View Full Version : 2nd Gen Dakota Tech
- Power locks problem.
- Question regarding High Temp Exhaust Manifold rust stopper products
- 98 club cab tool tray removal
- transmission instantly lost all gears
- rear axle wheelstud replacement
- Question regarding broken exhaust manifold bolts
- Engine noise at idle.
- Torsion crank question
- gas tank
- What's the Trick to R&R Plug #5 on the 3.9 ?
- upper control arm bolt torque
- please helo
- pocket flares any ones that will work
- '98 Dodge Dakota interior parts exchangeable with...
- So what oil change interval are y'all running?
- Dakota starts and dies right away
- 2002 dodge dakota 3.9 trans issues
- Problem with the brake line
- Do I need to remove some tranny fluid?
- Freeze plugs!!!
- 96 to 97?
- original exhaust
- Engine block coolant or antifreeze drain plug part number
- Water pump operation
- 03dakota 4×4 setvice 4×4
- Strange Idle and start up issue.
- Hesitant to change tranny fluid
- 1998 2.5 2wd AX15 Swap
- wiper fluid reservior r&r
- 4 hole injector upgrade?
- Tailgate not latching
- engine swap
- starting issues
- News help!! P0300 code
- So its been a while
- Tapping after new head install
- Stalling in closed loop...
- Engine swap
- missing door lock cylinder switch
- Po351
- 2004 Dakota Transmission Question
- 98 dodge Dakota Bad idle and jerking after warm up...
- Just Changed My Valve Seals
- Help!
- Transmission fluid pan bolt torque
- Torx size question
- spark plug question
- manual trans hard to shift gears
- power steering fluid change?
- Closed loop engine stalls...
- brake problem!
- Steering Shaft is Short
- replacing positive battery cables
- stuck bolt!
- Possible CTM Problems
- Brake line rust through... Replace entire line?
- Another Rough Idle question
- 99 project starting. need help
- 03 Hood latch broke ? or bad cable...
- 2004 blower motor resistor
- spark plug changing again
- Wiper blade sale at RockAuto.com
- weird noise
- opionons wanted on suspension and headers
- 2" body lift?
- Radio/Speaker Problems: 3/4 don't work...
- 2001 Dakota 4.7 V8 valve tappet noise question
- battery cables
- '97 Dodge P/U Won't start
- 2003-2004 factory radio question
- 04 dakota steering wheel skakes
- Plenum Gasket
- What performance mod should i do?
- Rear Disc Brakes
- 2004 3.7L valve covers
- leaf springs?
- distributor cap?
- 70mm BBK Throttle body 4.7
- Now What??
- aftermarket projector headlights??
- 04 Dakota high miles?
- Sound of Dragging Metal?
- HELP!! Replaced waterpump..!?!?
- pop sounds
- Steering/ Braking Riddle...
- Sticky Situation
- yay, wheel bearing time
- Engine problem
- Problems electrical connection 98 dakota transmission AX15
- body lift questions
- length of spark plug wires?
- a/c problems
- Which Transmission?
- p1281 2000 dakota
- 7mm or 8mm?
- A Dakota owner with a transmission question
- Fuel Injectors
- copper spark plugs
- oil leak/camshaft
- durango/dakotabumper and fender flare bed liner coating
- 2000 Dodge Dakota SLT 3.9L fuel filter?
- Intake Zerk fitting on side of head?
- Brakes locking up bad!!
- ABS Brake light comes on intermittently
- waterpump bearing endplay
- 2000 dakota 4cyl CEL code p0505
- 2004 Dodge dakota engine need help ASAP
- Dash Board Light Bulb replacement 2000 Dakota
- PO740 Code Questions
- Grinding and Grabbing Brakes... Still
- thus 3.9L is acting a LOT
- valve job vs engine replacement
- Intermittent power problem
- here's what I have been up to...
- Dodge Dakota 2000 slt 3.9L, Trans fluid change?
- 03 dodge dakota 4.7 q-cab 4x4
- EVS II please help
- o2 sensor thread size
- Coolant leaking from bell housing; not freeze plug, not heater core; possibly intake?
- Code P1776
- 98 Manual to Auto Swap
- Tires are a food group?
- Crankshaft sensor error
- How to Set Idle on '00 DD4WD w/4.9L
- Odd noise coming from air filter
- Pic posting from mobile device
- 5.9 Harmonic balancer
- OEM tire / wheel size vs. alternatives for 2000 4.7L SLT plus with 3.92
- engine size
- 04 Dakota Sound in rear-end.
