View Full Version : 2nd Gen Dakota Tech
- 4.7 exhaust manifold studs/bolts OEM replacements
- tranny cooler line
- superchips for 2004 4.7l dak?
- Correct U-Joint Size??
- dealer paint
- 3rd gear problem
- blinker issues
- Rumble Bee Dakota
- stock tire size?
- Msd Blaster 3 coil.. any good?
- Just for fun...
- Mangled lug, stud on alloy-equipped 2000 Dakota--How to get off?
- Autolite 5224 or 3923???
- got my new wheels
- sound coming from engine
- 98 Dakota AC coil or Clutch?
- noise from back window
- 2000 v6 dakota not charging
- Poss Exhaust Leak - OK to drive?
- in dash dvd player
- Doors locking automatically
- wheres the computer? 2000 dakota
- Ride of the Month is up!
- Water?!
- anyone a brake expert?
- Sway bars? Towing package?
- Oil coming out of front axle breather tube
- 97 Dak Body lift
- New Exhaust - Custom
- If I were to sell
- Newest iPod "mod"
- Front & Rear Differantials
- o my jesus...
- Fuel door blow out sale for '97 - '06 Dakota
- Issue getting started.. well sorta
- air/ fuel ratio faze problems
- Sct
- rear brakes locked up and wont release
- one more fan clutch question
- 01 dodge dakota oil pressure problem
- Rear brake question
- Electric fan conversion
- cold weather smoke
- Squeaking Front End
- Rotors?
- Broken door handles
- Truck Bed Speakers
- Vacuum Ports Question 2001 4.7L
- fan clutch nut
- New 3.9 owner
- Cruise Control
- Idle issue
- Some Good Websites For Parts
- O2 sensor signal wire
- exhaust hanger question
- 2004 Quad Cab *pics inside*
- What is this world coming to!!!!
- steering is sloppy?
- Head Light Relay
- Replaced speed sensor but abs/brake light still on 2000 dakota
- Gas light, where does your's come on?
- Problem with the blinkers
- Day Time Running Lights Relay or Fuse
- body rolling
- Just did it....
- MSD 6A Ignition Installed
- FS: 180 Thermostat 4.7L
- 5.2 power
- code: 1762
- New Dakota Owner :) ?'s
- well i cant make up my mind
- 03 dakota r/t 5.9L - supercharger help
- realistic mpg's v-6 vs. v-8
- should i race?
- fender flares
- How to shift 4wd??
- Won't Stay In 2H???
- help! I need to find this heater core
- 2002 Dakota
- Ecm
- trading in
- low mpg
- H.O or not?
- Bat needs help!!
- power steering "issues"
- Issues with Overheating
- to people who have headers...
- Gear suggestions ?
- Serious Question
- hitch drawings.
- what grease to use for my u-joints
- Can't Make up My mind:S
- Anybody know what this is?
- stock rim paint ideas?
- here ya go batty!
- Spin Tech Side Exit Exhaust Installed
- Dakota light problems.
- crank and bearings
- Electric Brake Control Harness???
- Will it start? Cross your fingers!
- Help! cant drive my 97 dakota
- photoshop experts help
- cam questions
- once in a lifetime pictures
- Front Driveshaft Help
- 3.9 Sound
- P0155 - 02 Sensor code vs Cat Back Duel Exh.
- 05 Dodge Dakota, needs engine work, no reserve.
- voltage spike, regulator?
- Squeaky suspension, where to lube?
- Exhaust Sound Clips, Pictures, and Info.
- this is gonne be the best christmas EVER!
- painted my bed
- lift
- 2009 Ram on Dodge Website
- I need help finding what is wrong.
- tire help asap!!!!
- Control arm part-what is it?
- Seafoam
- what are your thoughts on injectors?.....
- Fog Light Bracket?
- Goin to Harry's :D
- Exhuast Almost done.. Pics inside.
- LMC Truck accepted the Dakota/Durango
- for those with the 4.7:D
- valve cover leak
- hood opinions please
- Egr
- throttle body spacers
- 46RE problems in my 1996 Dakota SLT
- check engine light on.
- Exhaust Manifold problem, or something??
- lower ball joints
- Possible Fuel Filter or Cat. problem?
- torsion bar
- new headlights.
- bushwacker
- Weird bliker prob.
- just when you think it's all right...
- uh-oh, please help!
- new intake manifold w00t w00t
- gotta love hail damage....
- !HELP! Ball Joints
- Increase MpG on Dakota 2001 4.7L V8
- another ??
- CEL codes p0551 & P1282 HELP!
- 42RLE or 45RFE?
- needs help figuring out problems
- P0305 question.
- will i pass emissions testing with high flow cats?
- Good looking towing mirrors?
- Accidentally put jumper cables on in reverse when jump starting our 1998 Dakota
- Body Lift Question
- Do the hoses to the map sensor get clogged?
- wheels and tires
- gage cluster
- main bearings
- dakota suspension 98 and 2002 as the same?
- painted a tank
- 99 r/t
- What in the world does this mean??? P1762 Code
- Center Console speaker box
- crazy suspension idea
- Brake swap!
- Monitoring your Truck
- Adding forced induction with a different turbo
- Supercharger info needed
- car show questions
- Looking for Headlights
- Dual Exhaust Question
- Need more mods!!
- rumbling sound
- lights
- What size brake lines on 1997 Dakota 4X4?
- nitrous questions
- I named my truck
- anyone want a dak monster truck???
- Axle Ratio Change.
- '99 dakota rear brakes...
- 00 in cab vent controll
- opinions please
- New user name!
- Need Some Picture Help
- got bored, decided to weld AND support the troops
- MIL Codes help!+ Induction Kit.
- Truck Stalling
- Site to find cfm rating for filters?
- emission code/rough idle
- Howdy and need some assistance with a P1494
- truck wobbles
- U joints part II
- Ball Joints
- Speed Sensor?
- What am i in for???
- Frame mounted EVAP box leaking oil?
- Need help with 4.7L overheating issue.
- cleaned up the Dak
- '00 dakota slt
- brake theat to end all brake threads
- just bought a dakota got a few mod ?'s
- Parting out my 98
- How do you guys make...
- Anybody have this
- Rattling noise on front end
- I have new exaust now what?!!
- found an "affordable" winter project and BOUGHT IT!!!
- i installed a super 44 on 3.9l
- Pulling starter on 99 3.9....any tips!!???
- 97 exhaust
- Couple Problems with the Dak(Headlight Flicker)
- Filling in Fog light holes
- Any videos on how to remove fan clutch?
- tranny additive
- 2000 dakota idle miss
- lowering the with blocks
- Squeaky problems
- U-joints
- truck dies out while driving
- new truck, new problems
- Engine Caming at Idle
- should i race?
- Bolt Pattern
- Tires fit?
- Larger Alternator and Idler Pulley?
- Pvc CAI
- Site to check tsbs that have been done?
- Normal idle?
- new badge on!
- new spark plugs new problem???
- Stumbles and Dies at operating temp
- i wonder
- Passenger power seat
- Iac valve hissing sound.. this normal?
- Hydrogen EFIE Question
- Lowering the rear...
- just bought 2002 dodge dakota sport
- Rear wheel speed sensor replaced, same problem still...
- Installing Fog Lamps
- Exhaust parts coming together perfect.
- not starting
- 1997 5.2 v8 dakota for sale
- Trailer Hitch Installation (Remove mass-damper)
- Programmer and flowmaster for a 2004
- power programmer/ chip question
- more power??
- Seafoam question.
- should i trade wheels
- Easy way to make a heatshield for cai??
