PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. How to get rid of rat smell.
  2. R/T wheels
  3. Coolant troubles?
  4. Nerf bars and body bushing bolts
  5. 97 idles fine the stumbles then regains
  6. Hmmm what do you guys think
  7. Frustrating rattles
  8. Hot cams and Fastman TB.
  9. 99' dakota shifting problem?
  10. 3.9v6 Backfiring
  11. Electrical gremlins!
  12. A/C Question, I hope you have an answer.
  13. 2001 reprograming transfer case
  14. Normal operating temp
  15. Headlight flickering
  16. need quick pics of 2 & 3" lifts
  17. somthin cool to play with and learn a few things
  18. lift block help
  19. how to fix lean fuel mixture?
  20. camper shell install
  21. Fuel pump going out? hard to start
  22. Need help for this Friday. Taking '01 to repair shop
  23. Problems with my 01
  24. My new 2002 Dakota
  25. a/c problem ...
  26. 03 Steering Issues
  27. slow fuel gauge
  28. A/C evaporator leaking inside cab
  29. 1998 Dodge Dakota Lift
  30. Please, CTM Help!
  31. Short Shifter?
  32. Rear end swap.. Quesion???
  33. Sct or fastman?
  34. Hi I'm new... Can I tow my Z with 3.7L auto?
  35. Tranny ID?
  36. 1997 Dakota 3.9L rough idle/stalling problems
  37. camper shell installation
  38. Some pics
  39. Replacing door panel
  40. Dak-box?
  41. OEM #'s P1764 & P1762 and head lights.
  42. All in a days work
  43. 2 Questions, one post.
  44. Leaking Transmission
  45. Off road lights
  46. heater core replacement
  47. 2001 dakota 4WD problem
  48. Transmission cooling line
  49. 01 Dakota CD UNIT Power problems
  50. obd code p0320
  51. ABS and break light?
  52. Wheel Hub
  53. 2004 Dakota Ball Joints
  54. Drop in AC
  55. Anyone need a paint job?
  56. Need home users to beta test the site...
  57. August 27th Grapevine, TX Mopar Lake Party!
  58. space betweem cab and bed is off
  59. Screetching Noise
  60. Newbie
  61. Looking at new tires
  62. It's shackle time!!
  63. Can i get 1 inch more out of this?
  64. Window Regulator Part #
  65. loose
  66. M1 Intake Questions
  67. Stupid Truck
  68. custom valve covers
  69. wait what, no oil?
  70. help removing rear leafs.
  71. "pop" sound, right front, when turning
  72. Building a high performance 3.9L V6
  73. Looking at buying a gen 2 Dakota
  74. Short Throw shift kits?????
  75. Missing at 50!!!!
  76. Clicking or Raindrop sound at highway speed, driving me nuts!
  77. lost 2004 dakota keys
  78. Help with vacuum lines and LDP
  79. Fluctuating Tach
  80. by by ram hello dak
  81. Clearing PCM
  82. The 1000th SuperChips Q/A Thread... HELP
  83. you guys think this is a good deal?
  84. need a fan shroud bad!!
  85. oil change for new heads??
  86. building a custom intake for a 2000dakota 3.9 v6
  87. FS: CAI, Thin Tonneau Cover, Stock Grill (Central Florida)
  88. Bed hooks for tie downs
  89. Please help with my lift
  90. All new Lights.....
  91. Finally got it!
  92. rear shackle back broken
  93. How do I know if my diff is LSD
  94. Looking at a 97 Dakota 4x4
  95. differential swap
  96. Different water pumps for same engine
  97. Did Seafoam treatment and idle is rough now?
  98. should have called it 4.7 HO diesel
  99. damn 02 sensors
  100. waterpump went... i think? HElp!
  101. Dakota problem
  102. No air or heat in truck help
  103. V6/V8 swap
  104. kegger intake question
  105. Alignment questions
  106. any tips for putting on add-a-leafs
  107. Front end questions!
  108. 2000 Dakota 2.5l 4Cyl oil sending unit
  109. where to buy rear leaf springs.
  110. Hellwig Sway Bar Question
  111. truck for sale
  112. New Dakota?
  113. Killer Donut Video!! Dakota RT!
  114. Brakes problem...Maybe...
  115. tell me what you think new interior
  116. Do i need new shocks
  117. Wanted: 3.9 Magnum engine
  118. Drivers side front axle seal
  119. Quad Cab rear springs sit low
  120. 1998 3.9L slow to reduce RPM's
  121. catalytic converter
  122. major headaches! 2001 Dakota
  123. Got a shift kit..
  124. The dakota hauled the biggest load of its life!!
  125. Dodge Dakota/ Durango Interior Pieces 00 *FORSALE*
  126. 2003 dakota blower motor resistor connector
  127. no brake lights please help!!!!!!!!!!!
