- piston slap issue!
- 2000 Dakota 4.7 sparl plug?
- Pulling my Hair out
- Code P0442
- TRANSMISSION WANT SHIFT INTO OVERDRIVE
- Bad news for my R/T
- B&M finally done! With pics.
- Throttle body???
- Transmission? What is it?
- Cheapest place to get thermostat? Also some general questions on performance..
- What a day...
- Performance Parts
- should i buy it???
- New front bumbers?
- 2cd gen dak leveling kit
- All squirley, whats up
- Any problems with Goodyear tires?
- deep scratches
- Swap 42re for 46re?
- Smoking Truck...
- wire color code
- 2002 dodge dakota tire size
- O2
- silverstar
- water pump ideas
- 2001 QC Dakota AWD Questions
- How do you do it?
- Car died! Need help diagnosing, Gas probs?
- Factory speakers
- senior pics
- Finally got it back!
- For those of you who celebrate
- Did I Make A Mistake?
- Wheel Spacers?
- high pitch tranny noise
- in search dakota ext cab 4.7L
- pulled p0748 code
- Q3 mufflers
- O2 Sensor bad without check Engine light?
- Rear Bumper
- golf sucks
- looking for new rims
- 360
- So I'm driving home tonight
- Has anyone ever heard of this?
- Electrical Problem
- changing my exhaust soon, now am uncertain if i should
- Supercharged 4.7!!
- Heated Mirrors?
- Trans question?
- rotors
- Truck seems to shimmy.
- CRANK POS SENS
- Sway Bar Size???
- Another 2000...Dodge Dealer this time
- paint/powdercoat stock rims
- Bearing or out of align
- whats good
- what is this hose?
- r/t wheels
- Auto Transmission Slipping?
- r/t question??
- Radiator Draincock
- #&@!%@! heater core
- lifting my 98 4x4 6cyl
- 7 Way harness and tail gate problem.
- Will swapping my ring and pinion gears mess up my spedometer?
- catalytic converter replacement
- ball joint replacement
- AUTO TRANS PROBLEMS
- Heat\AC Control whining in accessory
- Air leak or something?
- 5 spd trans questions
- Parts found in rear diff HELP
- Duals on 5 sp?
- here is a weird one... CE Light
- POWER STEERING
- Ball Joint recall?
- 02 TRANSMISSION PROBLEM
- 4x4 Shift Knob *urgent*
- would you?
- performance help
- Good oil change
- Heres a picture of my Dodge
- code P0442
- ABS light and brake light
- Thursday Funnies
- bumper covers
- Talk about throttle bodys
- Gear swap - 3.55 to ?
- more mods need info
- gears
- transfer case allen key size???
- Stickers
- stoopid 02 sensor question...
- All the 4.7 owners...What size exhaust??
- Newb Drivetrian Questions
- Performance Tuners
- Tilt Steering
- the dreaded death flash!!
- About to Buy Dakota Quad Cab: 2000 or 2001?
- i think i broke it
- what next?
- wheels?
- Freakin' Crap.... brakes....
- Fuel Rail and Injector Cleaning??
- Seat Belt Reminder Light
- Philladelphia area dodge owners
- TIRES! LARGE! MUD! size?
- CAI and Exhaust- No power gain whatsoeva
- Dakota or Tundra?
- 2000 Dakota V6 longevity?
- Horn and Radio volume
- gas mileage
- Ram kit for 2003, 4.7
- got a new paint job...
- 2003 Dak. 4.7, Not running right
- TELL ME WHAT YOU THINK
- knocking
- Dodge Dakota Cup Holder for a 1997
- Aftermarket Fogs...
- Ne body else get this message?
- Phantom misfire on 2003 4.7
- need a new cup holder
- tweaking with superchips 3715
- Superchip Where is your RPM Limiter Set 3.9?
- 2000 Dakota 4.7
- Not starting all of the sudden
- Hmmmmmm....Power Steering Pump?
