- Transmission Identification
- Miami, help
- 2002 Dodge Dakota has anyone else had this problem?
- Setting ride height and compensating for leaf spring sag
- 2002 Dakota long crank
- 97 3.9L 4WD will not start
- 1996 Dodge Dakota 3.9 V6 magnum 2WD.. will not start
- 2004 Dakota keyfob/door locks issues
- Dodge dakota rt 99 It stopped turning on, there is no positive in the ignition coil
- 2003 Dakota 3.9L Bank One Misfires
- Brake hose lock lose on rear brake line
- 2003 quad cab sxt water pump
- passenger headlight dim not working
- Question on rear end fluid change
- 1999 Dodge Dakota
- engine swap
- Brakes pull to the right
- Truck dies in reverse when letting off gas pedal
- What's This Connector in between the ABS Module and Master Cylinder
- Steering Column?
- Electrical problem
- wrench size??
- Multi cylinder misfire?
- What's this connector
- Fan Shroud
- No shift from 3-4
- Suspension bottoms out after new lower control arm 2000 4x4
- 318 Mangum Rebuild
- A/C problems
- Other preventative maintenance while installing head gaskets.
- Deja-vu... all over again!
- 98 Dakota 5.2 Swap PCM?
- Long crank every time
- 2000 5.9 4 Wheel ABS Pump
- 2002 Dodge Dakota headlight issue.
- Oddly specific circumstances with a cylinder misfire.
- Transmission filter question & misc
- Wheel stud question
- Electrical issues
- 02 Kota 4 High
- 1999 Dakota cluster issue
- Floor panels
- P0121 code 2003 Dakota
- PCM replaced now new problems, are these all the same hardware?
- Excessive idle speed (1200RPM) hot or cold
- replacing the Oil pressure sender
- Codes my 2003 dakota is throwing
- 5.9 magnum cam bearings.
- which truck do I have??
- shifting woes...
- 408 - Oil stuck where?
- 02 R/T gear selection indicator
- Broken bolts in lower intake.
- Need some advice on my swap please.
- Need Detailed schematics
- Thought I had fuel???
- 2nd gen Durango the same?
- 2001 Dakota base head unit/display question(s)
- Mopar OEM thermostats
- ‘02 Dakota stock exhaust
- Very puzzled
- Fuel pump cutting out (electrical issue)
- No bus no start
- 2004 Dakota O2 sensor query
- 2004 Dakota towing package OEM radiator
- 2000 dakota 5.9l 4x4 engine swap
- P0 320
- 2001 Dakota Cruise Control Not Working
- 2002 Dakota headlight flash
- Do Oxygen sensors HEAL or SELF CLEAR?
- Engine swap need help
- 03 Dakota Engine Swap
- Differential fluid
- Painted the bumper!
- 2004 idles rough at startup and loses power briefly
- 97 dakota transmission compatability
- Bubble in NEW headliner. Possible fixes?
- Ignition switch power wire
- 1997 Dakota
- Bigger throttle body?
- Control arms
- help finding hoses for 2003 Dakota P0442
- 1998 5.2L Fuel Rail Cross Connect Hose Leak
- 98 Dakota 5.2 no start just replaced engine
- Manual Transmission Conversion
- Strut bushings finally replaced!
- Misfires
- 2004 dodge dakota won't shift new rebuilt transmission
- Oil pressure acting up
- Steering knuckle
- Sick and tired
- Engine Mounts
- p0138, p0141 - 97 dakota
- Steering knuckle
- 2000 3.9 10mpg HELP
- Engine swap for a '01 Dakota SLT
- 5.9 heads on a 5.2
- Pinion Bearing? Axle Bearings?
- Ignition coil screws
- Engine swap concerns
- Cruise Control Parts
- Might be tcm issue or tranny is goin??!
- Which is easier ?
- 2003 3.9 V6 Automatic
- Rear Main Seal Advice Needed
- 10 Inch Brake Backing Plates
- Gen 2 Dak 4.7
- 98 Dodge Dakota aftermarket Sunroof
- 1998 Dodge Dakota Sunroof handle
- Dakota 4.7 Fuel Rail
- 3.9 V-6 Fuel system
- Clutch selection for Dakota 4x4 3.7L
- 02 Dak weird electrical issue
- Best 5.9 cam
- No bus crank no start issue on 02 Dakota 4.7
- 2000 dakota cooling system.
- 2004 dakota 2wd lift question
- Dakota 3.9 to 5.2 swap injector wiring?
- '02 Dakota climate control question
- Can’t Communicate With Scanner
- Stuck brake pedal (2003 Dodge Dakota)
- Propane/natural gas smell
- Vexing issue at idle
- Belt tensioner question
- Cylinder 5 misfire fix
- Temp gauge not working
- 1st Gen Dakota, suddenly won't start
- Most Lift w/ Stock Pushrods on a 360
- 2000 Dakota Clutch Disengagement Issue
- Multi Issues
- Torque Specs
- Broken Thermostat bolt
- No sound
- No bus
- Help
- Clutch or master and slave?
