PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Creaky Steering - Low Fluid
  2. 2001 Dakota 4X4 towed behind RV
  3. Engine swap questions
  4. Standard bed size
  5. where to get rims?
  6. 2004 Dakota gear shift lever question...
  7. Do our trucks have chip keys
  8. Clunking noise
  9. Starter went bad while on a trip
  10. 97 Dakota, poor heat, not normal
  11. 2002 Dakota drive train Question
  12. R/T trans cooler
  13. What? No headlight fuse on a dakota?
  14. No high setting on blower
  15. 99 Dak Poor Heat
  16. Changed battery, Now the truck will not idle
  17. Grinding noise on startup when its cold
  18. Oil Problems
  19. quad cab roof rack?
  20. 2wd Dakota Suspension Lift
  21. voltage drop
  22. Pre-Purchase Advice - 2000
  23. What year transmission will fit?
  24. 99 dakota blower fan
  25. Intro and issues 2001 Dakota Sport, Auto 3.9L Quad CAB 2WD-
  26. Headlamp Question
  27. greenhorn
  28. cruise control
  29. No power steering 2001 4.7
  30. How to bypass 4wd shift
  31. Correct Center Caps for '03 Dak
  32. Wheel Question
  33. Remote Starter Issue
  34. Autolite
  35. Electronic shift will not work gone through everything
  36. Clunk While Slowly Braking
  37. cold weather engine vibration
  38. a/c electric cooling fan, over heating with plow
  39. confused
  40. 97 dakota 4x4 v6 intemitent stall no spark
  41. Brake bleed DIY
  42. 3 Bad Alternators and 2 Bad Batteries?
  43. 2001 Dakota SLT Radio
  44. cv shaft c clip?
  45. 2000 Dakota no start
  46. Hot oil smell when I turn engine off
  47. Valve Cover?
  48. cleaning wheels?
  49. shock touching upper a arm?
  50. Steering Issues. Maybe gear box?
  51. How to check idler pully?
  52. bouncing
  53. Front Wheel Bearing Replacement--Two questions
  54. Soft gas pedal when cold
  55. 70MM throttle body BBK, Item 7321
  56. 1998 dakota 2.5 Bored .060 over, Trouble Code P1391
  57. PCM pin out/schematic? 97 3.9l v6
  58. driving lights
  59. Front Steering Shaft problem
  60. NO HEAT How to Fix
  61. 00DAKDAN, or any one else is welcome
  62. Battery died in my ’04 – just a heads up
  63. help engine code 0622
  64. help
  65. very little heat
  66. rear diff. exchange
  67. Are these lug nuts ok to use? White Knight Acorn
  68. does front diff. need limited slip additive?
  69. Burning Smell on First Start Up
  70. 3.92 Rear End With Magnum 3.9
  71. P01391 and P0305 codes, loss of all power
  72. Which fuel injector brand / style
  73. Falken A/T tires
  74. Heater issue 2002 dakota
  75. Changing out stock audio system
  76. Parking brake gone soft
  77. 03 Dakota 4x4 Clicking on dry pavement
  78. Crashed Dakota, Need help (PICS)
  79. Blower motor burn out.
  80. Difference in a grille guard
  81. 1997 dodge dakota
  82. Lift
  83. Peeling clear coat
  84. Refilling coolant...stupid question inside.
  85. 1998 Dodge Dakota
  86. Front hub question
  87. Code P1494
  88. Wiring LED Interior Lights to Headlight Switch
  89. Truck wont start
  90. Gremlin in my Chargeing System
  91. Stroker Crank Question
  92. Tube Bumper Build
  93. Keeping door locks unfrozen
  94. Mounting a gun safe in a 2004 Dakota QC?
  95. 2000 Dakota 4WD not engaging
  96. 2001 Dakota Windshield
  97. 1997-2004 Front Seats
  98. 97 Dakota Cold air on Passenger side
  99. Lift Question?
  100. Need assistance with wiring my heated seat kit, please?
  101. Lifter Removal Tool
  102. 2.5l Question
  103. '01 dakota trans issues
  104. o2 sensors??
  105. 2003 Dodge Dakota
  106. 02 Dakota - P0551
  107. Check Gages Light - Oil Low
  108. Front wheel bearing on a '98 2wd
  109. Grille Guard
  110. 04 dodge dakota quad cab
  111. body lift
  112. Top end rebuild, rods and arms need help
  113. door replacement
  114. Coolant Leak..... Somewhere
  115. question about bypassing a/c compressor
  116. Help remote starter search
  117. Halo Headlights
  118. Driving lights
  119. Misfire+ sys rich+sensor circuit HV 6 cyl
  120. 99 Dakota Idle Stall
  121. lifters and stuff
  122. adding second battery
  123. mounting CB/HAM radio in cab
  124. 2001 Dodge Dakota problem
  125. 2001 quad cab won't accelerate
  126. #5 plug comes loose then tightens up again
  127. Reprograming 42RE Transmission
  128. 98 dakota, No overdrive, high oil pressure..