  128. Coil spacers
  129. Random electrical box?
  130. might be so long guys
  131. 5.2 swap
  132. Trailor Wire harnes??
  133. Timeing chain option question
  134. 3.9L best rebuild kit?
  135. what other mods are out there
  136. 390 stroker kit
  137. Heater wont turn off
  138. Engine Rebuilding Kits?
  139. A/C Clutch weak - rebuild the clutch or replace the compressor?
  140. front driveshaft CV joint took a poop
  141. 98 dakota with no spark
  142. 1/4 mile times
  143. 98 Dodge Dakota no power, starts and runs, but stalls?
  144. engine swap
  145. Giddy
  146. Anyone know what this is?
  147. update
  148. Insulation under hood? Advise
  149. Unhooking Electrical Connectors
  150. Anyone know how to program a keychain remote (fob)
  151. well got some toys ordered
  152. Wtf clutch 2 in 6 months
  153. first dakota
  154. Multiple Problems 1997 Dakota
  155. 03 5.9 randomly dies
  156. HELP. Hit a rock, alignment off.
  157. Grill Inserts
  158. possible bad lifter...maybe worse..
  159. third brake light doesnt work
  160. Air cleaners vs CAI
  161. lights behind grill?
  162. rpm's jumping need help!
  163. Tach and Cruise NOT working
  164. Will this fit?
  165. Truck occasionally dies when stopping
  166. flowmaster
  167. interchange info
  168. Need stereo help
  169. Newish member intro....Pics inside!!
  170. 1999 Dakota Shift Issues
  171. Best Transfer Case Switch?
  172. Timing Cover Pitted - 2003 Dodge Dakota
  173. I get to learn how to put in a door window
  174. 2000 dakota trans solenoid problem
  175. Clutch replacement
  176. 3.9 timeing chain questions
  177. O/H console mod took a dump
  178. 5.2L + 180 Stat=Poor MPG!!
  179. Got a 2000 Dodge Dakota Quad Cab
  180. Front 2 Speaker size... quick reply.
  181. new shocks?
  182. 2 door-4door size
  183. Ball Joints On 2002 Dakota
  184. lift questions. please help
  185. Open differential solution..?
  186. What are your opinions on this?
  187. tire question and update
  188. upgrading
  189. my two babies :]
  190. need some info on a part
  191. steering shaft
  192. New from W.V
  193. Thinking about buying a Dakota
  194. Emission Legal 4BT Swap?
  195. Front speaker Questions.
  196. Ping or Ticking from motor?
  197. 4.7 swap for another 4.7?
  198. Prerunner ?'s
  199. 5.2 and Trans Question
  200. Manual swap
  201. Wire Frame
  202. 03 Dakota sitting crooked
  203. Dakota Parts Canada
  204. 318 violent shack at 800-1200 rpm
  205. V10 swap
  206. neutral safety switch wiring chewed off
  207. Roadtrip/DF memebers
  208. in middle of plenum repair, have a question
  209. newbie here....questions about 2001 dodge dakota
  210. Removing O2 sensor
  211. i maybe getting a free tonneau cover
  212. Wtf
  213. magnum 3.9 floods when starting
  214. Power steering pump going out? Advice? Please!
  215. Kinda confused ( tps & speed sensor)
  216. Trying to decide on a new exhaust...
  217. idk if i trust the dealers around me anymore
  218. 2004 Dakota Transmission
  219. To correct a tranny problem...
  220. i cut my cat out.
  221. Simple maintenance questions. AND lift kits?
  222. 2001 backfires when cold
  223. Pvc
  224. Code ?s
  225. Rear passenger side brake line broke
  226. how do i
  227. 2001 rear end Interchange ?s
  228. lifter questions
  229. A/F tuning data videos
  230. Power steering problem, rear end problem. HELP?
  231. Dinomax super turbo
  232. size of pinion seal?
  233. Spark Plugs
  234. fuel system questions
  235. Just bought my 1st Dakota. Got sum ?'s
  236. well the fun lasted less than 700miles
  237. Lowering kits, AAR hood
  238. Finally replaced speed sensor!
  239. Stubborn Bumper Cover
  240. Fuel Economy
  241. ABS question
  242. Dodge dakota 2000 part out
  243. couple problems
  244. Access Lorado Tonneau Cover(44149) $375
  245. electric fan question
  246. just ordered new toys
  247. Dakota newbie looking for advice
  248. Took truck to 2 shops for hard shifting issues.
  249. i'm ready to buy my first dakota!
  250. 5.9 ecu