- time to start modding
- Need Help
- Really Need Your Help Guys?
- Bought my first Dodge....
- Finally joined the dakota ranks
- squeaky truck..not belts
- NGK Spark Plugs
- A How-to; On your Heater-Core & Evaporator-Core,..PIC's FIXED
- Pinhole leak
- Back drums lock up
- tailgate price?
- Racing a 68' Mustang with 289
- totaled my truck
- misfire issue
- Electric door lock stuck
- Headlight Problems...with the tilt wheel
- Werid spark plug wire question
- Fuel monitors
- Exhuast leak at clamp
- gas gauge
- my i4
- Window handle removal?
- Grinding when turning in 4 wheel drive?
- P0133 Engine code
- 8.25 rearend
- Ball Joints
- New o2 sensor!
- Changing Coolant?
- 360 builds
- Anyone got a clutch alighment tool?? 10 spline 1-1/8" shaft
- Cranking VS Torsion Keys
- 2000 Dakota will not move.
- wheels
- SLT emblems...
- Shaking Brush Guard
- Squeaky drivers seat..
- Who knows if these hooks will work?
- Paint Problem
- Brake replacement
- bad cat?
- bolt ons
- Cat or o2?
- Check Gauges Light
- cams
- Leaky plenum gasket & tranny not shifting update
- not the best of nights...time for new bumper
- Well,.. I got the dash & heater-box out,..
- anyone interested in a AMSOIL EeA air filter?
- Plug Wires
- idler pully and belt tensioner?????
- how frequently should you wax your car
- death flash
- abs indicator light is always on
- rear end swap
- Limited Slip Differential
- 5x4.5 lug conv. group purchase interest?
- How many quarts?
- Leak Detection Pump code... What to Do?
- how hard to replace intake manifold gasket??
- exhaust manifolds
- No Dash or Tail Lights???
- Buying an R/T what to look for?
- selling my dad's dakota sport
- Does anyone know what this picture is????
- Exploding Transfer Case????
- headers on 4x
- TRUCK STILL RUNNING FUNKY AFTER LAWN SPRINKLER INCIDENT
- Word of Caution - KYB Monomax Shocks
- Car..ahem TRUCK alarms
- motorsports rims
- starting problem 2001 5.9 v8
- problem with it cuting off while going down the road!!!
- AC condesor replacement
- clock spring
- F/ S2002 DODGE DAKOTA V8 BLIZZARD PLOW.
- Paint Clear Coat Warranty??
- 1997 Dakota Sport loud engine rattle! Please help!
- 01 Dak Blew Rear End?
- v6 to v8 throttle body swap
- first wash of the year
- Air Bag Light
- Transfer case
- e3 plugs
- 3-4 shift solenoid
- intermittent AC compressor
- Cheapest clutch for a 2000 3.9L??
- big rack and pinion question??? asap
- A.S.A.P.
- beefing up..Need help..
- 4x4 Gas Milage
- windsheild washers
- SONOFA-MONKEYSUNCLE!
- K&N CAI noise question-holy cra*
- Engine turns over but doesn't fire
- 2 questions ??
- turbo
- drivers side mirror
- bed rails
- HELP! Lookin at a 2000
- K&N FIPK recall
- The weirdest thing I've ever seen.
- oil pressure is low
- Flush or Drain AT Fluid change...
- thinking about a well used dakota and have a few questions.
- Friday Funny
- front end clunk
- Brake Problem - 2001 Quad SLT 4x4
- Headroom in a '00 Dakota
- Speedo not working
- rear end gears..gotta question??
- Thursday Funny
- A VERY well covered topic!
- funny story . . . what could have caused this?
- drop questions
- P0132, P0138 Codes
- need to find
- trick to unclipping o2 sensor OE wire connector???
- 4.7 L Cat.
- Automatic Transmission not going into reverse
