- Quick A/c question.
- Does your truck want to crawl up hills instead of run?
- I found a dyno
- Newbie needs help
- Trans Temp Gauge
- Upgrades
- Bed liner and bed tarp for the winter
- TBS
- My dad's 02' Dakota quad cab 4x4 and my 97' Dakota standard cab.
- Just Curious-How many 2nd Gen Daks here are AWD?
- headers and brakes
- dyno
- dakota help please
- new 03 r/t owners ?
- noises
- a few quick questions
- dumps
- Selling Brand New Paxton Novi-2000 Kit
- Miles per tank and Fuel cleaning question.
- Rear speakers in dakota
- A little help
- noise coming from suspension
- anybody done this
- headers
- gearing
- Stock O2 Sensor
- tornado air question
- turbo question
- Ambient Oustside Temperature Readings
- Power Steering Pressure Sensor
- Anybody done a engine flush?
- Tire size and speed.
- Pic
- cornering
- jet chip
- '99 3.55 L/S rear end rebuild kit?
- My baby
- Just got 2000 dodge dakota.
- Finally; a pic of MY truck
- hypertechs how good do they work?
- 3.9 to 5.9?
- MOVED: Couple of track questions
- Which Engine?
- 99' engine questions
- 97 seats in a 94
- So I got a chance to drive the Dokota At Sea-Level today.
- spring spacer
- warranty work
- Hemi Dakota.......
- MOVED: Posted on ebay, Brand new sub box for 97-03 dodge dak extended cab Fits 2 10's
- Wiring diagram
- 98 Dokota R/T, Where to start?
- Headers
- ABS problem
- A/C problems
- Subwoofer Box
- dakota power loss
- Parts
- Tire size and ac questions
- question about 3.9 with camper
- Dakota R/T ?
- lifting 2wd 98 5speed dakota
- camshaft upgrade 99'
- MTX Thunderform Club Cab Enclosure
- 2003 Dakota Stampede
- Where can I find VIN # besides dash on 98 Dakota ?
- Brakelights work, but no tail lights!
- 2000 4.7 timing chain and gears.
- Empty holes in 01 Dakota dash? Clip?
- HELLA 500 LIGHT INSTALL
- 4 sale Brand New Sub box 4 dodge dak extended cab. FITS 2 10's Under Rear seat !!!!!!
- cost versus horsepower
- tire size
- Truck shuting off when driving
- losing power in 97 Dakota 2.5
- lift or front lift with stock wheels?
- 98 Dakota Thermostat install....
- Dakota r/t club cab
- How do I purchase an extended warranty ?
- JETCHIP Install...
- Lower Ball Joints
- "clacking" noise coming from engine area
- holley tb
- Wiring Autodim mirror in 2001 QC
- Rough Idle
- 360ci
- air compressor
- Tranny on a 5speed
- swapping 15s onto an 02?
- Dodge Dakota Suspension
- 4 cyl Dakota?
- thinking about my next vehicle...
- Toasted Transmission
- 03 2wd lift kits?
- Rear end gone advice please!
- 2001 dakota - ticking?
- Got a problem.... I think
- Electrical short in lights
- linings and covers
- 2003 Dakota...Brakes???
- Fluctuating Oil Gauge
- 2002 Dodge Dakota
- AC Compressor
- c
- Fuel tank size / reserve
- Need buying advice from the experienced
- speaker size and ohms
- Stock wheel size.
- SubWhoofer Box for 1999 Dodge Dakota Sport Xcab
- Picking up a 97 next week
- Front driver side noises
- rough idle
- noisy steering pump
- Suspension Lift?
- front diff pinion seal leaking
- For those who have shorty headers...
- POSI and 4:10 Gears
- Transmission noise
- Just recieved body kit. . .
- 97 dakota valance on a 96 dakota ( update)
- Fan clutch
- 94 v-6 3.9 L dodge dakota firing pattern?
- In the Dark, No 4x4; Electrical? Help?
- In the dark, No 4x4: Electrical Help Please!
