PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Heater control Valve?
  2. Strange related (or not) issues and trans temp
  3. front drive shaft removal
  4. Win a Sony Playstation 3 (PS3) or Gran Turismo 5
  5. Center of wheels?
  6. sticking steering
  7. ? on seats
  8. HO cams, did i get screwd???
  9. Need instruction for changing fan clutch
  10. Magnum v6 cps location- can't find
  11. front end mystery.
  12. Keeps losing power steering after new pumps
  13. Click When Accelerating
  14. Truck Stuck out of town, need help
  15. bad mpgs on my dakota
  16. new to forums
  17. Spark Plug, Distributor Cap, Rotor install update w/pictures
  18. No Heat
  19. dont know what it could be
  20. dual fans? (dumb noob question)
  21. Fog Lights Kinda Work
  22. 2000 3.9l exhaust manifold bolts
  23. Hid kits
  24. 2000 Dakota SLT Loose Steering
  25. Timing issue
  26. 02, Dakota, 4x4, V-6 3.9 Powertrain Control Module
  27. Air intake system?
  28. Got her
  29. Shocks for 2000 Dakota Quad V6 Suggestions???
  30. Did I miss anything for the tune up??????
  31. choke/stalling out, air fuel adjustments???
  32. Antifreeze leak question.
  33. Bad news and good news
  34. weird clunk/rumble
  35. noise and grind at speed
  36. New member...got a question.
  37. Is this sound normal
  38. 2000 4.7 no start
  39. Gear change for better mpg's?
  40. Rear tire wobble
  41. Urgent Mistake Alternator Ground?
  42. 2nd Gen and the '04
  43. Dakota AWD question
  44. Summit Racing Distributor Cap/Rotor/Wire Kit GOOD?????
  45. Towing a 4WD truck possible?
  46. new hood and ram air intake question
  47. idling issue
  48. Rack and Pinon Tubing
  49. Truck won't start
  50. Help!!!! Tranny stuck in 5th gear!
  51. door lock makes a loud noise
  52. best throttle body spacer
  53. Whats the calculated rev`s per mile on the dakota speeometer ?
  54. urgent please help
  55. will not idle
  56. I need to stay off Craigslist: Rare Dakota Follows me home from vacation
  57. wheel studs, glad we have 6!
  58. 2000 2wd rack removal
  59. Heater Core Help
  60. Leveling my Dakota
  61. Lowering a 3.9 2nd gen
  62. tire size with lift
  63. lift
  64. 1997 Dakota help.
  65. P304 Code: Loud Clack Sound
  66. 4WD making a nasty noise...HELP!!!!???!!!
  67. Dakota VS Train, Dakota wins!
  68. Pitman Arm 98 4x4 Dakota
  69. lucas oil stabilizer
  70. 2000 Dodgd Dakota - No HEAT!!! HELP!!! ITS COLD HERE!!!
  71. 2003 Dakota 4.7 engine /cooling issue
  72. brake problem
  73. 3.7 L Clutch Fan Removal
  74. rear end noise
  75. Do I need re-gearing?
  76. need to know the correct tooth count on speedo pinion
  77. 01 front suspension, NEED HELP PLZ
  78. Urgent help needed
  79. Question about NGK V Power plugs and wire set for a 2000 Dakota V6
  80. Weird sound when turning steering wheel
  81. Signal light issues-1999 Dakota
  82. Adapters
  83. Jerky when turning in 4x4
  84. T.p.s question
  85. slip between 2nd and 3rd.will band ...
  86. heater no workie!!!!
  87. Wheel spacers... HELP!
  88. Death Flash
  89. December 18th Toy Drive - 1:00pm (Toys for Tots)
  90. front end noise...shocks?
  91. tie rod question
  92. 99 Dodge Dakota 4X4 V8
  93. 99 dakota wheel bearings
  94. dont know random miss fire
  95. mystery vibe...
  96. Performance Questions
  97. rear swary bar bushings
  98. Looking at 2 trucks but need advice
  99. bumper replacement
  100. same question
  101. 1999 dodge dakota leaf spring shim
  102. Gear Selector not lining up on cluster
  103. First Dodge Dakota (2000) Few Questions
  104. Low and High transmission band adjustment
  105. Skid pl8 / undercarrage guard
  106. trannys
  107. Check engine Light please help
  108. Temperture Control
  109. Transfer case noise
  110. 97 Dakota oil pan/differential removal questions
  111. Transmission shifting to soon 2001 5.9 Auto
  112. 2004 Dodge Dakota Rear end costs?
  113. tune up options for the 3.9L v6?
  114. 4x4 light question
  115. 2003 Dakota Auto Trans Shifting issue.
  116. Need a little input
  117. Quick cb antenna question
  118. Air suspension lifting
  119. 1997 Dakota Cummins swap... Parts $s ???
