PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. what about thermoplastic bushings ?
  2. brake pressure problem on 04 dak
  3. 5lug swap
  4. 1999 dakota no speedo and abs light
  5. Help me keep birds of my truck
  6. Dakota Converter and other stuff
  7. Code P0051
  8. Auxiliary light and mounting point choices
  9. Trans problems
  10. Old trick but still works.
  11. Stereo Compatability
  12. Help.. swapping out control arms
  13. Electric Water Pump Drive Installed**
  14. “Sticky” gas pedal
  15. Anti-theft alarm activated and truck will not start
  16. What is this sound?
  17. lower alternator bolt: 3/8-16 or M8x1.25?
  18. 2000 dakota elec fan won't come on
  19. 1998dakota motor and air noise into the cabin
  20. Rusty Brakes
  21. 33x10.5x15 on stock wheels
  22. stubborn coolant leak
  23. Squeaking in the rear
  24. '00 QC 4.7, 2 wd, auto tran, 215,000 miles. Garage Kept
  25. How much weight can a 99 Dakota haul?
  26. 98 Dakota 4x4 brake controller
  27. charging issue?
  28. ac clutch issues
  29. Ignition Problem
  30. Strange Things Happening
  31. 2003 Steering wheel play - video
  32. 2000 Dakota Dying on Hills
  33. Valve Body Cleaning?
  34. 97 Dakota 5.2 SLT Electrical Problem, Help!
  35. Gabriel Shocks
  36. Removing bed
  37. Upper Control Arm
  38. In need of soon!
  39. 4th gear popping out going uphill? Advice please!
  40. Keep My Dakota?? Advice Appreciated
  41. Horn Keeps Sounding
  42. AC Compressor isuues
  43. totalled
  44. Leaf Spring Shackles Will not budge. Tried everything
  45. 2002 crew cab 4x4,. swap from auto to manual transmission. Who has doen it?
  46. 2000 Dakota 4.7 V8
  47. 4.7 Hard to start and no bottom end
  48. instrument cluster or ignition switch
  49. Need Help!!! Can't find interior push pins; Dealer can't find either
  50. 01 Dakota SLT front seats
  51. New headlights
  52. Stripped Caliper Threads on Steering Knuckle
  53. What is this part?
  54. 5 volt draw, causing PCM issue then stall...
  55. Any AC Guys on here? Needs some help
  56. Problem with RPM
  57. Cargo lights?
  58. 4.7l or 5.7l which one is the better choice
  59. speed sensor location
  60. Weatherstripping Adhesive
  61. Getting better mileage with 10% Ethanole
  62. engine surge at idle
  63. No Hazard Flasher - '97 3.9L SLT 2WD
  64. 2000 Dakota Stereo Specs
  65. Leaking Coolant!!!
  66. Suddenly have TERRIBLE gas mileage!!!
  67. 00 Seats vs 05 Seats
  68. 2003 Dodge Dakota Stuck in 4x4
  69. Codes P1686 & P0633
  70. Intermittent rear main seal leak?
  71. 2004 3.7 engine common oil leak points?
  72. fan clutch, water pump?
  73. New tire suggestions
  74. 2002 water pump and fan clutch question?
  75. Dropped Rocker Arm- Rotate Crank?
  76. Teardown help with Mopar side step bars 2000 Dakota
  77. 03 Dakota 4.7 coil problems
  78. unique problem
  79. Swapping block lift from 99 to 01?
  80. Wierd A/C problem
  81. 2000 Dakota with after market alarm HELP!
  82. Stalling, backfiring 4 cyl
  83. Headlight flickering
  84. Looking to buy a Dakota
  85. Dang on gremilns
  86. Changed oil in my 2001 SLT V8 and....
  87. Trading custom rims for stock "venting"
  88. 2000 Dakota 4.7 AC "experience"
  89. Weird noise '03 Dakota
  90. what happened to the 2.5 engine section
  91. Basic Mods to Dakota
  92. glasspack set up
  93. Sounds like a failing coil?...
  94. new clutch, no start
  95. Need help to get my truck back
  96. 03 Dakota 5.9L Coolant Issues??
  97. Hi can someone help with a towing question!!
  98. overheating 4.7l
  99. 1st Gear issue
  100. Reversing a lift kit
  101. P 0505 - 2000 Dakota 4.7
  102. 04 Dakota infinity system wiring diagram
  103. "No bus" after stall...
  104. Door Switch Question
  105. is it a 44re or 46re???
  106. Exhaust leak
  107. Tire size difference
  108. 2002 truck keeps turning over, but will not start: please help
  109. lifted 4wd upper ball joint
  110. V8 Throttle Body MOD
  111. Rancharo Shocks?
  112. Changing front wheel hub assembly
  113. Glove box problem. Help PLEASE!!!
  114. Leaking Heater Core on 2004 Dodge Dakota 4.7 Quad cab
  115. Engine cutoff on me
  116. 98 4x4 steering gear box swap questions
  117. shift tower
  118. 03 dakota 4.7 horn, lights, come on by themselves
  119. needing some help before I buy. thanks
  120. Wheel Well Tool Box
  121. what kind of performance chips
  122. 1999 Dakota Rear Licence Plate bracket?
