PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 [73] 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Funny sound after a rough start
  2. Switch to synthetic...any issues?
  3. wheel travel
  4. Freezing weather, rad fan on from start
  5. 4.7 has rough idle and cuts out
  6. Glass Pack/ Intake
  7. Engine block heater
  8. Exhaust Manifold Gaskets
  9. HVAC resistor how to!!
  10. holley r/t
  11. Small Bug Shield
  12. Acceleration/hesitation issue
  13. Quick Turbo Question
  14. Anyone else ever get a p0420 code???
  15. 9 lives 2000 dakota
  16. R/T question
  17. check engine light
  18. Accessory questions
  19. factory speaker sizes?
  20. 2000 4.7 fuel filter location
  21. 98 Dakota
  22. 2004 Dakota
  23. Transmission fluid capacity
  24. best engine flush
  25. rust on my chrome bumper
  26. 98 dak problems
  27. front end conversion
  28. my new dakota pics
  29. manual to auto?
  30. 2.5l Engine Questions
  31. Blown up 3.9 dakota
  32. 97 3.9L Overheated in -35 weather.
  33. Tire info
  34. Biggest lift seen?
  35. Headlight High Beam Issue
  36. Keeper spring
  37. rims for dakota
  38. Friggen A! Defective chains tear up my paint job!
  39. R/T engine
  40. cd player
  41. Car Starter
  42. Dakota Exhaust
  43. vaccum port not conected
  44. rough idle 3.9 dak
  45. Wind noise from windshield
  46. Vinly Sticker Install (HELP)
  47. Dash rattle
  48. Heater Question
  49. Liftgate Cargo Light
  50. cluster lights
  51. helper springs
  52. Pulled the rear seats of my Quad Cab, put in this...
  53. Question about sliding
  54. Trans slipping
  55. Loud Pop --> Truck Won't Start
  56. heater controls
  57. Column shifter ignition lock problem
  58. subs and an ext cab: advice needed.
  59. Fan Clutch
  60. MOOG Ball Joints
  61. biggest tires
  62. Steering ATF+4 ?
  63. Synthetic oil Switch
  64. Computer Plug in?
  65. throttle body change
  66. Room behind Quad Cab seats?
  67. head light issues
  68. 2001 ECM
  69. need exhaust work .....
  70. OD acting strange
  71. hypertech vs super chip
  72. dak dying
  73. Looking to get a Dakota
  74. bad gas mileage!
  75. vote for my brother's car for the philly show
  76. Hard bed cover?
  77. FS: FTC1-E Fuel/Timing Calibrator and MAP Clamp
  78. A/C TSB question
  79. Exhaust
  80. clairification?
  81. Odd noise when turning, can't pinpoint.
  82. 4WD problems
  83. knocking front suspension
  84. Cabin air filter
  85. drop spindles
  86. dakota lift kit?
  87. stock exhaust size??
  88. WTF throttle cable
  89. Bad day at the dealership
  90. Leaf Spring Shackles
  91. Oil pressure!!!!!!
  92. Voting is going on now!
  93. bettr breathin 4.7
  94. Air/Heat Diverter Problem
  95. Throttle Body Spacer
  96. trouble code 0138
  97. Dakota probs
  98. tires on stock 98 4x4
  99. Over flow and Washer Fluid Reservoirs
  100. Dont want to take to a shop!!!!!
  101. removal of bugflector II??
  102. True Dual Exhaust
  103. Oxygen sensors
  104. Door weatherstrip?
  105. Paint Question?
  106. Headlight-Tailight
  107. Getting a Dakota, some Q's
  108. Easiest Way?
  109. Grim day for another dak...
  110. 98 Dakota with no heat
  111. some questions
  112. Headlight aiming
  113. tire calculators
  114. 04 dakota steering binding
  115. Regional Sections!!
  116. got stuck
  117. New radiator??
  118. Cold Air
  119. Repair Quote for the following: Too High?
  120. need advice, buying my 1st dakota
  121. 98 4 cyl. sluggish?
