5.9 will not even turn over
- What type of leak?
- 02 3.9 Dakota misfire
- overheating need help!!!
- hey ya'll
- oil question
- 97 Dakota custom bumpers (in progress)
- Power Steering Pulley Problem
- rev to 3000 rpm uphill
- Running Rough
- Exhaust leak 2 Flange rusted bad
- Front Dif Has No Oil
- Muffler Install HELP
- CEL: OD- reads 12 Help please
- Tensioner Clunk
- 42RE Hard Shifts
- What trannys will fit?
- 9.25 Rear axle Trac loc Clips
- 46RE Mopar rubber pan gasket tourque
- Front speaker wire color?
- small rpm variance @ cold start
- 4.7 L V-8 Stalls When Hot
- T-Case linkage
- Water Pump Noise?
- Exhaust leak - Whats in there?
- 01 3.9 parts
- Tranny problems
- Help: ABS/ Brake Light
- want to upgrade to bigget tires.. do i need more lift?
- Battery Drainage/Head Light Dome Light control for 1998 Dakota
- CTM follow up
- checking oil in rear differential
- Update on old issues
- Weird rear Brake/ABS issue???
- Would Map-sensor cause cold start-up wild idle?
- 2004 Dakota rear axle interchangeability.
- Relay or Drivers window switch??
- Rear suspension lift blocks installation?
- Whining under hood...water pump?
- 1997 Dakota A/C lubrication
- clutch fan nut
- True duals
- Rear end help!!
- Is the diff oil good for life?
- Mark VIII fan convert
- sticking kickdown
- Dakota R/T chrome wheels
- Codes codes codes
- Dodge dakota R/T wheels 450.00$ chrome
- two bent push rods
- Electrical Issue while raining??
- Pinging 02 QC 4.7
- Air Conditioner Compressor Clutch NOT Engaging
- Rear Pinion seal??????
- is it possible to damage valves with only a cat on?
- corection dist cap.
- Catalytic Exhaust help needed
- 2001 Dakota issues
- doing 1.7 RR Install
- Found an old, dodge hubcap
- Extra wire in spark plug wire kit?
- Gutter gaurd grill inserts. Did my hood latch differently than what I've seen
- Blower resister
- head removal
- 2004 dakota oil pressure
- single exhaust
- 2000 Dakota 4.7L exhaust issues
- sway bars
- Help!
- Fuel Injector Vacuum Leak
- Will these rims and tires work on my 2002 dodge dakota sport quad cab?
- Dakota Brake Problems
- Loss of power... Ideas?
- Self contained camper on '03 Dakota
- driveshaft question
- P1494 code
- 2001 dodge dakota need help
- 2001 4WD problem
- Check Engine P0303
- 24 valve dakota
- r&r rear diff 02 dakota loose still won't come out !
- Durango skids on dakota?
- Steering box issue
- bad fan clutch?
- Wheel Locks - Brand Suggestions & Wheel Balance?
- A/C Compressor
- 2003 Dakota.
- what is the biggest motor and best tranny that would drop into a 98 dakota
- 2001 Dakota knuckle/spindle
- Please help!! Coolant temperature sensor problem
- Signal light make me crazy
- distributer pointing to No.1 cylinder????
- 5.2L to a 4.7L?
- flashing head lights
- 2001 4.7 Dak QC overheating
- Power control module connector pin outs?
- tap tap tap
- Swapping Durango Rear Axle into a Dakota
- 02 Dakota 3.9 Not Starting
- Dakota Oil pressure and spark knock issues.
- Intermittent starting issue
- Torn CV boot
- Dakota Engine Control Problem?
- what type of coolant?? need help ASAP
- how to check fan clutch
- Exhaust help needed
- A/C Troubleshooting
- Upper control arm joints
- shocks?
- Need help with truck having no spark
- 00 4.7l rundown (jus bought it need help with ideas & options)
- next mod?
- 2001 3.9L lack of power/backfire through throttle body
- Wheel spacers to fit 33X10.50's
- 2000 42re tranny question
- another rant!!
- Vibration in my engine while using A/C
- convert manual locks to power locks 1998 dakota sport
- recommendation for shocks
- freeze plugs & motor mounts
- In dire need
- 2002 R/T trans replaced, now a tapping noise
- a/c issue
- Anyone have CB's?
