PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. engine swap
  2. RE: 2002 Sport transmission slippage
  3. Determining rear differential ( Swapped, but with what? )
  4. Chronic Check Engine Light Problem
  5. I won't give up on her
  6. Pls check my logic
  7. Light bar for 2nd gen dakota
  8. engine miss problem, 98 4x4 sport with 5.2
  9. Spark Plugs Extra Tight
  10. My Truck Flooded!
  11. '00 3.9L dak blowing white smoke
  12. Replace rear wheel housing
  13. IM BACK!!! Married into a dakota!
  14. 1997 Dakota Common Issues
  15. Dodge dakota gauge lights
  16. Plenium gasket
  17. HELP:Adjusting Emergancy Brake
  18. quick repair truck
  19. runs rough when hot and humid
  20. E-fan Options
  21. radiator upgrade
  22. Steering pop when driving NOT turning
  23. Heater is blowing warm air ...
  24. 2001 3.9 dakota power loss
  25. Is everyone else's 5.2 such a dog?
  26. pulsing radio
  27. hard steering on 03 dakota ?
  28. 99 Dakota V8
  29. 98 4x4 with loose steering
  30. What sensor on 3.9 tells computer the RPMs ?
  31. stock system crossovers?
  32. E-Fan Swap HELP
  33. AC Compressor Choice
  34. Trans fluid type
  35. Clutch, Master Cylinder & Slave cylinder Question
  36. towing ?
  37. removing camshaft
  38. P0700 need a little help
  39. trucks heating up
  40. Transmission swap
  41. 03 Dakota 3.9L running rough
  42. 1998 Sport 4x4 steering box
  43. 01 4.7L idle issues
  44. Fan clutch
  45. Whines while accelerating
  46. Replacement rear slider HELP
  47. OBDII Bluetooth device.
  48. My Dodge Dakota 99 need help bad
  49. might be a bad question
  50. 2000 Coolant drain cock
  51. What a feeling what a change !!!!
  52. 98 Kota tranny leak please help
  53. Flex Pipe Question
  54. New Brakes
  55. Tailgate Locks
  56. Bad rumble in right front
  57. new bumper cover
  58. X-tra Lube Oil Treatment
  59. 03 3.9l power questions?
  60. Transmission issues-help!
  61. Does 2003 SLT Quad Cab have a chip in the key?
  62. 98 Sport 4x4 water leak
  63. 99 Dakota Parking Brake
  64. Front driveshaft play
  65. 2000 3.9 a/c issues
  66. I am lost...
  67. Got a trailer. Need wiring advice
  68. Crate Engine for 3.9
  69. So many problems...out of time
  70. 04 Dakota interior air flow prob
  71. any help.
  72. 2003 Dakota sport 3.9L heads...
  73. Sas
  74. Help with AC problem
  75. 2002 dakota MIL light is on
  76. Huge Dilemma
  77. No air at vents. Air IS at feet and defrost.
  78. Refurbish 1999 Dakota
  79. Missing then cut off & now wont restart?
  80. FACTORY Drop in box liner fitment question
  81. 2002 Dakota Front Axle Question
  82. Camshaft Position Sensor near Nashville
  83. Battery Issues - 2002 Dakota Sport
  84. 2.5 to 4.7 swap?
  85. Dakota got backed into. Like a champ
  86. This fan for a swap?
  87. fuel pump replacement
  88. She's Done! Been fun!
  89. Rattle noise????
  90. Picture request: Back half of 2nd gen frame (with bed off)
  91. No speedometer
  92. 98 Dakota v8-4x4 shift problems
  93. Testing Plenum/ Vacuum gauge
  94. dodge dakota 4.7 swapped
  95. Please help 99 Dakota 5.2 trans harness connections
  96. Transmission rebuildt now truck wont start
  97. Underseat Storage
  98. buying a dakota
  99. Starter Help
  100. How do I Wire for trailer breaks
  101. 99 Dakota crate engine(?)
  102. SAS project
  103. Want some meat?
  104. 255/50/17s ?
  105. Where is the ambient battery temp sensor on 2000 dodge dakota located?
  106. "Beast of the northeast" build
  107. Sound from Rear
  108. 2002 Dakota quad cab 4X4
  109. She just died!
  110. Transmission replacement
  111. Normal Oil Pressure?
  112. Starting Issue
  113. 1998 Dakota 318 needs heads, cam, exhaust combo
  114. 99 Dakota R/t hypertech max HELP!!!
  115. which is colder?
  116. Suspension Lift Kit
  117. Plasti dip
  118. 2002 dakota 4.7 coolant leak
  119. truck box
  120. My 98 Dodge Dakota AC vent problems
  121. Plug deal(s)
  122. 98 Dodge Dakota Overheating
  123. ball joints
  124. 1999 Dakota slt V6 plugs and wires and cap
  125. Swapping out rear with Durango?
  126. lift kits
  127. Electric fan swap
  128. these gas tanks build pressure?