  122. Caliper Pin
  123. Super 40, 2in/2out
  124. air intake and exhaust
  125. dakota video
  126. Anyone need...
  127. 2001 4.7 SOHC Troubles
  128. Throttle body spacer
  129. Trying to fix my truck
  130. 2001 Dodge Dakota Fender Removal
  131. 2001 dakota slt horn problems
  132. skid plates
  133. High Idle On Cold Start???
  134. HID Conversion Kit??
  135. 2000 dakota with tranny problems p0753
  136. 5 speed transmission problem
  137. Muffler options - direct swap?
  138. bad thermostat.....right?
  139. throttle body swap
  140. Super turbocharger
  141. right front light won't shut off!?
  142. Length of header wrap
  143. fuse box diagram
  144. Coolant loss
  145. Tailgate Storage
  146. Just some questions
  147. 97 Dakota Tail light
  148. hey read this
  149. shocks
  150. Exhaust Options
  151. performance
  152. Twin Turbo questions
  153. 3.7 to 4.7
  154. More Pics.
  155. anyone one install
  156. Speed Sensor
  157. Just wondering,..
  158. A dumb question
  159. 3.9L to 5.9L
  160. Can't find LH Manifold...
  161. No hex nut on steering box??
  162. How
  163. performance parts
  164. spark plugs for the 4.7 motor...
  165. Hey Please help
  166. ??? about OEM fog lights
  167. New owner to a 2000 Dakota
  168. changed battery now got probelms
  169. Heater Blower Help needed!!
  170. 2004 Shifting Problems
  171. Some stuff for sale.
  172. NEED OWNERS MANUAL
  173. Powertrax No -Slip diff
  174. 1998-2000 Dakota
  175. Tire Wear
  176. fuel mileage
  177. hello
  178. First question for the forum
  179. New Pics
  180. Tire Pressure
  181. Recall G 28
  182. Security System
  183. Pictures?
  184. Lift Kits
  185. Overheated 2001 dakota sport
  186. stupid brakes
  187. 1999 dakota transmission problem.Help!
  188. wow. byebye transfer case
  189. Dakotas on 33s
  190. RW Speed Sensor has NO Power
  191. defroster part?
  192. Stripper Motorsports
  193. Clearance?
  194. 2-3 Shifting Problems
  195. Does the K&N air filter for the 5.2 fit 3.9?
  196. Newby here sayin hey!!!
  197. Dakota Steering Problems
  198. RS5000 or RS9000X?
  199. Sealing a Manifold
  200. 3" rancho on my 2001 cc
  201. 4x4 problem help!!!!!!!
  202. Differential case replacement?
  203. Synthetic Oil and FIlter
  204. 98 r/t shifting problems
  205. Bed liner
  206. Burning oil only at idle and warm, valves? 4.7
  207. 4 Wheel drive problem
  208. "Need Advice" 2003 V6 3.9 2WD Dodge Dakota Engine/Transmission Swap
  209. Air Bag Lite
  210. some work i've done
  211. tire sizes w/no lift
  212. any custum work?
  213. No clue how to do transmission fluid
  214. upgrades
  215. can't make it up the hill
  216. pegged speedo
  217. Transmission fluid!!!
  218. day time driving lights will not turn off
  219. Heater fan only runs on high
  220. P-0116
  221. 3.7L Engine Coolant Flush
  222. Park Lights Going Out
  223. Replacement Parts
  224. Resetting PCM w/ superchips
  225. Manual Locking or Automatic locking hubs?
  226. heater problems
  227. what are the biggest tires you can put on a 01 dakota quad cab 2wd v6???
  228. replaced battery
  229. map sensor cel codes
  230. CAI and Exhaust
  231. Hows the Cat setup?
  232. May have lost power steering pump?
  233. Dakota lift
  234. flowmaster 40 too loud inside?
  235. "no bus" dealership says new cluster
  236. 1999 Dodge Dakota
  237. bass
  238. changing a brake light bulb
  239. Little Rumble
  240. What's a Good Racing Chip for a Dakota 5.9RT?
  241. Groaning noise...Power Steering?
  242. V6-V8`
  243. Smoked OE tail lights?
  244. Problems With 98 V6 Sport
  245. Headlight Flicker
  246. any1 still use a cb?
  247. Should I buy Pro's and Con's
  248. Dash removal... help.
  249. Short circuit trailer hitch harnes Durango dead
  250. fog lights dont work
