PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. When does the fan kick in?
  2. 2001 Dak 3.9 Using Oil
  3. 2000 Dakota SLT 4x4 33" Tire on stock rim ???
  4. Moisture On Floorboard 2004 Dakota
  5. Lifter replacement.
  6. First dakota
  7. Dual battery?
  8. Parts parts parts
  9. How to remove oil pan
  10. 2001 Dakota with lift kit
  11. I have to laugh a little.....
  12. Would it be worth it would it work
  13. P0320, Intermittent Stalling, Won't Restart.
  14. 2001 brake proportioning elimination ?
  15. Swap questions (brakes and engines)
  16. Clutch fan nut
  17. Mysterious Idle issue etc . '04 Dakota CC 3.7L
  18. A Mystery for the experianced
  19. Temporary fix for a rusted fuel filler neck?
  20. 1997 Dakota 4x4 knuckle.
  21. 2000 Dodge Dakota 4x4 Clutch - Dull clunk when pedal pushed in under acceleration
  22. No crank No Start
  23. Cracked head or leaking gaskets?
  24. Would an Old el camino v8 engine fit in a 96 dakota
  25. 97 dakota stalls
  26. '01 Dakota--oil pressure drops to '0' when at a stop, or under 1k RPM
  27. 99 dak club cab sport 5.2 with a nv3500 swap QUESTIONS
  28. Overheating issue.
  29. Driverside door lock
  30. 2002 dodge dakota
  31. I recently bought a 1997 Dakota with a 3.9 liter and a standard tranny. will the 318
  32. Programmer for 3.9?
  33. Brake lights 4-way flashers
  34. 2wd front coil spring diameters
  35. Climate control
  36. brake proportioning valve leak
  37. 2000 dakota door won't open
  38. Inexpensive power upgrades
  39. oil pan removal
  40. 1-2 Shuttle shift (hunting) Fixed Finally
  41. Dakota RT build
  42. 1999 sport and 2002 sxt power door and locks compatibility
  43. Oil pump
  44. 99 dakota swap
  45. Throwout bearing and clutch replacement
  46. Tri-fold/rolling hard Tonneau
  47. Update On New PCM
  48. 2001 4.7L Intake Manifold Options
  49. Semi-high Idle
  50. Damper Bar question for the experienced.
  51. Buy or not to Buy Urgent
  52. Key fob died a horrible death
  53. Greetings, New member and future Dakota owner
  54. '97 Dodge Dakota 5.2 4x4 Leaking Tranny Fluid
  55. Getting closer, one fix at a time (98)
  56. Clutch not fully disengaging
  57. Dakota Suspension Lift
  58. Information please
  59. 5.2 with AX15?
  60. heads for 97 5.2 magnum
  61. 97 Dakota - Misfire on Cylinder #4
  62. Help with lift kit 1999 Dakota
  63. Overdrive ring
  64. 2002 dodge dakota exhaust smells
  65. dodge dim headlight problem
  66. OD keeps shutting off
  67. 97 5.2 manual to 99 5.9 automatic no start?
  68. Lower control arm removal instructions for rwd
  69. I have a 1997 Dodge Dakota 3.9l V6 Standard Tranny. Does it have an EGR Valve?
  70. Band adjustments
  71. key fob
  72. I recently bought a 97 dakota. There aren't any hoses hooked up to the evap. I'm lo..
  73. 2002 Dakota 3.9 SXT intermittent CEL with P
  74. Brake Plumbing Thoughts
  75. Repair Manual 2002 Dakota 4.7
  76. ATF+3 substitute?
  77. 1997 dakota starting issues
  78. Rear Brake Lockup, Help Please!
  79. What did this go to
  80. Lost Reverse
  81. 3rd Gen Wheels on 2nd Gen, Tire Size?
  82. 2001 Dodge dakota 4.7 to 5.2 engine swap?
  83. Ball joints, what were they thinking.
  84. Bucking at 40MPH?? '04 Dakota 3.7 V6 killing me....
  85. 02 pinion seal replacement
  86. 2002 Dakota Engine compatibility
  87. Live data from obd2 1997 dodge dakota 3.9l v6 4x4
  88. No Headlights or Wipers?
  89. Lifting this poor dakota....
  90. Reverse issue
  91. Transmission Cooler Lines
  92. DIY alignment for IFS?
  93. Head Gasket?
  94. 2013 dodge dart AC clutch
  95. 2002 Dakota third brake light
  96. To adjust or not adjust
  97. 02 Dakota No Spark
  98. Line Lock installed 03 Dakota (4.7L)
  99. Whistle on cold start
  100. BIG PROBLEMS (possible motor swap?)
  101. 5000 miles and engine oil still clean
  102. Airbag light comes on after long descents
  103. Backfire
  104. Who has blocks in the rear?
  105. 2000 Dodge Dakota - Rad Fan Relay Issue
  106. Engine Swap
  107. hard to start
  108. How do I find out my gas tank size 3.9 2003
  109. 2003 Dakota / Low Idle & Stalling
  110. 2000 dodge dakota hard start when hot
  111. Tailgate assist
  112. 46re nss nightmare
  113. check gauge light on and no oil pressure
  114. Crank sensor stuck in block
  115. Clunking, rattle sound when in park/ neutral.
  116. 2000 Dakota Brake Problems
  117. Thoughts on Shutdown cause?
  118. Spark plugs?
  119. Not sure if i have a transmission problem??
  120. Cel p0138
  121. Power Mirror and Power Door Lock Issues
  122. PCM from 97-99 5 into a 2000?
  123. Water on Passenger floor
  124. transmission lines 2000 dodge dakota
  125. My marvel experiance
  126. 1999 Dakota v6 manual transmission
  127. Valve body actuator plate/shifter solenoid
  128. Should I rebuild
  129. Exhaust
  130. Possibly Dead - Head Gasket Blew
  131. 2002 Dakota cranks but no start check fuel pump can make it run
  132. Rich and rough idle
  133. I just bought a 1997 dodge dakota pu. 3.9 v6 4x4 It's missing some parts...
  134. '00 2.5L new clutch slipping
  135. 98 3.9 5 speed, what transmission?