  123. dakota clunking noise
  124. Motor Mounts
  125. 04 Dakota infinity system specs
  126. lower control arm swap
  127. Exhaust pressure
  128. Help!! At my wits end!!
  129. A/C manifold assembly part number??
  130. Time for IAC valve clean
  131. steering shaft
  132. Wet floorboard
  133. Did a 2000 have key fobs ?
  134. front driver side fender on 97 dakota 5.2 4x4
  135. HELP --- power steering hose routing ---
  136. Help me with my 2000 4.7 problem
  137. speed sensors
  138. Secure removable bed cover
  139. What would you do? New motor?
  140. Speedometer still not working after sensor swaps
  141. help power steering leak dakota 4.7 v8
  142. 1997 dakota weird power steering issues
  143. Transmission Question
  144. Fiberglass Question
  145. Smart Lock - What is this?
  146. Differential
  147. Transmission issues
  148. '98 Dakota CTM and lighting
  149. Alternator not charging
  150. Tire Size
  151. Whole truck shaking
  152. NV3500 rebuild question
  153. Which wires go where?
  154. 2001 Dakota (Oil Pressure Bottoms OUT)
  155. brake caliper removal
  156. loose line
  157. Dodge Remanufactured Parts - cross reference
  158. Confusing Coolant Temp
  159. removing mechanical fan for MPG gain
  160. problem with cruise control
  161. AC problem
  162. Question on fuel level sensor?
  163. torque convertor bolt pita
  164. i think i might not have a dakota anymore>>
  165. Got a few questions
  166. New headache, Leaf spring shackle bolt is stuck
  167. 2000 2wd Lift Kit
  168. 15" wheels on an 01 quad cab sport?
  169. 2000, V6 3.9L, Sport - Exhaust Help
  170. Window stuck up Year 2000 Dakota
  171. new to dodge.. need help and info
  172. Hub/wheel bearing problems
  173. Alignment
  174. Oil guage dropped and wont come back up
  175. Possible trans issue need help
  176. Stupid Exhaust Leak Question
  177. Low price accessories?
  178. Soild axle swap help
  179. new belt,still squeels(video)
  180. Might buy quad cab w/ bad motor
  181. whos got 3.92 gears
  182. 2002 2.5L still runs fine, but now sounds terrible
  183. running rich
  184. positve & negative reverse tail light
  185. Replacement Steering Rack
  186. Cats
  187. PCM 32 way black connector get oil in it
  188. dakota rearend
  189. open loop/closed loop
  190. To Dual out or not to dual out?
  191. Threw 3 codes from hitting a pothole, rust?
  192. Mrquest
  193. Interesting vid bleeding the clutch system
  194. End link bushings
  195. 2004 power windows
  196. Throttle Body Cleaning
  197. 1998 Dakota Speakers
  198. leveling kit for 04 dodge dakota 2wd
  199. What is this?
  200. dakota rear disc
  201. '02 Dakota front bumper
  202. HVAC control question
  203. 318 ecu run a 360?
  204. 1997 Dakota 2wd Squeaking
  205. '04 Dak QC rear sway bar links
  206. 2002 Dakota QC - noise when backing
  207. single 3" exhaust for 5.2 ?
  208. Crank position sensor,is this normal??
  209. Replacement muffler advice
  210. 1997 Dakota mirror question
  211. 01 Dakota front driveshaft install problems.
  212. ABS and BRAKE light on, I've searched
  213. Power Windows
  214. really short life on the water pump
  215. torsion key and bar dakota 2001
  216. Scan tool mode $06?
  217. Any Mods for 1G Durango seats in Dakota?
  218. Thinking about getting another Dak
  219. O2 Sensor - P0138 Code Help - 2003 Dakota 5.9L
  220. trany slipping and hesitation
  221. Antifreeze leak question?
  222. will shavings hurt catalytic?
  223. pro parts piller gauge pod,with pics..
  224. factory amp bypass?
  225. 360 magnum oil pump gasket???
  226. Rhino Crazy
  227. fender flare mounting bolts
  228. 1.7 Harland Sharp Rollers
  229. Trouble with throttle
  230. AC/Heat problems
  231. Full front bumpers?
  232. Dam Spark Plugs $$$
  233. 15" / 16" front brake clearance
  234. Exhaust manifold gasket replace
  235. A little help with what these are?
  236. Major Interrogation about a 3.9L acting
  237. AC Blend door and cost to fix
  238. idle problems
  239. 98 dakota 2wd pulling hard to the right...
  240. 1998 5.2L no crank
  241. Vapor coming out of vents (A specific question)
  242. MSD Atomic EFI
  243. Swapping out the CTM
  244. Brush Guard
  245. 3.9L 98 Sport - bank 1 Misfire codes
  246. 7 different error codes at once
  247. 2001 dakota backseat backrest won't latch
  248. front brake line Q ( 3/16? )
  249. 97 Dakota no start, no spark 3.9L
  250. 03 Dakota 4.7 evap problem
