PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. speedometer off?
  2. Fuel Guage Issue
  3. 2004 3.7L Top engine noise, pressure in coolant ?
  4. No brake light ... No 12vdc power at brake switch pink wire
  5. dual exhaust question
  6. my dam passenger window.....
  7. Fogliught trouble
  8. Reverse Switch?
  9. 2000 dakota p0204 code fix
  10. Seat covers
  11. Tire and wheel question
  12. New Member
  13. dragging,brakes got hot & lockup
  14. Exterior lighting problem
  15. Input Shaft Bearing? Shaft Play?? 98 Dakota Manual (video)
  16. oil inside the intake -tried something and it worked - so far
  17. Removing steering gear
  18. basic ignition upgrades...?
  19. Intermediate shaft replacement - Steering wheel crooked
  20. 03 Dodge dakota v6. 10mpg????
  21. Brakes a bit mushy after change....
  22. Not a dakota but it can still handle off-road adventures
  23. oil cap snot?
  24. timing chain question
  25. Exhaust questions
  26. Large Serious Clunk - typically when starting to move
  27. Question about factory remote start
  28. 99 Dakota 3.9l 4x4. Front suspension clunk...?
  29. 1998 Dakota 5.2 with 3 inch short stacks
  30. New 2002 Dakota Sport 3.9L Reg Cab
  31. 2nd gen dakota fog lights
  32. 2002 3.9 dakota sport with ctm issue?
  33. Sound coming from speaker...no key!
  34. Transmission not moving
  35. rear bumper plastics
  36. Tire Noise Or Wheel Bearings?
  37. Antifreeze leak Need Help
  38. 03 dak foglights has anyone converted to driving lights ?
  39. Best way to flush power steering
  40. 98 Dakota 3.9 - Injectors Not Pulsing
  41. New here
  42. Does this look okay?
  43. 2001Dakota/Problem pumping gas
  44. NewMember
  45. 1998 Dakota Issue
  46. Headlight
  47. Ball Joint recall help needed please
  48. Dodge Dakota R/T
  49. '04 Dakota power steering pump whine
  50. 03 4.7 overdrive trouble
  51. 2004 Dakota SLT (4.7L Magnum) - questions
  52. WAZZZ HAPPENIN? (FNG intro)
  53. Crap.... Rod knock developed on a 2.5 01 RWD...
  54. Tire/wheel question
  55. Tired of the one tire fire!
  56. somethings wrong......
  57. Lift kit trouble
  58. Looking to buy another Dakota
  59. Keyless Entry and CTM Programming
  60. You gotta pay to play...
  61. Where to buy a new torque converter?
  62. turn signal problem
  63. looking to improve on-road highway/city handling, ride, and feel-any recommendations?
  64. 3.9 shifting issues
  65. This is pretty sick
  66. Service 4WD Light
  67. bumpers
  68. Greenhorn here
  69. Did I damage my transmission??
  70. Can you take fan clutch and fan off
  71. Beautiful 04 Dak. Does it have a lift?
  72. Durango leather seat swap.
  73. Is my Diff in trouble or is this normal wear
  74. Compressor
  75. Performance after CATCO CAT installed
  76. possible vaccum leak/ check engine code help
  77. Hiroshima size drive train explosion
  78. Do I need to change my tranny fluid?2004 Dakota 5 Speed Manual
  79. 97 5.2 SLT engine fuse block needed
  80. 02 dakota 4.7 4X4 lift
  81. Transfer Case or Wheel Bearings.....??
  82. NV3500 differences?
  83. Getting worse mileage
  84. reverse lights
  85. The Classic (apparently) oil pressure issue
  86. gas miliage
  87. Leaking rear window or windsheild!
  88. Chevy HHR fan and dccontrol controller
  89. need spindles/uprights
  90. 04' Transfer case noise????
  91. Service Intervals: What's right?
  92. 2000 Dakota solid front axle swap
  93. Need to replace the fan clutch (can't take the occasional roaring anymore)
  94. Wheel bearing ??
  95. Speakers pop randomly, no matter what volume.
  96. Finally pulling the V6 out
  97. Where do I find bigger shocks
  98. Bad Fuel Pump?
  99. Long overdue pictures of the new Coopers
  100. IT'S BALL-JOINT TIME,.. How hard?
  101. New Wheels and Tires on the Dak....
  102. Remote Start Help
  103. 4.7L Engine Takedown *Lots of Big Pics
  104. 2003 Dodge daktoa slt with p0441 code
  105. My trucks driving me nuts
  106. Can I put a flange on my exhaust?
  107. What year of doors will fit on an 03 dakota
  108. Old amp, new sub, pics
  109. Steering parts help, JCWhitney??
  110. Tweeter Help?
  111. 97 Dakota 5.2 auto trans problem and gauges dont work.
  112. How to Sea Foam Dakota
  113. towing questions
  114. What size tire can a fit?
  115. Now I Did It? ODBC
  116. Kota's Got New Boots :) Pic Heavy
  117. You need engine parts? I got engine parts!
  118. How to gut cat?
  119. Common Problems to Look For Before Buying
  120. small idle surge during complete stop
  121. Transmissions
  122. Issue: Power locks, Windshield wipers, and Headlights
  123. 3 fuel pumps later......
