PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Another heater post
  2. Oem tb?
  3. Milestone
  4. Foam in oil filler tube 4.7
  5. throttle body
  6. H.O cams help
  7. Car Seat?
  8. Oil Pressure Gauge Moving
  9. space behined the back seat
  10. bleeding coolent system
  11. Gearing
  12. another "will it fit" question
  13. 4x4 differential
  14. Factory tire size for 2001 Dakota Sport 3.9L 4x4?
  15. Dakota Newbie | Few Questions before buying one
  16. This can't be good... Need your help quickly
  17. swaping a 3.9 for a 5.2 need help
  18. thermostat housing still leaking
  19. Transfer case popping and grinding in reverse
  20. Do you have a grille guard/bull bar?
  21. suspension
  22. Engine troublem/Starting trouble
  23. running stupid cold
  24. Whats your dak on MPG??
  25. SRT Fiberglass hood group buy
  26. 4x4 actuator
  27. motor locked up
  28. Where do you keep your truck?
  29. Need new suspension
  30. My Radiator Froze Up This Morning(With Fix)
  31. Spark Plug Torque Value?
  32. iac valve or motor?
  33. gear ratios
  34. suspension lift
  35. Engines
  36. Everything at once
  37. oxygen sensor
  38. Computer codes
  39. my trucks suspension is play-dough!
  40. Help no spark
  41. Gibson Headers...
  42. Will it Survive?
  43. transfer case blew up
  44. Different heat range plug?
  45. transmission shop issues need advice!!!
  46. 2001 Dodge Dakota Sport Question
  47. *&&%$@#@Heater
  48. 97' 5.2L bizar Loping/Shuttering/creeping Need help
  49. having problems, startin to get angry
  50. Question about exhaust
  51. '01 Dakota tailgate hinge problem
  52. Trans slipping
  53. looking for some hard to find rims
  54. Engine Starting Problems.
  55. Bad Start
  56. my life is over. blown head gasket
  57. What rims? Pics plz!!!!
  58. Yellowish Sludge inside Oil Fill Cap. WTF?
  59. ATTN: Found a suspension lift for 2000-2002 Dakota 4x4
  60. MAP sensor and downstream O2 related?
  61. i'm done....
  62. Pivot Shaft Replacement?
  63. Crankshaft Position Sensor
  64. welding on a Dakota
  65. wht backspacing??
  66. Bulb question for a 2k dak
  67. new guy with an engine issue
  68. Well this don't look good.
  69. Another Transmission Question...
  70. New Cheap CAI!!
  71. TMR... Hate to bring it up
  72. Door Help
  73. the infamous TV cable issue..
  74. Help!! need a vin number..
  75. build sheet
  76. what a bad week. electrical issues possibly
  77. P0152 in 3.9L
  78. intake manifold has arrived
  79. Battery - Preferences
  80. Dang trannys
  81. Hey again.
  82. Help removing STK Line-A-Bed
  83. Introduction
  84. Where to buy a new fan for fan clutch?
  85. Got money.. Now I have to fix truck!!
  86. problem - 2" rearblocks
  87. trailer harness wiring
  88. my grille got chipped so now its black, pics
  89. 2004 Dakota shudder/misfire
  90. More transmission issues, go figure
  91. Changed tire size, should it make it ride so rough?
  92. Downstream oxygen sensor heating element circuit malfunction
  93. Heater Core / Stop Leak
  94. haPPY NEW YESR !~
  95. Heater Core Problems, 3.9, 2000 Dakota
  96. 01, 02, 03 Dakota Brakes
  97. Transmission Problems....AGAIN!!!!
  98. 2003 dakota heater core
  99. fuel rail fail, leaking gass
  100. Will Speakers Fit?
  101. Smell Coolant but See No Leaks Inside or Out. Help Please??
  102. Engine won't start
  103. got the superchips tuner
  104. Need Your Expertise Before Truck Goes to Garage
  105. weird overheating issue '00 Dak RT
  106. Need Help!
  107. Ram Cab lights on a Dakota
  108. Can you replace the light around the key ignition???
  109. 3.9 belt squeak
  110. another trans ?
  111. Front coil spacers?
  112. Custom Tuning
  113. whats + and whats - hooking up speakers
  114. whats + and whats - hooking up speakers
  115. 3.9l CEL code help
  116. HID switch question(where are you user!!)
  117. yes, another epic deal on ebay i just scored
  118. 1997 owners manual
  119. Trailer Towing
  120. A Few More Random Pics
  121. Changing trans filter is it a pain to do?
  122. Tire size on a 03.
  123. DIY 2nd Gen Dakota eFan upgrade with a Taurus 3.8L efan
  124. Boom head shot... wrecked the Dakota RT
  125. Ignition coil differences
  126. FS: Gibson Exhaust; 04 4.7 Quad Cab SB
  127. 2004 Dakota: Coolant and gauges issue? Anybody got an idea about what this is?
