PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. 02 Dakota tailgate does not latch
  2. LED headlights and bumper grill mesh
  3. 03 dakota r/t 5.9L dies after warm
  4. Are broken exhaust manifold bolts common ???
  5. O2 question .
  6. 2001 Dakota door locks
  7. No bus pls help
  8. 1998 Durango brake/ABS light on, no spedo.
  9. Dodge Dakota With a V-10 Viper Engine!
  10. Jumper for fuel pump to stay on continuously?
  11. Stuck spark plug advanced removal techniques
  12. 4wd problems
  13. OIL PAN GASKET REPLACEMENT 2.5l ENGINE
  14. Heat problem
  15. motor mount bolt size/thread and length
  16. Power Steering Pump Conversion
  17. Source for plug and play trailer harnesses.
  18. 1998 dodge Dakota 3.9l V6 coolant leak
  19. what do you think of the condition of this engine
  20. manifold bolts
  21. Air Conditioner on when not supposed to be
  22. Engine check code readout right on your truck
  23. 4x4
  24. Odd rear Brake Issue
  25. Oil guage info
  26. 2000 V6 overheat issue
  27. Overdrive light comes on randomly
  28. 2003 Durango Brakes = Upgrade?
  29. Battery tray pressure switch???
  30. odd hidden code/OBD
  31. Parking brake cable broke
  32. 2000 dodge Dakota 4.7 v8 mag, headlight issue
  33. Airbag light on
  34. Running lean
  35. 4x4 issues
  36. Dokota sport 2002 manuals
  37. Engine check light issues
  38. Slight clunking souns when decelerating
  39. Tire width
  40. exhaust check
  41. Installing keyless entry and remote start 2002 Dakota
  42. Problem with my dakota
  43. Rear Turn Signal/Brake Light Issues
  44. exhaust Y pipe question
  45. Starting issue
  46. AfTERMARKET 3.9 FLYWHEEL ?
  47. spark plug issue
  48. Anyone using Torque Pro? Or other OBD2 app?
  49. Rear license plate lights
  50. Infinity audio question
  51. Manifold Troubles
  52. 1997 2wd dodge dakota oil pan gasket
  53. Dash light problem
  54. 98 3.9 Boost questions PLEASE HELP !!??
  55. Water pooling on floor
  56. 2001 4.7 Dakota SLT whistling noise from intake
  57. Transmission trouble
  58. 02 4.7 smoking
  59. Tire size and error code
  60. Truck wont start after new brake lines
  61. Dakota 9in rear end swap gear to 410
  62. Open Squibb? Snap-on scan tool can't reset airbag light after r&r clockspring , cruis
  63. 2004 Dodge Dakota 4dr 4x4 4.7L
  64. Help Please! ASAP..
  65. Ignition problems
  66. 98 Dakota Brakes - Advice
  67. center console/seat swap question
  68. Need help ASAP please. 97 dakota 3.9 4x4
  69. 1999 Dodge Dakota Alternator Wire Gauge
  70. 2004 dakota 4wd, 4d engine miss firing
  71. 04 Dakota Alarm issue
  72. Power steering pump info
  73. Dak Owners i need help !
  74. 2001 engine cuts out
  75. Electric cooling fan not coming on.
  76. 2002 Dak Interior Lights Oddity
  77. Dakota lift
  78. Can't get the hood open anymore (98 Dakota)
  79. 1998 Dakota 3.9 A/C Air Duct Problem
  80. Help ID throttle body cable please
  81. 2003 dakota 4.7 engine codes
  82. 2002 Dakota Quad 4LO light not lighting
  83. How many of you are running 5W-20?
  84. Best engine oil 3.9
  85. Outer tie rod question
  86. 2000 Dakota 4.7 electr Radiator fan not working
  87. Heater / Thermostat related post
  88. I must be an Idiot
  89. Glove box doesn't open.
  90. New guy here with a question about Vacuum line
  91. Planning a 5 speed swap-- a few stupid questions
  92. Need Better Heat for winter
  93. 99 Dakota 4X4 clicking noise
  94. Hey guys need a little help
  95. Charging issue
  96. Security light on on cluster and truck wont run
  97. LED fogs and tails
  98. Odometer doesnt work, is it the sensor on the driveshaft that fixes this?
  99. 2004 DAKOTA 4.7 LITER (help)
  100. Help
  101. headlight strangeness
  102. Fuel Injector Replacement
  103. Emergency brake cable
  104. Wiring up the stock fuel pump
  105. Return line?
  106. Headlights and high beams flicker, fog lights don't work
  107. 4.7l cranks but no start.
  108. New engine and blue stuff
  109. 4.7 doesnt like to start
  110. 318 LA into 98 Dak 5 speed Help
  111. 02 Quad cab steering slop after new steering shaft?
  112. 2003 3.9 4x4 no bus cluster code 920 921 950 999
  113. No Bus update
  114. How's the side view mirror pop back on?
  115. HVAC Blend Door Issues
  116. Saying Goodbye
  117. 2000 dakota SLT 4.7 PCM swapping issue
  118. Cranks but hesitates to start
  119. 20 Amp Tran Fuse drawing power
  120. 45RFE trans issue
  121. Lowering a 2WD & improving handling WITHOUT airbags
  122. No Bus, No Start, New ECU
  123. Very Loud Rattle in drive and reverse
  124. '02 Electrical/starting problem
  125. Brake Tube
  126. Fan Clutch removal trick??
  127. 4.7L Lifespan
  128. Rear drums to discs---what else do i need to change?
  129. 03 dakota r/t 5.9L upgrade questions
  130. Transmission Question
  131. Door replacement
  132. 03 Dakota Sport rear bumper query
  133. 2000 4x4 dakota front axle noise
  134. 2004 Dakota Overhead Console Light bulbs for homelink buttons
  135. Sudden power gain
  136. 97 random cylinder misfire help!!!!