  124. Headliner decision
  125. Long Travel Dakota
  126. Haunted Dakota
  127. connecting a pod with gauges
  128. need help before i take it to the garage...
  129. dakota rear axle swap
  130. Crankshaft postion sensor location 98 V6
  131. It's actually fixed (governor pressure sensor/solenoid)
  132. 2001 quad 4X4 5.9 C205 front axle
  133. 3.9 sport 2000 m/t wont start
  134. hesistation idle and accelleration
  135. Reusing a Trans gasket that has been on for 4 days
  136. Exhaust for my AMC 150, looking to make the best outs what I got!
  137. Mopar Tonneau Cover
  138. 5.2 liter help???
  139. How do service departments clean fuel injectors?
  140. Shuddering around 40-45 mph
  141. strange pinging, only on highway??
  142. energy suspension ball joint boot.
  143. p0743 and output speed sensor problems
  144. Project prerunner has beguun
  145. Unexplained clicking
  146. 2001 Dakota Rear End
  147. Camshafts
  148. What's quicker 0-60 mph - 2hi or 4lo? (video inside)...
  149. 15 to 20 gallon tank help
  150. Just bought a 99. What are common problems?
  151. rear leaf spring
  152. Vibration after replacing rear differential
  153. PLEASE HELP!! Same check engine codes again 1762 and 1756 (with pic)
  154. Just a couple pics
  155. 42RE versus 46RE length
  156. Seems like low power starting from a stop
  157. 5 speed help please
  158. Need Torque Specs for 1998 318
  159. busy weekend
  160. 4.7 Miller 8350 tool dimensions
  161. Potentially Purchasing a 97 Dakota 4x4
  162. Yay, oxygen sensor...
  163. Truck dies at low rpms
  164. Blown out brake line :(
  165. Good Plennum Test?
  166. Any suggestions on preventative replacement parts
  167. Only has front brakes, No ABS!!!!!
  168. Emissions Help
  169. Vibration....can't figure it out
  170. Plugs Question
  171. Heater Fan Doesn't work
  172. 03 Quad Passenger Windows
  173. Pulsing during slow braking..... rotors or ABS?
  174. Wireing conversion help
  175. oh boy..
  176. 3 ding noise, no light
  177. Temperature gauge malfunction?
  178. Today I went muddin!
  179. Lets Talk Best Shocks For Dakota...
  180. Doing some bolt on upgrades
  181. 2002 front brakes dragging
  182. Sway bar size question??
  183. 2000 Dakota Bumper Cover - HELP
  184. Crank Position Sensor
  185. new wheel hub didnt fix noise
  186. Question on a portable jump starter...
  187. Peplacing Power Steering Transducer
  188. Advice on a Dakota purchase. All advice welcome.
  189. Service 4WD light
  190. Just gave the truck fresh plugs!
  191. Dakota ECU/PCM issue
  192. Govenor Pressure Sensor (need to replace)
  193. CTM Interchange
  194. 97 Dakota Build up
  195. Will this do what I want it to?
  196. Liftin' That Rear!
  197. Engine swap
  198. 2.5L engine vibration tracked to a cracked A/C bracket
  199. Wiring help
  200. Steering wheel noise
  201. serpentine belt question
  202. How much is this truck really worth?
  203. Please Point Me in the Right Direction!
  204. weird noise ?
  205. Spending Sweetest Day With My True Love...
  206. Strange electrical problem
  207. 01 Dakota Need Help Please ASAP
  208. Belt Tensioner
  209. park neutral reverse sensor
  210. Please Help!!! Squeaking sound !
  211. roll pan is in
  212. 5.2 Dakota Rough idle wanted. :D
  213. 2k Dakota Need Help PLEASE!!!
  214. Need advice on the cuase of a problem!!
  215. Exhaust recomendations per...
  216. I've got the repair bug.
  217. New Tires
  218. Howling after rebuild
  219. Newb and a few questions: 4.7L 2wd lift & dual exhaust
  220. 4.7 Knocking, losting oil pressure & overheating
  221. Back from the Dead
  222. Losing power uphill - no accelleration
  223. little hangers
  224. Using thumb drive in audio system
  225. Rebuilding vs Remanufactured
  226. Leaf Spring Project Done pics
  227. 1999 odge dakota sport vibration...help!!
  228. 2000 dakota 4x4 loss of all electrical power
  229. Driving on Dead Cylinder?
  230. Surging
  231. 99 wipper arm help
  232. 2 things!!!!!transmission and rear axle problem
  233. rear axle shaft question
  234. confused here
  235. tranny help
  236. Cleaned the IAC...
  237. CAI and programer
  238. (Power) Steering Issue
  239. Heating problems
  240. Tires-Please help Tire Noob.
  241. How do you read the codes on a 2000 Dak?
  242. Selling 2000 Dak
  243. v6- v8 swap info
  244. Strobe Kit.
  245. chuggle ?> & IAC
  246. A Question on the 2.5L engine regarding the Harmonic B. and timing chain
  247. Transfer Case Question
  248. Air intake
  249. Favor requested of a 1999 4wd regular cab guy
  250. Need Help - 2001 Dakota
