PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 [78] 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. fuel filter
  2. Has anyone
  3. So I lost to a Titan unfairly...
  4. starting problem
  5. Power Window Help
  6. Need Help!
  7. towing performance?
  8. What would happen if....
  9. air intake question
  10. r/t rear axle
  11. Smoked Tails Pics
  12. bull bar or brush guard for 99 dakota 5.2
  13. hughes 50mm throttle body
  14. Bad experiance with SoCalDakota...
  15. plenum gasket bad?
  16. heat works fine on all settings except....
  17. What The Heck Is This Noise?
  18. charge the AC
  19. Adventures in mechanics!
  20. rear end rebuild
  21. ABS light and Red brake light on speedometer floats FIXED
  22. Why 6-lug hubs on a dak?
  23. 99 Topper fit a 93?
  24. tow hooks
  25. Hi Flow Cat on an 00 4.7
  26. 1998 Dakota wiring harness question
  27. MAP or TPS?
  28. VOTE!
  29. Front end squeak
  30. Engine Stall
  31. I NEED HELP
  32. speed control switch AKA cruise control
  33. Rear Sway Bar Links
  34. 33x12.50/20 or 35x12.50/20 on the dakota?
  35. Interior cab fan (a/c, vents)
  36. 33's or 35's anyone? question
  37. WHAT EXHAUST SYSTEM DO YOU HAVE??
  38. My fuel pump died
  39. Rough Idle
  40. Cap and rotor
  41. Dakota Power windows not working correctly
  42. power window bolt-up?
  43. Car/Truck of the Month
  44. TPS mod anyone try it?
  45. Slicks
  46. Does the Jet T-Stat have the weep hole?
  47. No low beams!
  48. mechanical problems - many
  49. dodge lamb..?
  50. How much lift do I have?
  51. help i have a drum problem !
  52. Child carseats for a 2001 Dakota extended cab???
  53. Wheel Scrub Information Needed!
  54. Tires Scrubbing On Lowered R/T!!!
  55. stupid question but...
  56. rims?
  57. New pictures of the Dak
  58. Radar Detectors (cheap)
  59. High RPM and other annoyances
  60. Rattle from Right Front
  61. Shocks
  62. Friend 2nd gen with new rims
  63. heavy Vib at 70mph and up
  64. short throw
  65. Does switching to a 727 affect the computer?
  66. Cold Air Intake Questions...
  67. 'Starting Fluid' and leak checks
  68. opinions
  69. tool box
  70. black headlights for 2004 dakota
  71. i need a 360 HELP
  72. 4.7 trans
  73. dakota weight
  74. subs in a regualar cab.
  75. headlights...wanna buy?
  76. V10 hop ups
  77. rear end upgrade
  78. truck box centering.
  79. 3" PA BL with ....
  80. Air Bag Light
  81. Engine Roar Problem
  82. AC evaporator question
  83. Intermediate shaft swap
  84. leaky exhaust
  85. How is it that you go about...
  86. Chip Reliability
  87. Internal Control Module
  88. lets talk intake manifolds for the 5.9/ 5.2
  89. shocks baby!
  90. Rockers / Valve Seals
  91. evap emission leak . . . HELP
  92. Swapping out a 3.9 for a 5.9 my poor mans r/t
  93. brake size
  94. water damage!!!
  95. Hooker Aerochamber Finally got a vid
  96. just found this forum....HI all
  97. Window removal
  98. help with 22's?
  99. Tranny question
  100. where to begin?
  101. Real World Data on Gas Mileage
  102. Please help 1998 dodge dakota
  103. Just how GOOD are these Infinity speakrs?
  104. Stock Fender Flares
  105. A/C clutch fan bearings toast
  106. '98 Dakota 5.9 r/t problem
  107. 2002 Dakota BCM problems
  108. 4" rear drop
  109. 2.5l TURBO???
  110. A/C intermittent
  111. I hate not being able to charge my cell in the truck!
  112. 99 Hub/Bearing - 2 types??
