PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 [85] 86 87 88 89 90 91 92 93 94 95
  1. Looking for 4.7 Engine
  2. ?Another CAI info questoin?
  3. recalls on front end componets?
  4. club cab trim removal
  5. Radiator fan staying on
  6. DTC PO455
  7. 2000 Dakota 5.9 R/T (photo)
  8. 2002 dakota 4.7
  9. need info on 4.56 gears
  10. winding noise
  11. oil pressure
  12. heater core flush instructions Dakota by Virused
  13. heater problems
  14. pics of audio install on reg cab 02 dak...
  15. 2001 rear end
  16. JET PCM Stage 1 or Stage 2
  17. Difference between motors?
  18. Center console?
  19. Leak in the evaporative system
  20. CAI info
  21. decreasing heatup time
  22. Opinions and Feedback Please
  23. v-6 performance parts
  24. sound system
  25. Trying to replace the dome light
  26. HEATER PROBLEMS
  27. dist cap and wires??
  28. Clicking type noise?
  29. P0038 CODE
  30. Another Audio Question!
  31. New audio Equipment
  32. lil red dakota
  33. Hypertech power programmer
  34. no headlights
  35. Im guessing i need a belt?
  36. Tint
  37. check engine
  38. An 01 with 58k 5 speed vs 03 with 82K auto?
  39. Trans cooler line problem
  40. Sound System Question
  41. stripped front driveshaft flange bolts?
  42. wheel size question
  43. Deleted
  44. Torque specs for a dakota rear differential
  45. Power Locks
  46. new rims
  47. R/T Muffler
  48. Dash Rattle
  49. 4.7 Wont Start....Need Help.
  50. LIFTED 4X4'S
  51. V-TECH Tail Light Covers? Matching the year
  52. Is this better than a K&N CAI?
  53. Cat Convert Locations?
  54. heater problems
  55. Storing the Dakota?
  56. 2000 DAKOTA SPORT STARTING PROBLEM
  57. salvage yards
  58. Which is the better investment?
  59. Alarm system Problem
  60. does the front driveshaft spin when in 2 wheel drive?
  61. Tranny not going into 1st and reverse....
  62. Anyone want some tires for there kota?
  63. Headers... again
  64. Overhead console
  65. general dakota questions
  66. rear end swap?
  67. Rims
  68. Installing power windows help!
  69. 98 Dakota 4x4 questions
  70. Exhaust clip for those who own a 3.9
  71. something wrong with speedo
  72. new 2 forum
  73. tonneau cover question...
  74. Need Pinout for 00 Dak
  75. Car ECU to Computer program.
  76. How rare is this?
  77. engine retiming
  78. Need advice and instruction TODAY Whats that noise
  79. Reindexed Keys
  80. Annoying sqeaking noise from front end?
  81. Shaker hood?
  82. R/T Decals... where can i find them?
  83. Just received my new brake pads!
  84. Forced Induction for the v6?
  85. And I thought my 33's were fun
  86. Irregular RPM's?
  87. voltage regulator?
  88. Buzzing Noise
  89. dilemma for reg cab dak 02 SOLVED!!!!!
  90. System for a 01 Quad Cab
  91. turbo kits
  92. 32's
  93. Auto Parts stores in canada?
  94. Shift Kits?
  95. Whats a good sound system?
  96. Shifting when its cold out...
  97. Plans
  98. rack & pinion question
  99. transfer to power door locks
  100. Super Charger
  101. Automatic Transmission Problem No second gear?
  102. Lights flicker, Horn blows, wipers turn on
  103. P03xx Codes Misfires
  104. stranded on the way home
  105. easy fix or garage?
  106. HELP!-Why is Heater Blowing Cool Air??
  107. OB2 Readiness Monitor
  108. Swapping a 5.9 for a 3.9???
  109. About to buy '97+ Dakota..what to look for?
  110. + battery connector stuck
  111. 1997 dakota TCM
  112. Putting a resistor on your IAT plug....
  113. Roll Bar
  114. underdrive pulley
  115. Battery gauge
  116. TCM location?
  117. Soon to be Dakota QC owner
  118. heating issue
  119. just put the truck away for winter.
