PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. 97-Dak pinging after warm up
  2. RPM Range for a 2000 dakota 4.7L
  3. 2000 dakota 2.5 head
  4. light under hood
  5. gauge cluster
  6. changed oil filter fixed oil pressure dropoff!
  7. Holy crap!
  8. A/C Blower Flooded
  9. homemade lift?
  10. Tire Height
  11. Pulley noise
  12. Looking to bag the 97 kota need parts
  13. 03 dakota Fog Lamps that go out constantly
  14. 98 v6 dual exit exhaust system
  15. 2003 dodge dakota key flob
  16. Stupid and lazy question..
  17. 2 to 1 piece bumper change
  18. how difficult is it? (brake line problem)
  19. Transmission Cooler
  20. What years interchange parts w/a 99 dakota
  21. Jan. DOTM Come Vote!!
  22. 2nd Gen Dakota Lifts?
  23. i hate suspension and brakes
  24. Cummins 5.9L in dakota
  25. stalling!!!!
  26. It's a Sad Day :(
  27. bearing hubs
  28. Been a while...
  29. Worth the hassle?
  30. just bought my 98 and have some questions
  31. 2001 Dakota Motor and Tranny compatability ???
  32. tire and wheel package in canada
  33. 4.7 Ram for the wife????
  34. window problems
  35. wheel bearings
  36. 2002 Dodge Dakota Quad Cab 2x4 V6 Sharp truck! Near mint!
  37. turn signal problem
  38. considering a dakota
  39. Quick Door Panel Removal Question
  40. My 04 Dakota!!
  41. Torsion Keys, Hard install.?
  42. 03 Dakota 3.9L rear end.
  43. Dakota Hemi Swap!! With pics!!!
  44. Back seat center console
  45. tranny fluid level?
  46. Cold start problems
  47. Sub Ideas
  48. Are there any videos on how to remove control arm bushings?
  49. idle issues
  50. cost of installing lift kit in 04 dodge dakota
  51. truck for sale
  52. lifted dakota tire size
  53. Please help! code P0123 and truck stalls
  54. NV4500 Tranny swap
  55. tire size and 3 inch body lift
  56. Fatal Carwash
  57. 03 Dakota squealing coming from front tires.
  58. Any help out there
  59. v-6 to v-8 conversion
  60. Broken Bleed Screw (with rant)
  61. 99 dakota grinding?
  62. Squeal at idle on wet/cold days
  63. 2002 Dakota problems - knocking and sqeaking
  64. 99 Steering Question and 4x4 Light question
  65. 99 Dakota 3.9L blend door issue / recirculation issue.
  66. found this on craigslist
  67. pic of factory fog light wiring?
  68. its been 5 months and 17 days
  69. Best performance upgrades for a 02 4.7L QC Dak
  70. ..another 99 dakota that wont start !!!!!
  71. Want shocks, '00 Dak Quad 2x4
  72. how do you get the rear seats down on a dakota
  73. Headlight Restoration
  74. Jan. DOTM Nominations
  75. Fog light mod help
  76. Crazy speedometer bounce
  77. Humming while accelerating
  78. Swap a 08 4.7 into a 2000 4.7???
  79. Buy my exhaust?
  80. NeedHelp
  81. 2002 dakota heat problems
  82. factory fog light problem
  83. cheap billet grille
  84. Loss of power & mpg.
  85. O2 sensor replacement
  86. Air Horn
  87. 42RE reliability, early case vs late case designs
  88. SAS build :D
  89. Problems with front sway bar bolts
  90. 97 vibration
  91. 03 Rear Bumper Cover Push Retainer/Rivet Part Num?
  92. Transfer Case Problem or Linkeage Issue??
  93. installed a system in the runt
  94. Thinkin about gettin some new shocks
  95. rear sliding window
  96. new ecm its about time
  97. 99 DAKOTA 3.9 5 SPEED cranks but no spark
  98. extened warranty??
  99. factory 16 inch wheel weight limits?
  100. Timing question
  101. Console Sub??
  102. a sad day, selling the R/T
  103. My extended warranty expires soon
  104. Power Window Kit
  105. Disconnecting Warning Chime, Dinger, Buzzer
  106. are my brakes bad? lol
  107. 2002 Dakota Quad Cab 4.7
  108. 3.9L with 95,000 miles, performance...?
  109. idles down and dies
  110. Front end squeak
  111. Regular cab 97 speaker configuration
  112. transmission cooler line hook up???
  113. Tires and Wheel Issues?
  114. 2001 Dakota that won't Start. No spark
  115. 5.9 burning oil?
  116. Body Lift Pics
  117. Need Help! 2002 Dakota 3.9 V6 Wont shift
  118. problem with lights.
  119. Fs m1 $300
  120. Is the ecm for a 5.2 the same as a 5.9 magnum??????????
  121. shock upgrade??