  128. would these tires fit on stock rims
  129. What's my Dak worth?
  130. Finally got pictures of my Dakota on here (Link to Album)
  131. SCT Hemifever Tune
  132. what color is my interior (med gray or dark gray) how do you tell
  133. Weird Rattle noise
  134. Rollbar
  135. 2002 Dakota Cat Replacement
  136. Changing head gasket
  137. awd ?
  138. Axles
  139. curious about my R/T idea, need opinions
  140. Considering shaker hood system
  141. Spent Christmas day changing my hub assembly
  142. Larger tires rubbing
  143. wheel offset
  144. loud medal clicking
  145. fan blower switch issues
  146. Gas Egg Smell?
  147. Any pointers on replacing Fog-lights?
  148. Is it possible to disable ABS? I hate it!!
  149. Engine Questions
  150. NACA duct hood scoop ideas
  151. Idler Pulley Bearing
  152. Super chips with 318
  153. heater core rant
  154. Changing exhaust
  155. disable the anti-theft
  156. Overheating-2002 dakota 3.9v6 auto 2wd
  157. Overheating-2002 dakota 3.9v6 auto 2wd
  158. oil leak
  159. 99 dak, 3.9L antifreeze leak, need some help...
  160. off roading question concerning flex
  161. question about lug pattern
  162. Dakota Sport 2001 wire speaker + or -
  163. help Please
  164. keep old tranny fluid, or get it changed?
  165. No Heat Problems Problems!!!!
  166. Strange un-even brake pad wear
  167. P0138 p0158 won't go away
  168. engine wont run..
  169. 4.7 to 5.9 swap
  170. 2002 dakota won't start
  171. Put on you thinknig caps, 2002 dakota won't start
  172. 4.10's and mileage
  173. Front Sway Bushings
  174. My first load in the new truck
  175. '04 Auto Trans Question. Weird happening
  176. Looking for 2003 Dakota Service manual
  177. Fun times on the highway...
  178. jeep TCM mod
  179. heater hose verification
  180. H.O Cams installed!
  181. trans will not shift to 1st
  182. Truck died while driving. What the?
  183. Doors & Windows Freezing Up
  184. Transmission Issue
  185. Reconstruction. Pics!!
  186. power problems, Battery?
  187. ash tray bulb and so on
  188. need help, putting in speakers right now
  189. 2002 Dakota - No reverse torque
  190. new truck..new issue?
  191. winter prep
  192. Transfer Case compatibility
  193. No heat?
  194. Rough starting
  195. On the topic of brakes...
  196. I have a little money= tune up. plus ???
  197. Dakota SLT Badges
  198. Brakes...general maintenance...
  199. Need Heat
  200. all wheel drive ?
  201. What should i do to my truck
  202. 02 4.7 overheat help
  203. wrecked my truck (kinda...w/ pics)
  204. '97 automatic problem
  205. Just Joined Today !! /Truck Cap Question.
  206. wont idle
  207. Help - 97 3.9L Won't Start...
  208. hit big rock, how bad is it???
  209. New trans question
  210. Need Fog housings
  211. 98' Dakota Starting then Dies
  212. New wheels, question though
  213. Can you program key fob without oringinal???????
  214. Lets create a beast!
  215. sub locations
  216. radiator runs low of fluid but reservoir stays full?
  217. Bumper Covers
  218. Antifreez overflow
  219. Trans rebuilder in NEW Wisconsin?
  220. Gas Mileage (Winter Edition)
  221. transfer case
  222. intermittent stalling problems
  223. Just ordered new led dome light
  224. replaced the cv shaft and...
  225. front bumpers
  226. need help
  227. What rear do I have?
  228. Check out this Dakota
  229. Anyone wanna Sell everything to do a complete 5speed swap for a 318 4x4?
  230. How's it going
  231. Bought a dakota, horrible MPG.
  232. 2004 8.25 rear end
  233. in cabin pressure
  234. Transfer Case Problem 02 Dakota 4.7 Auto
  235. 2001 dakota 5.9 ?s
  236. Getting ready for winter!
  237. Heat working but not really??? Thermostat???
  238. Added driving lights
  239. '01 A/C Freeon problem
  240. another idle problem
  241. Need help with rear tire wobble
  242. Caster Adjustment
  243. Just Upgraded
  244. convertor lockup Q
  245. Weird intermittent problem
  246. 440 2000 Dodge Dakota
  247. need bed extender for 97 Dakota
  248. speedo calibration help/tuner question
  249. HELP no power to fuel pump!!
  250. tire pressures and plugs
