PDA
View Full Version : 2nd Gen Dakota Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Transmission drain plug addition?
  2. Brake light switch wiring
  3. No power on the supply side of 02 sensor fuse
  4. 2000 Dakota Dimmer switch turns dome light on
  5. Spark Plug Question..
  6. front end alignment
  7. new shocks
  8. What seats will interchange in a 99
  9. Starter issue or something else?
  10. Squeaking up front
  11. Got a front end bounce
  12. Alternator DIY??
  13. Update to my problem
  14. want to see this??
  15. Bad wheel bearing?
  16. diy bed liners
  17. MAP and other sensors
  18. Air box
  19. 2002 Dodge Dakota SXT 2WD V6
  20. Selling the dak. Whats it worth?
  21. Front bumper interchange
  22. help !
  23. Bad smells and misfires
  24. 2008 intake whos done it
  25. Replaced my rear QC seats...
  26. --->Strange Noise when coasting
  27. conventional vs synthetic
  28. Need help with my 98 dakota
  29. Another Overdrive Issue
  30. I'm back!!!...Finally
  31. V6 engine into 4 cylinder stick?
  32. CAI+smog
  33. Is my power steering pressure switch is causing my idling issue?
  34. 1999 dakota rims for sale in michigan
  35. Hi..!!! And please help...!!
  36. Front half shaft removal
  37. swap a 97 dakota 3.9l to 5.2l
  38. 2001 Dodge Dakota Club Cab Question
  39. Shift Kit or Sharadon Valve Body
  40. here we go heres the pics
  41. Heat doesn't get hot
  42. brake/abs light comes on-off on 02 2wheel dakota?
  43. Leaking low pressure AC port
  44. Efan issue?
  45. Torque Converter lock up
  46. 98 gauge cluster inop
  47. Looking for rims
  48. Where to get a new heater core from ?
  49. no light on AC/heater control or headlight switch
  50. Best/Cheapest way to lift?
  51. Pinging when on the throttle
  52. overhauled
  53. Hood won't open
  54. 4.7 spark plug recommendaction
  55. What interchanges with a 99?
  56. "Grinding" noise from under the engine?
  57. odometer inop
  58. 2004 Dodge Dakota leveling kit?
  59. 00 dakota P0303 driving me insane!!!!
  60. 1998 Dodge Dakota Sport 5.2L bouncing idle and voltage drop
  61. Just did my plenum...
  62. 00 dakota e-brake light stuck on
  63. Headlight/dash light/interior lights/fog light problem
  64. factory electrical connectors
  65. Front Reciever Hitch?
  66. Spark plug wire sets
  67. 2001 fog lights not working?
  68. poor air blowin from defrost
  69. Selling a CAI?
  70. Body Lift Q's
  71. Wheel advice
  72. Overhead Console
  73. 2000 dakota v6 rough/stumbling idle
  74. Tail Light Guards:
  75. Intermittent Radio Volume
  76. 2" Suspension lift installed
  77. instument cluster swap
  78. washing the engine, fried a TPS
  79. Quad Cab owners and fitting in the garage
  80. filler neck rusted
  81. throttle body
  82. new tires
  83. Bumper removal 2001
  84. Rough Running 318
  85. 98 Dakota CTM problems
  86. Looking to buy this Dakota now!
  87. 90k service cost?
  88. Lift Kits
  89. P1740, no R/3rd/4th
  90. Bad Catalytic Converter
  91. 4.7L We have the technology...
  92. 45RFE has two filters?
  93. 98 dakota idle problems
  94. 2000 dodge dakota sport 4x4 problems
  95. powersteering reservoir problem
  96. Calling 1997 to 2004 Daks with 35s
  97. Lower dash panel removal question
  98. Halo headlight problems
  99. New dakota owner, Knock Knock
  100. Squealing under the hood since the cold weather came to town
  101. Will this Mallory distributor work on my engine?
  102. ho intake manifold for sale
  103. Catalytic Converter
  104. Knock in front passenger side
  105. 5 bolt conversion
  106. Plenum gasket bolts
  107. Wendys Drive through
  108. Timing chain
  109. sun roof visor
  110. Engine squeak
  111. Finally some snow! - First snowfall with the Dakota (video)
  112. Tranny issue?
  113. truck won't start
  114. Camper shell questions.
  115. Need to repair my OBD-II Port on 04 Dakota
  116. reverse sounds weird
  117. what sensors keep 3.9 from running
  118. 2002 Dakota 4x2 - Clunk in the Front
  119. Shocks
  120. Replacement parts...
  121. Seattle ice storm
  122. bunch of new stuff for the 04
  123. 2004 4.7L engine interchange question
  124. plug
  125. Hesitates to Shift After Hard Driving
  126. If you have used coil spacers, let me know your input please.
  127. Winter driving
  128. oil question
  129. power sterring
  130. 3rd gen ram mirrors
  131. Dakota 99' V8 5.9 - My first car
  132. Strange vibration from engine.
  133. Box Covers
  134. 03 dakota 3.9 4x4
  135. Rear diff binding in 2003 Dakota
  136. 01 Dakota power window is extremely slow.
