View Full Version : 2nd Gen Dakota Tech
- Best way to lower a 2002 2wd quad cab?
- RWD steering rack bushing question.
- Transmission stuff
- ABS/BRAKE, check engine, no speedo or trip, air bag on
- Headlight LED upgrade- which bulbs do you guys use?
- 4WD Not Engage
- new shifter
- P0734 Only in overdrive
- 97 dak 3.9 AT 4X4
- 3.9 to 5.9 swap
- Are components from the 4.7L engine compatible with the 5.9L?
- 02 dakota 4.7 no spark
- 2003 46re NSS 5 prong harness to 3 prong transmission.
- Lifted 2002 Dakota Steering issues
- Spark plugs
- Trailer/Tow wiring
- Looking at an 04 Dakota SLT, main issues I should look for?
- Motor and pcm
- 98 dakota 4x4 blend door
- Ddoddge OEM front shocks
- 01 4.7l R&R
- A Lady Rear Ended Me. Truck Totaled Hurt Neck.
- Grinding when turning left
- ABS, BRAKE light on and no speedometer.
- PCM cycling after battery disconnect?
- Guess whos back.. back again.. LOL
- What the Heck Man! I just don't even know what to say.
- AWD Dakota??
- P0455
- Security system issues
- Tune up
- Is a 5.2l cylinder head inter changeable with a 3.9l?
- Po206 and po208 issue after 3.9 to 5.9 swap
- Front End Pop
- Oil fill cap condensation
- Blown transfer case??
- Steering Wheel Lock
- Spark plug question
- vent and heat problem
- CTM issue??
- 42RLE transmission cooling line check valve
- Injector Upgrade
- best repair manual 1998 dakota reg cab
- Help 42RLE Transmssion stuck in reverse.
- Sport doors on SLT body ?
- Rear End Frame Repair
- Transmisson struck in reverse
- NV244 to NV233 questions
- Help with slipping transmission
- 00 Dodge Dakota 5.9 Cylinder 2 Misfire.
- Lets talk Seats.....
- 01 dakota
- Stalls randomly and fuel gauge drops to empty
- Brake swap
- Brake swap
- Is there a way to disable overdrive besides the button on the shifter?
- Switch to synthetic now truck smokes!
- Help me identify this part!
- No Start No Bus ASD Ticking New PCM
- OBD1 5.2 Swap into 98
- Swapping auto to manual 3.9 ECM question
- front differential 2000 dodge dakota
- OK I should know this but I don't.
- Dodge differential
- 2002 Dakota Flowmaster 10 series
- 99 dakota limp mode problem
- 2004 dodge dakota 2wd
- Brake questions
- 2001 Dakota 4.7 auto trans dipstick length
- Rebuilding rear end on truck vs a donor rear end on a bench
- 2002 Dodge Dakota Grill Gaurd
- brakes locking up when cold
- 3.9 liter swap to a 2.5l possible?
- 2000 Dodge Dakota remote car start
- TPS recomendation
- Not Starting
- 1997 3.9L crank no start condition has me stumped
- 4.7l misfire in Cyl. #5
- 2001 4.7 Knock
- '99 Dakota 2.5 shootin' steam!
- Transfer case leak
- Issue with oil change
- Thirsty 4.7, and I don't mean gasoline!
- SKF BR930361 Hub/Bearing assembly installation log.
- autotrans shifter problem
- Please help, feels like slip under light acceleration
- 04 Dakota Help
- Fender flares
- No heat/ac.
- 3.9 takes for ever to warm up.
- Blower motor resistor
- Ac Blows Strong Through Middle Vents Only
- Coolant leak
- Front brake replace
- Speedometer bouncing cruise control erratic
- Odd vibrations at idle in 3.9L 1998 Dakota 2WD
- 01 Dodge Dakota Tranny dipstick replacement?
- 2002 RT v8 tranny into 2002 v6
- I recently bought a 1997 Dakota 3.9l. All the emissions parts were taken off. I have
- This Old Hub question. Timken vs SKF
- Anyone install a manual rack and pinion?
- Drum brake system adjustment
- Mitigating parasitic losses
- Engine shuts down no codes. Every electrical component has been replaced.
- overcooling/ no heat
- Body Lifts / For better or worse?
- Dakota oil leak
- Truck stalls out when put in reverse. Parts replaced.....
- dodge cuts out while driving
- installed LED headlights now my fog lights don't work
- Where do 99 Regular Cabs usually have interior water leaks?
- 2002 dodge Dakota
- Heat issue
- I have a red check gages light on in my 1997 Dodge Dakota dash
- 2.5l to 3.0l swap
- coolant loss/no heat at idle
- 2000 Dakota Sport Climate Control
- 2003 Dakota Electrical Issue
- 04 Dakota coolant smell inside with heater on, no wet carpet
- Rust hole in bed repair
- New Dakota owner, help me identify these wires/ advice on some other issues
- Power steering pressure switch questions
- Brake dust issue
- 04 Dakota Power steering whine again!
