View Full Version : 2nd Gen Dakota Tech
- V6 to V8
- parking brake wire
- Brake Light
- Good Deal?
- flowmaster 40
- 20 inch wheel upgrade
- Dakota engine swap
- In the market...
- Removing spark plugs
- Finally... a change inside
- what the hell is this crap
- Got my '00 Dakota R/T Dyno'd
- Springs/Torsion bar question
- 01 dakota 2x4 tire question
- poly bushings?
- am i being too harsh?
- power steering pump squeaking more??
- 2001 4.7 Won't Start seems like short?
- Antifreeze leak, 01 1500 v6
- Cruise Control
- New to the Forum Couple ?s
- Bags or permanent drop?
- K&N FIPK for 3.9?
- cruise control doesnt work
- Jack and Tool Set for '96 RAM 1500
- Vehicle Speed Sensor
- 2002 Dakota Service Manual
- Kenne Bell Supercharger Kit for 1999 Dodge Dakota R/T
- 1999 to 2001-2004 Dash/Door Panel Swap
- Dakota wont gear down!!!!!!!!!!!!
- heater
- Automatic won't shift into 1st
- 2000 Radio/Clock trouble
- Dashboard light help please
- How to reset pcm
- P0456 Code fix ideas?
- Transmission will not shift into gears
- Trans-GO shift kit which one do u have??
- 01 Dakota EVAP problems?
- bumper color paint
- 04 4.7 Supercharger
- underdrive pullys
- 180 Thermostat for 4.7L and exhaust
- Front brake question
- Wind Noise from Door gaskets
- evaporative sytem?
- performance advice
- What to look for 02 Quad Cab 5.9L
- 97 won't downshift
- ebay deals?
- Performance boost
- any opinions would be great
- Exhaust questions - Headers on down
- RPM's
- Dakota Fuel Pump Picture?
- Wheel size increase
- Gas mileage with ethanol gas?? WTF!!
- i feel like an idiot
- Truck won't start, i think something with security
- in need of help!
- normal oil pressure?
- How does a failed intake gasket get oil into the motor?
- 03 5.9 R/T Help
- Transmission
- PLEASE Help! Blower Motor Issues...
- clicking in the rotors
- Hemi Heads
- Fuel system
- HyperTech or SuperChips programmers?
- Mods
- power brake
- rear brake question...r/t
- door panels???
- Painting my bumper and plastic sides?
- How hard is it to replace auto belt tensioner.. 2000 3.9
- engine dies?
- Flash upgrade for 4.7 Auto?
- catalyst monitor hasn't run...
- Superchip 3715??
- window problems
- NewB w/Crazy lighting problem.
- Opinions?
- roof lights
- 1998 5.2 engine noise
- stock pipe on a 97 3.9L
- 4.7 Cooling
- Possibly something for Mythbusters
- TIRES for STOCK RIMS
- Exhaust
- trying to decide what crate to drop in my 97 Dak
- Programmers
- ABS & brake light on
- Click in steering wheel??
- New member looking for parts
- engine wont start
- Spark plugs for 4.7
- Gasket bad between Engine block andexhaust man.
- Clear Corner Install?
- Gears
- Aircraft Landing lights
- spring replacement, hours of labor
- Water on passenger side floor
- HOW TO INSTALL A POSI...
- Turbo blue prints
- new member - ignition problem and hissing
- AC/Heating Improvement
- spark plugs on a 3.9
- Viper motor swap
- 44RE to 46RE swap??
- Help With something
- license plate
- Lift
- vacuum leak/ Burning oil
- nvr mind
- backspacing
- lowering
- To many miles?
- What Size Tires are on Your Dakota
- Brakes
- thought TB spacers were out of control?
- stage 1 or 2
- tires after lowering
- Programers
- engine swap
- rhoads lifters?
- Stock 99 Dakota looking for suggestions
- No brakes! Need help!
- ignition
- Rockers or E-Fans
- Installing Dual Exhaust
- Dodge Dakota Taillights Smoked?
- computer tuning
- highest miles on a DD
- lug nut pattern
- Guage Mount Question
- TB cable
- 4.7 firing order
- Noise at idle, Tensioner?
- my kickass scan tool plan
- 97 Dakota Interior A\C|Heater|Outside Air Control Vent problem
- 545RFE transmission
- Late model Dakota
- General Info, Check Engine Light Codes, Paint Codes, Calculaters, ect.
- Transgo shift kits
- 2003 4.7L A/T Fluid Capacity?
- Paint Code
- Code reader
- A Dakota how-to!
- Replaced The Crank shaft Censor on my 2000 dakato 4.7
- heater core
- 02 slt
- brush guard
- 3" lift
- Trailor towing package...how good is it?
- remote start
- ball joints
- Shaker
- Exhuast and HP question
- hissing noise
- Sputtering
- 3.9 v6 ticking??
- Oil pressure sending unit
- Were is the Crank shaft Censor located
- Uncranked torsion bars and handling...
- Converting to power windows
- just curiouse-oil change...
- Were to buy turn signal lens
- Were to buy power lock acuators
- Help Crank shaft alignment Code
- Tonneau cover for sale
- part # for 98 dakota r/t
- Aftermark coil question?
- Help Cam shaft alignment Code
- round filter HELP ASAP
- help
- anybody know stock alt. amps?
- durango to dakota?????
- oil pressure gauge acting silly
- From vacation
- lost compression
- 4.7 with Auto, how durable over the long haul?
- Replacing the resistor block
- 2 engins problem codes - how do I check and fix these?
- U-Joint replacement - How difficult??
- Cooling fan
- Inside door panel
- Noob R/T questions!
- stereo speakers
- U joints or wheel bearings
- Underbody Thud and Dash Pop
- shifter knob
- n00b question about lowering springs
- Headlight adjustment
- Shocks
- which ones?
- Performance Intake manifold for 3.9?
- Dodge Dakota Manual Download
- 01 4.7 quad cab lift
- window cranks
- heater/AC
- srt-10 rims on a dakota
- NEW HORNS!!
- question on 2002 headlights
- 2002 DAKOTA RT TRANSMISSION FLUID
- themstat instalation??
- 2000 rwd rear axle question
- New member has questions
- Pictures wanted will pay
- windshield
- r/t engine fit w 3.7L engine swap
- Double din head unit?
- Turn signals not working??
- Wiper Blades
- Supercharger Question.
- New to forum....
- ANyone from Oklahoma?
- Center Console
- Another question about difforent Air intake systems
- Rear gear
- Striping kits
- Door panels
- Security device i found tonight.
- heatercore is leaking
- CarDomain dot com
- Gooseneck hitch
- Programmers
- What do you guys think?
- 180 Stat: Drill Hole?
- When is the air to cold??
- rims
- Exhaust headers
- fram boost availability when???
- helllllp!! can anyone help me with this????
- Advice, tips and suggestions needed!
- body lift
- headers
- air intake kits and higher mpg???
- polyeurethane bushings and header heat
- head unit
- Somebody Please Clear the 33" tire question up for me!!!!
- loud exhaust
- tires
- got her back from the bodyshop
- How to get more Bang.
- Looking For Quick Input: '99 vs. 2000 Dakotas
- 33x11.5x15
- Custom Grill "How to" anyone know?
- multiple questions thank you
- Answer this one please
- I want it loud
