- Still pinging under acceleration
- 99 v8 manual transfer case
- Window regulator
- Bought Some Wheel Hubs They Don't Look The Same
- What the heck is this??
- A/C problem
- Solutions for Brake Problems.
- License Plate Location
- Starting Issues
- need Dodge Dakota help
- Bad cat
- 04 dakota speakers-need help!!!
- Help Choosing Amp
- Transmission filters - Mopar vs aftermarket
- burnt out head light switch
- runs rough first thing.
- shocks/steering wheel
- Backfiring through the throttle body
- 98 Radio problem.
- 4x4 to 2wd
- Parking brake release lever.
- 1998 speedometer not working at all
- Central Timer Module
- 03 Dakota Quad transmission cooler
- Economical headlight replacement opinions wanted
- Racing V6 engine
- putting Fiberglass on rusted oil pan 4x4 4.7 v8 dakota??
- no highway power
- Not So Bad Rust?
- Dakota R/T?
- Rear Drum Brake Problems - 97' Dakota 3.9L
- Leaking Power Steering Fluid - 97' Dakota 3.9L
- What is this sensor
- Suspension help
- For those that have bled abs with scan tool
- 3,7 in 04 a good v6 never had one?
- Overdrive solenoid.
- Blower motor resistor - 2000 Quad
- Need Help with Rear Main Seal
- Changed calipers, now no brake pressure, HELP
- overhead computer
- dumb founded by '97 Dakota
- 99' Power Steering Pump Replacement
- Tuffy console
- Lockup delete
- Clear coat going on roof and Hood
- rattling noise when shifting into 4WD
- charging issues
- Puzzling Front Brake Guide Pin Size - 97 Dakota 3.9L SLT
- 2000 Dodge dakota 4.7 4x4 crew cab
- asking for opinions..
- ac compressor
- Engine and Trans Swap
- Please read and try to help!!!!!
- Slip Yoke Question
- 5.9 magnum fuel sync??
- 03 v6 dodge dakota, noise when I step on clutch
- Fuse for reading lights and radio out
- Davis Unified Ignition 10mm wires
- Single DIN to Double DIN Conversion on a 2001 Quad Cab Dodge Dakota
- power door lock issue
- Engine misfire... Please help
- < < Dodge Dakota 1998 - Vents Dont Work>>
- Exhaust Leak Near Muffler
- Trouble finding correct sway bar bushing size
- Can you guys give me a rundown on dakota V6's?
- Headliner Repair/Replace
- 2002 dodge dakota 4x4 won't work
- 2002 dakota inspection plate.
- front junction block fitting size/type
- 03 DAK Hitting 166k ..Things i should look for ?
- been awhile!! PICS!!
- M1 Intake manifold
- Stalling when switching gears?
- Taurus fan blowing fuses?
- Help with side exit exhaust
- Leaf Shackle
- Muffler inlet/outlet location
- Transfer Case Match Question
- Can't get brake pressure!
- Power window question
- LF custom shop in Maryland
- Splash guard question
- mileage
- Want to buy a 2nd gen Dakota---seeking advice on what to look for
- Tell me what this is....
- 1997 2.5 backfires an hesitate
- 4x4 suespension to 2x4
- Power Steering & Whistling Sound
- Hub noise but which one? Bad case of CRS
- 45RFE Teardown
- To Gunk or not to Gunk???
- SOL! With trying to find the right Driveshaft
- Moaning noise from left front at 35 and over
- Help with new exhaust system
- I got a 97 dakota 2.5 5spd tune up
- '03 overhead console wiring diagram
- transfer case trouble
- drivetrain change
- fender flares
- 03 dakota overhead console
- New dakota owner with evap question
- 97 Dodge Dakota window question
- Electrical problems with the Ignition Starter fuse and Back lights
- rim backspacing
- Hitch receiver for 97 Dakota
- tires and wheels
- Torsion Bar Removal
- 4.7 No Heat - Changed T-stat
- Water Pump Install?
- Turn signal problem
- ball joints
- '02 TCM upgrade
- 1.5 body lift
- 2000 Dakota lift kit
- rear axle question??
- brass or copper flakes in oil pan
- 2003 QC Headliner Replacment
- intake bolt thread size?