- Gas mileage for V8 Dakota vs. V6 Dakota?
- New grille
- POWERDYNE 4 SALE
- Request for info and suggestions...
- Squeaking in front; Noise in back
- 2000 Dakota crew 2Wd I want to lift !!
- O2 Sensors when Replacing Exhaust System with Dual
- 97 Dakota Head Removal HELP!
- Spark Plug Diagram
- Radio Removal
- -What's your current exhaust setup?
- SELLING MY DAK
- Crappy MPG...
- Clicking Sound when Braking
- trailer light wiring
- Valve cover breather hose question?
- General Information Link?
- 97 dakota speaker problem
- ALL OVER THE PLACE!
- oil pan questions
- Dual Air Intake !?!?!?!?!?!?!
- Engine Height Help!!
- all gone
- tow hooks?
- Well folks. . .
- TIE ROD
- CAI opinions
- CAI
- gear ratio in 2001 dakota
- where should the oil pressure gauge read at?
- HELP! TIMING CHAIN PROB!
- suspension lift
- rod bearing question
- tow/haul button
- Rim Sizes for a 2000 Dakota
- Help I need a 99ยด Dakota R/T owners manual
- tires again
- irregular starting
- Wheel Bearings
- Airaid intake question
- Squeak-part 2!
- Sick A$$ dakota
- Changing Colors?!?
- Electrical Problems
- 2004 Dodge Dakota
- 3.7 turbo
- Keyless Entry
- headlight/taillight covers
- 2001 sport power steering pump
- what to do, what to do. . .
- mopar performance pcm and big cam...
- Squeak??
- Dakota for Sale
- Help- My 3.9L Dakota Needs Ballz!
- Thermostat Change
- P dONE ?
- Foglights for 03 Dakota
- Buyer Beware: Cervini's Auto Designs
- Tie Rod & Exhaust
- Fitting bigger tires
- noise and vibration at different speeds
- accidental re-post
- 1997 dakota front axle won't disengage?
- 4.7 cams
- 2001 Dodge Dakota 2wd tires..
- 2001 Dodge Dakota Sport help...
- replacing stripped wheel studs
- fog lights
- i want my 99' dakota r/t to peel
- dakota: average flaws or a purchase mistake?
- 2000 Dakota Brake pad thickness
- Tornado and Fog Lamps
- 2000 Dakota quad cab 4x4
- Not that anyone cares or anything but. . .
- Preformance and Durability
- NEW CD PLAYER IDEAS
- 1999 Dakota ABS light
- moaning continues... so weak
- Engine Swap Help
- O2 sensor heater circuit malfunction?
- Brakes.....
- MOVED: FS: 02 4.7 intake k&n, lights
- MOVED: Parts for sale for best offer
- Wheels
- check engine light question
- Link for R/T for sale
- Cranking up the tortion bars on the front end.
- stuck speedo on '01 dakota
- 3.9 to 5.2 engine swap
- dakota upgrades?
- Downey SST Snap Tonneau!
- Rack & Pinion, Tie Rod
- K&N FIPK
- Ball Joints fixed today!!
- Throttle Body
- all wheel disc brakes
- Will 20's fit
- R/T For Sale
- engine revs to 2000 rpm when start
- Headlight Question
- dual exhaust for 4.7L
- Lowering a Dakota for handling
- What kind
- looking for best hp least amount of money?
- hood hinges
- 99 Dakota, ABS & brake light
- ABS CONTROL MODULE
- 2003 Dodge Dakota Mystery
- MOVED: Chrome 17's for sale... with tires
- security light in my Dakota
- Turbo Kit / Supercharger
- Catalytic Converter
- Moaning 2003 Dakota
- Exhaust on an '02 4.7L
- Which Dakota for a small camper?
- CD player
- how do u beat a SVT Lightning??
- High pitch Squeaking
- '95 Dakota Engine Skip
- tranny problems
- Ball Joint Rivet Problem
- cool truck stuff
- When looking for a used....
- Engine light on?
