View Full Version : 2nd Gen Dakota Tech
- Getting a group together
- what gears?
- lower control arm bushings
- 2001 paint job
- Lost 2nd Gear
- oil psi
- 3.9L Overheating / No Heat
- !help!
- Dash vents don't blow air (defrost/ floor vent do)
- Little noise, Big problem.
- Changing Thermostat/Sensor
- 7 Band EQ
- KRC cam find...
- 98 dakota 2wd 3.9 auto tranny problems
- signal lights not working
- Missfire from hell, have checked everything, minus a teardown.
- flag pole in truck bed
- outer/inner ball joints
- What could be causing this?
- I think the tranny is finally toast.
- 3.9 towing capacity
- code 78
- K&N Filter
- 2000 Dakota Club Seat Swap, Need Advice!
- Passenger headlight low voltage??
- Thanks Santa
- I missed her...
- wanting to change to power option
- Brake problems! Help!!!
- Remote Start Help (01SilverCC?)
- Truck won't Start after spark plug change
- Transmission whine
- Hard jump after warm when going from park, reverse, neutral, or drive.
- electrical outlet in truck
- Throttle Body
- Passenger Side Headlight Flicker
- Need some help with a bumper
- help with engine compatibility, please!!
- Oil cap/filler foam? WTF?
- Clunking in back of truck
- Coolant Temperature Sensor
- Dakota Speaker Size
- Fan Controls Not Working on 2003 Dakota
- Stock thermostat temp for 2k 3.9?
- 3.9 Gearheads
- 10 MPG Dakota
- Stereo stopped playing any sound after going over bump?
- Hedlights
- Brush guard/frame question
- MAP SENSOR: Honest oppinion?
- Any upgrades available for the 3.7?
- need your opinion
- Suspension lift
- Dakota Power/Starting Problem
- What else?
- 2wd axle compared to 4wd...
- Front turn signal issue (just one filament out of the four)
- Guess this part !!!! :D
- Tranmission Leak and shifting issue
- Signs of a bad Tstat?
- Strange Stalling Issue
- Output Speed Sensor Circuit Malfunction. Help please!
- New guy here, Looking for some help with my 97
- Stupid question
- Steering wheel groan
- Could my differential be bad?
- Headliner Problems
- drive shaft broke off today
- How reliable are Dakotas and should I buy one?
- Just did gutter guard grill inserts and have a question
- Will this bumper cover fit?
- aftermarket remote start help
- new code where to start?
- switching to 4x4
- 01 Dodge Durango 4 wheel drive
- New Headunit = Radio Static
- Evap Code P0441, but no visible leaks and new gas cap. What could it be?
- New MP Air Cleaner On Sale!
- Stock Muffler
- Lighted cup holders
- Club Cab subs?
- Fellow Dakota Owner Needs Our Help!!!!!
- Kickers!! With pics
- Bulldog 500 Deluxe Anti Grind
- Bigger motor
- Part 2 speaker install
- Fuel tank rollover valve
- Removing door pannels?
- removing a seat in a dakota
- Heater Blower Issue
- 99 Dakota rear axle
- hi flow cat
- upper control arm bushings
- Camo Seat Covers
- Cold outside air blowing on passenger feet
- Free to good home
- Another tire question
- Truck evaluation. To keep or to move on?
- Front middle seat
- Heater Cores or lines leaking?
- Voltage Spikes
- Help! Panic Alarm Sounds when I use the fob to unlock truck..
- TV Cable Slack
- Ride of The Month - ROTM!
- Fuel Economy - Post yours!
- Got my first 99 Dakota, need some beginner tips on general maintance and easy tuneups
- Check Engine Light NOT working
- 17mm or 18mm power steering pump, does it matter?
- Valve guide seals
- wire tracing question
- Upgrading Torsion Bars?
- rear tires/advice
- PCV Valve
- Best exhaust set up for dakota
- Never thought I would be saying goodbye
- fuc**ng bi*ch
- Clunking Noise
- Misfire back again
- Hi, Randy here.
- 02 Power Window Regulator
- Spark plugs...narrowing selections down.
- Upgrades for Headlights
- how to remove a dakota back window?
- Exhaust Manifold Rusted Through
- torsion keys???
- Need help with cruise control
- Blown Head Gasket?
- Dextron III in MTX?
- Lowered truck. How to raise it back up?