- Power steering pump! Help
- Need some help
- truck topper question
- Cracked rear Drum not good
- 99 dakota fog light help
- Cranks but No Start.
- 2000 Dakota 4.7 V-8 replaced PCM and now have P0505 code
- Your opinions needed.
- chevy 6 bolt conversion?
- lift kit
- any SAS guys in hear??
- taillights same?
- to repaint parts
- brake light
- Power Windows
- driveshaft
- Electrical draw trans fuse
- 2001 Dakota Door Locks
- trans slipping
- keggar mod or after market intake?
- Geez... Go figure..
- Broken rod?
- No Sonnax for gen. 1997 Dakota ?
- looking for baja kits for 04 dakota 4.7
- 4.7 Timing chains
- Trying to get clutch master to clear brake booster
- roll/light bar location errors?
- Wiper blades
- neutral saftey switch help
- Shifts with SCT
- Autos: How Long Until Your Truck goes into OD
- coilover conversion kit for 4wd???
- Thinking Axle Swap
- Stiff power steering when cold
- performance upgrade suggestions
- Pedals
- Valve lash adjusters or timing chain tensioners bad on a 4.7?
- Polyurethane trans mount?
- 2004 Dakota Tailgate
- No Heat
- Spec-D Racing Seats
- What's makes a rt well a rt?
- ****ty spark plugs and a Problem
- Uppers and Lowers need replaced
- Heat
- Add A Leaf Lift????
- Help need information on trans swap ASAP!
- O4 dakota 4x4 rim options
- NY engine swap
- Headlight out
- idle step up.
- Thinking about another Dakota.
- I'm at a Loss. AC Blower problems
- random click
- 98 Dakota Intermediate Shaft
- Oil taps in my 2001 Dakota? And battery goes to H when it snows?
- Great threads
- Water Pump died 2nd time
- fuel injector circuit open
- No power windows
- Mirror options
- dakotas with flatbeds pictures?
- fuel pump
- IOD Fuse Challenge
- Calling out you 2004 dakota owners
- Cuts off when coasting
- nerf bar?
- Reman Engine 4.7
- Leaking coolant from Overflow Reservoir 2000 Dak Sport
- No power when gas pedal pressed to floor on 2000 dodge dakota
- 04 4.7 hesitation
- truck is dying in two different situations
- Tools to rebuild NV5300 tranny?
- Need some input guys 02 dakota v6
- I need some help
- getting locked up
- How to take out consoul?
- Suspension Problems :-(
- Random multi cylinder misfire and misfire codes for all eight cylinders
- Tailgate issue
- Warm up or not - what do you guys do?
- Bed Covers
- heater issues
- Showing no oil pressure at startup
- Transfer case selector switch LEDs not working
- Transmission question.
- 97 dakota heater not blowing as hot
- parking brake release handle
- HID discussion
- No heat
- front brake T fitting thread size?
- New Pioneer tweeters and speakers w/pics
- finally got lights hooked back up
- How to remove above head consoul
- low range
- Service 4WD light on I 'm tired of it
- 3.7 race preped heads
- newly purchhased 04 dakota with airbag light on
- 98 Dakota 5.2 Mising at highway speed
- Grinding/Rattling
- My truck has received more damage.....[pics]
- O2 Sensors fuel Economy
- Dodge doesn't make the heater core o-rings anymore
- Factory remotes working distance
- Rear End Noise Cant Troubleshoot IT
- Help, lockers
- Oil pressure gauge problem
- 3.9 to 5.2 swap help needed.
- Manifold bolts broke off in head. Should I .....
- 2004 Dakota Quad Cab 4.7 Interchange
- BRAKES. Some people should NOT own tools
- Power steering pump swap
- new motor, or new truck?
- P0456 and P0440
- Power steering leak and squealing
- Black Steel Wheel Opinions
- Problems with Magnafow Exhaust
- Transmission fluid help!
- Loud Knocking in Engine
- 6 Speed manual for the 97 5.2
- 15" Wheels
- 04 dakota coolant
- Play in steering wheel
- 2003 Dodge Dakota 4x4 bad IAT
- No tag on transmission
- Low idle/voltage
- Muffler keeps rusting out!
- Broken torsion bar removal tips
- Floor mats?
- lean, and pull