  122. Replacement Ignition Coil, and tune up kit?
  123. Git low momma
  124. 3.9L black pipe intake...?
  125. Tonneau Cover Accessory
  126. switching out leds behind gauges and ac controls problem
  127. In search of engine!!!
  128. HS 1.7 Roller Rockers
  129. noob oil change question
  130. HVAC knob control, no face vents?
  131. Exhaust leak
  132. how many people have a 9 1/4 rear
  133. Valve Body
  134. running issues
  135. maintenance question
  136. I'm back again...
  137. help with running power cable through firewall
  138. Hey fellas..anyone running this exhaust?
  139. Does 1997 have an np231 or np231HD
  140. Christmas Presents...
  141. Need Spare Tire Winch Assembly
  142. Front brakes stopped working?
  143. would like a couple opinions
  144. Dodge Dakota 2002 4.7L overheating
  145. Engine Tick when Cold 3.9 V-6
  146. '03 Dakota A/C Heater Vents
  147. I need an expert
  148. I have a problem
  149. bigger tires
  150. Is this dual exhaust set-up bad?
  151. front end problem CV/balljoints ????
  152. another shock question??
  153. grinding noise
  154. Loose Steering fix
  155. How or has the 45RFE transmission evolved over the years?
  156. keyless pad doesn't work after jumping a car
  157. 2nd Gen Dak Transfer Case Rebuild
  158. weird noise
  159. Its been I while...
  160. what i did to my dakota today!
  161. Ram to Dakota Lift Blocks
  162. Speaker Suggestions? 2000 Dak
  163. '01 Fog Light Mod?
  164. CB radio, where could i mount this thing?
  165. Transmission stuck in 2nd gear.....
  166. P1781 & p1737
  167. 2000 Dodge Dakota Sport 4x4 v6 M/T
  168. Can someone tell me the manufacture of this Ball Joint?
  169. dual exuast suggestions?
  170. 2000 Rusty bumper fix?
  171. wheels and tires
  172. new dash led installed
  173. B-Pillar Question
  174. 2000 Dakota RT lower ball joint removal
  175. Power steering pump
  176. 2 interior issues?
  177. what trans in 2000 dakota
  178. 1997 dodge dakota HELP! WANNA GO 5.2 TO A 5.9 WILL IT WORK????
  179. Spark plugs
  180. Frustration Mounts!!! Engine won't start.
  181. New Fuel Rails Installed.
  182. 2001 Dodge Dakota PCM Issues
  183. Brake Lines
  184. Corroded Brake Lines
  185. Body lift
  186. Lookin to get a new muffler
  187. 4wd noise
  188. what does DF think of my new cb? *pics*
  189. Grinding while turning
  190. wheel spacers?
  191. Door pannel knocking when volume is UP!!
  192. new speakers!
  193. 2000 Dakota needs trans.
  194. Truck trade...worth it?
  195. need new waterpump, change anything else??
  196. 2000 Dakota R/T is overheating.
  197. Transmission Adjustment
  198. 4wd?????
  199. Supercharging kits for v6?
  200. 2002 dakota bed question
  201. Jet Chip 5.9
  202. Bed mat?
  203. Trans. shifting strange... high rpm / fast harsh shifts??
  204. let the modding begin
  205. Before I buy
  206. Two Questions?
  207. pro comp muds.... snow?
  208. gas mileage
  209. Superchips Help
  210. yo quick question, search not working
  211. Blower motor resistor
  212. Carnage!!!
  213. Hypertech Power Programer
  214. fiberglass cap question
  215. new custom badge
  216. 2002 dakota abs problems additional
  217. 2002 dodge dakota awd abs problems
  218. Darn Propane
  219. Blown transmission...options?
  220. Lookin' at 2nd Generation Dakotas....
  221. Traded a Z28 for a 99 dakota r/t
  222. 1999 Dodge Dakota Sport 4X4
  223. 1998 Dodge Dakota 2.5 engine
  224. 00 dakota help w master/slave cyl bleeder
  225. 1999 Dakota 4x4 Auto trans interchange
  226. Stopping by...
  227. An Early Christmas Present
  228. tilt steering column
  229. truck stalls when put in drive
  230. Gadgetman groove
  231. Snow!
  232. Check engine light
  233. mirrors
  234. Check engine light
  235. Dotm
  236. Sensor Bolts
  237. Looking to buy a pickup; any old Sales Brochures?
  238. power doors and power windows
  239. HELP with suspension issues
  240. Small squeak,help wanted...and needed!
  241. my 98 dokata radiator
  242. bad pcm?
  243. dont know were this connector plugs in
  244. clutch problems? unsure.. help
  245. Some Misc. Parts
  246. What are the stock gears...?
  247. 97 dak 3.9 no spark
  248. Wtb fog lights
  249. DOTM Dec. Come Vote!
  250. Passenger Side Window
