PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 [74] 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Little Rumble
  2. What's a Good Racing Chip for a Dakota 5.9RT?
  3. Groaning noise...Power Steering?
  4. V6-V8`
  5. Smoked OE tail lights?
  6. Problems With 98 V6 Sport
  7. Headlight Flicker
  8. any1 still use a cb?
  9. Should I buy Pro's and Con's
  10. Dash removal... help.
  11. Short circuit trailer hitch harnes Durango dead
  12. fog lights dont work
  13. P1757
  14. Help Tranny issue!!
  15. PO420
  16. Noob here in TN
  17. CEL P0300
  18. stereo removal
  19. Help in the hills
  20. New Here
  21. Whats the deal? (Check Engine Light)
  22. v6 10 mpg?
  23. plug wire problems
  24. 1997 Dodge Dakota Power Steering Problems
  25. cummins swap
  26. My last Dodge
  27. Power window regulator install
  28. Won't Start! Now with funny smell!
  29. '99 Dakota LOWER Ball joints
  30. Fel-Pro
  31. Instrument Panel problem
  32. thinking of adding air bags
  33. leaking antifreeze...
  34. 1999 Dakota starting issues
  35. Were Did They Hide The thermostat ?
  36. 3rd Gen Engine
  37. CEL Code 0400
  38. Oil fill cap.
  39. gas mileage
  40. slicks?
  41. Merry X-Mas
  42. engine replacement
  43. New brush gaurd
  44. Anyone tried these?
  45. 2004 Dakota steering problems AGAIN !!!
  46. moog ball joints
  47. Oil Issue Help/Rear main ?
  48. fuel Problems!!!!!
  49. Warranty Info Needed
  50. Manual window
  51. 04 dakota engine quits
  52. 2001 Dakota Quad Cab Window Regulator
  53. V8 w/ Manual Transmission
  54. Trac loc rebuild????????
  55. Fuel mileage
  56. Truck stalled in reverse!!!
  57. abs/proportioning valve
  58. 2 - 3 shift?
  59. 4H and 4L switch
  60. snow.. snow .. more snow!
  61. Just ordered a set of HID 6000k xenons
  62. Truck wont start
  63. Torque converter grenaded...
  64. Ext Cab and Quad Cab suspension the same?
  65. Need Some Advice
  66. tranny issue
  67. Broken......uhhhhh....not so sure what its called
  68. New bumper & grill (Also a light thing)
  69. oil spray 2000 dakota r/t
  70. 03 Dakota broken chassis bolt
  71. new back window!!!
  72. 33's and 3.55 gears
  73. rear brake swap
  74. I'll give you a new topic! Frames
  75. NEW gauge overlays
  76. Dad's 98 Dakota
  77. 97 Dakota heat problem
  78. XM Radio
  79. Creative Modifications
  80. new engin start up
  81. 4x4 slow to disengage and nasty thump when it does...any thoughts?
  82. sound system problems
  83. New topic
  84. Quick Radio Install Question
  85. Need a new rear axle, dont know where to look
  86. Back window Q's
  87. Highbeam Light Indicator Stuck On
  88. CEL on when really cold?!?!
  89. po420 low cat effic.
  90. 2000 Dakota
  91. What rims look good on a dak?
  92. Changing Brakes
  93. schrader valve on fuel rail
  94. o2 sensor
  95. Tranny service
  96. swicthing to synthetic oil
  97. power door locks
  98. Pics of your rides
  99. Need warmer air?
  100. Got my truck back after a month and a half.
  101. Check Engine light code P1294
  102. Performance Parts
  103. condensaion
  104. ABS
  105. Heated Seats HELP!!!!!!!
  106. idiot lights
  107. well im a dumbass
  108. Dak off getting a new tranny...
  109. HALOS
  110. MOVED: Rims and tires for sell
  111. bush bar pics.
  112. Instrument Cluster
  113. Drivers Window INOP
  114. AWD 2002 Dakota
  115. Help please
  116. FRESH THREAD
  117. clunk in front end
  118. Transfer case control...
  119. Advice on bumper and bumper cover
  120. Trac-loc disc cracked
  121. seems like activity is dying down here
  122. thermostat??
  123. Newbie Air Intake/Exhaust Question
  124. whats up wit that?
  125. Stuck in 4wd
  126. kenny bell superchargers?