- Headache #6742
- 1997 Dakota 3.9 v6. 2wd
- Missing Ground Wire?
- Service Manual (or just 42RE manual)
- 2003 dodge Dakota 3.9 has power but won't crank new starte
- Speedometer?
- Brake Issue?
- Wiper/Turn Signal Lever
- Coolant system will not bleed
- JBA Header Install in progress....
- Serpentine belt
- Factory tach wiring
- need help
- 3 O2 sensors reading high
- Transmission cooler/power steering O-ring help
- 2000 Dakota Spark Plugs
- blower fan and motor stops when I put dash together
- 97 blower motor replacement.
- 03 dakota 3.9 won't crank
- Noob question about a bottle jack.
- 2003 4.7L V8 Misfire?
- will a 04 fuel line fit a 01 dakota 3.9 v6 ?
- 02 Dakota 3.9 running light issues
- Wheels
- 42re transmission stall in reverse
- 97 Dodge Dakota security light flashing
- PCV valve
- Radiators
- 4.7 rebuild. Crank no start.
- 1999 dak 5.2L Auto 4x4 getting 10-12.5 consistently 81k original miles 1 owner
- Won’t Start
- On my drive home yesterday....
- 2000 Dodge Dakota
- 46RE STANDARD PROCEDURE - DRIVE LEARN PG 402-404 from FSM
- Engine rebuild
- What's up with my TRANS! Just replaced TC
- 1998 Dodge Daktoa 5.2L Wont Start/Fuel Pump Not Priming/Fried ECM?
- Itty bitty screws.
- Cluster problems
- 1998 2WD Dakota auto - What year/model trans bolt right in?
- Rear differential
- I have an 01 dodge dakota sport 4x4 with a 4.7l v8 my turn signals won't work help pl
- Where To Buy Torsion Bolts & Etc
- Dakota runs like crap after 360 swap
- 2000 Dodge Dakota 4.7 not starting
- ABS hubs fit non-ABS
- Rear seal
- 2000 Dakota Wrong CV Axle Stuck on Snap Ring
- 2000 Brake upgrade
- 2wd control arm nuts
- P0171 & P0201 baffled
- Center Armrest Storage Cover Won't Open '97 Dakota
- 245/75/17
- 2000 Dakota 3.9 Intermittent Misfire
- 02 dodge durango 3 inch body lift steering shaft replacement
- P0888 with no symptoms
- Diagnosing Dakota no start
- Seat foam core revisit
- 99 Dakota Front Suspension woes
- Caliper pin on 2002 Dakots
- HELP-2002 Dakota V6 3.9L(219k miles)-STALLING OUT
- Updates coming... 12 hole injectors + 03 Intake
- 1999 dodge dakota wont shift past certain gear
- Fuel filler hose
- I Just Got My Truck
- General Specs/Transmission Types Dodge Dakota...
- 02' Dodge Dakota Parts Cannon
- Would like to lower my 2004 Dakota
- ABS and Hand Brake Light on Dash are haunted
- Evap Codes and the fix
- Air bag light turning on and off
- What Brush Guard for 2001 Dakota Sport?
- Dakota wiring
- Swap 4.7 to 3.7. Yes you read that correctly.
- What could disable Blower and AC compressor at the same time
- Torsion bar bolts stuck
- 2003 Dakota SXT lug nuts
- Service 4wd lifht
- Suspension Mod...
- Headliner and back glass on my '02
- Weird Crank Position Sensor Problem
- Tie Rod thread pitch
- 1999 Dakota 5.2 4x4 Transmission Swap
- no start
- LongTube Options For 4x4
- Cat options for my '99 3.9L
- Tie Rod jam nut
- 4.7L - No mechanical fan, no shroud, no stat' and 90 degrees
- Vin decoder ???
- Dak slipped off floor jack
- 2003 Dakota starts when it wants to know
- Cam sensor code when engine gets hot
- Considering a 2003 Dakota (42re Question)
- experience with Champion truck plugs
- 4.7 knocking
- Front Driveshaft
- Engine overheating
- No Check Engine Light
- 93 dodge dakota axle issues
- 1993 Dak 4WD "Resto Project" Questions & Ideas
- 2003 dodge dakota brake bleeding not going well.
- Vacuum line sizes?
- unexplained engine problems
- 2002 dakota sxt 4x4 3.9 v6
- Help me help my son please
- Torsion removal
- Torsion bar replacement
- 2001 Dakota 4WD Regular Cab Short Bed Brake Lines
- Swap 5.9 to 3.9
- Front Coil Spring Question
- HVAC issue
- Unused connectors?