  129. Front Suspension Retrofit?
  130. Low gas milage
  131. 2002 Fuel pump regulator grommet
  132. Bushing and bump stop ?
  133. crazy Dodge Dakota 2002
  134. I got a 97 dakota 2.5 5spd tune up
  135. Build threads?
  136. replacement upper control arm
  137. 2004 Key/Remote combo on a 2002
  138. Coolant Temperature Sensor - where
  139. Ping with SCT
  140. 98 cooling issues
  141. what fits what
  142. re-using oversize brake pins / upright/spindle assy
  143. Antifreeze smell in air
  144. Tachometer Bouncing, Engine Reving
  145. weird transmission issue.
  146. TV Cable Question
  147. 1999 Dodge Dakota will start but dies when putting in gear
  148. steering rack leak
  149. 02 dakota lower ball joint
  150. Guage Issues
  151. Idle RPM problem
  152. terrible acceleration
  153. Odd behavior in OEM Security System
  154. 03 Dakota 3.9 V6 Tow Performance
  155. Sonnax Line Pressure Booster
  156. 2002 dakota 3.9 runs very rough
  157. 2000 Dakota
  158. Transmission Whine
  159. recepticle that matches electric fan
  160. HELP!! Just put 15 inch wheels and tires on and rubbing on inside lip of rim
  161. 1998 dodge dakota sport - seriouse backfiring
  162. Transmission help please!
  163. Need some tranny help :(
  164. No bus on odometer, blinking engine light -- Help please!
  165. ABS light
  166. will 15" wheels fit a truck that came stock with 16's?
  167. few cam questions.
  168. Lost reverse - please help
  169. 03 Quad Cab max tire size
  170. Heater motor or resistor?
  171. cv axle problem
  172. 2000 4.7 Dodge Dakota Electric Radiator Fan Not working
  173. Keeps throwing p1281??!?
  174. Tom Fox PCM Flash
  175. sun roof rear window install
  176. Tire/wheel well problem, can shake back and forth by hand
  177. Annoying Belt Sequel 1997 5.2
  178. No CCD (-) Wire on my OBDII plug
  179. 4.7L Cam swap
  180. heat not working
  181. No CEL but P0455
  182. bad spark plugs?
  183. have spark but no spark to my plugs ???????????
  184. Headlight problems
  185. 98 cruise control
  186. backup lights
  187. electrical plug
  188. 99 Dak getting old
  189. 2003 Dakota 4WD Erratic
  190. Heater Odor
  191. power window problem
  192. Emergency Lights, volunteer fire/ems/police use
  193. has anyone had problems like this? i need serious help 98 Dakota 3.9l v6
  194. air bag system?
  195. ideal is high at start up
  196. Problem dodge
  197. Generic CAI Question.
  198. dodge dakota no spark to the spark plugs coil is good help
  199. Transmission Questions
  200. Injector circuit open Dodge Dakota 1999?
  201. The real skinny... Durango seats in a Dak?
  202. Gas Monkey show
  203. 2002 dodge durango slt 4x4 P0138
  204. Urgent Help Needed. Knocking Noisr
  205. Electric fan size?
  206. CTM C2 Connector
  207. shorter belt???
  208. Need a 4.7L for a 00 what works?
  209. 03 Dak threw a B**** fit
  210. 97 dakota transfer case exploded
  211. Sensor Idenification
  212. heater is junk!
  213. High altitude operation ???
  214. Lengths of the battery cables on a '98-318?
  215. 2001 Durango > 2000 Dakota parts interchanability
  216. Mopar Performance cast valve covers; which ones fit?
  217. Good Brush Guard / Roll & Light bar
  218. Gurgling Noise from Behind Dash and P0455
  219. New to me 04, oil pressure problems and cruise quit working
  220. Single cooling fan?
  221. My new daily driver !
  222. Front Wheel Bearing and ABS...
  223. Rear Driver Blinker Not Lighting
  224. 2000 Dakota Question
  225. P0432, bad cat, info needed please
  226. Wheels for 2wd dakota
  227. No stock fog lights, want to install some
  228. ABS noise, no light
  229. 01 Dakota
  230. Torsion bars on a 2wd Dakota
  231. Tune up
  232. Thinking about buying an R/T
  233. Hi all been awhile
  234. Maximum Cooling radiator
  235. Best oil filter for 4.7?
  236. Bump Stop Replacement
  237. P1740 Code and Inspection Question
  238. Body Lift Pics
  239. 2002 Dakota Parts manual
  240. Inner tie rod replacement, 99 dak
  241. Engine won't stop accelerating...Hits Max Rpm as soon as you turn it on
  242. 1st post - Just picked up a 250K Dakota
  243. 02 Dakota Caliper bolts/pins
  244. Engine wiring harness
  245. Starting issues HELP
  246. Are 00 and 02 Dakota engine interchangeable
  247. No Start Dakota
  248. passenger power window problems
  249. Rear Diff Issue !!!
  250. 99 Dak Just stops
