- Chassis lubrication
- Remote turbo questions
- Door Panels
- brakes raise rpms?
- throttlebody swap question
- ABS/brake light on, ABS pump fuse GONE!
- Rear Block Lift on 4x4
- help with 4 banger mods
- supercharger computer ?????
- tires
- Should I buy a dakota, truthful thoughts needed
- looking for tow rating for 98 3.9 2whl dakota
- 17 byy 12 inch wide r/t wheels for sale
- check engine light p0700 code
- 97 3.8 rough idle, stalls, terrible milage???
- wont start Please help me
- left signal light and brake light problem
- Fuel gauge ... ???
- Headers
- Remote entry
- interior electrical oddities
- Door sensor?
- The age old question
- installing a s/c!!!
- Dakota hitches
- How do you replace a ball joint?
- Should I rebuild or replace 91 5.2
- Whats that DINGING sound?
- premium radio
- P0463 - Solution?
- cylinider #5 location
- keyless entry
- V8 Swap
- lowering
- 3 problems no clue please help!
- Headliner and OH Console Removal
- Bed Light install help
- Sluggish windshield wipers
- Blown Head Gaskets?
- Removing white printed letters...
- Automatic Transmission Identification
- Tail Happy-Anyone else have this issue.
- Fire/EMS
- Blower motor resistor on 2004 Dakota
- questions on rim sizes?
- control arm bushing replacement on 2000 RT
- Electrical problem
- need some info?
- Rear axle
- Reverse lights not working
- No Radio??? Please help
- 2001 dakota steering wheel clicking
- torsion bar lift? what and how?
- Another Question
- bell tech lowering shocks
- 2002 DAKOTA WIND NOISE PROBLEM
- 2nd ball joint in 10K miles!!!!
- polar bear products
- Who here from cali wants to hit the trails?
- Question
- 2001 quad heater blower fan not working all speeds.
- Quick technical qeustion??
- TPS and MAP sensor check light!
- '01 Dakota Low Oil Pressure at idle - New engine needed?
- Auxiliary Power Outlet
- locking diff
- tranny rebuild...$2000!!!!!
- '04 dakota body lift + push bar = possible?
- NEW TO FORUM
- 2000 Brakes upgrade to 2003 Dakota's style??
- How to tell if I have 4-wheel ABS.
- which tranny???
- whistling noise in cold weather...
- New images
- supercharger?
- First post - easy tranny question
- Fastman TB installed today
- 01 SLT
- Aftermarket fog lights?
- sunroof
- Maintenance and roof console on a 2000 SLT
- dont wanna get reamed again!!
- Oxygen Sensor!
- selling...but still dodge.
- 04 V8 VSS
- headlight wire??
- Blower Switch Replacement "Solved"
- Getting trouble codes
- Rough Ride
- parking lamp wire rubbing???
- Check engine light codes
- 1999 dakota check engine light
- tires
- swappin motor
- 4.7 high output upgrade kit
- ABS/brake light on, no speedo problems
- 99 Dakota died
- 2002 Dakota stuck in park
- poor gas milage!!!rough Idle
- 2001 dakota 4x4 problem
- 2004 Dakota mud flaps / splash guards?
- Muffler installation--Tips?
- Stereo removel 2003 diffrent from older versions
- Potential New Dakota Owner
- heater
- PCM Question
- looking for headers
- gas mileage with larger tires
- normal temp. range
- swaps
- trans
- trans
- Fun in the snow!
- 99 dakota fog lights do not work
- hard steering
- Parking lights won't turn off on Dakota
- Repair Manuals
- Superchips for 4.7 ??????
- Rough starting
- tint
- Another 1999 5.9 R/T question
- Turbonator question
- Looking for Opinions on Exhaust Systems.
- rattling/bumping noise when in 4 wheel drive
- wiper blades for 2002 Dakota ??
- please post pics! where do you have your exhaust exit?
- Please Help!
- 42RE band adjustment
- 4x4 indicator light not working?
- Looking for a truck
- problem with window wipers (newbie)
- One dim headlight
- what and will the 5.2 swap work please help
- can a 5.2 engine swap go perfect in a 3.9 f
- 2003 SXT ??????????
- Dome lights and radio.
- Second Trans Rebuild?
- Dakota Steering Stabilizer
- Power steering pump
- Exhaust Help
- ANYBODY heard of Truckin' Suspension??
- 94 dakota 318
- Bosch oxygen sensors don't work well
- WTB Altezza tail lights
- 2001 Hard start problem (newbie)
- 2000 5.9 quad
- 2000 5.9 quad
- 99 dakota water pump bypass hose 3.9 V6
- 5.2l roller rockers
- Fumoto Oil Drain Valve
- Hypertech vs new ECU
- Gas mileage dropped
- Timing Chain
- new shocks in
- Blue Light!!!!!
- 99 dakota w/ 318 doesn't idle when cold
- Good News to share
- gear shift stuck in park
- Need to do a Tranny Flush?
- 2000 dodge dakota brake pulsation
- 1999 5.9 R/T questions
- Flowmaster, Gibson, Borla....
- 2000 Dakota 4x4 question?
- transmission filter(s)?
- Newbie here...Tell me what you think
- radiator
- transmission fluid?
- Question about some 20" wheels
- 2000 abs question
- In-Channel Side Window wind deflectors
- Tranny issues
- 99 dakota dual exhaust question
- Tranny Fluid
- 3.9l Intake manifold gasket leak
- Shell
- 97 dakot problem help needed asap
- Muffler
- Reving at constant speed
- Synthetic Oil Question
- Removing Oil Pan
- v8 5 speed HURST shifter problems
- LOWER HEATER HOSE IS COLD
- fuel filter question??
- 383 Magnum Engine
- Tires
- Front bumper removal
- Torsion bar cranking good or bad?
- Truckin suspension lift kits?
- Running bad, any suggestions?
- code #p31?
- wheres the ignition harness
- 02 Dodge dakota tire question
- Stereo replacing
- Noisy power door locks
- Users Manual?
- Aux Power Outlet
- BUYING DAKOTA GOT SOME ??'S
- Intermitent Electrical Drain
- load air suction
- Bogging down from stops
- the tall curb and my undercarriage
- Annoying throttle lag in my 2001 4.7 QC
- lowering a 4x4
- suspension questions (hauling with a lowered truck?)
- Rims to check out that will go on my 01dak
- next power mod
- need some help on modifying my truck
- engine codes
- Front Shocks on 02 Dakota Sport 4x4
- 98 Dakota-no second gear-auto
- windshield defroster not working! help?
- Removing Dash Trim
- interior &exterior lights inop & service 4X4
- FOR SALE: 1998 Dakota 4x4
- read window defroster/heated mirrors
- subs/speakers '01 Dak QC
- tire spinning
- Blower Motor Resistor
- Vibration
- NEED DAKOTA INFO PLEASE!
- tires rubbing
- Dakota R/T ECU
- Borg warner wires?
- Have to find out how to pull engine light codes, can anybody help?
- rpm's at idle
- New Dakota
- Bed Sizes
- torsion bar adjustment
- water into the driver side only?
- heated seats
- frt brk feedback
- cold air intake
- web site help
- Rust in rear quarter around wheels
- Dakota r/t speedomiter won't work plz help
- Experts only!!!
- No Heat
- New Dakota owner with odd front end sounds
- Like to change out my headlight bulbs.
- drop
- MOVED: any one selling?
- oil in coolant
- a kina funny thing just happened
- stock TB size
- Another plug wire question lol
- New Member ?'s
- Clutch fan roar
- Well new heater core is in....
- convience console install
- Is this normal?????