  129. Favorite Clutch kit and why?
  130. Raised Hood 99 Dakota Sport
  131. slave cylinder issue
  132. Transmission slips?
  133. Short Ram vs. Cold Air
  134. Dual exhaust problem?
  135. Lights for grille???
  136. dual exhaust? problems...
  137. "Frankenstine" look
  138. no bus
  139. steering coloums
  140. what is this?!?!
  141. Swap 4.7 for 5.9?
  142. Dodge Dakota SLT 1997
  143. speedo won't work until 40mph
  144. DRB Code Scanner vs Key Trick
  145. Will Not Start When Hot
  146. 99 Dakota R/t tire sizes
  147. "Bulletproof" Ball Joints
  148. Lifting a quad cab?
  149. The infamous NP231D... swap advice?
  150. Tailgate light bar
  151. busted bumper cover
  152. Stumped Need a Wizard's Help!
  153. Headlight not mounted securely
  154. Headlight wire colors?
  155. Bagged Dakota Questions
  156. Halo headlight wiring?
  157. o2 sensor
  158. Rancho RS5000 shocks
  159. Stalls when turning left
  160. battery question
  161. New guy 5.2 oil psi low at idle
  162. water issue!!! help please!!!
  163. Weird Noise! HELP!!!!
  164. So... Sludge under valve covers.... Need help! Rebuild or other options?
  165. Raising the front bumper
  166. Air intake
  167. 98-99 5peed dakota clutch set up tip...
  168. noise advice
  169. Mileage dropped from 21 to 14 mpg
  170. A/C Drain Tube Fix??
  171. 265 vs 285 tire question?
  172. Front Axle Seal Leak
  173. Idle control valve question
  174. Still Some Ping...
  175. A/C condenser bolts
  176. Abs
  177. A/C problems
  178. 97 Auto Transmission Ran Out of Fluid
  179. Some darn engineer
  180. Steering Clunk, Pop, Groan, Leak
  181. Gas Mileage issues...tires?
  182. 1999 Dodge Dakota 4x4 wont stay in and grinds
  183. leaky windshield
  184. Someone please help
  185. Bank 1 misfire
  186. Bad gas mileage - 1999 Dodge Dakota 4X4
  187. Rough idle repaired
  188. Clutch Master and Slave Cylinder Assembly
  189. No power...especially in hot, humid weather
  190. 1998 dakota was cutting out now wont start
  191. E-fan Wiring Diagram?
  192. Autotek installed today...pics
  193. AC Question
  194. 4x4 problem
  195. desperate for help starting problem
  196. frustrated in Ohio
  197. Remote Start?
  198. replacement stock oem wiring harnesses
  199. 2001 dakota. A/C only blows on full blast and my drivers side floor is constantly wet
  200. Black Rear Bumper?
  201. Is rhere a trick to getting the tranny pan back on?
  202. Speedo is out, NO lights or codes~!
  203. 360 Swapped 99 3.9 - Need tranny/t-case upgrade
  204. 45rfe shifting problems
  205. 1998 Dakota transmisson fluid leak from bell housing
  206. Drop the tank or ....
  207. p0305 cylinder misfire solution not mentioned before
  208. Advice on 1998 Dakota V8
  209. Smoked LED Tailights?
  210. possible botched job...
  211. 2001 dodge dakota mudder??
  212. Cluster swap or mod?
  213. engine swap?? 99 5.2/2000 4.7
  214. Transmission Identification 46RE vs 48RE vs ?
  215. squirrely front end
  216. Broken Rocker arm/lifter/head
  217. Horrible noise from front wheel?? Help!!
  218. 4.7 5 speed won't go into gear
  219. 97 Dakota 3.9l AC cutting out on hills
  220. HELP! Truck keeps dying
  221. Bedlined My Rocker Panels (pic heavy)
  222. Whine/ shreak while coasting
  223. Crappy mileage
  224. Bouncing/vibrating when braking
  225. Used 2001 Dodge Dakota V8
  226. Used exhaust manifolds
  227. Brake upgrade idea
  228. Replacement Door Speakers
  229. 98 Dakota, poops out
  230. 2001 dakota 4.7 lean bank one code
  231. fuel level is all fubar
  232. Average mpg?
  233. done f**ked up fuel sync..
  234. Oil in Coolant Resevoir??
  235. Dakota shifting
  236. 1998 Manual to Auto Transmission
  237. rear differential gear swap
  238. Blower motor resistor connector issues
  239. stalls when in reverse
  240. No electrical power, PDC or ignition switch?
  241. evap code po422/po455
  242. Rancho shocks
  243. Won't Start - "No buS" Code
  244. 2001 Dodge Dakota 4.7 V8 Trans temp Light
  245. Dakota on tee beach?
  246. No reverse
  247. header recomendation?
  248. Lift on a 97 2wd
  249. Tail light and dash fuse
  250. 99 Dakota
