- 1st gen to 2nd gen engine swap
- hooking up my CB? New CB?
- Red Connector right of ODBII/hood latch under dash
- wheels
- Part number for throttle body cable needed
- poor fuel mileage fix
- secondary o2 sensor
- Cold Air Intake Question
- transmission issues and my fix
- 2wd FABTECH 2inch leveling kit
- lug nut thread size???
- WANTED AIR INTAKE!!!
- Torque specs for auto 3.9 tranny pan?
- Pride & Joy (Truck Pictures)
- Power Lock issue
- Power Windows
- Need Help!!
- 04 Dakota
- Clutch fan removed
- bed length for 2002 Dakota quad?
- toolbox!
- finally got some pictures for ya...
- Putting a 1500 suspension on a Dakota
- fuel filter
- Rattling from Front Suspension
- Help with codes
- Oil Question
- Truck won't start...clicking noise
- How hard would it be...
- Problem Code Reader Suggestions
- i need help
- Temperature gauge issues?!
- Could use some ideas
- Light Question
- don't need no stinkin....
- fuel needle placement
- speeo calibration???
- fuel pump problem?
- my project is coming together
- EVAP sensor malfunction codes
- solid front axle
- Will a 03 rear axle fit a 2000
- Smart Mods
- need help p0601 2000 dakota v6
- Heater Core Change
- Remote starter
- Manual Tranny fluid and Transfer Case fluid change: EASY
- traded in my R/T for a smart car....
- fan spins when off
- digital scanner
- Ball joint removal
- removing front sway bar end links?
- Rough idling.
- Need opinions on tires!!
- '04 Ford Ranger will dust your Dakota!
- Routing Speaker Wires To Front Door Speakers
- Got some new parts!!!
- 2003 Dakota 4.7 and E85
- I need some help please
- Well, traded the dak yesturday for....
- wierd brake pad wear
- 2001 Dodge Dakota Sport - won't start!
- cam swap help
- 2nd Gen Dakota Guys
- 5.9 Manifold & Throttle Body for 3.9
- 2002 dakota drive shaft
- Radiator hose too short
- 302$ Speeding Ticket and court lost it in system.
- tranny or transfer case clicking
- Hurst Shifter DIY and Reations
- Help! Heater blower does not put out much air
- Changed out TStat Housing old style m1
- A/C won't work
- radiator hose exploded
- }Project{ Battruck
- ABS/ Break warning light
- Off-road?
- Oil Seal
- Little highway fun at 1am
- Cell Help : P0455
- shift linkage?
- Here comes trouble...
- What Gas Mileage Do You Get?
- Heat and AC only work on high
- spark knock
- Maybe you Stereo-guys can help me out here,..
- tranny problems
- Finally the pics I promised!!
- V6 Muffler
- uh oh, trans issue getting worse
- CEL HELP
- Problems with pics on this forum ??
- srt-10 swap
- How to get 45+ mpg
- 1994 3.9 Runs poorly
- 1.7's
- Difference between a sport??
- DIY HHOGENERATOR
- Exhaust for v6?
- Hurst Shifter!
- 01 dakota pinion seal
- P0303 MISFIRE HELP PLEASE
- no air from vents! please help!
- power programmer ???'s
- Error code P1776 for 2004 Dakota
- ABS/Brake light on and Speedometer don't work
- Airbag Light on
- Misfire
- 98 3.9 recently gutless!!??
- Mud Tires???
- fender flares
- A/C compressor bearing
- 12volt plug blowing fuse from laptop
- Cruise Control Wheel
- mystery overheating
- Need firing order help badly.
- code p-0455
- Highway Terrain Tire: Nitto Dura Grappler
- Engine RPMs
- Output speed sensor
- Carfax please
- Yall come vote in TOTM
- speed density
- 2001 Dakota horn chirp
- bypassing factory amp
- Engine sluggish after O2 replaced?
- cherry bomb
- factory dakota head unit question
- code p0138
- Question About Power Door Locks Problems
- blower not working,no heat or air coming out
- pcm pinout
- wheels
- holley TB
- clear headlight peices
- wet carpet
- buying a dakota
- Help with Overheating engine
- oil pressure
- July TOTM
- Help with Gears!!!
- wet floor
- Mod help!
- PCM Question - Will a 97 2WD PCM work on my 97 4x4 - both are 318 Auto
- 2001 4.7 interchange
- engine swap????
- Face plate for climate control
- diesel in a kota
- Speaker Questions
- Hub adaptator kit
- Engine tick???
- Clicking sound after start up.
- 01 quadcab 4x4 3" body lift how-to
- need guidance on 2001 speed sensor location
- $2400 3" lift
- new vid!!!
- Rimz!
- over heating
- Factory limited slip/or aftermarket
- Rims?
- Hemi in a 2wd DAK??
- DOdge Window VEnts
- How to ...?
- engine light
- new wheels:backspacing
- cost for swap
- no radio/interior lights
- Squealing rotors... not the pads or surface
- Best R/T
- Steering wheel hub adaptor kit
- New Shocks?
- Clutch Linkage
- Map sensor connector
- Just a Thought/Summer Project
- Removing the head
- key fob problems?
- Full exhaust system
- Dakota Rim Pattern
- Dakota parts
- Air cleaner for sale
- constant overheating rotors!
- Need to replace brake line
- Rear O2 sensor heater has <1v going to it
- Chicago Area Dodge Mechanics???
- DAKOTA RECALLS (2003-2007)
- RESEARCH REQUESTED!
- My posssible new ride!!!
- swaping hoods from '04 to '99
- dakota tire sizes
- dakota tire sizes
- 97 Wheel Hub Help
- Shaker hoods???
- 4 cylinder performance
- Link For download manuel repair (140M)
- 2001 r/t
- photo gallery
- lights are acting up???
- Need some help, 1999 Dakota
- Unlock all doors -> ignition off?
- fast idel
- serpantine belt 3.7L
- got some cutting done
- Dakota of the month VOTE!
- stealth gauges
- I am baffled....battery drain
- Custom Air Intake Idea?
- Engine light on....then off.......
- electronic brake controller hookup
- front differential question
- 2001 Dakota R/T rims engine/tranny cores wanted
- Subject: 4.7 to 5.9 swap info (wiring)
- hum noise while pressing on gas pedal
- Location of kickdown solenoid?
- help with my 4.7 cams
- a sad day in dakota history
- Tow equipment questions?!
- Need some help on 01 Dakota
- Gears 3.55 to 4.56
- odd shift in first
- Transfer Case
- bolt broken off
- O2 sensors
- `98 Tune up...& a 180!
- Dak of the month nom's are open!
- 2004 Dakota RECURRING Steering Issue!
- Engine Swap
- Dropped the Dak 2in front 2in rear.. total 3/3 pics inside.
- Cold Air Intake Issues HELP
- Newbie, and in need of serious help. calling all experts.
- Billet Fuel Rail Group Buy 5.9
- ??rims question???
- Knocking noise out of nowhere
- water down the throttle body?
- I FINALLY found my project car!!!
- new exaust clips and pics
- no shift selector light
- Anybody in or around Garland Tx?
- A quick question.
- What size are those pins?
- Almost had 4 R/T wheels for $50
- Speedo
- Shocks
- Why are gas prices so high???
- I had to share this
- remote entry
- Possible Dakota Newbie
- Tranny dipstick
- STUPID GAS PRICES!!!!
- WOOT GOOD NEWS!!!
- small rust spot fix how too??