- HO Cams
- New to the group and looking to lift
- Disassembling headlight assembly how to?
- help please
- help please
- new rims for dakota
- Crazy Idea for my Dakota!!!
- superchip 200.00$ craigs list
- craigs list R/T wheels 600.00$
- Lower Control Arm Bushings
- quick clean on TB?
- 318 maganum in 01 dakota
- dodge dakota no start
- Air Resonator Box sensor?
- Extend Lower Ball Joint Zerks?
- Puling the trigger on fogs
- Under Seat Sub Enclosure
- need to know asap lol
- 03 Dakota window switch problem
- Craigslist brushguard post, Can some one tell me if its actually for my dakota?
- Truck died help!
- 95-96 Dodge Dakota constant sporadic stalling
- Gas with Ethanol (E10) makes for crappy running engines
- 2001 dakota tranny issues?
- Emissions
- Check Engine Evap Troubles
- P0172 Code
- Will a Durango rear fit on a Dakota
- Buy or pass on this dakota?
- Spark plugs
- badly stripped lug need ideas
- '04 Dakota - Cuts out between 45-65 mph
- Short Commute - what do i do?
- Lift options?
- Is this 2001 dakota a good deal?
- 01 Dakota 4.7L shudder/hesitation on highway
- where to install transmission pan drain
- Oil Pan removal
- How to Measure Torsion Bar Crank?
- Switch for power mirrors?
- exhaust diameter
- 9" or 11"
- Just installed mt flowmaster super 44. Not sure If I like it
- odometer flashes,reads "no bus" gauges not working
- Need help
- Hi guys!! Understanding Torsion Bars
- 3 Inch PA Lift
- pcv valve
- Strange electrical issue
- matching shackle flip height
- 98 dodge dakota abs/brake light on
- Ottawa/Ottawa valley?
- "Check Gauges"
- Mesh grille?
- 6th gear Added to 45RFE!
- Dakota Grille Question
- Ignition Coil Seals
- driving with no shock?
- Radiator
- A/C issues
- Rock Auto
- Help me know I am not the only one!!!!
- sway bar wear
- Fan motor and control fire...
- swap 92 3.9L into a 99
- estimate on 2003 dakota deer damage?
- July ROTM voting is open
- Bad Shakes low RPM and idle things
- Nitrous
- Trouble Installing Jimmi Jammers
- ignition coil form '99 ram fits '98 dak
- Bad Transmission or Wheel Bearing?
- brakes issue
- STOCK 2003 Dakota quad cab. How big of tires can I use?
- What is it? Idle issue
- 2002 dakota 3.9L P0171 & P0131 issue
- Finished my newest project - A flag pole!
- another blower resister up in smoke
- Remote sets off alarm 2001 QC 4.7
- air bag light and ac defroster light
- Struck by lightning
- Water/Methanol Injection
- Adding Fender Flares
- Newb help!
- 08+ 4.7L Intake Manifold finally installed
- Third brake light?
- No more Edelbrock shocks?
- Questions on Exaust Piping
- Cluster Lights?
- Power plug died
- A/c depletion question for DIY'ers
- C'mon Good karma I need a solution
- Headlight Lens question?
- Driver's window has separated from lift
- front hub
- Round air cleaner?
- need help wire harness pinout
- What Did I Break This Time?
- odometer says "no bus"?
- no reverse lights, but have 12 volts?
- 2000 V8 4.7L Gas Mileage Has Plummeted
- steering wheel/column clunk
- Throttle body
- Ground wires
- Coolant level?
- swiched throttle bodies, hard peddle
- 04 Dakota engine
- Gas leaking and truck stalling
- Anyone with a Body Lift and step bars and/or bull bar
- looking to lift the dakota
- blown out brake caliper
- plastidip
- Mileage/questions
- Trouble starting & Staying running
- Spare tire holder Exension
- Missing Air Conditioning System
- PO441 03 Dakoda V6
- ac system
- Accessory key position question
- A/c plug wire color 2000 Dakota
- LT265/70/16 Pressure
- Durango to Dakota
- Help, please! Complete loss of power steering