  137. Power Locks
  138. Instant Stain remover including rust!
  139. 4.7 HO pistons in non-HO engine
  140. Rusty marks on glass
  141. What if I disobey tire's width ratings?
  142. '03 4.7L Water Pump replaced
  143. Dakota won't start, but honk horn and it starts right up!
  144. Strange whine under acceleration.
  145. 98 head light tool
  146. wheel backspacing for lift questions looking for imput from people who have done it
  147. Cold temp. starting problem
  148. looking for recommendations
  149. cummins swapping a 2wd?
  150. Lets talk programmers!
  151. long block or short block
  152. 97 dak transfercase
  153. 2001 Dakota 4.7 --Low Voltage--
  154. No Start
  155. Dakota newb with a couple questions
  156. 99 dakota shuts off while driving
  157. Performance Chips
  158. Lets see your rims!
  159. 04 dakota 4.7 whining noise
  160. good engine?
  161. Timing chain tensioner
  162. Suspension Question -Need advise
  163. Truck Whistles While Cruising.
  164. Motor problems!
  165. motor hesitating question
  166. Front sway bar bushings 32 mm
  167. Can fueling with motor running cause CEL to come on?
  168. True duals make better flow on 4.7?
  169. '03 4.7 Low Oil Pressure
  170. Tow hitch question
  171. front brake drag
  172. exhaust leak problems. Need advice
  173. saggy front bumper
  174. Timing cover bolts
  175. Enigine likes to stop running in damp weather
  176. Low pressure on idle.
  177. low end engine knock
  178. Performance chips for 2003 3.9 Dakota
  179. Plz Help ran out of options
  180. new dakota owner
  181. Fuel leaking....stumped!! Need help
  182. Need help!! 3 different check engine codes
  183. 3.9 to 318 swap.
  184. P/S whine will not go away!!!!!
  185. Looking to add a lift cheaply! I know not the best idea
  186. 2 wheel drive to 4 wheel drive conversion 4x2 to 4x4 conversion
  187. custom audio in my 99
  188. Installation of timing gear.
  189. 2001 BCM/CTM (timing alarm module) issues??
  190. Cabin air distribution/selector?
  191. 02 3.9L - Big Effin' Coolant Leak
  192. Exhaust system needs help!!
  193. In need of engine ?
  194. 97 dakota need help lowering
  195. 2001 Dodge Dakota starting problems
  196. 3.9 boat pulling
  197. Stock 3.55 gears to 4.56 gears
  198. '04 v6 towing capacity
  199. bed size question
  200. 2008 intake manifold
  201. I'm screwed X 2.....brake issue(s) UPDATE and need advice
  202. dakota power steering problem/question
  203. Map sensor uh-oh
  204. 2001 Dodge dakota coolant leak
  205. trying to pick out tires any advice
  206. Loud Crunching Noise When Turning/Slowing Down
  207. Electrical problems
  208. CV axle too short
  209. Multiple misfire codes , what the heck ??
  210. Not bad for the camera on my phone
  211. Throttle Body
  212. Got a knock and a question
  213. 2001 3.9L Dakota Dies While Idling
  214. Happy new year
  215. 3.9 to 5.9l swap in process
  216. Are you a happy Dakota owner?
  217. Dodge Dakota 2001 code p1282
  218. Removing Door Panel - No power options
  219. Broken driveline part Dakota 4x4
  220. Bad blower motor?
  221. valve springs
  222. Update on rear brake replacement
  223. Tranny issue....?
  224. Headlights cutting on and off
  225. Cruise control issue 2000 dakota
  226. Update on sputter/misfire issue, looking for input
  227. HIDs
  228. r/t rims, old tires....burnout
  229. Do's and Dont's of 4x4
  230. where are my oxygen sensors located?
  231. Rear Diff Question
  232. Limp mode !!!! Help
  233. Looking at Second Gen Dakota 3.9 4x4 - Common Issues?
  234. exhaust flange bolts
  235. Pics of temp gauge?
  236. Installing a dual exhaust
  237. Leak in the Tranny???
  238. Stronger torsion bars
  239. looking for a link
  240. Low Beams not working also wipers
  241. 1998 dodge dakota 3.9 v6 starting problems
  242. which should i use????
  243. Merry Christmas, Dak brothers!
  244. New Plugs=Joy to man and no peace in my town
  245. Broken rear caliper piston - Next steps?
  246. Reprogram a key fob 1997 Dakota?
  247. Assembling the engine
  248. vacuum help 2000 3.9
  249. Running Light Not Working?
  250. ScanGaugeII X-Gauge Commands
