View Full Version : 2nd Gen Dakota Tech
- OD question
- Wacko Gauges
- Update on horrible vibration
- LSD
- Recommend a good OBD scanner for me?
- Carbed + Fuel Injection???
- bouncing idle is driving me nuts!!! help!!!
- IAT Removal
- Headers
- overhead console mpg
- Which intake is better?
- Tranny Problems
- New to Dakotas but not Dodge.
- seat exchange
- tach signal
- supercharger, will it fit?
- oem wheels dont fit on lift kit? no problem
- Shifting 1st to 2nd
- Missing Bolt on Rear Differential - Size?
- throttle body
- trouble code P1756
- new tires...
- G-Tech Tesla Experts?
- 5.9 R/T Performance Questions
- gears
- performance chips/programmers
- Water on the passenger floor?
- Synthetic transmision fluid
- 97 Dakota
- Performance Mods For 02 Dakota
- Speaker Replacement
- windows smashed out
- 160 degree vs 180 degree
- trouble codes...need help
- 4x4 floor shifter loose (flappin') how to fix?
- tires
- 5.2 fuel system problem ?
- Can't Clear Code.
- dur
- performance please
- pics after fabtech lift
- 98 dakota, 3.9 v6, transmission trouble code
- a little help would be nice
- HELP!!!!! I Have Rust.
- ? about plugs
- codes 355..357..any ideas?
- Exhaust
- What else can I do
- 2000 Factory Service Manual, PFD Download
- for the 5.9ers
- Replacing a head w/ new aftermarket
- A painful Vibration
- 2001 Dodge Dakota Service Manual
- Transmission Problem
- What kind of wax?
- Want To Raise the Rear up a Little?
- Bauging Down At idle when Turning Sterring Wheel ! TSB?
- 2000 Daktoa Shifter Knob
- 5.9 transplant
- electrical ?
- anyone want a tutorial?
- Has anyone Here Tried The Turbonator Out?
- 2.5 gets 8.66 mpg......Help!
- HID lights????
- Need Your Opinion: Keep the Decals or Not
- 97 running hot
- anti spin diff lube
- a arm install
- 01 R/T wont run
- What the HeLL!!!
- Hi To ALL ,I'm New on The Forum (?)'s
- eyelids?
- Jerky starts......
- 2000 Dodge Dkota Sport, need advice on next upgrade
- throw out bearing?
- temp sensor
- Cold air intake?
- sts Turbos
- aftermarket stereo/taillights problem...
- Engine Shutter Problem
- New Dak in the yard
- Few questions...cooling system...
- throttle body spacer
- Ring and Pinion Question
- no code
- cruise control problem
- Hard steering on 2000 SLT, 4x4, 4.7 Liter
- grille ?
- Two questions...
- Battery
- 1997 Dakota Ball Joint Torque Specs
- Dakota Quad Cab MTX Thunderform
- 2003 QC SLT Overhead Console Question
- 2000 Dakota Quad 2WD - Need new right side bed panel
- Truck Alarm help
- Trailer RELAY's
- New "to me" Dak coming this weekend!!!
- headers
- Check Engine -> Catalytic Converter
- Qesuton on the 4.7 liter automatic tranny
- trans problems???
- MOVED: 2002 lifted dakota for sale
- Error codes P0442 and P0456...
- New Tires...
- 3.9 to a 5.9
- Transmission giving me trouble..
- bought a flowmaster 50 series..
- TB sensor
- Stolen!!!
- 1997 dodge dakota brakes locked up
- Coolong fan...
- New Member and a question
- lil... how's the truck...
- overdrive mod?
- Speaker size question
- Headliner Removel,club cab r/t
- a/c help
- another stupid exhaust question
- 04 Over heating
- Viper Brake Kit for Dakota
- Towing Question
- Fluids
- Putting into park from drive.
- Troublecode P0551
- Starting Problems
- Bored Out Throttle Body
- rear window
- dakota 4x4 front driveshaft removal prob
- Front End Shaking
- Straight Pipes on my 3.9
- MBRP Cuda Roll Pan & Tips
- Headers and performace chip
- Truck pic finally on here
- Any pics of 275/60/15's on 15x8 stock wheels ...
- lift kit
- want to pull 8k pounds..
- Header Tape
- Yet another exhaust question
- power programers?
- gas
- ECM or CTM? Problem w/ high beams
- Oil Pressure 2003 Dak Quad 4.7
- Location of electric brake module
- rev's 200 - 300 rpms?
- another accident
- My AC doesnt work right. Help!
- R/T question
- headlight replacement
- best tonneau cover?
- sub box
- headers for my 3.9
- interior mods
- Getting a Dakota as my first truck!
- I need help with Cooling system...
- 04 dodge dakota for sale
- Lil, took your advice....
- r/t mods
- wheels, cant find them
- P300 Series Codes Reset?
- lift or lower
- will my muffler rot out?
- thinking about buying a Dakota
- Lowering kits! What do you think?
- header gaskests
- Dakota 0-60 question
- New Section Moderators!!!!!!!!
- intake
- How restrictive is the stock y-pipe?
- new struts worth it?
- tire question
- Trailer Relay's
- another exhaust question
- dakota sat 1 year, got running, gauges dead idiot lights all on, runs fine whats up?
- 5.2 stumbling under load
- Dakota Brake light
- 98 Dakota - AC works at first, but...
- 1998 dodge ram 5.2 L
- 98 dak problem please help
- co2 emission
- NOS
- Won't stay running
- Transmission agian
- Where is crank position sensor on 97
- gas mileage
- Dak not starting. HELP!!
- Dakota with Lean misfire
- AIR INTAKES CHEAP, GIMMICK OR WHAT?
- Gas and Check Engine Light
- humming after flowmaster install
- underdrive pulley
- alignment?
- 2001 Dakota Front Brakes
- Throtle body spacer
- New member
- Engine stalls when the air conditioner is turned on
- Headers?
- new head liner
- A very stupid q....
- wiring harness and check engine light
- August Car & Truck of the Month!!!!!
- Gas CAp smack in face!!
- weird problem
- what should i do
- Exhaust w/ mods help
- Code P1698 2002 Dodge Dakota 4x4 4.7L V8
- So what should i get for the truck?
- 2000 Dakota w/4.7L and FT4WD Club Cab A/C Problem
- Sticky O2 Sensor
- Check engine light
- 2003 Dakota Quad Cab Brakes- (V-6)
- Axle Swap and the Odometer
- Superchips programmer...
- faulty transmission range sensor?
- transmission range sensor
- common problems to look for???
- First Dakota
- soft cover for 99 short bed
- Fiber Glass Console
- Heater/AC blower doesn't work..
- Long Tube Tuned Dakota Headers
- 14 miles per gallon -- OUCH
- Clear Coat and Paint problem
- New Truck
- I love my truck!
- anybody running a 160 thermostat?
- How do i get at my rear speakers??
- Adding Cruise?
- Larger Radiator??
- Fuse wiring diagram
- Cross-Threaded Guide Pin Bolt on Front Brake
- Will not start after running a while
- pcv valves
- Removing Fan on 99 Dak...HELP!!!
- Cluster Change
- Getting started
- Looking for Dodge Dakota E-Paper - PDF
- dakota r/t?? supercharger??
- reducing noise in cabin
- magnaflow exhaust- single or dual???
- reverse beeping
- 3.9 exhaust
- CAI & Spacer for '04 3.7L V6???????
- Sound clips of 4.7 Dakota....
- Coolers?
- A/C
- Helix Power Tower
- performance mods for my truck
- 2003 Dak blower resistor location
- Serpantine Belt
- Tool Box Tonneau?