  136. 2001 Dakota bad running
  137. 3.9 with 5 speed?
  138. IAC motor
  139. Larry
  140. Dakota Idling Problem
  141. Do most 2nd gen's have 29 spline rears?
  142. HELP. 1999 Dodge Dakota Sport 3.9 cylinder 5
  143. Steering Shaft replacement
  144. 2004 3.7 won't start
  145. Starts but dies
  146. 03 Dodge Dakato Headlight
  147. More 2000 dakota trouble
  148. Error codes, p0300, p0307 & p0207
  149. 2001 Dakota 3.9L sudden overheat after hearing timing chain slap
  150. 4wd problem
  151. No Bus Code
  152. 2000 Dakota
  153. 2008 cams in 2001 4.7 heads
  154. Transmission Alien Parts
  155. Transmission Interchange 97 Dak 3.9 engine
  156. Will a trans from a 98 Dur 5.2 Fit My 97 Dak 3.9?
  157. Factory radio on the fritz!
  158. 2001 Dodge Dakota.
  159. Blowing fuses for dash lights and tail light,tag.
  160. defrost vents only
  161. 5.9 pcm...yes again !
  162. bushingfix, does it actually work?
  163. Bad MAF sensor, intake leak, or injector leak? How do I find the culprit for P1196
  164. 2001 Dakota CC R/T
  165. Trying to make sense of '01 Dakota A/C
  166. Ice cold ac no airflow
  167. Transfer case replacement
  168. Quick gas tank question
  169. 2003 Dakota 3.9 Towing
  170. NEED AC - Heater Core Door - Blocking
  171. Differences between 99-00-01
  172. Upgrading my sound system
  173. Cat back dual exhaust
  174. would a 4wd pcm fit on 2 wd dakita?
  175. Heater blower issues continue
  176. inspect for rust
  177. First post, first truck, 97 Dakota 4x4 slt 5.2 v8
  178. P0335 No start after engine swap
  179. Just replaced clutch
  180. 4 random electrical probs, bad pcm?
  181. Putting 1999 6cyl in 2000 4cyl Dakota Sport
  182. 2002 dakota help
  183. 98 Dak SLT Random Stalling
  184. Gage light
  185. Cat and Map Sensor Threshold Question
  186. A/C warm on high fan speed
  187. Fuel pressure
  188. speedometer dead, trans not shifting
  189. O/D light
  190. 2002 dodge Dakota A/C
  191. how to install fog lights in 2011 dodge ram crew cab
  192. 2002 Dodge Dakota A/C
  193. Newbie with a big problem.
  194. 03 dakota vent question
  195. 2004 Dodge Dakota maintenance help
  196. Lowering kits or work needed to lower a 4x4
  197. 2003 dodge dakota
  198. Cruise control out!
  199. Squeaking behind steering wheel?
  200. how to increase my feuel economy from dodge dakota on a budget
  201. Crazy Brakes Dodge Dakota 2002 4WD
  202. Greasing pulleys
  203. Looking for intake manifolds
  204. Tailgate Assist
  205. Truck wont drive until it shifts to second gear
  206. I'm A New Member And Need Some Help.
  207. In Drive oil pressure loss
  208. 2004 4.7 Dakota turns off sometimes if I give it a little gas?
  209. Replacing Intermediate Steering Shaft
  210. No AC, Clutch Doesn't Kick On / Engage!
  211. 99 dakota 5.2 swap pcm problems
  212. Hey Everyone!
  213. 2002 dodge dakota power windows won't go up
  214. Lug Nut Broken off
  215. Hi everyone...ECM
  216. Can I put a 98 5.9 in my 02 that came with a 5.9
  217. Paintable lower front valance for 2004 Dakota
  218. Front transfer case noise /clunking
  219. Idle Speed Too Low 2001 Dakota
  220. upper ball joint question
  221. What towing mirrors would you recommend?
  222. 2003 model 4.7 code po340
  223. got a 2nd gen
  224. No Oil Pressure
  225. Radiator fan NEVER turns on. Over heating regularly.
  226. HD rear end wheel bearings
  227. 3.9 fouling plugs in cylinders 3 and 5
  228. Replacement panels for cab mounts?
  229. 2000 Dakota Sport Tilt Steering Wheel lever
  230. Hesitation
  231. Reliability
  232. UCA mounting bolt
  233. Front end aligment
  234. A/C won't come on
  235. finally swapped 5.9 , but still transmission problem
  236. When run AC truck over heats
  237. Queston on tires
  238. 2000 dakota steering shaft
  239. Temp gauge antics
  240. So... another v8 swap post...
  241. will my 98 fit 2003????
  242. 4.7 Timing chain Install Tips and tricks
  243. Crank no start- sometimes.
  244. 97 Dakota 5.2 camshaft??? Pull torque
  245. Temp gauge acting wierd
  246. Oil coming from grommets on crankcase
  247. 97 Dodge Dakota need new rear end 3.92
  248. Air suspension?
  249. 97 5.2l Radiator/Transmission Line leak
  250. @003 4.7 replacement