- help understanding codes
- My Hood is out of wack need help please?
- bahahaha
- Electric super charger kit?
- When turning steering wheel I hear alot of noise
- Best free mod
- where can I find stock/oem 4.7 cam?
- P/S pump brand suggestions
- HC and NOx - mutually exclusive?
- planning on buying a 99 dakota tomorrow
- Can this be fixed with a rack seal kit?
- 99 Dak, HVAC controller issues?
- 03 2WD Lower Ball Joints
- New owner - Emissions failed on 99 Dakota Sport, HELP!!
- Heater Fan
- Hello, from new member, and looking for a little help.
- Need advice, looking to buy a dakota, common problems
- 99 Dakota, 4x4 with a 8.25 Chrysler rear...what lockright locker to use?
- Cold Air Intake for 3.9L
- Transfer case shift Motor (Indexing)
- Help, my horn has a mind of its own
- Abs
- Engine rattling/clacking noise
- cv axle removal?
- Pics of my 97 Dakota
- So....the drink holders....
- ? about oil pressure guage.
- My new to me Truck
- Help Please
- Instrument Cluster LEDS
- Regular cab V6 4x4 with short bed
- 3.9 V6 Engine, which will work?
- auto door lock defeat
- 3.9L to 5.9L engine swap PCM question
- oil pressure issue?
- 2.5 4 cyl injectors
- Headlight Assembly... What Were They Thinking?
- 2001 4.7 dakota max km
- 1999 dodge dakota windshield wipers stoped working
- can't find a REAR doorskin
- Fuel pump/filter?
- Trying to wire in brake light on camper top
- cruise problem
- 2001 quad 4X4 5.9 1/2 question
- help! hesitation and miss after washing
- Couple Questions ??/
- uh oh trouble on chassis
- OD switch on dash overide
- 2001 Dakota injectors not firing at start
- Brakes! And tailgate question.
- Rattle, Rattle, Tick, Tick.........HELP!!
- Looking for a missing vacuum component.
- 4.7 dropped seat (PICS) need advice
- 99 dakota, ext. cab 4x4, pop/clunk sound from front end..?
- 2002 front caliper anti-rattle springs
- Hub/Bearing Torque setting question
- Need help- loud high pitched humming noise at high speeds after changing all fluids..
- Real quick...
- Lower Ball Joint torque question
- Spark Plugs
- Tire Recommendations
- 2002 Dak-4x4-3.9L Lower Ball Joint issue
- Dodge Dakota transmission
- HIDs
- wants to start but wont
- 2003 Dakota Quad Manual Window Regulator
- New Member - need parts help
- misfire under load.
- 01 Dakota won't start when warm
- tick solenoid?
- adding more to my lowering kit
- Strange thing this morning
- u joints?
- I have a mighty lame horn horn for my Dakota - anyone running a better one?
- Nerf Bars Close to the Body
- Rust Protection
- New member; 2000 Dakota 4x4 club needs exhaust
- Good deal?
- Installing Aftermarket Deck
- Vac Line / Leak Detection Pump
- 2003 Dodge Dakota questions
- ATF 4+ or mopar power steering fluid?
- New Thread Overhead Console
- Throttle body spacer?
- Bail me out with a picture of power steering lines to rack
- have a mirror question
- RPM's bouncing, Wont Shift, Engine bogs down
- Front end noise when in 4wd
- Rims?
- Back To Stock Headlights
- 8k hids?
- 02 airbag light
- Rear Differential Questions
- Power loss
- 3.9 to 5.9 Emissions/PCM Questions
- One Tough Truck
- '96 Dakota 3.9 4x4 code 34
- water under driver's side floor mat
- Is this normal on a Dakota?
- Fuel cunsumption
- 2002 Dakota 3.9L Questions
- Flipping rear leaf springs?
- 2003 Dakota Club Cab ABS issues
- Exhaust Manifold Bolt Problem
- ignition light
- emergency flashers
- Tires
- Tps?
- Dies/shuts it self off
- speedometer off?
- Fuel Guage Issue
- 2004 3.7L Top engine noise, pressure in coolant ?
- No brake light ... No 12vdc power at brake switch pink wire
- dual exhaust question
- my dam passenger window.....
- Fogliught trouble
- Reverse Switch?
- 2000 dakota p0204 code fix
- Seat covers
- Tire and wheel question
- New Member