  137. Torque conveter to flexplate torque specs
  138. P0441
  139. OBD 2 port wire diagram/colors
  140. Front Fender Replacement
  141. Can't remove antenna nut
  142. Cruise Control Cannot Maintain Speed \ Sometimes Works Fine
  143. Engine/ trans. Swap computer info
  144. What's your guy's opinion on putting a supper 44 flowmaster muffler on a 3.9l truck??
  145. 2001 dodge dakotas quad cab wont start
  146. just joined, right directional doesn't work when light are on
  147. How to remove front seats? Make easier to remove?
  148. Radio wont turn on?
  149. Flasher Relay Part No. for 97' Dakota
  150. sloppy shifter after clutch replacement
  151. Fuel filler neck 97 dodge dakota
  152. 5.9 magnum swap or rebuild
  153. Po720 witch one should I do?
  154. Replace door jamb switch, 98 Dakota
  155. Dakota Dash Guages Not Working
  156. Prestone splashed everywhere! Where could be the leak?
  157. 4.7 hard start, fuel pressure issue
  158. 2001 Towing Upgrade
  159. 2002 4.7 Loses fuel pressure as soon as key off
  160. Drive Cycle for Evaporative Sys OBD
  161. oil pressure question
  162. Random misfire
  163. Nobus prob - pls help
  164. 99 dakota 5.2 bucks when driving
  165. 2001 4.7 Dodge Dakota Transmission Codes
  166. 02 dakota dash lights go out
  167. not charging
  168. Fire + Fuel & still no start, ECM??
  169. 2002 dodge dakota radio issue
  170. wiring harness part # location
  171. '04 Dak - Code P0058
  172. Will NV3500 MT from 1999 work in 2003?
  173. Gen 2 dakota front seats
  174. 3.9L plug removal??
  175. 1999 Dakota Club 4x4 5.2L Automatic, Resurrection
  176. Low end knock isolated
  177. low battery cause no fire?
  178. 01 leveling lift help
  179. 03 Window
  180. 03 dakota 5.9 rt dies when gets warm
  181. Battery keeps draining
  182. Axle Isolator Bracket installation... of doom
  183. Window Vent shades
  184. Which shocks???
  185. Where does my trans. dipstick tube bolt too?
  186. stupid question '97, camshaft sensor or distributor ign pickup?
  187. engine installation quick tips? time crunch
  188. Front shocks
  189. 2004 Dodge Dakota Quad Cab - Key doesn't work in door
  190. 04 Dakota SXT -Front Brake Calipers
  191. Passenger window from Drivers side 03 Dakota Quad Cab
  192. 2001 spare tire hoist bolt size
  193. Replace 2.5l 4 cylinder engine, or part out?
  194. Pan plug
  195. AC Orifice Tube Location
  196. dakota killing driving down highway
  197. Auto trans '97 4x4 5.2
  198. People with new engines... did you bother with break-in oil?
  199. water in passenger floor
  200. HELP - Missing part of my transmission case?
  201. 03 Dakota Driver window Regulator
  202. Steering rack groan
  203. Removing spare tire hanger/crossmember
  204. Cruise control retrofit for '02 SLT with 3.9L/5spd manual?
  205. Steering slop 97 dodge dakota sport 4wd with a 318
  206. Mystery solved... pics to follow
  207. Stock '02 3.9 clutch time. Should I upgrade?
  208. 99 Dakota intermittant no bus.
  209. Dodge dakota 1998 v6 3.9 new exhaust
  210. Dakota Durango part swap
  211. 1998 Dakota won't start
  212. steering rack question
  213. 98 Dakota 5.2 Coolant Guage not working
  214. 02 Dakota Starts But Won't Run?
  215. transmission fittings into radiator
  216. 03-04 Dakota rear disc backing plate?
  217. 2001 Windshield Trim
  218. interior lighting issue
  219. Questions about a replacement tcase
  220. power door locks
  221. syncros
  222. clunk in front end help
  223. My 2nd fuel injector wont fire? On my 01 dakota sport 4.7
  224. tire size with suspension lift
  225. Help with rear wheel cylinders
  226. Front Suspension Overhaul
  227. 03 shocks
  228. 8.25 to 9.25 help please
  229. Needing some help. New truck issues
  230. Dakota 3.9l v6 magnum 2003 180k - p1391
  231. Front Brake Noise / Grind
  232. 2000 Dakota Hard Brake Lines
  233. over heating issue. please help.
  234. Crankshaft Sensor Harness
  235. Front Brake caliper
  236. Front End Issues
  237. Tips for R&R the Front Brake Lines
  238. Heater Fan Smoking
  239. 2001 Dakota Quad Cab - Front Noise
  240. 2001 Dakota Quad Cab - Rear Door inside latch
  241. still check gauges and new parts
  242. Need Help... Brakes Sticking.... Why ??
  243. Evaporator temperature sensor - anyone know typical value?
  244. Check engine light/p0128 code
  245. ... What's my next move?
  246. New Ign, new Idling issues.
  247. Chipped keys
  248. Body Lift Steering Extension
  249. 2001 Headlight Switch W/Fogs
  250. Need help diagnosing intermittent A/C issues