  120. Ash Tray Light
  121. My 1999 Dodge Dakota won't start.
  122. 4.7 bottom end
  123. new guy,need help
  124. Add Acetone to gasoline?
  125. Not good.. Dana44 issue.
  126. Gas question!
  127. 2004 dakoda
  128. member parts
  129. gear shifter
  130. 1998 Dakota v6 won't start
  131. 3.9 engine swap 96-97 Problems??
  132. 03 Gas Gauge Problem
  133. new owner w/ questions
  134. engine starting problem?
  135. Multiple misfire
  136. tie rod ends/don't laugh
  137. difference between 899 and 898 bulbs?
  138. Cleaned throttle body, now shifts wierd.
  139. to lift or not to lift
  140. I love my Dakota
  141. 22s anyone? (pics)
  142. Just out for a little ride and found THIS...hmmm
  143. finally got pics with the new tires
  144. rear drum adjustment?
  145. painted some more stuff last weekend.
  146. Manual window very hard to open
  147. Dakota transmission????
  148. roll pan?
  149. 01 dakota fog light lens replacement
  150. 1998 Dodge Dakota opinions please
  151. 2003 V6 Water Pump Replacement
  152. new guy with question
  153. tire fitment question
  154. 4x4 shifter boots
  155. chassis lube
  156. 01 3.9 cat replacement
  157. dak 5.9 swap! will ram ecu work in dakota?????
  158. 44RE Trans Temp Sensor
  159. 2003 V6 Fan Removal
  160. 2001 dakota quad cab question
  161. Canadian Lighting
  162. kick pannel speakers
  163. lift kit
  164. Full Bumper Replacement's for Dakota's?
  165. Sooo I test drove a brand new Taco...
  166. Rpms fluctuating
  167. truck barly started this morning?
  168. Problem with stalling.
  169. No Heat/AC compressor engaged
  170. Tranny question!
  171. Just checkin out the FLEX!! check it out
  172. Nitto Tire on Facebook, LIKE to win tires
  173. new to forum-replacing starter problems
  174. 2001 Dodge Dakota Sport 4.7L
  175. Angry & Frustrated - Plenum door
  176. Is the 2004 dakota 3.7 v6 engine year specific ?
  177. Winter preparation.
  178. AC and Heating Issues
  179. remote start acting up
  180. reliable motor...I think not THREAD NUMBER 2!
  181. Sound like a good deal?
  182. Wanted Dakota
  183. 2002 Dodge Dakota
  184. 2004 2WD Dakota Doetsch Lift and Gears
  185. Panel Bulbs
  186. Engine Light wont disappear
  187. Liftin my 02
  188. 4.7 5-speed Conversion
  189. Dodge Forum Decals?
  190. New exhaust build *pic heavy*
  191. Some Random Offroad Pics
  192. Clock spring ?'s
  193. Non dak ? 04 jeep grand cherokee tranny probs
  194. 2004 Parking Brake
  195. Plug Change!!!
  196. new guy here and i have got a question about the wiring harness
  197. Is it really the Pinion FActor?
  198. Roof Rack
  199. Been a while since I've been here, U-joint question.
  200. 03 Dakota v6 Water Pump
  201. Anyone wanna upgrade Wheels ?
  202. thermostat
  203. tire question?
  204. new guy
  205. Nitto Tire on Facebook, LIKE to win tires
  206. A serious Mis-Fire problem!
  207. Truck seems a little slow?
  208. 2002 Dodge dakota 4.7 80k miles OIL QUESTION
  209. Power Steering?
  210. axel's what do you guys think ?
  211. gen 3 rear bumper on gen 2?
  212. intro
  213. low groan and a shake.
  214. rear wheel wells
  215. dakota shifter cable adjustment how to
  216. New truck! tranny question
  217. problem at 1900 rpm
  218. Improving 4.7 mpg?
  219. compatible rear ends
  220. Superchip and PCM bolt size
  221. Gear oil leakin rear pass. axle
  222. engine replaced... idles great when in gear studders???HELP
  223. Will 94 dakota rims fit on a 99 dakota?
  224. 2002 dodge dakota positrac
  225. tranny swap
  226. truck stalls when stopping
  227. Revs really loud with no power
  228. Torsion bar question.
  229. Afew questions and update
  230. Body Lift Questions and Advice
  231. torsion key bolts
  232. torsion bars
  233. What is it
  234. Help My Headlights Dont Work!
  235. Shifter cable
  236. Bad Steering pump and Rack & Pinion
  237. Trans question
  238. Just Lost First gear
  239. New Dodge owner
  240. 4 Cyl Dakota Motor Mounts??? Stealership the only option?!?!
  241. 4.7 has a little trouble starting....help???
  242. lift kit question
  243. Clicking brake noise
  244. more trans trouble
  245. An annoying squeak..
  246. Coolant leak
  247. 2000 Dakota Dim Lights
  248. Reliable motor..I think not. help?!
  249. T-Bars After Awhile
  250. On my 3rd ecm.