  120. engine codes
  121. using my 33"s
  122. 2001 Dakota backfires and runs rough cold
  123. Replacing Shifter Lights
  124. pic finally
  125. "no bus" reading on odometer
  126. SYSTEM
  127. pic problems
  128. V6 to a V8?
  129. This is pissing me off...
  130. Weird Sound
  131. cant decide and need help
  132. Widest tires that can fit on a 17x9in rim.
  133. Reverse lights- bulbs & fuses
  134. Power Steering Fluid Pressure Switch
  135. Nitrous Setup
  136. whisteling noise
  137. Tailgate wont stay shut!!
  138. Rear main seal replacement
  139. Convert from 2wd > 4wd
  140. Factory build sheets...
  141. max rpm
  142. Towing with a 97' Shortbed/Single Cab
  143. Got stuck in the mud today..
  144. awsome gauges
  145. 97 5.2L tune up help
  146. 97 dakota stalling when cold
  147. Getting new tires... lets have fun with the old ones.
  148. headers
  149. P0270 code won't clear
  150. Happy Thanksgiving
  151. need a system in my reg cab truck...is this probable??
  152. heater core / dash out pics
  153. Put some LEDs on the interior of my truck today..
  154. TPS goin bad?
  155. Rear Limited Slip
  156. remote start
  157. Hotchkis R/T Drop Info.
  158. I Need a Transmission rebuild...read!!!
  159. Idle question...
  160. Bringing the Dakota in
  161. dakota idle issue
  162. Aftermarket Fuel Injection.
  163. changing diff oil
  164. 2" body lift
  165. 2004 Dakota on 15" wheels
  166. Air Shocks?
  167. i'm back
  168. Need some help dropping the truck...
  169. Exhaust Manifold Bolt Size
  170. no second gear?
  171. need help diagnosing a driveline clunk
  172. Changing the Transfer case chain(NP 231)
  173. clunking...stabilizer links/nuts?
  174. wtb 98 r/t parts
  175. 10.2 mm spark plug wires
  176. Transmission not shifting out of 1st...help!
  177. Woot. Got some 275/40/17s coming in for my truck.
  178. The extent of a 3" body lift???
  179. The extent of a 3" body lift???
  180. Max 2WD Tire Size
  181. Need some advice
  182. Neutral safety switch on a 2001 Dakota?
  183. dakota v6
  184. up in the air please
  185. cant find one
  186. Idle controls and computer module reflash
  187. I wanna Raise
  188. Buying used Dakota - What to look for?
  189. BIG PROBLEM 98 dakota 5.2l
  190. How to? Water Pump removal 97 3.9L V6
  191. Max tire size
  192. might be looking @ a '97 v8 std cab...
  193. strange
  194. heater
  195. 2000 Dak Wing?
  196. Clutch Fan? HELP PLEASE
  197. Clutch fan And Seafoam
  198. Chip/Tuner/Programmer Question
  199. Where to get Chome R\T center caps?
  200. puttin truck away for winter. what should I do?
  201. 3.9 owners with the v8 TB...
  202. Operating temp too low
  203. Newbie's question.
  204. Wheel backspacing
  205. mopar street truck
  206. When are they gonna bring back the shellby?
  207. power programer
  208. Driver's side window issues?
  209. Muffler and Rear End
  210. Where do I get this front end??
  211. I need a quote on exaust fix!
  212. 03 vehical speed sensor
  213. stroking
  214. problem
  215. Oil pressure issue
  216. info for those looking for better mpg...
  217. Generations wrong??
  218. greasing driveshaft yoke
  219. Speaker/Woofer
  220. 4 wheelin'
  221. tire size
  222. 4.7 MISFIRE
  223. MY FIRST POST, new Dakota owner here.....
  224. Burnouts, DriveBy's, and more.
  225. MOVED: FOR SALE: 15X8 FACTORY CAST ALUM WHEELS
  226. Rear end sitting lower
  227. ? about my '99 dak
  228. Tire size w/ stock rims and 3" body lift
  229. Check engine light..Cant get it off
  230. oil pressure sensor switch R2
  231. any one tried sea foam
  232. My truck can whistle
  233. rear end making noise
  234. Relays
  235. play in driveline
  236. NP 231 chain
  237. New member - 2000 R/T with some pics
  238. Weird noise
  239. opinions on intake kit
  240. Throttle Body V8 for a 3.9 V6 dakota
  241. 1 sweet Dak
  242. i need some tie rod help!
  243. gearing
  244. Throttle Body
  245. driver side headlight
  246. custom Y pipe
  247. Underdrive pulleys
  248. Steering issue
  249. viper dak
  250. Wheres the performance intake for me?