- 2001 Dodge Dakota 4.7 overheating when idling for too long?
- Seeking some Radiator experience and advice.
- Confused about 4x4
- Replacing the clutch pack in a 9.25 without removing the casing?
- Exhaust manifold bolts
- ABS and Brake dash light coming on
- Rear differential round tab??
- 99 dodge dakota
- What is this intake hose?
- Shakes at idle, sluggish(slight, quick drop) in rpms around 2-3k
- Pipe connection after cat separating, exhaust leak P0420
- I recently bought a 1997 Dakota. Is it a full frame pickup?
- daytime and high beam lights not working
- Right side front end noise/vibration
- Looking for bed corner panel
- Transfer case compatibility
- steering wheel pops out of sync
- Key remote?
- 2004 dakota first time owner help
- 02 Dakota 4.7 post-timing replacement
- Fuel gauge not working even after pump replacement
- Replacing rear wheel bearings
- My new project
- 04 dakota knocking
- Checking water pump - without removal
- Cup holder solution?
- Brake questions - No fluid at rear driver side cylinder.
- Factory alarm or just keyless?
- looking for discontinued Dodge Part Wiring Harness -5183475AB
- 1997 5.2 Dakota hard to start in 70> weather, runs fine otherwise
- Only finding one o2 sensor on my 03 dakota
- Timken/National Rear Main Seal
- Remove exhaust manifold heat shields on 4.7?
- 04 3.7 V6 Timing cover gasket leak?
- You won't believe it!!!
- 99 club cab sport nv3500 swap need help!!
- '99 3.6L - Shifts at high RPM
- Dodge Dakota 2001 45RFE No shifting after pan drop.
- 99 dakota 3.9 to 5.2 swap
- Leaking freeze plugs on 2001 4.7 I bought yesterday
- was running great, now on the fritz
- 99 dakota 2wd. Want to make it 4wd
- dodge dakota help please
- 04 Leveling kit for 2wd?
- no headlights and tail lights
- battery gauge
- 2000 Dakota. Hot idling and throttle problems. Please help!
- 99 Dakota Non-starting/running mystery NEED HELP
- 2004 Dakota oil use and intermittent blue smoke(but lots of it)
- Trac loc. Or any rear locker.
- Has anyone swapped there stock injectors
- Turning radius
- 2 computers???
- Performance intake manifolds for 02 Dakota rt extende cab,where are they?
- Tires, tires.... Tires !
- park brake
- after rebuild, running rich, rough, black soot
- Hood springs... I need low tension...
- 02 Dakota 5 Speed Transmission
- Adapting 2000 tranny nss for 2001 dakota
- oil pan / pickup screen flush
- Fuel Pump?
- 4X4 Run no front sway bar?
- Seats Swap
- Hard steering and water pump ???????
- 02 Dakota headlight issue
- alarm goes off when i unlock my truck
- Looking for LSD
- Dakota Barely Runs, Very Rough Idle, Backfires
- What type of diff oil?
- Blend Door Problems 2004 Dodge Dakota v8
- Exhaust hum/buzz at 1500 rpm
- 99 dakota fan shroud
- cruise control issues
- new door lock actuator
- V8 swap
- injectors
- 97 dakota sport 3.9l Kind of sounds like a diesel after water pump replacement.
- long tube headers
- P0340 Error
- I have a 97 Dakota SLS 5 speed stick, 4wd. Tcase is Blown. I have a 99 Durango i beli
- 98 Dodge Dakota No spark or pwr to fuel pump
- Can cranking torsion bars affect shock fitment?
- Running board repair
- 3.9 Vs 318
- no power to obd port 99 RT
- Key on 3 times
- 98 Dakota 2 wheel drive Control arm nut
- camper shell
- IAC stays extended when cold
- 99 dakota obd connector has no power?
- 2000 quad cab bed replacement panels.
- p0132
- Third brake light (back of cab) wire route
- Owens Update..Again
- What the heck is this plug??!!
- 97' lost first gear throwing P1763
- 140A Fusible link location
- Will this hood fit?
- Won't come out of park
- Heater core replacement thickness and mode door questions.
- Transmission cooling lines (I Think) leaking?
- Is this fuel mileage normal?
- Mystery Harness under dash
- fusible link
- Suspension Lift In Brazil Help
- Your shifting feedback
- Front Axels and Seals
- Need bolt size, please!
- 98 Dakota 2.5L heater core
- 01 Dodge Dakota Rough start/40-45 mph shift issue
- Brake fluid
- 3.9 questions.
- 02 Dakota 4.7 timing
- Sterio instsll help please
- 2001 Odd Dakota question
- '03 headlights on all the time with engine running !
- 1999 Dakota SLT 3.9 Fuel Filler tube
- Idle control valve brand?
- Water on passenger side
- brake booster
- Backing plate/dust shields
- 2002 SLT Ext Cab 2WD Lift?
- 98 dodge dakota 3.9l vacuum line on top of tranny goes where?
- Tick noise odd ball
