PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. shocks - again
  2. Transfer Case question
  3. Rearview mirror falling down , falling down !
  4. 04 Dakota power steering pressure hose
  5. actual resistance on an ignition coil
  6. lowering ideas
  7. Brakes Pulse While Stopped 98 Dakota
  8. Roaring front end
  9. 2000 Dodge Dakota wiring for radio
  10. To shift kit or not to shift kit
  11. how bad is the job of replacing a water pump on a 318?
  12. drive shaft part id
  13. Steering Idler Arm
  14. Just a huge Thank You!
  15. Some advice would be great!
  16. win
  17. Rear Diff/gears
  18. idle shake no idea what it is
  19. opinion on exhaust
  20. water pump bolt
  21. water/meth injection
  22. 2000 dakota won't shift out of 4WD
  23. Frame paint & undercoating
  24. Transmission - Dealer Can't Figure It Out
  25. little black box
  26. My A/C won't charge above 35psi? Any ideas?
  27. transfer case on an auto trans able to go on a manual trans?
  28. Resetting the computer
  29. help my trucks a complete disaster
  30. What's your gas mileage?
  31. 04/3.7 keeps blowing trans fuse while towing
  32. 2002 Dakota, 42RE, 3.9
  33. Where to buy engine emblem (V6 Magnum)
  34. ideas for exhuast tips
  35. Pulling heads on 4.7
  36. Checking in
  37. 98 sport destroying transfer cases
  38. 1999 Dakota 5.2L CEL on, OBD2 not talking
  39. 2000 Dakota SLT Funky Electrics - First Post
  40. Dakota overheating/leaking coolant
  41. Top ball joint rivets removal made easy
  42. Cam/Crank sensor issues
  43. Cleaning my garage.
  44. Shift kit
  45. Tie rod end problem
  46. TPS Wires chewed
  47. Might be a new owner!
  48. valves
  49. Seriously, sliding the tires BAD! [+story]
  50. Looking to buy 04 Dakota
  51. 98 Dakota 2.5 won't start
  52. Aftermarket trans controler
  53. 5.2L Stroker
  54. How to remove the grill from a 04 Dakota
  55. Driver Side Window Problem
  56. 5.2 dakota engine problems
  57. Update 2001 4.7 just up and died
  58. 3.9 02
  59. diff fluid checks
  60. Dakota 4.7 cold start problem!
  61. Mirror Connectors & Terminals
  62. New Headliner!
  63. 03 5.9 pcm
  64. 3.9L v6 upgrade to v8
  65. 04 w/ 3.7 transmission question
  66. 2000 Sport - No heat after replacing top radiator hose
  67. 2001 Dakota 5 Speed Shakes while switching gears
  68. Looking for rust repair panels for bed
  69. 2002 Dakota 3.9L Exhuast
  70. Removing engine decal (near front headlights) on '99 Dakota
  71. exhaust choices.
  72. So tired of putting money into it! Help please!!
  73. need help!
  74. muffler pick!!!!!!
  75. AC Relay
  76. P0172 fault code. Nude women.pole dancer.
  77. Performance Shocks
  78. Bed swap
  79. Water in Drivers side
  80. Herculiner vs Dupli-color bed armor
  81. speedometer not working
  82. Odd noise
  83. t-case?
  84. Wanting to modify my Dakota Sport.
  85. does your truck whistle?
  86. Removing the wheel well insert Help 98 Dak
  87. ABS and Park Brake lights
  88. Ridiculous Front End Hum
  89. 2001 Dakota R/T
  90. 1999 Dodge dakota starting issues.
  91. 2001 Dakota SLT Leaf Spring shackle
  92. Rear End Help
  93. Lost all electrical? On the road, could use help!
  94. Aftermarket HUD?
  95. wheel spacers
  96. dodge 4.7 chip?
  97. My truck
  98. unknown Dakota issue
  99. 2002 dakota & 2007 mazda 3
  100. Awesome truck i saw today!!!
  101. New Tire Pics
  102. dakota hotcat
  103. 2002 dakota alignment issues
  104. sway bar delete?
  105. ball joints
  106. engine stumbling
  107. Defroster and floor vents work, but not my dash vents?
  108. P0132, bad sensor or wiring??
  109. are all my problems related? e-fan a/c overheating
  110. 2001 Dodge Dakota - Revving high and jerjink into second etc
  111. Rear brakes and abs light
  112. My Herculiner Bed Liner Project
  113. Loud Squeak
  114. Clutch master keeps going out
  115. o2 sensor swap
  116. straight pipe?????
  117. Emissions inspection: Sensors not ready
  118. What is this hole for?
  119. New Guy Shopping for a Dakota
  120. engine stuttering
  121. Speedometer not working. ABS and Brake light will not turn off.
  122. Steering Shaft question
  123. 98 Dak 2WD front bushing replacement?