  113. VIN Lookup
  114. BOOOOOOST! The retarded kind...
  115. Just got myself a 99 Dodge Dakota
  116. WTB: OEM INTAKE TUBE
  117. Water Pump?
  118. Synthetic Power Steering Fluid
  119. Front Driver Wheel Squeak
  120. Burning Oil... !!!
  121. WTF?!! 2 days late :(
  122. Kill Story.
  123. A/C On All The Time?
  124. Cold Air Intake
  125. MSD Ignition
  126. Correcting For gear Change!
  127. What should i do?
  128. Uh Oh! Tranny issue?
  129. ride of the month
  130. ROTM nominations open
  131. Window regulater
  132. Dyno!?!?
  133. Water spots
  134. Strange Sound
  135. cai hai.
  136. 275s...
  137. ball joints again
  138. 2000 Dak 4x4 lift
  139. 4.7L TPS replacement
  140. r/t emblems
  141. NEW TO DAKOTA'S HELP!!!!
  142. Cooper stt
  143. 8.25 open differental on awd 4.7
  144. 04 Dak q's
  145. new to forum, A/C problems
  146. Air Conditioner problems
  147. Cam Swap
  148. Adjustable air shocks?
  149. New Dakota
  150. I need this resolved
  151. cooling fan redux.
  152. Installing Subwoofers
  153. Quadcab Drivers side rear power window???
  154. Slotted and Drilled Rotors
  155. 2400 Stall
  156. 3.9 Engine Knock or Tapping noise
  157. Cabin Air Filter
  158. Power Steering
  159. Crackling noise
  160. front wheel bearing
  161. KLINGS DESIGNS!
  162. tps mod? Code now...
  163. tranny swap questions
  164. march steel underdrive pullies
  165. new here and need help with fuel system
  166. tranny cooler
  167. Im told i need a replacment tailhousing
  168. what tranny?
  169. Little bit of an issue
  170. Pics Of The 99 R/T
  171. 1998 Dodge Dakota 5.9L V8 AEM Intake
  172. 1997-99 Dodge Dakota 5.2L V8 AEM Intake
  173. electric cutouts?
  174. Sway Bar Bushing for 4wd Dak!?!
  175. Shocks questions
  176. newbie need help w/idle!
  177. 00 dakota 4.7 drums to rotars
  178. drum to rotar swap?
  179. treadd...
  180. Air Conditioning
  181. pics of my truck
  182. Dustin' a bit
  183. A/C evaporator replacement
  184. Rear Window vinyl design idea
  185. Spark Plug Compression Ring and Spark Knock Questions
  186. SmOkEd 0_o
  187. Location??
  188. what truck should I buy, 99 or 00?
  189. water pump bad?**** updated with fix
  190. 2wd suspension up's
  191. '98 Dakota starter question
  192. Rear Seats
  193. headlight issues
  194. uhh...bent rear axle apparently?
  195. Malfunction Indicator Light.
  196. Smoked 3rd break light
  197. Body Kits and Such
  198. Hood? Urg..
  199. control arm removal
  200. rear wheel alignmen
  201. I love my dealer
  202. 52mm throttle body
  203. Alignment, now my steering wheel isn't straight
  204. V6 Sound clips please
  205. Window problems Help...
  206. unscientific MPG results
  207. how many miles
  208. Cruise issue
  209. Questions
  210. Towing Set Up
  211. Quad Cab Subs
  212. are these R/T rims?
  213. V8 exhaust on V6?
  214. Stock 15x7s for sale. Got pics.
  215. Engine coolant bubbling?
  216. Intake Throttle body Combo
  217. Audio System
  218. electrical problems
  219. Would dropping in a 5.7L hemi be worth it?
  220. window hinge
  221. Stock injector Size
  222. Spark Plugs/General Maintanence
  223. how much of a difference does an M1 really make?
  224. Overhead console?
  225. tranny slip
  226. 2001 4.7 tune up ?
  227. 1/4 Mile Time
  228. Programmer and PCM Help
  229. abs
  230. reg vs club
  231. Red line?
  232. tonneau cover
  233. i finally did it!!!
  234. flowmaster 50 suv series question
  235. 4.7 opinions
  236. New R/T and Quad Cab Pics
  237. New guy with a bunch of questions
  238. down to one probelm, and happy about it
  239. whats the difference between AWD & 4WH
  240. 5.9 power adders and Californis Smog
  241. Steering wheel stereo controls not working
  242. new with question
  243. Diesel in a Dak...
  244. installing a new instrument panel face plate
  245. Stick with the Tang?
  246. Heater Core access panel
  247. back glass weatherstriping
  248. Evaporator replacement
  249. thermostat question
  250. Electric Fan Cooling Suggestions?