- 4.7 or 5.9?
- New to Dodge Dakota and New to This Forum
- rear axel
- need more horse power
- Help. Head gasket? Crack?
- Best EFAN kit for 2001 5.9 R/T
- 99 2wd 3.9 accessories help!?!?
- Video: Changing Transmission Lubricant
- No audio from new stereo receiver.
- 2000 Dakota 4x4 v8 mag overheating?
- Replacing freeze plug
- P0509
- Need help
- 2000 Dakota
- CBer's Maintenance Pics
- Dakota quadcab SAS project
- corner lights/marker lights, and dash lights out
- 2.5 cooling fan not kicking on
- 4 wheel drive problems
- Headlight/grill gaskets?
- 46RE common issues and improvements DIY - Need advice
- 42re problems after fluid change
- EIS/Napa Drum Spring set
- Which 2nd Gen Dakota should I get?
- Differential fluid change
- Transmission failing to disengage
- 98 5.2 running rough and pops when i shift
- fuel injectors tell me what you think
- Fuel injectors 97 2.5 5spd
- mesh grills
- 2004 Dodge dakota 3.7 how to set timing
- Double Transmission Fluid Leak?
- 2001 Dakota 3.9 Overheating Problem?
- Engine Mounts - Hoist points
- front differential bearings and seals, 4x4
- dang I'm fat
- 5.2 swap into 99' Dakota
- 1999 dakota
- Dakota 3.9 5.9 swap
- Please help with 03 dakota 3.9 not starting
- New E-Fan Project -
- Heat issues with 03 Dakota
- boost it??
- "No Bus" Error in odometer, AND Hi beam light stays on After cluster swap
- 1999 dodge dakota sport v6, extended cab. 2 wheel drive.
- Dakota with 32x11.50 r15s. Too big?
- wheel bearings
- electrical issue 02 dakota
- No bus
- 2002 Dakota error code p0455
- OEM headliners are discontinued
- Aftermarket HeadLights
- Track Lok replacement question
- Would 35s fit on a Dakota 99 4wd with a 2in body lift??
- SAS Questions
- Transmission Squeak on Clutch Release
- Transfer case selector switch
- LED bulbs
- Window Lock Switch
- 03 dakota r/t starting and idle problems
- fog light reviews
- Should ALL '03 4.7l Dakotas come with an electric fan?
- Using Coil + side as ign hot?
- Problem starting 98 Dakota
- headlight switch
- Intermediate steering shaft
- quick question
- 5.2 crankshaft sensor misfire
- Another HOT dakota issue
- Low air flow from vents
- Either you buy it or Pick 'N Pull will
- Intermittent Rough Idle?
- code p0499
- Cab swap from '02 V6 2WD to a '99 V8 4WD
- 2002 Dakota Door Lock/Wiper/Climate control Problems
- Newbie replacing head on 4.7l: Any tips?
- Dakota bumper grill inserts – DIY?
- 99 dakota door problem
- wheelwells
- Engine bogs and sputters
- Cylinder 2 misfire code with trans temp warning
- Loss of Power. Any suggestions???
- 1997 V6 3.9L low port for AC recharge
- Bad misfire (cylinders 1 through 4), P0300
- Installed a used bedliner... ways to prevent rust?
- Under dash light bulb
- updates on my newer 98 Dakota
- Loss of power. Low mpg, new map sensor, HELP!
- Centering the wheel
- interchange body parts 2003 dakota
- 98 Dakota no factory tow package
- Antenna on windshield?
- need help
- What size is bleeder zerk on 2001 dakota?
- 04 Dakota Rear Axle help
- replaced headlight switch now, air bag light on
- Brake Line Fittings (to junction block)
- i got my poor dak back!!!!!!
- 03 passenger window problem
- any ac guys want to help with my 1997 5.2
- Need help with O2 sensor fix
- Help a clueless 18 year old?
- sorry if this is an FAQ rear end and perf Q's
- 2004 Dodge dakota 3.7 engine
- Interior wiring
- Starting to overheat
- CODE P1389, '98 3.9l v6NO Spark, no start
- timing chain slap after timing kit install
- What calipers do you recommend?
- what about thermoplastic bushings ?
- brake pressure problem on 04 dak
- 5lug swap
- 1999 dakota no speedo and abs light
- Help me keep birds of my truck
- Dakota Converter and other stuff
- Code P0051
- Auxiliary light and mounting point choices