  124. Vendor For PCM
  125. Fuel pump problem?
  126. smokes only when
  127. ps leak
  128. Ever seen a tool like this?
  129. Body Lift Installed - Pics
  130. 2001 headlight issue
  131. motor swap
  132. Selling camshaft kit
  133. 2000 Sport 2.5 - how do I access spark plug #1
  134. transmission swap
  135. Body Lift Install Help - Steering
  136. Steering shaft
  137. lots of play in the steering
  138. Fuel Rail Removal
  139. 2003 Air Bag Light
  140. exhaust for my 04 dakota with 3.7l
  141. Tire Sizes
  142. 2000 Dakota 4.7 won't turn off
  143. Dakota Transmission slowing truck
  144. 98 Dakota front tire rubs frame all of a sudden
  145. The new ride
  146. random starting issue
  147. suspension issue ??
  148. 00 RT with ABS and BRAKE light on?
  149. second try
  150. Transfer case clicking
  151. 98 3.9 tcm
  152. HELP Please
  153. Lift kits
  154. Intrepid Trans Problem
  155. 99 3.9 Hard to start
  156. transmission starts off in 2nd
  157. finally made my custome exhaust!!
  158. Need Help - front dif bolt
  159. v6 backfires need help
  160. dakota v6 engine and trans proble
  161. Transmission Question
  162. how much is a 4.7 worth?
  163. Trans Question - Pic Included
  164. Missing On Six Cylinders.
  165. Rad Removel
  166. 2000 Dakota steering problems
  167. 1998 Dakota Speedometer Recalibration - Clarification
  168. Durango doors
  169. AC Drain
  170. Changing Color of Odometer
  171. is it possible to swap a 5.1 into a truck with a 4.7?
  172. Wheel assembly
  173. Window motor replacement
  174. 2004 dakota rough idle
  175. consistently overheating
  176. Is there some trick to remove a fender ?
  177. Its Time To Lift
  178. elecrical issue..moisture related
  179. Winch, PRESENT FOR US MARINE
  180. Does anybody have OBD-II MODE $06 test and component definitions for 2001?
  181. intake runner size
  182. Disabling air bag
  183. Oil Sender Bad? Now Tappet Noaise
  184. What is this plug for?
  185. 1999 Dodge Dakota Sport 5.2l v8 magnum 4X4 3.55 axle ratio
  186. Rear brake froze. Shoe adjuster stripped?
  187. Tranny line on RT busted
  188. Weight
  189. on firt try
  190. New shocks squeaking
  191. E-Brake and Driveshaft questions.
  192. Map Sensor 4.7
  193. Half shaft?
  194. 2000 Power Window Prob
  195. 97 Dakota throwout bearing
  196. intake swap
  197. Crank Position Sensor
  198. Rattle from front end, 2000 Dodge dakota
  199. '98 Dakota brake problems - rear not getting fluid
  200. Boom tube exhaust tip good or bad??
  201. SAS swap
  202. Mode $06 Test help.
  203. HID's question
  204. P0135 Code
  205. erratic idle in park
  206. Hesation and gas mileage just went down.
  207. transmission pan material?
  208. Exhaust in radiator
  209. Exhaust Manifolds 4.7
  210. 4.7 Idling issues
  211. hazards work, turn signals don't
  212. No power to the cabin blower motor.
  213. o/d button on gear shift
  214. Replacing Stereo Power Wires
  215. Ac condenser removal
  216. p0300,po305,p0306 trouble
  217. 2001 4.7 engine just quit
  218. Repairing door seam rust?
  219. how high is safe to rev engine while shifting?
  220. 2001 4.7 problem ticking or knocking loss of oil pressure??
  221. Fan issues
  222. blower motor resistor
  223. transmission problem
  224. 2000 Dakota 4.7 revs high when started cold....
  225. 3.9L v6 magna flow cat-back dual exhaust
  226. Fuel Pump Location
  227. 2000 radiator flush
  228. Dakota 2004 - Vibration Problems
  229. 99 Dakota Side Speakers and Air Conditioning Problem
  230. Had an accident :(
  231. 93 dakota bedliner fit a 2004?
  232. 1992 dakota rear bumper interchange?
  233. Crankshaft Positioning Sensor
  234. Electrical Problem
  235. Weird 4x4 problem
  236. 2001 Dakota Sport
  237. Headlight Issue
  238. intermited power failure while driving
  239. 01 Dodge Dakota
  240. Days like this are the days I love my Dakota a little more.
  241. 2002 Cruise Control
  242. Multiple P codes as read from odm read out
  243. Inner axle replacement
  244. 2002 Dakota 5.9 will not even turn over
  245. What type of leak?
  246. 02 3.9 Dakota misfire
  247. overheating need help!!!
  248. hey ya'll
  249. oil question
  250. 97 Dakota custom bumpers (in progress)
