View Full Version : 2nd Gen Dakota Tech
- Transmission interchange
- 2003 dakota 3.9 cat y pipe options
- I finally shut off the AIR BAG light!
- black box
- Rear license plates lights
- Some lights work, some don't always work... I'm fairly certain my truck is haunted.
- Code P171 FIXED
- Front axle nut
- Attempted theft how to fix?
- 2001 TRS Mounting Bracket
- New here - Need help with my Dakota project
- Failing Alternator Cause Missfire codes?
- How do I remove the dust cover on the trans??
- i got bored
- 1997 Dakota cv shaft
- I need help finding a transmission
- security tool for screws on 2000 Dakota ignition switch
- when to replace the timing chain?
- Tensioner Pulley?
- non start
- wheel well
- Cranks, No Start, ignition coil wire always grounded
- 1998 Dak troubles getting check engine codes (
- Random Dash Ding
- how to determine curb weight
- long tubes
- Battery drain, lights half on and buzzing!
- Ac issue
- 1998 dakota ignition wiring
- Emissions for wiring harness
- Unexplainable slightly rough idle
- Trans Cooler Line
- New Dakota wishes
- 97 4WD Rear Differential Pin
- Wheel Crazy
- Intermittent Starting Issue - 2004 Quad Cab 4.7L
- '02 Dakota code: PO443
- 3.9-5.9 engine swap flywheel
- Intermittent Crank But No Start, Runs fine when started
- Does your AC do this?
- Air only blows like it should on defrost
- High water
- Need help. My 2004 Dakota has a problem with the temp gauge going to hot while idling
- 98 Dakota 5.2
- Engine Verification
- fog lights
- California vs Federal emissions
- 97 Dakota 3.9l possible gauge/oil issue.
- Dash lights in Dakota 03 4.7 don't work
- Part fitting
- Power Stop z36 brake install
- 97 Dakota stereo wiring issues
- Middle of the 5.9 swap..
- 02 dodge Dakota ecm problem
- 02 Dodge Dakota stalling
- 97 dodge dakota starting problems
- 98 Dakota R/T 5.9 ~ RPM's are there but wont accelerate
- Forgive my ignorance
- interesting transmission issue
- Drivers side Valve Cover Removal....
- Radiator tube.
- Engine swap?
- 2001 Dakota caliper question.
- Tps
- No cruise control
- Brake pedal stuck- vacuum issue?
- Spring rate ponderings.
- Best mods for a 2000 dodge Dakota club cab 4.7 4X4
- 5.9 dakota/ 5.9 ram 1500 oil pump difference
- Low roar-- failing p/s pump? Or?
- Crankcase ventilation filter elements 2002 4.7L
- Bottoming out
- 45rfe park to reverse clunk and buzz
- 1998 Dakota 5.2L Fuel Rail Crossover Leak
- Ambient Air Temperature Location?
- Transmission woes
- Transmission Woes 3.9:/NV3500
- Rattle when Decelerating
- EFI control solutions for OBD I
- No cruise control
- gear oil question
- Accidentally added too much LOS to my 3.7
- No crank, no start please help
- My driver side headlight won’t work
- Rebuilding my first engine:2001 3.9L V-6 from a Dodge Dakota
- How to splice 2 injectors for the 3.9 to 5.9 swap
- Head gasket replacement on a '98 5.2
- 2002 Dakota instrument cluster random off/on
- Radiator change
- 2002 dodge dakota 4.7L spit and sputtering and loss of power
- no gauges
- 2wd: 2 inch front extenders / add a leaf rear?
- 1997 dodge dakota 4x4 3.9l slt
- please help first time rebuild dodge motor
- Oil pressure issues, 99 dodge dakota slt 4×4, 3.9 liter
- Electronics....
- 3.9 to 5.9 swap compatibility
- 98 dakota
- Newbie Here
- backlite
- clockspring
- Looking for 99 Dakota CTM harness diagram
- Boosted v6 vs 360 v8
- New on the site
- Bad front differential pinion seal!! 2003 dakota 4.7l
- 02 Dakota won't start
- 2000 dakota 9" to 11" rear drums upgrade
- 02 Dakota electrical problems with ignition switch
- exhaust help
- 97 dakota starts in reverse only
- tail lights /brake lights won’t turn off
- Aftermarket headlights
- 2002 Dakota cooling
- Rear running lights not working
- 2001 dodge dakota 4.7l transmission
- New Here.
- Rear-end for my Dakota
- Misfire/plug
- discontinued engine to front axle bracket
- 1999 Dakota 3.9 clutch pedal problems
- LED upgrades
- Electrical No-Crank Issue + Sparks!