  127. Engine oil dipstick breaking
  128. Brake Lights Sticking
  129. Front Brake Uneven Contact
  130. Truck overheating and smoking
  131. Right minded Radio?
  132. Another RECALL for 2nd Gen Dakotas and Durangos
  133. Another RECALL for 2nd Gen Dakotas and Durangos
  134. Anybody out playing in the snow yet with there trucks?
  135. My accident......
  136. Tilt Wheel and broken wire
  137. semi-scary noise
  138. Front Air Dam
  139. HELP!! Idle problems CEL code P0601
  140. Know your Dakotas?.. Then help me out!
  141. Headlight switch Q
  142. 5spd 4cyl touch-up
  143. XM Antenna Mount
  144. ITS DONE!!!
  145. SNOW!!
  146. anyone else??
  147. front bumper mount brackets
  148. ROTM make you nominattons!
  149. Noobie...
  150. air intake question?
  151. Where to put the amp?
  152. Posi blown?
  153. Power Steering Problem
  154. lifted 03?
  155. Experts PLease Help me!
  156. Very Important !
  157. Vacuum squeal
  158. why do i have an E-fan and a clutch fan??
  159. tranny fluid change
  160. wiring diagram
  161. idle problem...
  162. Back up lights, working, then not working
  163. Engine mod list
  164. Changing antifreeze
  165. Problem with my projector headlights
  166. What other years of rear axle would fit mine.
  167. Dakota exhaust
  168. slight thunk
  169. TOWED A CHEVY
  170. Aftermarket Rim Choice and Size?
  171. Engine Upgrade
  172. Tire size help needed!!!
  173. cam break in?
  174. RPM stickin problem
  175. shifting problems- any ideas?
  176. dakota rt trouble
  177. The Famous Creak...
  178. Tires
  179. Dodge Paint Codes
  180. lost cruise control on 2000 Dakota 3.9
  181. Anti-freeze in Cylinder need help!
  182. Speaker Upgrade
  183. WHO HAS THE CEL CODES
  184. Stock 5.2 and a supercharger
  185. whos got the CEL codes
  186. Engine Sludge???
  187. How many quarts of oil??
  188. Fog light problem
  189. 4 wheel drive.. driving me NUTS!
  190. lowering---the right way
  191. 3.9 cam swap
  192. 1998 Dakota 3.9 won't start have to wait an hour
  193. Are there any Dakota lift kits?
  194. Anyone got any REAL fuel saver tricks??
  195. AIRAID use
  196. Drive cycles
  197. 5.9 Mods.....
  198. Anyone have any RT heads fs?
  199. R.I.P DAKOTA
  200. Rear End Noise
  201. 3" control arm/spring lift
  202. Lift Limits
  203. DIY TPS sensor fix.
  204. just a few pics for the hell of it
  205. Average Milegae for 99 Dakota
  206. DIY Rack & Pinion Steering swap (4WD)
  207. Tranny issue....maybe(long)
  208. AEM Brute Force
  209. Electric Fan
  210. running boards 82205050
  211. Tires
  212. Autolite 3923s
  213. thinking about getting a RT
  214. Congrats User2006
  215. rocker arm adjustment
  216. Corner lights? Bulb but no lighting?
  217. Why was the paint codes deleted?
  218. Computer Chip
  219. Looking for advice for my up comming projects
  220. CEL on then off.
  221. Dakota quit going down road...
  222. Lower Center Console Light
  223. transmission cable?
  224. v6 fuel consumption
  225. what size is fuel tank?
  226. Quick Opinion Needed For Possible Tire Purchase Tomorrow
  227. Can someone help me out?
  228. New owner 99 r/t MAYBE
  229. Need new rubber...
  230. can you lower a 4x4?
  231. SMOG Test
  232. Thanks!!
  233. Anyone ever use Royal Purple??
  234. NV3500 1st to 2nd
  235. 99 dakota having starting trouble
  236. post your winter projects
  237. 90MPH+ check engine??
  238. End of an era
  239. Project Dak gets its feet dirty...
  240. new wheels put on
  241. exhaust for an '01-03 on an "04
  242. Pictures of 2000 Dakota
  243. A few questions and a few ideas
  244. Halo Projector Lights/ Xenon Lights
  245. Custom front tag Brackets ?
  246. add-a-leaf
  247. Blinking ABS Light
  248. Getting Hard to Start
  249. Cant find a sub box that will fit.
  250. Dashboard "brake" light on....