- 98 Dakota 5.2
- Resistor went out
- 2000 2x4 quad cab 4.7 issues
- New Build Sheet Link:
- Random "Thump" felt in steering wheel turning Left under braking.
- Grinding after hitting bump
- Joined the 300K mile club today
- Found hidden rust spot underneath my truck
- 5.2 swap
- Engine swap
- 2003 Dakota 4.7l to 5.7l Hemi Swap (Help)
- Injector 3 Circuit A Issue
- No start fuel woes
- Radiator /engine ,coolant question
- Rear axle bearings
- Rear spider gears. Where to find 29 spline posi gears
- I'm back, and its 5.2 time
- 99 Dakota rt wont shift 1-2 with more than light throttle.
- 4X2 to 4x4 Swap
- Uneven brake wear
- p0308 2001 Dodge Dakota 4.7L
- can anyone walk me through raplacing a back up light switch?
- Speeeeeed
- Test TCCM, how to.
- '99 Dakota Strange Electrical Problems
- Performance of "Mopar" wipers
- 02 Dakota 4.7 misfire chase PLEASE HELP!!!!!!
- Cruise Control Problems.
- Lets talk about Engine Sludge.
- Need a ctm
- P0846 Code & Limp Mode
- PCM source?
- 98 ram 1500 5.9L Crank, No Start
- 97 Dakota nv3500
- 97 Dakota nv3500
- Front Drive shaft interchange
- Misfire #4 - running out of ideas 02Dak 3.9L
- PCM and moisture issues
- Why does my 4WD "stick" when going back to 2WD?
- Discussion: Impeller material. Plastic vs Cast vs Welded steel
- Dakota crank/no start fixed only by battery reset
- No heat...overheating...2004 V6
- Torsion Bar Key Bolt Bearing Info
- Need More Speed
- Heater door motor
- 1997 Dakota Sport 2.5 L Engine Help
- Starting trouble 2002 4.7 V8
- Power Steering High Pressure Hose
- 6lug to 5lug conversation
- 2000 dakota heater not blowing hot air
- Water pump Coolant leak question.
- Replacement Tires
- Engine overheating with no heat inside
- Major Electrical Issues, Need Suggestions please
- P0068 after JTEC to NGC Swap on a '04 Dakota
- Water pump bolts for 2001 3.9 V6
- Torsion Key Lift
- New Engine I may have set the Dist shaft wrong
- 02 Dakota Fuel tank/ gas gauge
- 2002 Dakota steering wheel
- 2004 dakota rust repair
- Transfer case question
- Missing O2 sensors?
- 02 dakota 4.7 where is the asd loacted ?
- Need a ctm
- 04 Dakota electric issue
- Volt gauge reads voltage for a minute then disappears
- TCCM help!!
- Engine swap or rebuild?
- whats the difference?
- transfer case noise
- 2002 Dakota dies in the cold
- 2000 Dodge Dakota Sport, Loss of power
- TCCM? Switch? Encoder motor?
- Signal and Hazards does not respond
- 1997 Dak 3.9 Engine Swap question
- HELP!! 2001 3.9 “Service 4x4”
- need help asap, 4.7 wont go over 3000 rpm
- Front driveshaft length?
- Exhaust Manifold Hardware Kit
- Heating
- truck starting issue
- NO BUS - sometimes only
- Weight of OEM wheels
- Lower coolant hose leak question.
- Oil guage
- 01 Dakota 4x4 “steering knuckle”
- Turbocharging 3.9 v6
- Identifying Part
- u-joint question
- 2001 4.7 engines
- Block heater?
- 2004 dodge dakota blows two codes
- Guages and airbag alert 1998 Dakota 3.9
- Exhaust manifold. Replacement/ generic
- Humming/whining in 4WD
- Shop costs header bolt replacement.
- New Electric Fan not working
- Equipment List/Build Sheet Link
- windshield wiper arms
- 4.7 to 5.7 Swap
- overhead console?
- 4.7L radiator cap pressure rating
- AC
- Plastic cover?
- 3.9 4X4 Dakota Trans 42RE
- rear ant-sway bar
- Heated leather Durango rt seat swap in reg cab Dakota
- 02 Dakota dead on road-- fuel pump failure?
- Hard Sputter
- Dakota windshield
- Rusted Front Cab Mounts
- limp mode
- Does anyone know !!
- No Key!
- Differential fluid
- 01 Dodge Dakota 2-3 Hard Shift
- windshield wipers
- Power steering issue
- HVAC and vacuum
- insulated tube by throttle body
- Aftermarket Upper Control Arms
- 2000 Dodge Dakota rear end
- Shift linkage removal + install
- Door Seals
- Quad cab rear bumper
- Reverse Lights
